Könnt ihr mir über dieses Skript kurz drüberschauen, ob ich was vergessen habe oder einen Logikfehler eingebaut habe.
Ich möchte nicht, dass mir die Markise davon fliegt. :-)
Spoiler <xml xmlns="http://www.w3.org/1999/xhtml ">
<variables>
<variable type="undefined" id="timeout3">timeout3</variable>
<variable type="undefined" id="timeout4">timeout4</variable>
<variable type="undefined" id="timeout2">timeout2</variable>
</variables>
<block type="on_ext" id="0.Tcg.|FVV@zWgm#c9X" x="-1237" y="-12"> <mutation items="2"></mutation> <field name="CONDITION">ne</field> <field name="ACK_CONDITION"></field> <value name="OID0"> <shadow type="field_oid" id="9N:~4[Ubr[Pfw%7Tajp]"> <field name="oid">javascript.0.Regen</field> </shadow> </value> <value name="OID1"> <shadow type="field_oid" id=".ajiR}(6tHBbQsIR2cq5"> <field name="oid">javascript.0.Wind</field> </shadow> </value> <statement name="STATEMENT"> <block type="controls_if" id="6z?G6LOhk.*pUJ[3nBly"> <mutation elseif="1"></mutation> <value name="IF0"> <block type="logic_operation" id="(^1Ymf._%Znb7+8yh+e}"> <field name="OP">AND</field> <value name="A"> <block type="logic_compare" id="o@j/1V#|3=UD.RzQXy^b"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="{7Is|D.,kxItJ_bK:XS}"> <field name="ATTR">val</field> <field name="OID">javascript.0.Regen</field> </block> </value> <value name="B"> <block type="text" id="hKsfoH1S)-VE8mUk}s9E"> <field name="TEXT">Regen</field> </block> </value> </block> </value> <value name="B"> <block type="logic_compare" id="q{}FDHOXk|3qg60S7d~f"> <field name="OP">EQ</field> <value name="A"> <block type="get_value" id="+4ri0UBGpu}1+(exICSj"> <field name="ATTR">val</field> <field name="OID">javascript.0.Wind</field> </block> </value> <value name="B"> <block type="text" id="Y2AjZ@=8MJbx=sIv0Rm_"> <field name="TEXT">Kein Wind</field> </block> </value> </block> </value> </block> </value> <statement name="DO0"> <block type="control_ex" id="GdxLk(H{J[(l__d%L,H6"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="%IFjtn9qKJn,YBezkIDY"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_41_ZU</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="*PgLQuJ;/Mr9o2f8fOn5"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="LFl|NmeM_88bD8OIA36q"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="YjN-x-csaPd%9hP5*IKP"> <field name="NAME">timeout3</field> <field name="DELAY">12</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control_ex" id="7s)UtVK|j%@NjiE(r/zY"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="^]EYt7Zl1p3l/+RsIa;f"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_STOP_41</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="T*MgSZ@sN5[ibKyI?eR5"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id=".sncOg3vAp=[t8V#f]Q2"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="DiT0F9C}Ev9G_O0e6ua">
<field name="NAME">timeout4</field>
<field name="DELAY">2</field>
<block type="control_ex" id="gzg8CYe2fG^vmEm!;Nr"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="ex!lvTl2{*B*]Xu8BO=w"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_41_ZU</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="(cj2/qjmlKjapXj[y_KR"> <field name="BOOL">FALSE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="liocXn#BgYb}tUsh=f"> <field name="NUM">0</field> </shadow> </value> <next> <block type="timeouts_settimeout" id="tx+r[H8n+2nJPu8;f%8O"> <field name="NAME">timeout2</field> <field name="DELAY">11</field> <field name="UNIT">sec</field> <statement name="STATEMENT"> <block type="control_ex" id="v6XZ7R]C?p#Un~qC=9)|"> <field name="TYPE">false</field> <field name="CLEAR_RUNNING">FALSE</field> <value name="OID"> <shadow type="field_oid" id="MLOp|OOOIkE88~whqu=N"> <field name="oid">rflink.0.channels.BrelMotor_1.BLIND_STOP_41</field> </shadow> </value> <value name="VALUE"> <shadow type="logic_boolean" id="dnflsA}ChFCd|Wvd}75Q"> <field name="BOOL">TRUE</field> </shadow> </value> <value name="DELAY_MS"> <shadow type="math_number" id="HLVbLCvvMb;]hHV2@+5">
</shadow>
</value>
</block>
</statement>
</block>
</next>
</block>
</statement>
</block>
</next>
</block>
</statement>
</block>
</next>
</block>
</statement>
<value name="IF1">
<block type="logic_operation" id="85j@T+LZ@9dr59_keRkx">
<field name="OP">OR</field>
<value name="A">
<block type="logic_compare" id=")BO7rPDr#8rm~4U)vQ!0">
<value name="A">
<block type="get_value" id="haKIKct]1#g)?*^7^o">
</block>
</value>
<value name="B">
<block type="text" id="B;S~4QTF/q_P2z,BmG|M">
<field name="TEXT">Kein Regen</field>
</block>
</value>
</block>
</value>
<value name="B">
<block type="logic_compare" id="(bt03@z2e*GRAMVY3KZE">
<field name="OP">NEQ</field>
<value name="A">
<block type="get_value" id="*0D1F=!/}W%8SdanndJt">
</block>
</value>
<value name="B">
<block type="text" id="ji{=p|J#/Nu8bg[c.h!n">
</block>
</value>
</block>
</value>
</block>
</value>
<statement name="DO1">
<block type="control_ex" id="9rwMgpV4e~|-r@geH1GZ">
<value name="OID">
<shadow type="field_oid" id="y1fi!C@DTn{^Bk@Z={e!">
</shadow>
</value>
<shadow type="logic_boolean" id="xNQ`_}Lc2drcpyj%+Nu8">
</shadow>
</value>
<shadow type="math_number" id="L6H)tzc+x3nzvRiUJ0Pz">
</shadow>
</value>
</block>
</statement>
</block>
</statement>
</block>
</xml>
Regen:
Zuerst muss ich die Markise zu fahren ca.20 Sekunden (ich weiß ja nicht wo sie steht)
2 Sekunden Wartezeit mit STOP
11 Sekunden Auffahren
STOP
Wind:
Sofort Zufahren und alle anderen Ausführungen Stoppen, bis 1 Stunde lang "kein Wind".
Wie Verzögere ich das vernünftig?
Änderung zu "kein Regen":
Zufahren (Regenabfrage "kein Regen") ist in einem anderen Script mit Netatmo "one hour no rain" verzögert.
Bitte um Ratschläge und Ideen
Liebe Grüße
