  4. Frage zu Installation Zigbee-Adapter
    2.8k
    4.8k
    4.1k
9 Beiträge 2 Kommentatoren 1.2k Aufrufe
    Rapsi
    Hallo IOBroker-Gemeinde,
    ich habe einen Mini-PC mit Windows auf dem mein IOBroker läuft.
    Ich habe versucht Zigbee-Adapter zu installieren.
    Dabei habe ich folgende Fehlermeldungen erhalten:
    Kann mir jemand helfen?
    $ ./iobroker add zigbee –host IOBrocker-PC
    NPM version: 6.4.1
    npm install iobroker.zigbee --production --save --prefix "C:/ioBroker" (System call)
    prebuild-install
    WARN install No prebuilt binaries found (target=10.14.2 runtime=node arch=ia32 platform=win32)
    gyp
    ERR! configure error
    gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR! stack at PythonFinder.failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:484:19)
    gyp ERR! stack at PythonFinder. <anonymous>(C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:509:16)
    gyp ERR!
    stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp ERR! stack at FSReqWrap.oncomplete (fs.js:154:21)
    gyp ERR! System Windows_NT 6.1.7601
    gyp
    ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\iobroker.zigbee\node_modules\serialport
    gyp ERR! node -v v10.14.2
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm ERR! code ELIFECYCLE
    npm ERR! errno 1npm ERR! serialport@6.2.2 install: prebuild-install || node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-30T09_14_33_361Z-debug.log
    host.IOBrocker-PC install adapter zigbee
    NPM version: 6.4.1
    prebuild-install
    gyp
    gyp
    ERR!
    gyp ERR!
    stack
    at FSReqWrap.oncomplete (fs.js:154:21)gyp
    ERR!
    gyp
    ERR!
    gyp
    ERR!
    cwd C:\ioBroker\node_modules\iobroker.zigbee\node_modules\serialportgyp
    ERR! node -v
    v10.14.2gyp
    gyp ERR!
    not ok
    npm
    npm ERR! errno 1
    npm ERR! serialport@6.2.2 install: prebuild-install || node-gyp rebuildnpm ERR! Exit status 1
    npm ERR!
    npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-30T09_14_58_653Z-debug.log
    NPM version: 6.4.1
    prebuild-install
    gyp
    ERR!
    configure error
    gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29
    gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
    npm
    npm ERR! errno 1
    npm ERR!
    npm ERR! A complete log of this run can be found in:npm ERR! C:\Windows\system32\config\systemprofile\AppData\Roaming\npm-cache_logs\2019-01-30T09_15_25_390Z-debug.log
    ERROR: host.IOBrocker-PC Cannot install zigbee
    ERROR: process exited with code 13</anonymous></anonymous></anonymous>
    • AsgothianA Offline
      AsgothianA Offline
      Asgothian
      @Rapsi:
      gyp ERR!
      stack at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\polyfills.js:284:29gyp ERR! stack at FSReqWrap.oncomplete (fs.js:154:21)</anonymous> `
      Im log steht das er nicht weiss wo er python findet. Daher die Frage:
      Ist Python installiert ?
      Wenn ja, ist die Executable in der Pfad Variable drin ?
      A.
        Rapsi
        Danke für die Antwort.
        Python ist nicht installiert.
        Wie kann ich das machen und wo muss es installiert sein?
        Entschuldigung für meine Unkenntnis.
          AsgothianA Offline
          Asgothian
          Am Besten folgst Du dieser Anleitung:
          https://www.npmjs.com/package/node-gyp
          A.
            Rapsi
            Danke für die Hilfe Asgothian,
            leider hat es bei mir nicht geklappt.
            So habe ich gemacht:
            1. im CMD mit Administrator ausgeführt habe ich -npm install -g node-gyp- eingegeben.
            2. npm install –global --production windows-build-tools eingegeben
            3. Zigbee-Adapter versucht zu installieren
            Leider ohne Erfolg - gleiche Fehlermeldungen.
            Warscheinlich habe ich es falsch gemacht, aber ich weiss nicht was.
            Kannst du mir die richtige Reihenfolge erklären?
              AsgothianA Offline
              Asgothian
              Da muss ich leider passen. Ich habe es in genau dieser Reihenfolge versucht - bei mir hat es funktioniert.
              Kannst Du mir mal sagen welche Software Versionen du hast:
              npm -v
              node -v
                Rapsi
                npm 6.5.0
                node v10.14.2
                  AsgothianA Offline
                  Asgothian
                  Ich bin nicht sicher ob der ZigBee adapter mit Node 10 läuft. Ich hab bei mir extra noch node 8 laufen, da es mit Node 10 auffälligkeiten beim ioBroker geben soll.
                  Vielleicht liegt es da dran ?
                  A.
                    Rapsi
                    Jawohl, so ist es.
                    Node v10 deinstalliert und v8.14 installiert.
                    Sofort konnte ich den Adapter installieren.
                    Vielen Dank.
