  5. [gelöst] Zahl aus json-Objekt m. Blockly auswerten
12 Beiträge 2 Kommentatoren 1.7k Aufrufe
  • capitaenzC Offline
    capitaenzC Offline
    capitaenz
    schrieb am zuletzt editiert von capitaenz
    wir interessieren uns dafür, welcher Hubschrauber gerade über uns kreist.
    Ich schreibe mit dem Systeminfoadapter alle 30 sek. die Flugdaten von dump1090-fa in ein Objekt.
    Jetzt würde es mehr Sinn machen nur die Hubschrauber signalisiert zu bekommen, welche im Umkreis von etwa 3-5 km sind.
    Ich habe die Signalstärke mit in das Objekt aufgenommen:
    ["3c5ee1",-19.6,"3e350d",-20.5,"4851ad",-14.6,"45d968",-19.6,"344290",-2.1,"3c5ee7",-14.8,"44083f",-12.2,"406c39",-14.5,"4692d0",-19.7,"3c4826",-13.1,"394a60",-2.5,"780a36",-15,"4ca625",-20.3,"3c6518",-13.3,"485123",-9.3,"3e1679",-2.2,"4249b2",-11.2,"ad3f67",-10.7,"3c6646",-11.7,"3d3d27",-19.9,"3c66b8",-3.8,"424b39",-8.4,"3d0590",-12.1,"a5d4c3",-11.2,"4a05a3",-14.8,"47834b",-13.9,"4853f4",-9.4,"4631cc",-4.5,"71c275",-4.2,"47945c",-2,"3c65d0",-10.1,"43e94f",-2.6,"485870",-14.5,"3c64a1",-13.1,"3c662d",-5.9,"4d21e0",-5.4,"3eb6aa",-14,"485345",-2.2,"3c496d",-14.5,"4b16b9",-7.5,"484161",-15,"484f7e",-10.4,"400d90",-4,"4cafcd",-2,"4855d0",-3.8,"471f2f",-7.7,"300782",-8.6,"78071c",-1.4,"4ac8b5",-3.2,"3c6643",-3.2,"440309",-11.6,"461f6e",-6.9,"3e3afb",-12.5,"42435f",-7.4,"4ac9e1",-2.6,"3c6514",-7.6,"3cc932",-2.7,"4840de",-2.3,"78037b",-3.5,"44056b",-15.7,"406c43",-13.7,"3c5ef9",-5.6,"406f77",-1.9,"4840e0",-2.2,"3c6dd4",-3.4,"461f96",-2.2,"488a63",-2.7,"4074b2",-13.1,"4baa92",-6.8,"3c6517",-16.1,"4ca679",-13,"4ca7a4",-10.1,"4ca8e9",-1.5,"3c56f3",-8.2,"394c18",-12.5,"461f69",-3.2,"3c6594",-1.5,"452068",-3.1,"896192",-14,"4ca6a3",-13.6,"4cacca",-6.3,"3944e5",-4.2,"3eba1c",-3.2,"3c66ad",-2.2,"4b1a3c",-6,"406674",-14.3,"4baa6b",-2.5,"4bb84d",-12.8,"4009db",-14.8,"3c56f1",-1.3,"06a10c",-2.2,"424131",-14.1,"71be12",-6.2,"781103",-15.2,"485085",-14.3,"452086",-13.8,"3c4a31",-15,"3c6dcf",-12.6,"3c5070",-6.3,"400a69",-13.8,"34444e",-14.1,"440582",-4.2,"78076c",-14.2,"4bb181",-15.2,"392ae8",-11.9,"502ce3",-15,"3c66b6",-9.5,"3c6dd0",-8.5,"3e2e94",-14.6,"405a47",-15.1,"406890",-13.7,"461fa8",-15.6]
    Mein jetziges Script sieht so aus (ich weiß, dass ich den Intervall durch einen Timeout ersetzen könnte):
    Jetzt kommt die Schwierigkeit:
    Wie kann ich die Signalstärke "3c5ee1",-19.6 mit Blockly auswerten?
    also z.B. ist "3c5ee1" ein Hubschrauber und -19.6 die Signalstärke... Jetzt möchte ich jedoch erst ab z.B. -6.0 darauf reagieren...
    Hat jemand einen Tipp für mich?
    VG
    Leif
    ioBroker auf Synology DS920+ (SSD Raid / 20GB RAM) im VMM
    • capitaenzC capitaenz
      VG
      Leif
      @capitaenz sagte:
      So wie es aussieht, enthält das JSON ein Array, in dem eine "ID" mit der zugehörigen Signalstärke abwechselt.
      Das folgende Blockly sollte dann im Log alle IDs ausgeben, deren Signalstärke > -6 ist.
        capitaenzC Offline
        capitaenz
        Daran habe ich noch gar nicht gedacht, erst nach Signalstärke zu sortieren und dann die Flugnummer zu filtern 👍
        Allerdings muss ich zugeben, dass ich trotzdem deine Hilfe gebraucht hätte.
        Ich probiere es aus und werde dann berichten.
        Danke und VG
        Leif
          capitaenzC Offline
          capitaenz
          leider scheint da noch ein Kinken drin zu sein:
          Es muss ja jeder 2. Wert überprüft werden nach ">-6", aber wieso zählst du "i" hoch?
          Kannst du mir da grad noch einmal helfen?
          VG
          Leif
            VG
            Leif
            @capitaenz
            Was steht im Javascript-Code in Zeile 15 ?
            Wenn die erzeugte Liste den Bezeichner Hex-Flugnummern hat, muss auch auf diese Liste zugegriffen werden und nicht auf die Variable Liste.
              capitaenzC Offline
              capitaenz
              dort steht:
              if (Liste[((i + 1) - 1)] > -6) {
                dort steht:
                @capitaenz sagte:
                Richtig wäre
                if (Hex_Flugnummern[((i + 1) - 1)] > -6) {
                  capitaenzC Offline
                  capitaenz
                  Danke, jetzt scheint es das zu machen was ich brauche.
                  Sitze jetzt nur am Tablet, probiere morgen weiter.
                  Schönen Abend
                    capitaenzC Offline
                    capitaenz
                    Hallo Paul,
                    ich muss noch einmal nachfragen:
                    Also ich kann jetzt die Flugnummern eingrenzen, das sehe ich in der Debugausgabe, aber auf welche Variable muss ich jetzt reagieren? Wie kann ich mir anzeigen lassen wohin diese Daten geschrieben werden?
                    Ich nehme an, dass was ich in der Debugausgabe sehe, der Inhalt von "i" ist?
                    Wenn ich jedoch "i" durchsuchen möchte nach z.B. "3ab3cc", bekomme ich einen Fehler angezeigt, welcher sich auf die Zeile mit der Variable "i" bezieht.
                    Wenn ich die "Hex-Flugnummern" durchsuche, greift die Eingrenzung nach dB nicht...
                    VG
                    Leif
                      Hallo Paul,
                      VG
                      Leif
                      @capitaenz sagte:
                      Die Daten werden noch nirgends geschrieben. Um diesen Teil muss das Programm noch ergänzt werden. Was soll das Ergebnis sein ?
                      @capitaenz sagte in Zahl aus json-Objekt mit Blockly auswerten:
                      Nein, das ist der Inhalt des Arrays an der Stelle, die durch i indiziert wird.
                      Dann muss ein Vergleich erfolgen
                      falls in der Liste Hex-Flugnummern nimm das i. Element == "3ab3cc"
                      mache ...
                        capitaenzC Offline
                        capitaenz
                        Hallo Paul,
                        ich muss mich noch einmal bedanken! Es läuft jetzt, jetzt setzte ich mich noch einmal hin, um es auch komplett zu verstehen.
                        Solch eine Hilfe ist nicht selbstverständlich.
                        Hier ein Ausschnitt, vielleicht kann es noch jemand gebrauchen:
                        VG
                        Leif
                          Hallo Paul,
                          VG
                          Leif
                          @capitaenz sagte:
                          Es läuft jetzt
                          Dann markiere bitte das Thema in der Überschrift als [gelöst].
