  4. Installationsproblem Raspi 3
installation raspberrypi
4 Beiträge 3 Kommentatoren 540 Aufrufe 2 Beobachtet
    adarof
    Hallo
    Ich habe mich sklavisch an die Anleitung gehalten:
    http://www.iobroker.net/docu/?page_id=8323&lang=de
    Damit habe ich folgende Versionen installiert:
    pi@raspberrypi:~ $ node -v
    v8.15.1
    pi@raspberrypi:~ $ nodejs -v
    v8.15.1
    pi@raspberrypi:~ $ npm -v
    6.9.0
    Leider bekomme ich vom Installationsskript:
        Installing ioBroker (3/4)
    ../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
    ../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(        int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(2, argv);
    In file included from ../src/./serialport.h:6:0,
                     from ../src/serialport.cpp:1:
    ../../nan/nan.h:1674:3: note: declared here
       Call(int argc, v8::Local<v8::Value> argv[]) const {
    ../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
    ../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
       data->callback.Call(1, argv);
    ../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
    ../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
    ../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
    ../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call        (int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]
    ../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
    Was kann ich da machen?
    • A adarof
      Hallo
      v8.15.1
      v8.15.1
      6.9.0
      @adarof
      Mit welchen Meldungen endet die Installation?
      A 1 Antwort Letzte Antwort
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @adarof sagte in Installationsproblem Raspi 3:
        warning
        Das ist normal. Eigentlich waren die Meldungen mal unterdrückt, um Verwirrung zu vermeiden.
          @adarof
          adarof
          @Homoran Ganz normal mit Erfolg, dass man mitm Browser loslegen kann.
          Dank Euch
