  4. Sonoff RF Bridge Tasmota Handsender
    6.8k
15 Beiträge 5 Kommentatoren 2.9k Aufrufe
  • L Offline
    ludino
    ich habe eine Sonoff RF Bridge mit Tasmota geflasht alles soweit gut. Dazu habe ich mir 4 Handsender mit jeweils 4 Tastern gekauft.
    Leider wird bei jeder Fernbedienung auf jeder Taste der gleiche Data gesendet bzw Empfangen.
    Habe versucht den einzelnen Tastern einen RF Key zu speichern was aber auch nicht Funktioniert.
    Egal welche Taste drücke, ersagt mir RFKEy 1
    Log
    19:13:17 MQT: stat/RF-Bridge/RESULT = {"RfKey1":"Start learning"}
    19:13:21 MQT: stat/RF-Bridge/RESULT = {"RfKey1":"Learned"}
    19:13:56 CMD: RfKey2 2
    19:13:56 MQT: stat/RF-Bridge/RESULT = {"RfKey2":"Start learning"}
    19:13:58 MQT: stat/RF-Bridge/RESULT = {"RfKey2":"Learned"}
    19:13:59 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8640,"Low":300,"High":890,"Data":"B0DEXX","RfKey":1}}
    19:14:02 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8680,"Low":350,"High":840,"Data":"B0DEXX","RfKey":1}}
    Vielleicht übersehe ich ja irgendetwas.
    Hier noch mal ein paar daten.
    Handsender
    Innenleben
    Iobroker
    Und hier etwas Log Material
    Taste A:
    18:25:56 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8720,"Low":340,"High":850,"Data":"B0DEXX","RfKey":"None"}}
    18:34:20 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8700,"Low":340,"High":850,"Data":"B0DEXX","RfKey":"None"}}
    18:35:28 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8690,"Low":340,"High":840,"Data":"B0DEXX","RfKey":"None"}}
    18:36:28 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8690,"Low":340,"High":850,"Data":"B0DEXX","RfKey":"None"}}
    Taste B:
    18:33:31 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8700,"Low":290,"High":900,"Data":"B0DEXX","RfKey":"None"}}
    18:34:32 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8660,"Low":300,"High":890,"Data":"B0DEXX","RfKey":"None"}}
    18:35:37 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8680,"Low":290,"High":900,"Data":"B0DEXX","RfKey":"None"}}
    18:36:53 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8640,"Low":300,"High":890,"Data":"B0DEXX","RfKey":"None"}}
    Taste C:
    18:33:55 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8750,"Low":330,"High":860,"Data":"B0DEXX","RfKey":"None"}}
    18:34:42 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8680,"Low":330,"High":860,"Data":"B0DEXX","RfKey":"None"}}
    18:35:55 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8670,"Low":330,"High":860,"Data":"B0DEXX","RfKey":"None"}}
    18:37:02 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8680,"Low":330,"High":860,"Data":"B0DEXX","RfKey":"None"}}
    Taste D:
    18:34:09 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8660,"Low":290,"High":880,"Data":"B0DEXX","RfKey":"None"}}
    18:34:58 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8650,"Low":300,"High":870,"Data":"B0DEXX","RfKey":"None"}}
    18:36:05 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8650,"Low":290,"High":880,"Data":"B0DEXX","RfKey":"None"}}
    18:37:37 MQT: tele/RF-Bridge/RESULT = {"RfReceived":{"Sync":8690,"Low":300,"High":880,"Data":"B0DEXX","RfKey":"None"}}
    Hat jemand eine Idee was ich machen Kann das die 4 Sender sich die 4 Tasten unterscheiden?
    Mit besten Dank im Vorraus
      Bernd
      Sorry, ich kann Dir zwar nicht direkt mit Deiner Fernbedienung helfen, aber ich benutze diese hier:
      https://www.banggood.com/433Mhz-Transmi … rehouse=CN
      Die RF Bridge mit Tasmota läuft damit einwandfrei. Ich hab momentan um die 8 Stück im Haus verteilt, jeder Taster von jedem Sender liefert unterschiedliche Codes.
      Teilweise hab ich die gestrippt und an meine Busch Jäger Lichtschalter/Taster angelötet. (Natürlich hängen die nicht mehr am 220V Netz). Die passen ohne Gehäuse locker zusammen mit dem Lichtschalter zusammen in die Unterputzdose
      Die kosten um die 2.50€ werden mit 2x Knopfzellen betrieben (sind mit dabei)
      Edit: Wenn Du 3 Stück kaufst, sogar nur 1,74€/Stück. Dafür bekommst in D nicht einmal die Knopfzellen :lol:
      Zeigen die 4 Sender denn bei den Objekten auch gleiche Werte an?
      Bei den Sendern aus dem Link habe ich nichts an der RF Bridge angelernt, sondern mit einem Blockly Script die Aktoren schalten lassen
      Lg Bernd
      • L Offline
        ludino
        Danke ich werde diese auch kaufen.
        • J Offline
          Jan1
          Bei Dir stimmt was nicht. Ich habe die gleichen Fernbedienungen wie Du auch und die senden unterschiedliche Codes. Die sehen auch etwas anders vom Aufbau aus.
          Was zeigt denn der Sonoff Adapter bei Data an?
          • L Offline
            ludino
            Der Adapter sagt bei jedem Knopf den gleichen Code!
            Wenn du etwas anders aufgebaut sind dann sind es wahrscheinlich nicht die gleichen! Wo hast du diese denn bestellt?
            gruß
            • J Offline
              Jan1
              Oh, ich glaube direkt beim Ali.
              Dein RF Key ist doch "B0DEXX" und genau da liegt Dein Problem, da X nicht Hex ist. Deshalb wollte ich auch wissen, was bei Dir unter Data im Sonoff Adapter steht, was Du unkenntlich gemacht hast (warum eigentlich?).
              Bei mir sieht der RF Key so aus: 59C8A4 und ich denke auch die sind immer in dem Schema aufgebaut. Das sieht bei DIr eben komplett anders aus.
              • L Offline
                ludino
                Das xx habe ich reingemacht ich wusste nicht in wie weit es sonst wegen Code und sowas!
                • J Offline
                  Jan1
                  Du bist ja auch lustig, das sind die relevanten Infos und Xst die aus :lol:
                  OK, kann aber schon sein, dass Du welche erwischt hats, die die selben Codes senden. Wo hast Du die bestellt?
                  • L Offline
                    ludino
                    Bei Ebay von einem Chinesen mit de Stock.
                    • J Offline
                      Jan1
                      Wenn schon in China, dann immer direkt bei Aliexpress. Da habe ich bis jetzt selbst bei sehr seltenen Reklamationen nie Probleme gehabt. Funktioniert fast so gut wie bei Amazon ;)
                      Schreib mal den 1 2 3 Händler an, vielleicht schickt er was nach. Ich hatte da auch schon mal bei nem Chinesen ne Reklamation wegen eines RGB Controller und der hat mir einfach nen neuen geschickt samt 5m LED Stripes. Die stehen nicht auf negative Bewertungen und das Zeug ist so billig, dass die nicht lange fackeln.
                      • CookiemonsterC Offline
                        Cookiemonster
                        @ludino:
                        gruß `
                        Ich hab den gleichen Sender und der sendet unterschiedliche Codes. Bestellt bei Banggood oder Gearbest - weiß ich nicht mehr…
                        Bin aber Anfänger - habs aber hinbekommen, dass ich ne Steckdose mit dem einen Knopf an und mit dem zweiten wieder ausschalte. Komisch.
                        @Bernd:
                        https://www.banggood.com/433Mhz-Transmi … rehouse=CN `
                        ^^ danke bernd, werde ich wohl dann auch an die vorhandenen Lichtschalter basteln… :-)
                        • J Offline
                          Jan1
                          hier beim Ali: https://de.aliexpress.com/wholesale?cat … xt=433+mhz
                          Billiger gehts nicht und portofrei liefert der auch.
                          Meine laufen und wenn die nicht funktionieren würden, bei dem Preis ab in die Tonne.
                          • L Offline
                            ludino
                            ich habe mir mal die aus Banggood bestellt. Ich werde berichten ob die bei mir was tun oder nicht.
                            Danke euch allen
                            • W Offline
                              W Offline
                              westphh
                              ich habe auch einige Handsender mit der Sonoff RF Bridge (mit Tasmota) in Benutzung. Die Handsender sind von Aliexpress. Die Handsender sind eigentlich als Ersatz von vorhandenen RF-Sender gedacht. Deshalb gibt es einen Kopiermodus. Leider kann man nicht alle Handsender kopieren. Bei den letzten hatte ich auch Probleme. Nach dem Reset sendeten die Handsender keinen Code mehr. Deshalb habe ich diese Fernbedienung "Goobay 93997 Fernbedienung als Erweiterung oder Ersatz für das Funksteckdosen-Set" bei Amazon gekauft (4,99 €). Damit konnte ich alle Handsender neu programmieren und alle funktionieren mit der Bridge. Die gekaufte FB kann ebenfalls an der RF-Bridge angelernt werden.
                              • L Offline
                                ludino
                                handsender von Banggood laufen gut.
                                Danke und Gruss
