  5. Wrong type of javascript.0 BLOCKLY PROBLEM
    5.7k
blockly
5 Beiträge 2 Kommentatoren 408 Aufrufe 2 Beobachtet
  • H Offline
    helfi9999
    Hallo Habe folgendes Blockly am laufen
    kriege aber folgende Fehlermeldung
    javascript.0 2019-05-21 20:07:14.033 warn at TCP.onread (net.js:601:20)
    javascript.0 2019-05-21 20:07:14.032 warn at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0 2019-05-21 20:07:14.032 warn at readableAddChunk (_stream_readable.js:250:11)
    javascript.0 2019-05-21 20:07:14.031 warn at addChunk (_stream_readable.js:263:12)
    javascript.0 2019-05-21 20:07:14.031 warn at Socket.emit (events.js:211:7)
    javascript.0 2019-05-21 20:07:14.030 warn at emitOne (events.js:116:13)
    javascript.0 2019-05-21 20:07:14.030 warn at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0 2019-05-21 20:07:14.029 warn at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0 2019-05-21 20:07:14.028 warn at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0 2019-05-21 20:07:14.028 warn at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0 2019-05-21 20:07:14.027 warn at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0 2019-05-21 20:07:14.027 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0 2019-05-21 20:07:14.026 warn at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0 2019-05-21 20:07:14.025 warn at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0 2019-05-21 20:07:14.021 warn at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0 2019-05-21 20:07:14.020 warn at WebSocket.emit (events.js:214:7)
    javascript.0 2019-05-21 20:07:14.020 warn at emitTwo (events.js:126:13)
    javascript.0 2019-05-21 20:07:14.019 warn at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0 2019-05-21 20:07:14.019 warn at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0 2019-05-21 20:07:14.018 warn at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0 2019-05-21 20:07:14.018 warn at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0 2019-05-21 20:07:14.017 warn at WS.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-21 20:07:14.017 warn at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0 2019-05-21 20:07:14.016 warn at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0 2019-05-21 20:07:14.016 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/engine.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-21 20:07:14.015 warn at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2019-05-21 20:07:14.015 warn at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0 2019-05-21 20:07:14.014 warn at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0 2019-05-21 20:07:14.014 warn at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
    javascript.0 2019-05-21 20:07:14.013 warn at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2019-05-21 20:07:14.013 warn at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0 2019-05-21 20:07:14.012 warn at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-21 20:07:14.011 warn at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2019-05-21 20:07:14.011 warn at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0 2019-05-21 20:07:14.010 warn at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0 2019-05-21 20:07:14.010 warn at Socket.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0 2019-05-21 20:07:14.009 warn at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0 2019-05-21 20:07:14.008 warn at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0 2019-05-21 20:07:14.008 warn at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0 2019-05-21 20:07:14.007 warn at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0 2019-05-21 20:07:14.007 warn at Object.<anonymous> (script.js.Alexa_Bedienung.Alexa:14:5)
    javascript.0 2019-05-21 20:07:14.006 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0 2019-05-21 20:07:13.994 warn Wrong type of javascript.0.TabletVis.echo.wohnzimmer_status: "string". Please fix, while deprecated and will not work in next versions
    Ich finde den Fehler einfach nicht.
    Vielleicht ist jemand hier der sich damit gut auskennt
    Gruß helfi9999
    Intel NUC mit Iobroker
    • H helfi9999
      Gruß helfi9999
      @helfi9999 Wrong type of javascript.0 BLOCKLY PROBLEM:
      Schau mal im Reiter "Objekte" unter Eigenschaft (Stiftsymbol rechts) welchen Typ der Datenpunkt "javascript.0.TabletVis.echo.wohnzimmer_status" hat.
      H 1 Antwort Letzte Antwort
        helfi9999
        @paul53 der Datenpunkt ist Logikwert, müsste ich den ändern auf "gemischt"
        • H helfi9999
          @helfi9999 sagte:
          Auf "string", wenn die Werte im Skript funktionieren wie sie sollen.
            @helfi9999 sagte:
            helfi9999
            @paul53 ok werde ich morgen mal probieren.
            Danke erstmals für deine Hilfe
