  4. [Backitup] Fehler beim starten der Instanz
backitupfehler
1 Beiträge 1 Kommentatoren 173 Aufrufe
  • Lenny.CBL Offline
    Lenny.CBL Offline
    Lenny.CB
    schrieb am zuletzt editiert von Lenny.CB
    kann mir das mal jemand "übersetzen"?
    Hintergrund: Instanz lässt sich nicht starten. Wollte dann "drüber installieren", bekomme dann diesen Fehler:
    root@rockpro64:/opt/iobroker# npm install iobroker.backitup -production
    > diskusage@1.1.3 install /opt/iobroker/node_modules/diskusage
    > node-gyp rebuild
    Traceback (most recent call last):
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>
        import gyp
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/__init__.py", line 8, in <module>
        import gyp.input
      File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>
        from compiler.ast import Const
    ImportError: No module named compiler.ast
    gyp ERR! configure error
    gyp ERR! stack Error: `gyp` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.4.184-rockchip64
    gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /opt/iobroker/node_modules/diskusage
    gyp ERR! node -v v10.16.3
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    > @serialport/bindings@2.0.8 install /opt/iobroker/node_modules/@serialport/bindings
    > prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
    prebuild-install WARN install No prebuilt binaries found (target=10.16.3 runtime=node arch=arm64 libc= platform=linux)
        import gyp
        import gyp.input
    gyp ERR! cwd /opt/iobroker/node_modules/@serialport/bindings
    gyp ERR! not ok
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/asn1/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/ecc-jsbn/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/safer-buffer/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.telegram/node_modules/stack-trace/package.json'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.9 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.9: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 (node_modules/diskusage):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: diskusage@1.1.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 (node_modules/@serialport/bindings):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @serialport/bindings@2.0.8 install: `prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild`
    + iobroker.backitup@1.2.0
    added 2 packages from 3 contributors, updated 1 package and audited 9735 packages in 51.449s
    found 189 vulnerabilities (81 low, 43 moderate, 65 high)
      run `npm audit fix` to fix them, or `npm audit` for details
