  5. [gelöst] Gerät kallibrierung
    5.6k
25 Beiträge 2 Kommentatoren 2.7k Aufrufe 1 Beobachtet
    @Aphofis sagte:
    0,001 volt sollen 1 ppm
    Dann wäre der Faktor 1000.
     <variables>
       <variable type="" id="V=8^)5!TN`mJYTZyK?}/">faktor</variable>
       <variable type="" id="np_ESNEK^(|%pWm2/+]g">ppm</variable>
     </variables>
     <block type="variables_set" id="Wyc(F6WE.RunEojHKezU" x="-913" y="-438">
       <field name="VAR" id="V=8^)5!TN`mJYTZyK?}/" variabletype="">faktor</field>
       <value name="VALUE">
         <block type="math_number" id="0m(OXeOCW9rO-30mkfwz">
           <field name="NUM">1000</field>
         </block>
       </value>
       <next>
         <block type="on_ext" id="avox)=chmrxdaDFRG-dy">
           <value name="OID0">
             <shadow type="field_oid" id=",C$d.ocnGPCx/k`IpXX8">
               <field name="oid">i2c.0.0x48.0</field>
             </shadow>
           </value>
           <statement name="STATEMENT">
             <block type="variables_set" id="gU]EFQoDCq7pZ_gXgsBV">
               <field name="VAR" id="np_ESNEK^(|%pWm2/+]g" variabletype="">ppm</field>
                 <block type="math_round" id="tfFn8b$DIcK6UgYUQLE!">
                   <field name="OP">ROUND</field>
                   <value name="NUM">
                     <shadow type="math_number" id="1rQ^liVvpA`qyoY-R+U0">
                       <field name="NUM">3.1</field>
                     </shadow>
                     <block type="math_arithmetic" id="z+2C/OkD|}uE3=6MdUCz">
                       <field name="OP">MULTIPLY</field>
                       <value name="A">
                         <shadow type="math_number" id="hLvmB6l:PJjs[Z^6U6Lk">
                           <field name="NUM">1</field>
                         </shadow>
                         <block type="variables_get" id="ZTxPi1?TDqNx2q)2dc@[">
                         </block>
                       </value>
                       <value name="B">
                         <shadow type="math_number" id="DJOGrbHj}ZjVO7X_N$%{">
                         </shadow>
                         <block type="math_arithmetic" id="`EtdUInhrJzLU5hYt.ni">
                           <value name="A">
                             <shadow type="math_number" id="Sv!4Jvf@;/5af-4#^zd3">
                             </shadow>
                             <block type="on_source" id="bLi3*73^M%Mwj2r{6A,t">
                             </block>
                           </value>
                           <value name="B">
                             <shadow type="math_number" id="ctchP~,SwZ)pZgY[TVQX">
                               <field name="NUM">0.0019</field>
                             </shadow>
                           </value>
                         </block>
                       </value>
                     </block>
                   </value>
                 </block>
               </value>
               <next>
                 <block type="controls_if" id="VF:wqhFGoKV@BQ$M#q/$">
                   <value name="IF0">
                     <block type="logic_compare" id="}c[xQ`sZe/aF{]@BYlJW">
                       <field name="OP">LT</field>
                       <value name="A">
                         <block type="variables_get" id="fPA|hiRl}%,`7Em[IH6w">
                         </block>
                       </value>
                       <value name="B">
                         <block type="math_number" id="??b[r*Ec(=X9.6H4ZUr[">
                           <field name="NUM">0</field>
                         </block>
                       </value>
                     </block>
                   </value>
                   <statement name="DO0">
                     <block type="variables_set" id="mBUB~[vPgUW8@?SY3w=~">
                         <block type="math_number" id="XeuqyxxtJ%,$vqa0xu[F">
                         </block>
                       </value>
                     </block>
                   </statement>
                   <next>
                     <block type="update" id="x4.IV.iv.PVA1(!0yqW8">
                       <field name="OID">Aqua_Control.0.Sensoren.TDS_Meter</field>
                         <block type="variables_get" id="08@R%~?^RV-!rIklWyO-">
                         </block>
                       </value>
                     </block>
                   </next>
                 </block>
               </next>
             </block>
           </statement>
         </block>
       </next>
     </block>
    </xml>
    AphofisA Offline
    AphofisA Offline
    Aphofis
    Es klappt! und funktioniert Super Danke!
    Jetzt ist es so das ich den ppm Wert gerne alle 10 min prüfen möchte.
    Den Aktualisierungsintervall wollte ich auf 60 sek stellen.
    Dh eine Steuerung mist 10 mal den wert und wenn der Wert 10 mal 1 ppm ist dann soll eine meldung ausgegeben werden.
    • AphofisA Aphofis
      @Aphofis
      Verwende einen Zeitplan, der jede Minute triggert:
      Erhöhe jedesmal eine Zählvariable. Wenn der ppm-Wert > 1 ist, setze die Zählvariable auf 0. Wenn die Zählvariable = 10 ist, sende Meldung.
      Wenn das im gleichen Skript erfolgt wie oben, kann die Variable ppm verwendet werden und es muss nicht der Datenpunkt eingelesen werden.
      • AphofisA Offline
        AphofisA Offline
        Aphofis
        ich habe das jetz so aber ich denke das ist wohl falsch
          <variables>
            <variable type="" id="2d2K!}ki!wOyi^mvo-D.">Counter</variable>
          </variables>
          <block type="schedule" id="g0YOJMLZmMB,(4:F3OP;" x="-987" y="-312">
            <field name="SCHEDULE">* * * * *</field>
              <block type="on" id="=t|AR~F?F.POz.9;n6s?">
                  <block type="controls_if" id="Bts^3NiX*:eNi-l(luks">
                    <value name="IF0">
                      <block type="on_source" id="rU%vRkoU/c-0FA@qyTT0">
                      </block>
                    </value>
                      <block type="controls_for" id="ZJKHN9jAeN#8:CYK];RR">
                        <field name="VAR" id="2d2K!}ki!wOyi^mvo-D." variabletype="">Counter</field>
                        <value name="FROM">
                          <shadow type="math_number" id="yOPQFHe.*oQM#h.5cv/L">
                          </shadow>
                        </value>
                        <value name="TO">
                          <shadow type="math_number" id=";q4G9f;jzh@IpN#Hw?7d">
                            <field name="NUM">10</field>
                          </shadow>
                        </value>
                        <value name="BY">
                          <shadow type="math_number" id="CR6(M*dyJ1(bRaa[PC]l">
                          </shadow>
                        </value>
                        <statement name="DO">
                          <block type="controls_if" id="B-?d}*r)V!nKL8nyY]3+">
                            <value name="IF0">
                              <block type="logic_compare" id="DRMG/z6M$-J-VFhUi;^/">
                                <field name="OP">EQ</field>
                                <value name="A">
                                  <block type="get_value" id="}|dMpJQSIM(8G]CTB%ZJ">
                                  </block>
                                </value>
                                <value name="B">
                                  <block type="math_number" id="^O^RgW$boq@-63tqK-/+">
                                  </block>
                                </value>
                              </block>
                            </value>
                              <block type="schedule" id="^A(_aRQa;vVx1vKY-V-J">
                                <field name="SCHEDULE">5 18 * * *</field>
                                  <block type="telegram" id="J,iXl(9m{hxX8B5dzrU0">
                                    <field name="INSTANCE">.0</field>
                                    <field name="LOG"></field>
                                    <value name="MESSAGE">
                                      <shadow type="text" id="%vvA9a71{#pBL7sP6VuJ">
                                        <field name="TEXT">Mischbettharz Kartusche muss gewechselt werden</field>
                                      </shadow>
                                    </value>
                                    <next>
                                      <block type="control" id="VPki1bO?hssLGQEl/QSW">
                                        <field name="OID">alexa2.0.Echo-Devices.G090LV0371040175.Commands.speak</field>
                                          <block type="text_join" id="iPHU6.VfiSF[{Ih5Ql?8">
                                            <value name="ADD0">
                                              <block type="text" id="F4CDr?yvuDd{]$$IyrJF">
                                                <field name="TEXT">Mischbettharz hat 1 ppm erreicht</field>
                                              </block>
                                            </value>
                                            <value name="ADD1">
                                              <block type="text" id="+-2pu*N9GLZ-W,J1)0!M">
                                                <field name="TEXT">Kartusche muss gewechselt werden</field>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </statement>
                          </block>
                        </statement>
                      </block>
                    </statement>
                  </block>
                </statement>
              </block>
            </statement>
          </block>
        </xml>
        • AphofisA Aphofis
            <variables>
            </variables>
                      <value name="IF0">
                        </block>
                      </value>
                          <value name="FROM">
                            </shadow>
                          </value>
                          <value name="TO">
                            </shadow>
                          </value>
                          <value name="BY">
                            </shadow>
                          </value>
                              <value name="IF0">
                                  <value name="A">
                                    </block>
                                  </value>
                                  <value name="B">
                                    </block>
                                  </value>
                                </block>
                              </value>
                                        </shadow>
                                      </value>
                                      <next>
                                              <value name="ADD0">
                                                </block>
                                              </value>
                                              <value name="ADD1">
                                                </block>
                                              </value>
                                            </block>
                                          </value>
                                        </block>
                                      </next>
                                    </block>
                                  </statement>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </statement>
            </block>
          </xml>
          @Aphofis sagte:
          das ist wohl falsch
          Ja. Keine Trigger innerhalb von Triggern verwenden !!
          Oder so, wenn die Meldung zu einer bestimmten Uhrzeit kommen soll:
          AphofisA 1 Antwort Letzte Antwort
            @Aphofis sagte:
            das ist wohl falsch
            AphofisA Offline
            AphofisA Offline
            Aphofis
            Das mal wieder Spitze!
            Vielen Dank @paul53
