  4. Warnmeldungen bei Adapter Update
    6.5k
11 Beiträge 4 Kommentatoren 956 Aufrufe
  • nieIPN Offline
    nieIPN Offline
    nieIP
    Hallo
    wenn ich über die Admin Oberbfläche ein Adapter Update mache, bekomme Ich WARN Meldungen angezeigt. Der Vorgang funktioniert trotzdem, auch wenn zwischen den einzelnen Schritten immer lange Wartezeiten entstehen. Das hat aber wohl nichts mit den Meldungen zu tun.
    Kann ich eine Komponente updaten, um die Meldungen weg zu bekommen ? Oder müsste da auf Entwicklerseite etwas geändert werden?
    $ ./iobroker upgrade backitup
    Update backitup from @0.4.3 to @0.4.4
    NPM version: 6.4.1
    npm install iobroker.backitup@0.4.4 --production --save --prefix "/opt/iobroker" (System call)
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.backitup"
    npm
     WARN
     deprecated gulp-util@3.0.8: gulp-util is deprecated - replace it, following the guidelines at https://medium.com/gulpjs/gulp-util-ca3b1f9f9ac5
    npm
    WARN deprecated graceful-fs@3.0.11: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm WARN
     deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm
     WARN deprecated minimatch@0.2.14: Please update to minimatch 3.0.2 or higher to avoid a RegExp DoS issue
    npm WARN
     deprecated graceful-fs@1.2.3: please upgrade to graceful-fs 4 for compatibility with current and future versions of Node.js
    npm
     notice created a lockfile as package-lock.json. You should commit this file.
    got /opt/iobroker/node_modules/iobroker.backitup/admin
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    Update "system.adapter.backitup.0"
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    Adapter "backitup" updated
    process exited with code 0
    • blauholstenB Offline
      blauholsten
      Siehe hier
      viewtopic.php?f=17&t=19114
      Entwickler vom: - Viessman Adapter
      - Alarm Adapter
      • J Offline
        Jan1
        Liegt an Deine NPM version: 6.4.1
        Kann aber ignoriert werden, an sonst Downgrage auf die 4.
        • nieIPN Offline
          nieIPN Offline
          nieIP
          Danke für die Infos.
            blauholsten
            @Jan1:
            Kann aber ignoriert werden, an sonst Downgrage auf die 4. `
            Na das erkläre mal bitte näher….
            - Alarm Adapter
            • J Offline
              Jan1
              Wenn ich auf 6.* hoch gehe, belomme ich ebenfalls Warnungen. Meiste mit Hinweis, dass es am der NPM Version liegt. Dieser Hinweis fehlt hier zwar, der Rest kommt mir allerdings recht bekannt vor.
              Kann man aber einfach testen, NPM Downgrade und den Adapter noch mal installierten. Wenn ohne Warnungen, dann lag es daran.
                blauholsten
                @Jan1:
                Kann man aber einfach testen, NPM Downgrade und den Adapter noch mal installierten. Wenn ohne Warnungen, dann lag es daran. `
                Na dann lies mal meinen Link oben.
                - Alarm Adapter
                • J Offline
                  Jan1
                  Auf die schnelle sieht Deine Fehlermeldung auch ganz anders aus.
                  Oder hast auch ne 6er NPM?
                  Ein Zitat vom Post oben dran ist auch nicht nötig, zieht nur den Thread in die Länge, hier im Forum wohl üblich. Ich kenne Foren, da gibt so was gleich Mecker vom Admin :lol:
                    blauholsten
                    Sorry wenn du dich angegriffen fühlst, das wollte ich nicht. Es geht nur darum, das ich nicht denke das das was mit der npm Version zu tun hat, bzw. nur indirekt.
                    Das Problem sind veraltete Pakete, daher kommen diese Warnungen. Appolon hat das in meinen Verlinkten Thread beschrieben.
                    - Alarm Adapter
                    • apollon77A Offline
                      Korrekt. NPM hat damit NICHTS zu tun und nur wegen einer anderen npm Version wird da keine Meldung ne andere sein, ok in npm4 vielleicht kein "Audit report" am Ende.
                      Also for now: Ignore. Wir sind schon dran da Dinge zu fixen
                      • J Offline
                        Jan1
                        @blauholsten:
                        Das Problem sind veraltete Pakete, daher kommen diese Warnungen. Appolon hat das in meinen Verlinkten Thread beschrieben. `
                        Da hast mich falsch verstanden. Ich fühle mich nicht angegriffen, durch was auch? Die Anmerkung zu der hier im Forum falsch verstandenen Funktion des Zitieren war allgemein und ist eben gedacht, um ein Bezug auf weiter entfernte Posts zu gewähren, was eben überflüssig ist, wenn der Post auf den man sich bezieht exakt darüber steht ;)
                        Oder hast wa anderes gemeint?
                        Die eigentliche Frage wurde ja final geklärt. Bei den vielen Warnungen die da ab und an kommen, blick man eben auch nicht immer durch. Wie geschrieben, ich hatte mit NPM Versionen größer 4.x eben deutlich mehr Warnungen, wobei da meist auch konkret auch die NPM Version hingewiesen wurde.
