  4. ioBroker Objekte aus javascript object erzeugen
    5.8k
javascript
5 Beiträge 2 Kommentatoren 2.8k Aufrufe 1 Beobachtet
  • dewenniD Offline
    dewenniD Offline
    dewenni
    ich experimentiere gerade mir meinem WLAN Grillthermometer.
    Dieses sendet per MQTT einen Status im JSON Format.
    Hier ein Beispiel:
    {"system":{"time":"1555763739","unit":"C","soc":87,"charge":false,"rssi":-76,"online":2},"channel":[{"number":1,"name":"Smoker","typ":0,"temp":33.70,"min":95.00,"max":150.00,"alarm":0,"color":"#FFC100"},{"number":2,"name":"Fleisch Un","typ":0,"temp":999.00,"min":10.00,"max":94.00,"alarm":1,"color":"#22B14C"},{"number":3,"name":"Fleisch Ob","typ":10,"temp":999.00,"min":10.00,"max":94.00,"alarm":1,"color":"#EF562D"},{"number":4,"name":"Kanal 4","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#FFC100"},{"number":5,"name":"Kanal 5","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#A349A4"},{"number":6,"name":"Kanal 6","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#804000"},{"number":7,"name":"Kanal 7","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5587A2"},{"number":8,"name":"Kanal 8","typ":0,"temp":999.00,"min":10.00,"max":35.00,"alarm":0,"color":"#5C7148"}],"pitmaster":{"type":["off","manual","auto"],"pm":[{"id":0,"channel":1,"pid":2,"value":100,"set":110.00,"typ":"auto","set_color":"#ff0000","value_color":"#000000"}]}}
    Ich würde nun gerne daraus ein entsprechendes Objekt im ioBroker erzeugen.
    Dazu habe ich nun mittels javascript angefangen aus dem JSON ein Objekt zu erzeugen.
    Das klappt prima mittels JSON.parse recht elegant.
    // path to json data
    varJSON = 'mqtt.0.WLanThermo.Nanotherm.status.data';
    // get json data
    var rawJSON = getState(varJSON).val;
    // JSON to object
    obj = JSON.parse(rawJSON);
    // Test output
    console.log(obj.system.time);
    console.log(obj.system.unit);
    console.log(obj.system.soc);
    console.log(obj.system.charge);
    console.log(obj.system.rssi);
    console.log(obj.system.online);
    Wie erstelle ich denn jetzt am einfachsten aus dem bestehenden javascript Objekt ein Objekt im ioBroker?
    Muss ich das für jedes Element einzeln machen, oder gibt es sogar eine Möglichkeit das mit einem Befehl zu machen?
    Zu Fuß habe ich nun so angefangen:
            id = 'javascript.0.nanotherm.system.time'
            createState(id, false,{
                type: 'number',
            id = 'javascript.0.nanotherm.nystem.unit'
                type: 'string',
    Das wäre ok, da ich aber noch recht neu bin in ioBroker und javascript wollte ich lieber mal fragen ob das so der richtige Weg ist.
    • dewenniD dewenni
      Hier ein Beispiel:
      // get json data
      // JSON to object
      // Test output
                  type: 'number',
                  type: 'string',
      @dewenni sagte:
      Nicht ganz. system.unit ist sicherlich konstant und gehört wohl zum Wert system.soc. Die Zeit in s seit 1.1.1970 darzustellen, ist sicherlich nicht so elegant.
      const path = 'nanotherm.system.';
      createState(path + 'soc', obj.system.soc, {
         type: 'number',
         unit: obj.system.unit,
      createState(path + 'time', formatDate(parseInt(obj.system.time), 'hh:mm:ss'), {
         type: 'string',
      EDIT: obj.system.time von String nach Zahl gewandelt
      • dewenniD Offline
        dewenniD Offline
        dewenni
        Danke für die Antwort. Mir ging es auch erstmal generell um die Frage ob man jedes Element einzeln erzeigen muss. Dies scheint ja so zu sein.
        Aber wo wir schon bei den Details sind. Das mit der Zeit klappt nicht. Ich hatte das auch schon probiert.
        Der Wert von time ist z.B. "time":"1555766679"
        mit formatDate(obj.system.time, 'hh:mm:ss') ergibt das aber NaN:NaN:NaN
        An anderer stelle habe ich auch schon mit formatDate() gearbeitet, aber hier passt irgendwas nicht.
        • dewenniD dewenni
          @dewenni sagte:
          Versuche es mal mit Wandlung in eine Zahl:
          • dewenniD Offline
            dewenniD Offline
            dewenni
            das passt!
            Danke!
