  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Ошибка cannot delete
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
4 Beiträge 4 Kommentatoren 2.0k Aufrufe
    shimaro
    всем привет
    с недавнего времени в логе регулярно появляется серия ошибок:
    Cannot	2019-01-10 15:54:23.920	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_14-28_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.919	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_13-37_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.919	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_11-37_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.918	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_09-37_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.918	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_07-37_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.917	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_05-36_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.917	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_03-36_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.916	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-08_01-36_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.916	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_23-35_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.915	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_23-13_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.915	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_22-34_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_20-34_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_18-33_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.914	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_16-33_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.913	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_14-33_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.913	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_12-33_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.912	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_10-33_states.json.gz: {}
    Cannot	2019-01-10 15:54:23.911	error	delete file "/opt/iobroker/node_modules/iobroker.js-controller/lib/states/../../../../iobroker-data/backup-objects/2019-01-07_10-32_states.json.gz: {}
    Вроде бы все работает корректно, но смущает
    Буду рад совету, с чем может быть связано и как убрать.
    Спасибо.
      Pooh
      Проверить права на папку и от кого иоб запущен
      https://play.google.com/store/apps/details?id=com.roy.royclub - код: UMI201155
      https://play.google.com/store/apps/details?id=com.blockchainvault - код приглашения: Freepooh
      https://play.google.com/store/apps/details?id=games.bee.app - код приглашения: freepooh
      https://www.timestope.com/freepooh - witness code: freepooh
      • V Offline
        V Offline
        voretsen
        Грохнул день, чтобы разобраться...
        Ошибка не в правах и не в открытых файлах, которые никто не закрыл... Все проще.
        \opt\ioroker\node_modules\iobroker.js-controller\lib\objects\objectsInMemServer.js
        содержит функцию
        function deleteOldBackupFiles() {...},
        в которой вот такой кусок кода:
        try {
                fs.unlink(backupDir + file);
              } catch (e) {
                 log.error(`Cannot delete file "${backupDir + file}: ${JSON.stringify(e)}`);
        Здесь используется асинхронный unlink без второго параметра и то ли глючит, то ли выплевывает ошибку "по дефолту" - do not know...
        Можно поставить вместо него fs.unlinkSync, но я предпочел не портить синхронностью асинхронность
        fs.unlink(backupDir + file, function (err) {
           if (err) log.error(`Cannot delete file "${backupDir + file}: ${JSON.stringify(err)}`); });
        Такой унлинк вполне хорошо стирает старые бэкапы без ошибок.
        Совершенно аналогичный кусок кода в
        \opt\ioroker\node_modules\iobroker.js-controller\lib\states\statesInMemServer.js
        (см. ту же функцию)
        Кстати, в процессе ковыряния в этом деле выяснилось, что настойки для бэкапов objects und states в opt\iobroker\iobroker-data\iobroker.json не подхватываются сетапом. Разбираться пока некогда.
        Я человек в обчестве новый, готов скинуть инфу разрабам, но с немецким совсем плохо и не знаю куда :)
        salambelgorodS 1 Antwort Letzte Antwort
        • V voretsen
          содержит функцию
          try {
                } catch (e) {
          (см. ту же функцию)
          salambelgorodS Offline
          salambelgorod
          @voretsen said in Ошибка cannot delete:
          Привет мил человек, а ты есть в телеграме? https://t.me/iobroker
          По хорошему то пулреквест бы сделать ну или хотяб ишуе..
          https://github.com/ioBroker/ioBroker.js-controller/blob/master/lib/objects/objectsInMemServer.js
