  4. [solved] Custom HTML with Object ID bindings
    5.2k
vis
9 Beiträge 2 Kommentatoren 987 Aufrufe 1 Beobachtet
  • KarolisLK Offline
    KarolisLK Offline
    KarolisL
    schrieb am zuletzt editiert von KarolisL
    Hello, I've noticed this question was asked at least 2 times but without answers.
    I have custom html code:
    <!DOCTYPE html>
    <html>
        <body>
            <canvas id="myCanvas" width="401" height="401" style="border:1px solid #d3d3d3;">
                Your browser does not support the HTML5 canvas tag.
            </canvas>
            <script type="text/javascript">
                var X = 200;
                var Y = 200;
                var outterRadius = 180;
                var innerRadius = 110;
                // 1. get a reference to myCanvas element.
                var c = document.getElementById("myCanvas");
                // 2. get canvas context
                var context = c.getContext("2d");
                // 3. draw donut chart
                // RED
                setRadialGradient("#DC1C29", "#B7161B");
                drawDonut(Math.PI * 0.5, Math.PI * 0.75);
                // GREEN
                setRadialGradient("#84BC3D", "#5B8829");
                drawDonut(Math.PI*0.75 , Math.PI* 1.5);
                // BLUE
                setRadialGradient("#27A1D4", "#2182AD");
                drawDonut(Math.PI * 1.5, Math.PI*2);
                // YELLOW
                setRadialGradient("#ECCF2D", "#F1C433");
                drawDonut(0, Math.PI*.5);
                // drawDonut() function drawes 2 full or partial circles inside each other one clockwise and the other is counter-clockwise
                function drawDonut(sRadian, eRadian){
                    context.beginPath();
                        context.arc(X, Y, outterRadius, sRadian, eRadian, false); // Outer: CCW
                        context.arc(X, Y, innerRadius, eRadian, sRadian, true); // Inner: CW
                    context.closePath();
                    // add shadow
                    addShadow();
                    context.fill();
                function addShadow(){
                    context.shadowColor = "#333";
                    context.shadowBlur = 5;
                    context.shadowOffsetX = 0;
                    context.shadowOffsetY = 0;
                function setRadialGradient(sgc, bgc){
                    var grd = context.createRadialGradient(X, Y, innerRadius + 5, X, Y, outterRadius);
                    grd.addColorStop(0,sgc);
                    grd.addColorStop(1,bgc);
                    context.fillStyle = grd;
            </script>
        </body>
    </html>
    How to make
                // RED
                // GREEN
    dynamic Object ID bindings something like:
    drawDonut(Math.PI * {node-red.val1}, Math.PI * 0.75);
    • KarolisLK KarolisL
      <!DOCTYPE html>
      <html>
          <body>
              </canvas>
                  var X = 200;
                  var Y = 200;
                  // RED
                  // GREEN
                  // BLUE
                  // YELLOW
                      // add shadow
                      addShadow();
                      context.fill();
              </script>
          </body>
      </html>
      How to make
                  // RED
                  // GREEN
      foxriver76F Offline
      foxriver76F Offline
      foxriver76
      @KarolisL To the best of my knowledge, Bindings are not possible in Javascript code, only in the vis attributes. If your topic is realated to html in vis, then you could get the states value by using the value of vis.states. But note that vis.states only contains the values of the states which are necessary for your widgets. So you could add a dummy widget with the desired states and make it invisible. Probabaly there is also the possibility to use socket.emit('getState', 'yourState', function (err, state) {}) when socket io is included.
      Videotutorials & mehr
      KarolisLK 1 Antwort Letzte Antwort
      • foxriver76F foxriver76
        KarolisLK Offline
        KarolisLK Offline
        KarolisL
        @foxriver76 Thanks for quick response. Sadly I didn't understand fully:
        Lets say I tried to use state admin.0.info.updatesNumber which is internal in admin.0 object
        var part1=vis.states(admin.0.info.updatesNumber);
                    // RED
                    drawDonut(Math.PI * part1, Math.PI * 0.75);
        As I understand I'm missing something, how to extract state value by using:
        vis.states
        command?
                      // RED
          vis.states
          command?
          foxriver76F Offline
          foxriver76F Offline
          foxriver76
          schrieb am zuletzt editiert von foxriver76
          @KarolisL vis.states is just an array. By logging it you can get the contained information in the browsers console.
              console.log(vis.states);
          </script>
          It's an array with the following structure:
          So it contains the states value, ts, last changed ts and acknowledge flag. You can access an array by its unqiue id:
              console.log('The state has been changed at ' + vis.states["denon.0.zoneMain.volumeDown.lc"]);
          </script>
          which results in:
            </script>
            </script>
            which results in:
            KarolisLK Offline
            KarolisLK Offline
            KarolisL
            @foxriver76 Thank you. For future references if anybody will have similar problems:
            to access global variables/objects you just have to address them through
             var variable = vis.states["node-red.0.DATA"] // or whatever you see in console.log (vis.states())
            can't thank you enough
            How to mark as solved?
              foxriver76F Offline
              foxriver76F Offline
              foxriver76
              @KarolisL you are welcome.
              When editing the first post, you can change the title and e. g. write ‘[solved]’ in front of it.
                KarolisLK Offline
                KarolisLK Offline
                KarolisL
                @foxriver76
                One last question, this is how it looks in editor (pic1)
                Why parts with vis.states are missing like that in runtime (pic2)?
                <!DOCTYPE html>
                <html>
                    <body>
                        </canvas>
                            console.log(vis.states["admin.0.info.updatesNumber.val"]);
                            var part1 = vis.states["admin.0.info.updatesNumber.val"]/7;
                            var X = 200;
                            var Y = 200;
                            // RED
                            drawDonut(Math.PI *part1, Math.PI * 0.75);
                            // GREEN
                            // BLUE
                            drawDonut(Math.PI * 2*part1, Math.PI*2);
                            // YELLOW
                                // add shadow
                                addShadow();
                                context.fill();
                        </script>
                    </body>
                </html>
                  @foxriver76
                  <!DOCTYPE html>
                  <html>
                      <body>
                          </canvas>
                              var X = 200;
                              var Y = 200;
                              // RED
                              // GREEN
                              // BLUE
                              // YELLOW
                                  // add shadow
                                  addShadow();
                                  context.fill();
                          </script>
                      </body>
                  </html>
                  foxriver76F Offline
                  foxriver76F Offline
                  foxriver76
                  @KarolisL only the states which are on the active view will be synced, that’s why in my screenshot so many values are null and browser console said only requested 5 states. So probably it’s due to this fact?
                    KarolisLK Offline
                    KarolisLK Offline
                    KarolisL
                    @foxriver76 The problem was that all states were present in tab-objects, but for them to appear in visualization and to be synchronized, you have to create dummy widget and make it invisible later as you mentioned in post 2. "So you could add a dummy widget with the desired states and make it invisible. "
