  4. iobroker/testing error
test
4 Beiträge 2 Kommentatoren 609 Aufrufe 1 Beobachtet
  • 孙善明孙 Offline
    孙善明孙 Offline
    孙善明
    schrieb am zuletzt editiert von 孙善明
    I wrote an adapter, but the following error occurred during automated testing, I need a little help
    travis-ci log
    github source
    "@iobroker/testing": "^1.2.5",
    The command "npm run test:package" exited with 0.
    1.37s$ npm run test:unit
    > iobroker.serve@0.0.1 test:unit /home/travis/build/smarthomefans/ioBroker.serve
    > mocha test/unit --exit
      Test the adapter (in a mocked environment)
        1) The adapter starts in normal mode
        2) The adapter starts in compact mode
      0 passing (78ms)
      2 failing
      1) Test the adapter (in a mocked environment)
           The adapter starts in normal mode:
         Error: Cannot find module '/home/travis/build/smarthomefans/iobroker.js-controller/lib/tools.js'
          at loadModuleInternal (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:166:26)
          at Module.fakeRequire [as require] (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:36:16)
          at require (internal/module.js:20:19)
          at startAdapter (main.js:36:58)
          at __dirname (main.js:151:2)
          at Object.<anonymous> (main.js:153:3)
          at Module.module._compile (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:158:24)
          at Object.replaceJsLoader (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:162:9)
          at Object.loadModuleInHarness (node_modules/@iobroker/testing/build/tests/unit/harness/loader.js:185:12)
          at Object.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:79:45)
          at next (native)
          at /home/travis/build/smarthomefans/ioBroker.serve/node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:8:71
          at __awaiter (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:4:12)
          at Object.startMockAdapter (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:36:12)
          at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:65:83)
          at next (native)
          at /home/travis/build/smarthomefans/ioBroker.serve/node_modules/@iobroker/testing/build/tests/unit/index.js:9:71
          at __awaiter (node_modules/@iobroker/testing/build/tests/unit/index.js:5:12)
          at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:61:20)
      2) Test the adapter (in a mocked environment)
           The adapter starts in compact mode:
          at Object.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/harness/startMockAdapter.js:89:17)
          at next (native)
          at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:80:105)
          at next (native)
          at Context.<anonymous> (node_modules/@iobroker/testing/build/tests/unit/index.js:76:24)
    npm ERR! Linux 4.4.0-101-generic
    npm ERR! argv "/home/travis/.nvm/versions/node/v6.17.1/bin/node" "/home/travis/.nvm/versions/node/v6.17.1/bin/npm" "run" "test:unit"
    npm ERR! node v6.17.1
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! iobroker.serve@0.0.1 test:unit: `mocha test/unit --exit`
    npm ERR! Exit status 2
    npm ERR!
    npm ERR! Failed at the iobroker.serve@0.0.1 test:unit script 'mocha test/unit --exit'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the iobroker.serve package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     mocha test/unit --exit
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs iobroker.serve
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls iobroker.serve
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR!     /home/travis/build/smarthomefans/ioBroker.serve/npm-debug.log
    The command "npm run test:unit" exited with 1.
    @Bluefox
    • 孙善明孙 孙善明
      solved
      dataDir = path.normalize(utils.controllerDir + '/iobroker-data/')
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      schrieb am zuletzt editiert von AlCalzone
      @孙善明 If you are relying on files from js-controller (like tools.js), you need to mock the methods in order to use them in unit tests. Remember, those don't have a real js-controller in the background.
      This is documented here: https://github.com/ioBroker/testing#adapter-startup-unit-test (in the middle of the code block). You would have to mock getDefaultDataDir, like this:
      "{CONTROLLER_DIR}/lib/tools.js": {
          getDefaultDataDir() { return "../../iobroker-data"; }
      (I'm not 100% sure about the actual return value).
      Warum sudo böse ist: https://forum.iobroker.net/post/17109
      • 孙善明孙 Offline
        孙善明孙 Offline
        孙善明
        I found the problem here.
         * @param {Partial<ioBroker.AdapterOptions>} [options]
        function startAdapter(options) {
        	// Create the adapter and define its methods
        	dataDir = path.normalize(path.join(utils.controllerDir, require(path.join(utils.controllerDir, 'lib', 'tools.js')).getDefaultDataDir()));
        	return adapter = utils.adapter(Object.assign({}, options, {
        		// The ready callback is called when databases are connected and adapter received configuration.
        		// start here!
        		ready: main, // Main method defined below for readability
        		// is called when adapter shuts down - callback has to be called under any circumstances!
        		unload: (callback) => {
        			try {
        				adapter.log.info("cleaned everything up...");
        				callback();
        			} catch (e) {
        				callback();
        • 孙善明孙 Offline
          孙善明孙 Offline
          孙善明
          solved
          • 孙善明孙 孙善明
            solved
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
