  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Решение проблем при обновлении драйверов
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
2 Beiträge 2 Kommentatoren 2.6k Aufrufe
    RDim
    Попытка обновить драйвер web Adapter приводила к ошибкам -
    $ ./iobroker upgrade web
    host.cubietruck Adapter "system.adapter.web.0" is stopped.
    npm install iobroker.web --production --prefix "/opt/iobroker" (System call)
    npm
    WARN enoent ENOENT, open '/opt/iobroker/package.json'
    npm WARN iobroker No description
    npm WARN iobroker No repository field.
    npm WARN iobroker No README data
    npm WARN iobroker No license field.
    host.cubietruck Adapter "system.adapter.web.0" is started
    npm install --production --prefix "/opt/iobroker/node_modules/iobroker.web" (System call)
    npm
    ERR!
    Linux 3.4.106-cubietrucknpm
    ERR! argv "node" "/usr/bin/npm" "install" "--production" "--prefix"
    ! "/opt/iobroker/node_modules/iobroker.web"npm ERR! node v0.10.42
    npm ERR! npm v3.8.1
    ! npm ERR! Cannot read property 'target' of nullnpm
    ERR! npm ERR! If you need help, you may report this error at:
    npm ERR!
    <https: github.com/npm/issues="">
    ! npm ERR! Please include the following file with any support request:
    npm ERR! /npm-debug.log
    Cannot install iobroker.web: 1
    ERROR: process exited with code 25</https:>
    В закладке админа показывает, что обновил драйвер до новой версии 1.3.5, но в консоли при запросе````
    iobroker list adapters
    system.adapter.admin : admin - 0.8.6
    system.adapter.megad : megad - 1.1.2
    system.adapter.mqtt : mqtt - 0.4.1
    system.adapter.owfs : owfs - 0.0.2
    system.adapter.ping : ping - 0.1.4
    system.adapter.pushbullet : pushbullet - 0.0.11
    system.adapter.sayit : sayit - 0.3.17
    system.adapter.web : web - 1.3.4
    system.adapter.flot : flot - 0.2.6
    system.adapter.vis : vis - 0.9.2
    system.adapter.javascript : javascript - 2.0.3
    system.adapter.socketio : socketio - 1.2.3
    system.adapter.vis-bars : vis-bars - 0.1.1
    system.adapter.vis-colorpicker : vis-colorpicker - 0.1.3
    system.adapter.vis-google-fonts : vis-google-fonts - 0.1.0
    system.adapter.vis-hqwidgets : vis-hqwidgets - 0.2.5
    system.adapter.vis-jqui-mfd : vis-jqui-mfd - 0.1.0
    system.adapter.vis-keyboard : vis-keyboard - 0.0.2
    system.adapter.vis-lcars : vis-lcars - 0.1.6
    system.adapter.vis-metro : vis-metro - 0.2.1
    system.adapter.vis-rgraph : vis-rgraph - 0.0.2
    system.adapter.vis-timeandweather : vis-timeandweather - 0.1.0
    system.adapter.history : history - 0.2.1
    system.adapter.rickshaw : rickshaw - 0.3.1
    system.adapter.text2command : text2command - 0.1.7
    system.adapter.telegram : telegram - 0.1.0
    system.adapter.sql : sql - 0.1.2
    system.adapter.vis-fancyswitch : vis-fancyswitch - 0.1.0
    system.adapter.vis-justgage : vis-justgage - 0.4.0
    видно что адаптер web имеет старую версию 1.3.4
    Причина, типа устаревшая версия nodejs
    npm WARN deprecated latest stable version. To upgrade to npm@2, run:
    npm WARN deprecated
    npm WARN deprecated   npm -g install npm@latest-2
    npm WARN deprecated
    npm WARN deprecated To upgrade to the latest stable version, run:
    npm WARN deprecated
    npm WARN deprecated
    npm WARN deprecated (Depending on how Node.js was installed on your system, you
    npm WARN deprecated may need to prefix the preceding commands with `sudo`, or if
    npm WARN deprecated on Windows, run them from an Administrator prompt.)
    npm WARN deprecated
    npm WARN deprecated If you're running the version of npm bundled with
    npm WARN deprecated Node.js 0.10 LTS, be aware that the next version of 0.10 LTS
    npm
    Попытка обновить как рекомендуют````
    Решение было найдено здесь - [https://nodejs.org/en/download/package- … tributions](https://nodejs.org/en/download/package-manager/#debian-and-ubuntu-based-linux-distributions)
    Набираем
    curl -sL https://deb.nodesource.com/setup_4.x | sudo -E bash -
    apt-get install -y nodejs
    После сего шаманства, версии стали - npm 2.14.20, node v4.4.0
    Затем````
    reboot
    ````и возможно````
    iobroker restart
    Теперь с консоли можно обновить адаптер web -````
    iobroker upgrade web https://github.com/ioBroker/ioBroker.web.git
    Проверяем````
    ````видим обновленный адаптер web 1.3.5
    Может кому поможет, я долго бился.
    • V Offline
      V Offline
      vtec
      По хорошему это косяк, в базе не должна была обновиться версия.
      А так спасибо, у себя 0.10 обновился на 4.4. Пойду обновлю инструкцию для Cubieboard.
