  4. Adapter Alexa Update Fehler
alexaadapterupdateerrorzugrifffsrechte
2 Beiträge 2 Kommentatoren 392 Aufrufe
  • Marco RarraschM Offline
    Marco Rarrasch
    Hallo Leute ich habe folgende Fehler beim Update von Alexa auf dem Iobroker.
    Kann mir jemand bitte helfen?
    $ ./iobroker upgrade alexa2
    Update alexa2 from @1.1.3 to @2.3.3
    NPM version: 6.9.0
    npm install iobroker.alexa2@2.3.3 --production --save --prefix "/opt/iobroker" (System call)
    npm
     WARN
     registry
     Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
    npm
    WARN registry
     Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
    npm
     ERR! code EINTEGRITYnpm ERR! errno EINTEGRITY
    npm
     ERR! Invalid response body while trying to fetch https://registry.npmjs.org/debug: Integrity verification failed for sha512-3B1veGTUmiSgBiCNl81P1UAuDTCfSpoHj/G2xpS0Uo7c6vKeGyTsRxr1EMavWobMR+rwlLH+BbKUVdzehG5l4w== (/home/iobroker/.npm/_cacache/content-v2/sha512/dc/1d/6f7864d49a24a006208d97cd4fd5402e0d309f4a9a078ff1b6c694b4528edceaf29e1b24ec471af510c6af5a86cc47eaf094b1fe05b29455dcde846e65e3)
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-06-25T19_13_18_600Z-debug.log
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.alexa2"
    npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was emptynpm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
    npm
     WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm
     WARN
     deprecated
     graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
     WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
     WARN deprecated natives@1.1.6: This module relies on Node.js's internals and will break at some point. Do not use it, and update to graceful-fs@4.x.
    npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm ERR! code EINTEGRITYnpm ERR! errno EINTEGRITY
    npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/debug: Integrity verification failed for sha512-3B1veGTUmiSgBiCNl81P1UAuDTCfSpoHj/G2xpS0Uo7c6vKeGyTsRxr1EMavWobMR+rwlLH+BbKUVdzehG5l4w== (/home/iobroker/.npm/_cacache/content-v2/sha512/dc/1d/6f7864d49a24a006208d97cd4fd5402e0d309f4a9a078ff1b6c694b4528edceaf29e1b24ec471af510c6af5a86cc47eaf094b1fe05b29455dcde846e65e3)
    npm ERR!     /home/iobroker/.npm/_logs/2019-06-25T19_13_39_379Z-debug.log
    Cannot install iobroker.alexa2: 1
    Ich wollte zB auch den Iobroker updaten und bekomme da auch nur Fehler. Vielleicht liegt es ja auch alles an einem Fehler. Ich möchte bloss nichts falsch machen
    sudo iobroker upgrade self
    Update js-controller from @1.5.7 to @1.5.11
    NPM version: 6.9.0
    npm install iobroker.js-controller@1.5.11 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/readme.md': Die Operation ist ni        cht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/package.json': Die Operation ist        nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules': Die Operation ist        nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex': Die        Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/readm        e.md': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/packa        ge.json': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/index        .js': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/licen        se': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/index.js': Die Operation ist nic        ht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/license': Die Operation ist nich        t erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/bin': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/bin/which': Die Operation ist nicht erlaub        t
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/LICENSE': Die Operation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/package.json': Die Operation ist nicht erl        aubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules': Die Operation ist nicht erl        aubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe': Die Operation ist nic        ht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/LICENSE': Die Operation        ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/package.json': Die Oper        ation ist nicht erlaubt
    chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/test': Die Operation is        t nicht erlaubt
    Chmod finished. Restart controller
    Starting node restart.js
    A 1 Antwort Letzte Antwort
    • Marco RarraschM Marco Rarrasch
      NPM version: 6.9.0
      npm
       WARN
       registry
      npm
      WARN registry
      npm
      npm
      npm
      npm
       WARN
       deprecated
      npm
      npm
      NPM version: 6.9.0
      aleks-83
      @Marco-Rarrasch sagte in Adapter Alexa Update Fehler:
      NPM version: 6.9.0
      Da kannst du versuchen den CHMOD Befehl mit sudo auszuführen.
      sudo chmod 777 /opt/iobroker/
      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
      = Node.js v20.19.6 = NPM 22.22.2 = JS Controller 7.2.2 =
      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
      Glasfaser 400
