  5. Blockly fhem Loop ?
    5.7k
Blockly fhem Loop ?
2 Beiträge 2 Kommentatoren 464 Aufrufe 2 Beobachtet
  • C Offline
    ChrisXY
    frage einfach nur einen Wert der per fhem adapter kommt ab.
    Present/abesent
    Aber er Spammt mich mit nachrichten zu .. verstehe nicht wieso.
    12:59:36.888	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"present","ack":true,"ts":1558436376871,"q":0,"from":"system.adapter.fhem.0","lc":1558436376871}
    12:59:36.889	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: sendTo(adapter=telegram, cmd=send, msg={"text":"Tanja DA FHEM UNIFI"})
    12:59:36.939	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436376927,"q":0,"from":"system.adapter.fhem.0","lc":1558436376927}
    12:59:36.940	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.presence, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436369215,"q":0,"from":"system.adapter.fhem.0","lc":1558436369215}
    12:59:44.198	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"present","ack":true,"ts":1558436384189,"q":0,"from":"system.adapter.fhem.0","lc":1558436384189}
    12:59:44.198	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: sendTo(adapter=telegram, cmd=send, msg={"text":"Tanja DA FHEM UNIFI"})
    12:59:44.246	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.state, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436384241,"q":0,"from":"system.adapter.fhem.0","lc":1558436384241}
    12:59:44.247	info	javascript.0 script.js.Tests.unifi_fhem_tanja_check: getState(id=fhem.0.handy_tanja_unifi.presence, timerId=undefined) => {"val":"maybe absent","ack":true,"ts":1558436377409,"q":0,"from":"system.adapter.fhem.0","lc":1558436377409}
    • LausiDL Offline
      LausiDL Offline
      LausiD
      schrieb am zuletzt editiert von LausiD
      @ChrisXY
      getState(id=fhem.0.handy_tanja_unifi.state) wechselt zwischen present und maybe absent.
      Und bei jeder Änderung wird dein Script neu gestartet.
      Solltest schauen in FHEM das "state" stabil bekommen
      LausiD
      Doku zum FHEM Adapter
      Aktuelles zum FHEM Adapter
      Test FHEM Adapter
