    2. Marco Rarrasch
    • Posts 1
    Marco Rarrasch
    @Marco Rarrasch
    66
    Marco Rarrasch Follow
    Latest posts made by Marco Rarrasch
    • Adapter Alexa Update Fehler
      Hallo Leute ich habe folgende Fehler beim Update von Alexa auf dem Iobroker.
      Kann mir jemand bitte helfen?
      $ ./iobroker upgrade alexa2
      Update alexa2 from @1.1.3 to @2.3.3
      NPM version: 6.9.0
      npm install iobroker.alexa2@2.3.3 --production --save --prefix "/opt/iobroker" (System call)
      npm
       WARN
       registry
       Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
      npm
      WARN registry
       Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
      npm
       ERR! code EINTEGRITYnpm ERR! errno EINTEGRITY
      npm
       ERR! Invalid response body while trying to fetch https://registry.npmjs.org/debug: Integrity verification failed for sha512-3B1veGTUmiSgBiCNl81P1UAuDTCfSpoHj/G2xpS0Uo7c6vKeGyTsRxr1EMavWobMR+rwlLH+BbKUVdzehG5l4w== (/home/iobroker/.npm/_cacache/content-v2/sha512/dc/1d/6f7864d49a24a006208d97cd4fd5402e0d309f4a9a078ff1b6c694b4528edceaf29e1b24ec471af510c6af5a86cc47eaf094b1fe05b29455dcde846e65e3)
      npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2019-06-25T19_13_18_600Z-debug.log
      npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.alexa2"
      npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was emptynpm WARN registry Using stale data from https://registry.npmjs.org/ due to a request error during revalidation.
      npm
       WARN deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
      npm
       WARN
       deprecated
       graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
      npm
       WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm
       WARN deprecated natives@1.1.6: This module relies on Node.js's internals and will break at some point. Do not use it, and update to graceful-fs@4.x.
      npm WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
      npm ERR! code EINTEGRITYnpm ERR! errno EINTEGRITY
      npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/debug: Integrity verification failed for sha512-3B1veGTUmiSgBiCNl81P1UAuDTCfSpoHj/G2xpS0Uo7c6vKeGyTsRxr1EMavWobMR+rwlLH+BbKUVdzehG5l4w== (/home/iobroker/.npm/_cacache/content-v2/sha512/dc/1d/6f7864d49a24a006208d97cd4fd5402e0d309f4a9a078ff1b6c694b4528edceaf29e1b24ec471af510c6af5a86cc47eaf094b1fe05b29455dcde846e65e3)
      npm ERR!     /home/iobroker/.npm/_logs/2019-06-25T19_13_39_379Z-debug.log
      Cannot install iobroker.alexa2: 1
      ERROR: process exited with code 25
      Ich wollte zB auch den Iobroker updaten und bekomme da auch nur Fehler. Vielleicht liegt es ja auch alles an einem Fehler. Ich möchte bloss nichts falsch machen
      sudo iobroker upgrade self
      Update js-controller from @1.5.7 to @1.5.11
      NPM version: 6.9.0
      npm install iobroker.js-controller@1.5.11 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/readme.md': Die Operation ist ni        cht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/package.json': Die Operation ist        nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules': Die Operation ist        nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex': Die        Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/readm        e.md': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/packa        ge.json': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/index        .js': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/node_modules/shebang-regex/licen        se': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/index.js': Die Operation ist nic        ht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/shebang-command/license': Die Operation ist nich        t erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/bin': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/bin/which': Die Operation ist nicht erlaub        t
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/LICENSE': Die Operation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/package.json': Die Operation ist nicht erl        aubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules': Die Operation ist nicht erl        aubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe': Die Operation ist nic        ht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/LICENSE': Die Operation        ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/package.json': Die Oper        ation ist nicht erlaubt
      chmod: Beim Setzen der Zugriffsrechte für '/opt/iobroker/node_modules/iobroker.j        s-controller/node_modules/yargs/node_modules/os-locale/node_modules/execa/node_m        odules/cross-spawn/node_modules/which/node_modules/isexe/test': Die Operation is        t nicht erlaubt
      Chmod finished. Restart controller
      Starting node restart.js
      Marco Rarrasch
      Marco Rarrasch
