  4. Hallo Tester.
Hallo Tester.
45 Beiträge 7 Kommentatoren 10.4k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    #41
    root@RPi2-1:/home/pi# cd /opt/iobroker/
    root@RPi2-1:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js stop
    Stopping iobroker controller daemon...
    iobroker controller daemon stopped.
    Exit code for "killall.sh": 0
    root@RPi2-1:/opt/iobroker# sudo npm install https://github.com/ioBroker/ioBroker.sql/tarball/master –production
    ! > sqlite3@3.1.3 install /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3
    ! > node-pre-gyp install –fallback-to-build
    ! make: Entering directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
    ! ACTION deps_sqlite3_gyp_action_before_build_target_unpack_sqlite_dep Release/obj/gen/sqlite-autoconf-3090100/sqlite3.c
    ! TOUCH Release/obj.target/deps/action_before_build.stamp
    ! CC(target) Release/obj.target/sqlite3/gen/sqlite-autoconf-3090100/sqlite3.o
    ! AR(target) Release/obj.target/deps/sqlite3.a
    ! COPY Release/sqlite3.a
    ! CXX(target) Release/obj.target/node_sqlite3/src/database.o
    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginOpen(node_sqlite3::Database::Baton*)’:
    ! ../src/database.cc:143:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! int status = uv_queue_work(uv_default_loop(),
    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginClose(node_sqlite3::Database::Baton*)’:
    ! ../src/database.cc:227:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginExec(node_sqlite3::Database::Baton*)’:
    ! ../src/database.cc:505:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! ../src/database.cc: In static member function ‘static void node_sqlite3::Database::Work_BeginLoadExtension(node_sqlite3::Database::Baton*)’:
    ! ../src/database.cc:605:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! CXX(target) Release/obj.target/node_sqlite3/src/node_sqlite3.o
    ! CXX(target) Release/obj.target/node_sqlite3/src/statement.o
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginPrepare(node_sqlite3::Database::Baton*)’:
    ! ../src/statement.cc:118:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! In file included from ../src/statement.cc:6:0:
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginBind(node_sqlite3::Statement::Baton*)’:
    ! ../src/macros.h:125:9: warning: unused variable ‘status’ [-Wunused-variable]
    ! ../src/statement.cc:322:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(Bind);
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginGet(node_sqlite3::Statement::Baton*)’:
    ! ../src/statement.cc:370:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(Get);
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginRun(node_sqlite3::Statement::Baton*)’:
    ! ../src/statement.cc:438:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(Run);
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginAll(node_sqlite3::Statement::Baton*)’:
    ! ../src/statement.cc:504:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(All);
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginEach(node_sqlite3::Statement::Baton*)’:
    ! ../src/statement.cc:601:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(Each);
    ! ../src/statement.cc: In static member function ‘static void node_sqlite3::Statement::Work_BeginReset(node_sqlite3::Statement::Baton*)’:
    ! ../src/statement.cc:724:5: note: in expansion of macro ‘STATEMENT_BEGIN’
    ! STATEMENT_BEGIN(Reset);
    ! SOLINK_MODULE(target) Release/obj.target/node_sqlite3.node
    ! COPY Release/node_sqlite3.node
    ! COPY /opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/lib/binding/node-v46-linux-arm/node_sqlite3.node
    ! TOUCH Release/obj.target/action_after_build.stamp
    ! make: Leaving directory '/opt/iobroker/node_modules/iobroker.sql/node_modules/sqlite3/build'
    ! iobroker.sql@0.3.2 node_modules/iobroker.sql
    ! ├── mysql@2.10.2 (bignumber.js@2.1.4, readable-stream@1.1.14)
    ! ├── pg@4.5.5 (packet-reader@0.2.0, pg-connection-string@0.1.3, generic-pool@2.1.1, buffer-writer@1.0.1, semver@4.3.6, pg-types@1.11.0, pgpass@0.0.3)
    ! ├── sql-client@0.7.0 (argf@0.0.1, optimist@0.6.1, inote-util@0.8.1)
    ! ├── mssql@3.3.0 (generic-pool@2.4.2, promise@7.1.1, tedious@1.14.0)
    ! └── sqlite3@3.1.3 (nan@2.2.1)
    ! root@RPi2-1:/opt/iobroker#
    root@RPi2-1:/opt/iobroker# node node_modules/iobroker.js-controller/iobroker.js start
    Starting iobroker controller daemon...
    iobroker controller daemon started. PID: 10400
    • derAugeD Offline
      derAugeD Offline
      derAuge
      #42
      Frage:
      Ist der Test nun abgeschlossen?
      Jürgen
      • BluefoxB Offline
        BluefoxB Offline
        #43
        ich denke ja.
        Es gibt noch influxdb, was auch getestet werden muss.
        Nächste Woche werde ich dann alles veröffentlichen.
        • derAugeD Offline
          derAugeD Offline
          derAuge
          #44
          @Bluefox:
          ich denke ja.
          Nächste Woche werde ich dann alles veröffentlichen. `
          Danke für die Rückmeldung.
          Das bedeutet ist sollte bis nächste Woche mit der Installation des SQL-Adaptern auf meinem neuen Produktiv-System (DS412+) noch warten.
          Jürgen
          • eric2905E Offline
            eric2905E Offline
            eric2905
            #45
            Moin zusammen,
            bzgl. SQL-Adapter und mySQL-DB teste ich gerade einen Anbieter, der hosted SQL (MS-SQL und auch mySQL) anbietet.
            Keinen "Ärger" mit Backup, Last, usw. - und das für kleines Geld (wie ich finde)
            Schaut selber : http://www.ecs-webhosting.de/de/cloud-m … osting.htm
            Gruß,
            Eric
