  4. IoBroker simple web Adapter nach Update zerschossen
7 Beiträge 4 Kommentatoren 1.4k Aufrufe
  • L Offline
    LDSign
    Hi
    Seit vorhin ist ein Update für den simple Web Adapter verfügbar. Allerdings konnte man dieses nicht vollständig installieren und der Adapter war danach zerschossen.
    Eine Neuinstallation ist ebenfalls nicht mehr möglich:
    $ ./iobroker add web
    npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
    npm
    ERR! notarget
     No compatible version found: iobroker.socketio@'>=1.3.0'npm
    ERR! notarget
     Valid install targets:npm
     ERR!
    notarget
     ["0.1.1","0.1.2","0.1.3","0.1.4","0.1.5","0.1.7","0.2.0","0.2.1","0.2.2","0.2.3","0.3.0","0.4.1","0.4.2","0.4.3","0.4.4","0.4.5","1.0.0","1.2.1","1.2.2","1.2.3"]
    npm
     ERR!
     notarget npm
    ERR! notarget This is most likely not a problem with npm itself.
    npm ERR!
    notarget
     In most cases you or one of your dependencies are requesting
    npm
     ERR!
    notarget a package version that doesn't exist.
    npm
     ERR! System
     Linux 4.2.0-35-generic
    npm
    ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.web" "--production" "--prefix" "/opt/iobroker"
    npm ERR!
     cwd /
    npm ERR!
     node -v v0.10.25npm
    ERR! npm -v 1.4.21npm ERR! code ETARGET
    npm ERR! npm ERR! Additional logging details can be found in:
    npm ERR!     /npm-debug.log
    npm ERR! not ok code 0
    ERROR: host.SmartHome Cannot install iobroker.web: 1
    Eine manuelle Installation (npm install iobroker.web) über die Konsole liefert folgendes:
    npm ERR! notarget No compatible version found: iobroker.socketio@'>=1.3.0'
    npm ERR! notarget Valid install targets:
    npm ERR! notarget ["0.1.1","0.1.2","0.1.3","0.1.4","0.1.5","0.1.7","0.2.0","0.2.1","0.2.2","0.2.3","0.3.0","0.4.1","0.4.2","0.4.3","0.4.4","0.4.5","1.0.0","1.2.1","1.2.2","1.2.3"]
    npm ERR! notarget
    npm ERR! notarget This is most likely not a problem with npm itself.
    npm ERR! notarget In most cases you or one of your dependencies are requesting
    npm ERR! notarget a package version that doesn't exist.
    npm ERR! System Linux 4.2.0-35-generic
    npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.web"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v0.10.25
    npm ERR! npm -v 1.4.21
    npm ERR!
    npm ERR!     /opt/iobroker/npm-debug.log
    Was läuft hier schief?
    Viele Grüße,
    Frank
      Pman
      jup, socketio ist erst bei 1.2.3, der neue web verlangt aber nach 1.3.0
      • L Offline
        looxer01
        das gleiche hier.
        Könnte das mit dem ADMIN Adapter update zusammenhängen ?
        Github:
        1.0.2 (2016-04-07) - (bluefox) show npm errors of version
        vG
        • L Offline
          LDSign
          Danke. Wie kann ich das kurzfristig lösen? Oder ist ein Update in Vorbereitung?
          Gruß,
          Frank
          • BluefoxB Offline
            BluefoxB Offline
            @LDSign:
            Hi
            npm
            ERR! notarget
            ERR! notarget
             ERR!
            notarget
            npm
             ERR!
             notarget npm
            npm ERR!
            notarget
            npm
             ERR!
            npm
             ERR! System
            npm
            npm ERR!
             cwd /
            npm ERR!
             node -v v0.10.25npm
            npm ERR! notarget
            npm ERR!
            Viele Grüße,
            Frank `
            Probier noch mal.
            • L Offline
              LDSign
              Läuft wieder :) Danke für die schnelle Hilfe :)
              Gruß,
              Frank
              • L Offline
                looxer01
                hier auch.
                vielen Dank
