  4. BLE-Adapter instalation
ble-adapter instalation
3 Beiträge 2 Kommentatoren 772 Aufrufe 1 Beobachtet
  • L Offline
    Leon111
    Hallo, beim updaten bzw. instalieren von BLE-Adapter bekomme ich die Meldungen:
    $ ./iobroker add ble --host raspberrypi
    NPM version: 6.4.1
    npm install iobroker.ble@0.7.2 --unsafe-perm --production --save --prefix "/opt/iobroker" (System call)
    npm
    notice created a lockfile as package-lock.json. You should commit this file.
    ../authenticate_pam.cc:30:31: fatal error: security/pam_appl.h: Datei oder Verzeichnis nicht gefunden #include <security/pam_appl.h>
    compilation terminated.
    make: *** [Release/obj.target/authenticate_pam/authenticate_pam.o] Fehler 1
    gyp
    ERR! build error
    gyp
    ERR!
    stack
    Error: make failed with exit code: 2gyp
    ERR!
    stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)gyp ERR! stack at emitTwo (events.js:126:13)
    gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
    gyp ERR! System Linux 4.14.79-v7+
    gyp ERR!
    command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/authenticate-pam
    gyp ERR! node -v v8.15.0
    gyp ERR! node-gyp -v v3.8.0
    gyp
    ERR! not ok
    node-pre-gyp
    WARN Using request for node-pre-gyp https download
    node-pre-gyp WARN Tried to download(404): https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v57-linux-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for usb@1.5.0 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    In file included from ../src/helpers.h:3:0, from ../src/node_usb.h:21,
    from ../src/transfer.cc:1:
    ../src/transfer.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Transfer_constructor(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/transfer.cc:25:12: internal compiler error: Speicherzugriffsfehler
    NAN_METHOD(Transfer_constructor) {
    ../../nan/nan.h:1413:33: note: in definition of macro ‘NAN_METHOD’
    Nan::NAN_METHOD_RETURN_TYPE name(Nan::NAN_METHOD_ARGS_TYPE info)
    Please submit a full bug report,with preprocessed source if appropriate.
    See <file:///usr/share/doc/gcc-6/README.Bugs> for instructions.
    make: *** [Release/obj.target/usb_bindings/src/transfer.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack
    at emitTwo (events.js:126:13)gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    gyp ERR! System Linux 4.14.79-v7+gyp
    ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node" "--module_name=usb_bindings" "--module_path=/opt/iobroker/node_modules/usb/src/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd /opt/iobroker/node_modules/usb
    gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/usb/src/binding/usb_bindings.node --module_name=usb_bindings --module_path=/opt/iobroker/node_modules/usb/src/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
    node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/usb/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
    node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
    node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
    node-pre-gyp ERR! System Linux 4.14.79-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/usb/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/usb
    node-pre-gyp ERR! node -v v8.15.0
    node-pre-gyp ERR! node-pre-gyp -v v0.11.0
    node-pre-gyp ERR! not ok
    node-pre-gyp
    node-pre-gyp WARN Tried to download(404): https://github.com/sandeepmistry/node-bluetooth-hci-socket/releases/download/0.5.3-1/binding-0.5.3-1-node-v57-linux-arm.tar.gz node-pre-gyp WARN Pre-built binaries not found for @abandonware/bluetooth-hci-socket@0.5.3-1 and node@8.15.0 (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::poll()’:../src/BluetoothHciSocket.cpp:252:95: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
    Nan::MakeCallback(Nan::New<Object>(this->This), Nan::New("emit").ToLocalChecked(), 2, argv);
    In file included from ../src/BluetoothHciSocket.cpp:8:0:
    ../node_modules/nan/nan.h:980:46: note: declared here
    NAN_DEPRECATED inline v8::Localv8::Value MakeCallback(
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::emitErrnoError()’:../src/BluetoothHciSocket.cpp:283:93: warning: ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated [-Wdeprecated-declarations]
    ../src/BluetoothHciSocket.cpp: In member function ‘void BluetoothHciSocket::bindControl()’:../src/BluetoothHciSocket.cpp:201:6: internal compiler error: Speicherzugriffsfehler
    void BluetoothHciSocket::bindControl() {
    make: *** [Release/obj.target/binding/src/BluetoothHciSocket.o] Fehler 1
    gyp
    ERR! build error
    gyp ERR!
    stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp
    ERR! System Linux 4.14.79-v7+gyp ERR! command
    "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node" "--module_name=binding" "--module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding" "--napi_version=3" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v57"gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    gyp
    ERR! node-gyp -v v3.8.0gyp ERR! not ok
    node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding/binding.node --module_name=binding --module_path=/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/lib/binding --napi_version=3 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v57' (1)
    node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR!
    stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)node-pre-gyp ERR! System Linux 4.14.79-v7+
    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/@abandonware/bluetooth-hci-socket
    node-pre-gyp ERR! node-pre-gyp -v v0.12.0
    npm WARN JSON.parse Failed to parse jsonnpm WARN JSON.parse Unexpected token
    npm WARN JSON.parse in JSON at position 14 while parsing '{
    npm WARN JSON.parse "_argsb: [
    npm WARN JSON.parse [
    npm WARN JSON.parse {
    npm WARN JSON.parse $ "ra'
    npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.npm WARN bl@0.7.0 requires a peer of stream-browserify@* but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@0.1.4 (node_modules/xpc-connection):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 (node_modules/authenticate-pam):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: authenticate-pam@1.0.2 install: node-gyp rebuild
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 (node_modules/usb):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: usb@1.5.0 install: node-pre-gyp install --fallback-to-build
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 (node_modules/@abandonware/bluetooth-hci-socket):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: @abandonware/bluetooth-hci-socket@0.5.3-1 install: node-pre-gyp install --fallback-to-build
    host.raspberrypi install adapter ble
    got /opt/iobroker/node_modules/iobroker.ble/admin
    upload [7] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/words.js words.js application/javascript
    upload [6] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
    upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
    upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index.html index.html text/html
    upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.map build/index.map application/json
    upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
    upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
    upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
    host.raspberrypi object system.adapter.ble created
    host.raspberrypi create instance ble
    host.raspberrypi object ble.0.options.allowNewDevices created
    host.raspberrypi object ble.0.options created
    host.raspberrypi object ble.0.info.driverState created
    host.raspberrypi object ble.0.info.connection created
    host.raspberrypi object ble.0.info created
    host.raspberrypi object system.adapter.ble.0.outputCount created
    host.raspberrypi object system.adapter.ble.0.inputCount created
    host.raspberrypi object system.adapter.ble.0.uptime created
    host.raspberrypi object system.adapter.ble.0.memRss created
    host.raspberrypi object system.adapter.ble.0.memHeapTotal created
    host.raspberrypi object system.adapter.ble.0.memHeapUsed created
    host.raspberrypi object system.adapter.ble.0.cputime created
    host.raspberrypi object system.adapter.ble.0.cpu created
    host.raspberrypi object system.adapter.ble.0.connected created
    host.raspberrypi object system.adapter.ble.0.alive created
    host.raspberrypi object system.adapter.ble.0 created
    process exited with code 0
    dannach bleib der Instanz rot.
    In den Einstalungen habe ich:
    -Gerät auswählen: 0 ( das interne Bluetooth ist aktiviert)
    RSSI Update-Intervall [ms]: 1000
    -Aktive Plugins: xiaomi
    Was mach ich falsch?
    Was fehlt noch?
    Hatte bis jetz die Version 0.5. irgendwas und es hat funktioniert
    Gerne würde ich aud die Erfahrung der Profis zurückgreifen und für Tips und Hilfe bin ich sehr dankbar
    Leon
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Bitte keine Doppelposts - ich habe hier geantwortet: https://forum.iobroker.net/topic/21291/ble-adapter/5
      • L Offline
        Leon111
        Sorry, etwas ist schiefgelaufen
