  2. English
  3. ioBroker general
  4. Z-Wave Installation
    6.0k
Z-Wave Installation
Geplant Angeheftet Gesperrt Verschoben ioBroker general
z-wave
6 Beiträge 2 Kommentatoren 1.5k Aufrufe 3 Beobachtet
    ap2017
    schrieb am zuletzt editiert von ap2017
    I updated NODE.JS to v10.16.0 on my X86 Linux Mint computer per following instructions:
    sudo apt-get --purge remove node
    sudo apt-get --purge remove nodejs
    sudo apt-get autoremove
    sudo reboot
    curl -sL https://deb.nodesource.com/setup_10.x | sudo -E bash -
    sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
    sudo reboot
    cd /opt/iobroker
    sudo npm rebuild
    iobroker start
    Now I am trying to install Z-Wave adapter, see below installation log with errors and permission denied messages. What am I doing wrong?
    $ ./iobroker add zwave --host ap-linux
    NPM version: 6.9.0
    npm install iobroker.zwave@1.4.1 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm WARN rollback Rolling back iobroker.zwave@1.4.1 failed (this is probably harmless): EACCES: permission denied, unlink '/opt/iobroker/node_modules/iobroker.zwave/node_modules/openzwave-shared/build/Makefile'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/clone-deep/package.json'npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-base/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-choices/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/prompt-question/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-ui/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/readline-utils/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/shallow-clone/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/static-extend/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.discovery/node_modules/window-size/package.json'
    npm ERR! path /opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLognpm ERR! code EACCES
    npm ERR! errno -13npm ERR! syscall unlink
    npm ERR! Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'npm ERR! { [Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog']
    npm ERR! cause:
    npm ERR! { Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'
    npm ERR! errno: -13,
    npm ERR! code: 'EACCES',
    npm ERR! syscall: 'unlink',
    npm ERR! path:
    npm ERR! '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog' },
    npm ERR! stack:
    npm ERR! 'Error: EACCES: permission denied, unlink '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog'',
    npm ERR! path:
    npm ERR! '/opt/iobroker/node_modules/.iobroker.zwave.DELETE/open-zwave-1.4/ChangeLog',
    npm ERR! parent: 'iobroker' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    npm ERR! /home/iobroker/.npm/_logs/2019-06-23T22_25_14_617Z-debug.log
    ERROR: host.ap-linux Cannot install iobroker.zwave@1.4.1: 243
    • A ap2017
      sudo reboot
      sudo reboot
      cd /opt/iobroker
      sudo npm rebuild
      iobroker start
      NPM version: 6.9.0
      npm ERR! cause:
      npm ERR! path:
      npm ERR! stack:
      npm ERR! path:
      npm ERR!
      npm ERR!
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      @ap2017
      You messed up the permissions when you ran sudo npm rebuild. sudo should (almost) never be used together with npm anymore. You might want to read this (although it is in german):
      https://forum.iobroker.net/topic/17109/wichtige-hinweise-bei-neueren-npm-versionen-und-sudo
      Please run the installer fixer
      and try installing zwave again.
      A 2 Antworten Letzte Antwort
      • AlCalzoneA AlCalzone
        @ap2017
        ap2017
        @AlCalzone Thank you. I am getting message
        bash: line 1: Moved: command not found
        In response to the fixing script
        • A ap2017
          ap2017
          @ap2017 I am good, made an error is -sL, did not use capital L.
            @ap2017
            ap2017
            @AlCalzone Hello, I am trying to install ZWave on X64 Intel platform with Linux, getting some errors during installation of adapter, then errors during adapter start. I have controller 1.5.12, Node.js 10.16.0 and NPM 6.9.0
            ZWave on X64 Intel.txt
            Never mind, after following https://github.com/ioBroker/ioBroker.zwave#known-issues everything starterd to work
            • A ap2017
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @ap2017 Your adapter is still compiled against OZW 1.4:
              2019-07-06 21:10:51.257 - error: zwave.0 uncaught exception: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
              2019-07-06 21:10:51.257 - error: zwave.0 Error: libopenzwave.so.1.4: cannot open shared object file: No such file or directory
              Please take a look at https://github.com/ioBroker/ioBroker.zwave/issues/57, specifically this comment:
              https://github.com/ioBroker/ioBroker.zwave/issues/57#issuecomment-510884233
