  4. JS Update auf 4.1.7 Error 20
    6.7k
javascripterror
15 Beiträge 3 Kommentatoren 1.2k Aufrufe 4 Beobachtet
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Ich wollte gerade mein JS von 4.0.12 auf 4.1.7 updaten.
    Bekam am Schluss einen Error 20.
    iobroker 2019-03-02 16:01:43.650 info exit 20
    iobroker 2019-03-02 16:01:43.637 error host.ioBroker error: reading io-package.json Error: ENOENT: no such file or directory, open 'null/io-package.json'
    iobroker 2019-03-02 16:01:43.635 info host.ioBroker create instance javascript
    iobroker 2019-03-02 16:01:43.558 info npm ERR! Please include the following file with any support request:npm ERR! /opt/iobroker/npm-debug.log
    iobroker 2019-03-02 16:01:43.557 info
    iobroker 2019-03-02 16:01:43.481 info npm ERR! There is likely additional logging output above.
    iobroker 2019-03-02 16:01:43.481 info npm ERR! npm owner ls iobroker.javascript
    iobroker 2019-03-02 16:01:43.481 info npm bugs iobroker.javascriptnpm ERR! Or if that isn't available, you can get their info via:
    iobroker 2019-03-02 16:01:43.480 info ERR!
    iobroker 2019-03-02 16:01:43.478 info npm
    iobroker 2019-03-02 16:01:43.476 info npm ERR! You can get information on how to open an issue for this project with:
    iobroker 2019-03-02 16:01:43.476 info npm ERR! node ./install/installTypings.js
    iobroker 2019-03-02 16:01:43.476 info npm ERR! Tell the author that this fails on your system:
    iobroker 2019-03-02 16:01:43.476 info npm ERR! not with npm itself.
    iobroker 2019-03-02 16:01:43.476 info npm ERR! If you do, this is most likely a problem with the iobroker.javascript package,
    iobroker 2019-03-02 16:01:43.476 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    iobroker 2019-03-02 16:01:43.476 info npm ERR! Failed at the iobroker.javascript@4.1.7 postinstall script 'node ./install/installTypings.js'.
    iobroker 2019-03-02 16:01:43.476 info ERR! iobroker.javascript@4.1.7 postinstall: node ./install/installTypings.jsnpm ERR! Exit status 1
    iobroker 2019-03-02 16:01:43.475 info npm
    iobroker 2019-03-02 16:01:43.475 info ERR! code ELIFECYCLE
    iobroker 2019-03-02 16:01:43.474 info npm
    iobroker 2019-03-02 16:01:43.474 info npm ERR! npm v3.10.10
    iobroker 2019-03-02 16:01:43.474 info npm ERR! node v6.14.4
    iobroker 2019-03-02 16:01:43.474 info ERR! Linux 4.4.59+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript" "--production" "--save" "--prefix" "/opt/iobroker"
    iobroker 2019-03-02 16:01:43.473 info npm
    iobroker 2019-03-02 16:01:43.468 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    iobroker 2019-03-02 16:01:43.468 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIO
    iobroker 2019-03-02 16:01:43.467 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):
    iobroker 2019-03-02 16:01:43.467 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    iobroker 2019-03-02 16:01:43.467 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/@abandonware/noble/node_modules/xpc-connection):
    iobroker 2019-03-02 16:01:43.467 info WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/@abandonware/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for
    iobroker 2019-03-02 16:01:43.465 info npm
    iobroker 2019-03-02 16:01:42.175 info at bootstrap_node.js:507:3
    iobroker 2019-03-02 16:01:42.175 info at startup (bootstrap_node.js:160:9)
    iobroker 2019-03-02 16:01:42.175 info at run (bootstrap_node.js:394:7)
    iobroker 2019-03-02 16:01:42.175 info at Module.runMain (module.js:611:10)
    iobroker 2019-03-02 16:01:42.175 info at Function.Module._load (module.js:424:25)
    iobroker 2019-03-02 16:01:42.175 info at Function.Module._resolveFilename (module.js:476:15)
    iobroker 2019-03-02 16:01:42.175 info Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
    iobroker 2019-03-02 16:01:42.175 info ^
    iobroker 2019-03-02 16:01:42.175 info module.js:478 throw err;
    Unter "Adapter" scheint der JS-Adapter zwar auf, aber nicht als installiert!
    Unter "Instanzen" scheint der JS-Adapter aber auf und funktioniert auch.
    Kann jetzt aber auch nicht mehr die 4.0.12 installieren.
    Da kommt ein Exit 10
    iobroker 2019-03-02 16:03:12.521 info exit 10
    iobroker 2019-03-02 16:03:12.507 error Cannot find io-package.json in null
    iobroker 2019-03-02 16:03:12.478 info npm ERR! Please include the following file with any support request:npm ERR! /opt/iobroker/npm-debug.log
    iobroker 2019-03-02 16:03:12.477 info
    iobroker 2019-03-02 16:03:12.404 info npm ERR! There is likely additional logging output above.
    iobroker 2019-03-02 16:03:12.404 info npm ERR! npm owner ls iobroker.javascript
    iobroker 2019-03-02 16:03:12.404 info npm ERR! Or if that isn't available, you can get their info via:
    iobroker 2019-03-02 16:03:12.404 info npm ERR! npm bugs iobroker.javascript
    iobroker 2019-03-02 16:03:12.404 info ERR! node ./install/installTypings.jsnpm ERR! You can get information on how to open an issue for this project with:
    iobroker 2019-03-02 16:03:12.396 info npm
    iobroker 2019-03-02 16:03:12.392 info npm ERR! Tell the author that this fails on your system:
    iobroker 2019-03-02 16:03:12.392 info npm ERR! not with npm itself.
    iobroker 2019-03-02 16:03:12.392 info npm ERR! If you do, this is most likely a problem with the iobroker.javascript package,
    iobroker 2019-03-02 16:03:12.392 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    iobroker 2019-03-02 16:03:12.392 info npm ERR! Failed at the iobroker.javascript@4.0.12 postinstall script 'node ./install/installTypings.js'.
    iobroker 2019-03-02 16:03:12.392 info npm ERR! Exit status 1
    iobroker 2019-03-02 16:03:12.392 info npm ERR! iobroker.javascript@4.0.12 postinstall: node ./install/installTypings.js
    iobroker 2019-03-02 16:03:12.392 info npm ERR! code ELIFECYCLE
    iobroker 2019-03-02 16:03:12.392 info v6.14.4npm ERR! npm v3.10.10
    iobroker 2019-03-02 16:03:12.390 info npm ERR! node
    iobroker 2019-03-02 16:03:12.390 info ERR! Linux 4.4.59+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript@4.0.12" "--production" "--save" "--prefix" "/opt/iobroker"
    iobroker 2019-03-02 16:03:12.388 info npm
    iobroker 2019-03-02 16:03:12.385 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    iobroker 2019-03-02 16:03:12.385 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/noble/node_modules/xpc-connection):
    iobroker 2019-03-02 16:03:12.385 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupp
    iobroker 2019-03-02 16:03:12.376 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    iobroker 2019-03-02 16:03:12.376 info npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})npm WARN optional SKIPPING OPTIO
    iobroker 2019-03-02 16:03:12.373 info WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/@abandonware/noble/node_modules/xpc-connection):
    iobroker 2019-03-02 16:03:12.371 info npm
    iobroker 2019-03-02 16:03:11.434 info at bootstrap_node.js:507:3
    iobroker 2019-03-02 16:03:11.434 info at startup (bootstrap_node.js:160:9)
    iobroker 2019-03-02 16:03:11.434 info at run (bootstrap_node.js:394:7)
    iobroker 2019-03-02 16:03:11.434 info at Module.runMain (module.js:611:10)
    iobroker 2019-03-02 16:03:11.434 info at Function.Module._load (module.js:424:25)
    iobroker 2019-03-02 16:03:11.434 info at Function.Module._resolveFilename (module.js:476:15)
    iobroker 2019-03-02 16:03:11.434 info Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js'
    iobroker 2019-03-02 16:03:11.434 info ^
    iobroker 2019-03-02 16:03:11.434 info module.js:478 throw err;
    Hab ich was falsch gemacht?
    ° Fixer ---> iob fix
    • NegaleinN Negalein
      @Negalein sagte in JS Update auf 4.1.7 Error 20:
      Wie hast du diesen installiert?
        NegaleinN Offline
        NegaleinN Offline
        Negalein
        @Homoran sagte in JS Update auf 4.1.7 Error 20:
        Über GIT, da mir mit dem ganz rechten Symbol nur die 4.0.12 angezeigt wurde.
          @Negalein
          Aber du hast das im Link des anderen Threads wirklich gelesen was bei GIT zu beachten ist?
          NegaleinN 2 Antworten Letzte Antwort
            @Negalein
            NegaleinN Offline
            NegaleinN Offline
            Negalein
            @Negalein
            Ja, das habe ich.
            Dazu muss im Reiter Admin der Expertenmodus aktiviert werden. Danach erscheinen weitere Icons in der Kachel. Der nach oben gerichtete Pfeil (3. Icon von rechts) führt diesen Upload aus.
            Expertenmodus habe ich. Aber keinen Pfeil für den Upload.
              @Negalein
              NegaleinN Offline
              NegaleinN Offline
              Negalein
              @Negalein
              oder meintest du was anderes?
                @Negalein
                Ja, das habe ich.
                @Negalein
                Welche admin version?
                Hast du es auch im Kachelmodus versucht, so wie es im "Video" aussieht?
                  @Negalein
                  NegaleinN Offline
                  NegaleinN Offline
                  Negalein
                  Admin 3.6.0
                  Welches Video?
                  Im Kachelmodus fehlt mir auch der Upload
                  Über Terminal kommt auch eine Fehlermeldung.
                  root@ioBroker:/opt/iobroker# iobroker upload javascript
                  sudo: Hostname ioBroker kann nicht aufgelöst werden
                  module.js:478
                  throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                    Admin 3.6.0
                    Welches Video?
                    module.js:478
                    throw err;
                    @Negalein
                    Nach dem anklicdes Expertenmodus musst dubwarten bis die seite neu geladen worden ist, bevor du die Kacheln öffnest
                      @Negalein
                      NegaleinN Offline
                      NegaleinN Offline
                      Negalein
                      funktioniert auch nicht
                      • NegaleinN Offline
                        NegaleinN Offline
                        Negalein
                        @Homoran
                        Jetzt lässt sich die Instanz auch nicht mehr starten.
                        host.ioBroker 2019-03-03 00:30:24.996 error Cannot download adapter "javascript". To restart it disable/enable it or restart host.
                        Auch ein Neustart vom ioBroker brachte nichts.
                        host.ioBroker 2019-03-03 00:36:52.754 error Cannot download adapter "javascript". To restart it disable/enable it or restart host.
                        host.ioBroker 2019-03-03 00:36:52.253 error Cannot download adapter "javascript". To restart it disable/enable it or restart host.
                        host.ioBroker 2019-03-03 00:36:51.253 info iobroker exit 0
                        host.ioBroker 2019-03-03 00:36:51.234 error iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                        host.ioBroker 2019-03-03 00:36:51.209 error iobroker host.ioBroker Adapter directory "null" does not exists
                        host.ioBroker 2019-03-03 00:36:51.178 info iobroker npm ERR! Please include the following file with any support request:npm ERR! /opt/iobroker/npm-debug.log
                        host.ioBroker 2019-03-03 00:36:51.176 info iobroker
                        host.ioBroker 2019-03-03 00:36:51.090 info iobroker WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/@abandonware/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported plat
                        host.ioBroker 2019-03-03 00:36:51.083 info iobroker npm
                        host.ioBroker 2019-03-03 00:36:48.856 info iobroker module.js:478 throw err; ^ Error: Cannot find module '/opt/iobroker/node_modules/iobroker.javascript/install/installTypings.js' at Function.Module._resolveFilename (module.js:476:
                        host.ioBroker 2019-03-03 00:35:56.945 info iobroker npm install iobroker.javascript --production --save --prefix "/opt/iobroker" (System call)
                        host.ioBroker 2019-03-03 00:35:56.391 info iobroker NPM version: 3.10.10
                        host.ioBroker 2019-03-03 00:35:54.778 info iobroker install javascript
                        host.ioBroker 2019-03-03 00:35:54.778 warn startInstance cannot find adapter "javascript". Try to install it... 3 attempt
                        host.ioBroker 2019-03-03 00:35:53.752 info iobroker exit 0
                        host.ioBroker 2019-03-03 00:35:53.733 error iobroker Cannot parse null/io-package.json:Error: ENOENT: no such file or directory, open 'null/io-package.json'
                        host.ioBroker 2019-03-03 00:35:53.702 error iobroker host.ioBroker Adapter directory "null" does not exists
                        Möchte ich auf eine kleinere Version gehen, kommt auch ein Fehler.
                        $ ./iobroker upgrade javascript@4.0.12
                        Update javascript from @0.0.0 to @4.0.12
                        npm install iobroker.javascript@4.0.12 --production --save --prefix "/opt/iobroker" (System call)
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/@abandonware/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm WARN optional SKIPPING OPTIONAL DEPENDENCY: xpc-connection@~0.1.4 (node_modules/iobroker.radar/node_modules/@abandonware/noble/node_modules/xpc-connection):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for xpc-connection@0.1.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
                        npm ERR! Linux 4.4.59+
                        npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.javascript@4.0.12" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.14.4
                        npm ERR!
                        ERROR: Cannot find io-package.json in null
                        ERROR: process exited with code 10
                        Was könnte ich noch versuchen?
                        • NegaleinN Offline
                          NegaleinN Offline
                          Negalein
                          Habe jetzt ein Backup von gestern aufgespielt.
                          Jetzt läuft wieder alles.
                          Ich bleib dann mal bei JS 4.0.12 ☺
                            @Negalein
                            NegaleinN Offline
                            NegaleinN Offline
                            Negalein
                            @Negalein
                            heute hätte ich versucht auf 4.1.12 ein Update zu machen.
                            Selbes Problem wie Oben.
                            Was könnte ich noch probieren, außer wieder das Backup einzuspielen und auf 4.0.12 zu bleiben?
                            • wendy2702W Online
                              wendy2702W Online
                              wendy2702
                              npm v3.10.10
                              Vielleicht sind deine NPM/Node Versionen zu alt?
                              npm v3.10.10
                              • wendy2702W wendy2702
                                npm v3.10.10
                                npm v3.10.10
                                NegaleinN Offline
                                NegaleinN Offline
                                Negalein
                                @wendy2702 sagte in JS Update auf 4.1.7 Error 20:
                                Ahhhh, hab ich glatt übersehen.
                                Dann muss ich jetzt doch mal ein Update machen.
                                Hab mich davon immer gedrückt.
