  4. Cloud.0 funktioniert nicht mehr, entfernen nicht möglich
    6.8k
45 Beiträge 2 Kommentatoren 3.0k Aufrufe
  • apollon77A Offline
    #41
    Zu Logs:was steht denn da do? Welche Adapter?
    Cloud: was willst denn tun mit der Cloud? Alexa oder Fernzugriff? Wenn Alexa dann pro Cloud Account und iot. Anleitung alles ganz oben abgepinnt in dem Forum
    Gesendet vom Handy …
      Altersrentner
      #42
       javascript.0	2019-01-29 20:34:39.786	warn	at Timer.listOnTimeout (timers.js:290:5)
      javascript.0	2019-01-29 20:34:39.785	warn	at tryOnTimeout (timers.js:323:5)
      javascript.0	2019-01-29 20:34:39.785	warn	at ontimeout (timers.js:511:34)
      javascript.0	2019-01-29 20:34:39.785	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1294:29)
      javascript.0	2019-01-29 20:34:39.784	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
      javascript.0	2019-01-29 20:34:39.782	warn	Wrong type of fhem.0.Ventilation.state: "boolean". Please fix, while deprecated and will not work in next versions.
      fhem.0	2019-01-29 20:34:38.786	info	event ioBroker "fhem.0.GewaechshausHeizung.state off" > set GewaechshausHeizung off
      javascript.0	2019-01-29 20:34:38.781	warn	at TCP.onread (net.js:597:20)
      javascript.0	2019-01-29 20:34:38.781	warn	at Socket.Readable.push (_stream_readable.js:208:10)
      javascript.0	2019-01-29 20:34:38.780	warn	at readableAddChunk (_stream_readable.js:250:11)
      javascript.0	2019-01-29 20:34:38.780	warn	at addChunk (_stream_readable.js:263:12)
      javascript.0	2019-01-29 20:34:38.780	warn	at Socket.emit (events.js:211:7)
      javascript.0	2019-01-29 20:34:38.780	warn	at emitOne (events.js:116:13)
      javascript.0	2019-01-29 20:34:38.780	warn	at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
      javascript.0	2019-01-29 20:34:38.780	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
      javascript.0	2019-01-29 20:34:38.779	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
      javascript.0	2019-01-29 20:34:38.779	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
      javascript.0	2019-01-29 20:34:38.779	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
      javascript.0	2019-01-29 20:34:38.779	warn	at RedisClient.emit (events.js:217:7)
      javascript.0	2019-01-29 20:34:38.779	warn	at emitThree (events.js:136:13)
      javascript.0	2019-01-29 20:34:38.779	warn	at RedisClient. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:596:25)
      javascript.0	2019-01-29 20:34:38.779	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
      javascript.0	2019-01-29 20:34:38.778	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
      javascript.0	2019-01-29 20:34:38.778	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:756:38)
      javascript.0	2019-01-29 20:34:38.778	warn	at Object. <anonymous>(script.js.Gewächshaus.Heizung_schalten:25:7)
      javascript.0	2019-01-29 20:34:38.778	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
      javascript.0	2019-01-29 20:34:38.775	warn	Wrong type of fhem.0.GewaechshausHeizung.state: "boolean". Please fix, while deprecated and will not work in next versions.
      fhem.0	2019-01-29 20:32:16.055	info	check channel fhem.0.CN_Brennstoffverbrauch | name: CN.Brennstoffverbrauch | room: 1.3.1 Heizraum | role: undefined | function: no | 1/1
      fhem.0	2019-01-29 20:32:15.453	info	check channel CN.Brennstoffverbrauch > jsonlist2 CN.Brennstoffverbrauch
      fhem.0	2019-01-29 20:32:13.949	info	check channel fhem.0.CN_Brennstoffkosten | name: CN.Brennstoffkosten | room: 1.3.1 Heizraum | role: undefined | function: no | 1/1
      fhem.0	2019-01-29 20:32:13.750	info	check channel CN.Brennstoffkosten > jsonlist2 CN.Brennstoffkosten</anonymous></anonymous></anonymous>
      Das ist ein Part von den orangenen Eintragungen.
      Zur Cloud;
      Alexa soll integriert werden, dann möchte ich vis nutzen, gelegentlich wenn wir z.B. im Urlaub sind möchte ich mir ioBroker ansehen
      z.B. wenn etwas nicht läuft.
      Gruß Michael
        Altersrentner
        #43
        Ich habe jetzt mal die Log Einträge kontrolliert.
        Bei den orangenen Einträgen handelt es sich immer um javascript.0 Einträge.
        Ich glaube, das etwas mit den Blocklys nicht stimmt obwohl sie richtig schalten.
         host.ioBroker-RasPi	2019-01-29 21:50:00.047	info	instance system.adapter.dwd.0 started with pid 24674
        fhem.0	2019-01-29 21:48:24.619	info	event ioBroker "fhem.0.Ventilation.state off" > set Ventilation off
        javascript.0	2019-01-29 21:48:24.616	warn	at Timer.listOnTimeout (timers.js:290:5)
        javascript.0	2019-01-29 21:48:24.616	warn	at tryOnTimeout (timers.js:323:5)
        javascript.0	2019-01-29 21:48:24.616	warn	at ontimeout (timers.js:511:34)
        javascript.0	2019-01-29 21:48:24.616	warn	at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1294:29)
        javascript.0	2019-01-29 21:48:24.616	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
        javascript.0	2019-01-29 21:48:24.615	warn	Wrong type of fhem.0.Ventilation.state: "boolean". Please fix, while deprecated and will not work in next versions.
        fhem.0	2019-01-29 21:48:23.616	info	event ioBroker "fhem.0.GewaechshausHeizung.state off" > set GewaechshausHeizung off
        javascript.0	2019-01-29 21:48:23.615	warn	at TCP.onread (net.js:597:20)
        javascript.0	2019-01-29 21:48:23.615	warn	at Socket.Readable.push (_stream_readable.js:208:10)
        javascript.0	2019-01-29 21:48:23.615	warn	at readableAddChunk (_stream_readable.js:250:11)
        javascript.0	2019-01-29 21:48:23.615	warn	at addChunk (_stream_readable.js:263:12)
        javascript.0	2019-01-29 21:48:23.615	warn	at Socket.emit (events.js:211:7)
        javascript.0	2019-01-29 21:48:23.615	warn	at emitOne (events.js:116:13)
        javascript.0	2019-01-29 21:48:23.615	warn	at Socket. <anonymous>(/opt/iobroker/node_modules/redis/index.js:274:27)
        javascript.0	2019-01-29 21:48:23.614	warn	at JavascriptRedisParser.execute (/opt/iobroker/node_modules/redis-parser/lib/parser.js:574:12)
        javascript.0	2019-01-29 21:48:23.614	warn	at JavascriptRedisParser.returnReply (/opt/iobroker/node_modules/redis/index.js:192:18)
        javascript.0	2019-01-29 21:48:23.614	warn	at RedisClient.return_reply (/opt/iobroker/node_modules/redis/index.js:833:9)
        javascript.0	2019-01-29 21:48:23.614	warn	at return_pub_sub (/opt/iobroker/node_modules/redis/index.js:794:18)
        javascript.0	2019-01-29 21:48:23.614	warn	at RedisClient.emit (events.js:217:7)
        javascript.0	2019-01-29 21:48:23.614	warn	at emitThree (events.js:136:13)
        javascript.0	2019-01-29 21:48:23.614	warn	at RedisClient. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:596:25)
        javascript.0	2019-01-29 21:48:23.614	warn	at change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
        javascript.0	2019-01-29 21:48:23.614	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:358:25)
        javascript.0	2019-01-29 21:48:23.614	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:756:38)
        javascript.0	2019-01-29 21:48:23.613	warn	at Object. <anonymous>(script.js.Gewächshaus.Heizung_schalten:25:7)
        javascript.0	2019-01-29 21:48:23.613	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1236:28)
        javascript.0	2019-01-29 21:48:23.613	warn	Wrong type of fhem.0.GewaechshausHeizung.state: "boolean". Please fix, while deprecated and will not work in next versions.</anonymous></anonymous></anonymous>
        Wäre es sinnvoll die Einträge unter Skripte einzustellen?
        Gruß Michael
          #44
          Das Relevante hier ist das:
          Du hast einen State der einen bestimmten Datentyp hat und Du schreibst einen anderen rein. Ja Du musst deine Blockly so anpassen das der Datenyp korrekt ist
            Altersrentner
            #45
            Danke für Deinen Hinweis. Habe mir gerade mal das Blockly angesehen,
            komme aber nicht auf den Fehler.
            Werde die Frage morgen unter Skripte einstellen.
            Wenn dann alle Punkte bereinigt sind werde ich mit der Cloud weiter machen.
            Danke für Deine Unterstützung.
            Gruß Michael
