  4. Viele Warnungen im Log vom Javascript Adapter
    1.0k
    6.1k
warnungen javascript
47 Beiträge 5 Kommentatoren 6.7k Aufrufe 1 Beobachtet
  • ostseereiterO Offline
    ostseereiter
    #41
    nein die kommt erst später wie eben.
    	2019-07-08 22:39:07.389	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-07-08 22:39:07.389	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-07-08 22:39:07.389	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-07-08 22:39:07.389	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-07-08 22:39:07.389	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-07-08 22:39:07.389	warn	at emitOne (events.js:116:13)
    javascript.0	2019-07-08 22:39:07.388	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-07-08 22:39:07.388	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-07-08 22:39:07.388	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-07-08 22:39:07.388	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-07-08 22:39:07.388	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-07-08 22:39:07.387	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-07-08 22:39:07.387	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-07-08 22:39:07.387	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-07-08 22:39:07.387	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-07-08 22:39:07.387	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-07-08 22:39:07.387	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-08 22:39:07.387	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-07-08 22:39:07.387	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-07-08 22:39:07.387	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-08 22:39:07.386	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-07-08 22:39:07.386	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-07-08 22:39:07.386	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-07-08 22:39:07.386	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-07-08 22:39:07.386	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-07-08 22:39:07.386	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-07-08 22:39:07.386	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-08 22:39:07.386	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-07-08 22:39:07.386	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-07-08 22:39:07.386	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-07-08 22:39:07.385	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-07-08 22:39:07.385	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-07-08 22:39:07.385	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0	2019-07-08 22:39:07.385	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-07-08 22:39:07.385	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-07-08 22:39:07.385	warn	at Object.<anonymous> (script.js.Skripte.TV.TV_AN:5:5)
    javascript.0	2019-07-08 22:39:07.385	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-07-08 22:39:07.381	warn	Wrong type of harmony.0.Harmony Hub.Philips 42PFL5604H/12.PowerOn: "boolean". Please fix, while deprecated and will not work in next versions.
    Gruß OSR
    Plattform
    Linux x64 CPUs2 AMD G-T56N Processor 1646 MHz 8GB RAM
    ostseereiterO 1 Antwort Letzte Antwort
    • ostseereiterO ostseereiter
      ostseereiter
      #42
      :12.095	info	javascript.0 script.js.Probe.rfidtuer: {"type":"access","time":1562618411,"isKnown":"true","access":"Always","username":"Heike","uid":"56b2e9f7"} Typ: string
      22:50:30.902	info	javascript.0 script.js.Probe.rfidtuer: {"type":"heartbeat","time":1562619030} Typ: string
      22:50:30.903	warn	javascript.0 at Object.<anonymous> (script.js.Probe.rfidtuer:10:7)
      Gruß OSR
      Plattform
        ostseereiter
        #43
        das war eine andere Warnung
        javascript.0	2019-07-08 22:53:00.182	info	script.js.Probe.Wetter: []
        javascript.0	2019-07-08 22:52:00.144	info	script.js.Probe.Wetter: []
        tankerkoenig.0	2019-07-08 22:51:43.626	info	Reading data from tankerkoenig ...
        host.debianhp	2019-07-08 22:51:03.068	info	instance system.adapter.tvspielfilm.0 terminated with code 0 (OK)
        tvspielfilm.0	2019-07-08 22:51:02.544	info	force terminating adapter after 1 minute
        javascript.0	2019-07-08 22:51:00.263	info	script.js.Probe.Wetter: []
        javascript.0	2019-07-08 22:50:30.905	warn	at TCP.onread (net.js:601:20)
        javascript.0	2019-07-08 22:50:30.905	warn	at Socket.Readable.push (_stream_readable.js:208:10)
        javascript.0	2019-07-08 22:50:30.905	warn	at readableAddChunk (_stream_readable.js:250:11)
        javascript.0	2019-07-08 22:50:30.905	warn	at addChunk (_stream_readable.js:263:12)
        javascript.0	2019-07-08 22:50:30.905	warn	at Socket.emit (events.js:211:7)
        javascript.0	2019-07-08 22:50:30.905	warn	at emitOne (events.js:116:13)
        javascript.0	2019-07-08 22:50:30.904	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
        javascript.0	2019-07-08 22:50:30.904	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
        javascript.0	2019-07-08 22:50:30.904	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
        javascript.0	2019-07-08 22:50:30.904	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
        javascript.0	2019-07-08 22:50:30.904	warn	at WebSocket.emit (events.js:214:7)
        javascript.0	2019-07-08 22:50:30.904	warn	at emitTwo (events.js:126:13)
        javascript.0	2019-07-08 22:50:30.904	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
        javascript.0	2019-07-08 22:50:30.904	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
        javascript.0	2019-07-08 22:50:30.904	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
        javascript.0	2019-07-08 22:50:30.904	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
        javascript.0	2019-07-08 22:50:30.904	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-08 22:50:30.904	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
        javascript.0	2019-07-08 22:50:30.904	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
        javascript.0	2019-07-08 22:50:30.904	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-08 22:50:30.903	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-08 22:50:30.903	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
        javascript.0	2019-07-08 22:50:30.903	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
        javascript.0	2019-07-08 22:50:30.903	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
        javascript.0	2019-07-08 22:50:30.903	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-08 22:50:30.903	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
        javascript.0	2019-07-08 22:50:30.903	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-08 22:50:30.903	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
        javascript.0	2019-07-08 22:50:30.903	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
        javascript.0	2019-07-08 22:50:30.903	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
        javascript.0	2019-07-08 22:50:30.903	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
        javascript.0	2019-07-08 22:50:30.903	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
        javascript.0	2019-07-08 22:50:30.903	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
        javascript.0	2019-07-08 22:50:30.903	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
        javascript.0	2019-07-08 22:50:30.903	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
        javascript.0	2019-07-08 22:50:30.903	warn	at Object.<anonymous> (script.js.Probe.rfidtuer:10:7)
        javascript.0	2019-07-08 22:50:30.903	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
        javascript.0	2019-07-08 22:50:30.902	warn	Wrong type of javascript.0.Tuer: "object". Please fix, while deprecated and will not work in next versions.
        Gruß OSR
        Plattform
          #44
          @ostseereiter
          Es ist der "heartbeat", der die Warnung verursacht. Dann muss anders geprüft werden.
          const idJson = 'mqtt.0.RFID'; // ID des Datenpunktes mit dem JSON-String eintragen !
          const idUid  = 'Tuer'; // Name des uid-Datenpunktes
          createState(idUid, '', {type: 'string'}); // Datenpunkt erstellen
          on(idJson, function(dp) { // triggert bei Änderung des JSON-Strings
             var obj = JSON.parse(dp.state.val);
             if(obj && obj.type == 'access') setState(idUid, obj.uid, true);
            @Shepherd sagte in Viele Warnungen im Log vom Javascript Adapter:
            Und was haben die Warnungen mit
            Die geben an wo sich eine Zugriff auf diesen State mit dem Falschen Typ im Script/Adapter versteckt
            In der Form "Zeile:Zeichen"
            Shepherd
            #45
            @Homoran
            Seit ändern der Rolle auf Zahl, kamen bisher keine weiteren Fehlermeldungen.
            Danke für deine Hilfe.
            • S Shepherd
              @Homoran
              ostseereiter
              #46
              @Shepherd
              habe ich getan im Moment sind für dieses Script keine Warnhinweise zu sehen.
              Gruß OSR
              Plattform
                Shepherd
                #47
                Auch jetzt eine Fehlermeldungen mehr im Log navh ändern der rolle im Datenpunkt auf Zahl.
                Vielen Dank mochmals.
