  4. Problem installation Dash Button
15 Beiträge 6 Kommentatoren 1.7k Aufrufe
  • K Offline
    kaschperle83
    Ich versuche nun seit einiger Zeit den Dash Button Adapter zu installieren. Aber es will einfach nicht.
    Hier der Log mit sudo
    sudo npm install iobroker.amazon-dash
    [..................] | loadCurrentTree:normalizeTree: sill install loadCurrentT
    [..................] \ loadCurrentTree:normalizeTree: sill install loadCurrentT
    [..................] - loadCurrentTree:normalizeTree: sill install loadCurrentT
    [..................] / loadCurrentTree:normalizeTree: sill install loadCurrentT
    [..................] | loadIdealTree:loadAllDepsIntoIdealTree: sill install loa
    [..................] / loadRequestedDeps: sill install loadAllDepsIntoIdealTree
    [..................] - loadRequestedDeps: sill install loadAllDepsIntoIdealTree
    [..................] / fetchMetadata: verb afterAdd /root/.npm/iobroker.amazon-
    [..................] | fetchMetadata: verb afterAdd /root/.npm/iobroker.amazon-
    [..................] - fetchMetadata: verb afterAdd /root/.npm/iobroker.amazon-
    [..................] \ fetchMetadata: verb afterAdd /root/.npm/iobroker.amazon-
    [..................] | loadDep:socketwatcher: sill resolveWithNewModule pcap@2.
    [..................] / fetchMetadata: sill resolveWithNewModule pcap@2.1.0 chec
    [..................] | fetchMetadata: sill resolveWithNewModule pcap@2.1.0 chec
    [..................] - fetchMetadata: sill resolveWithNewModule pcap@2.1.0 chec
    [..................] \ fetchMetadata: sill resolveWithNewModule pcap@2.1.0 chec
    [   ...............] / loadRequestedDeps: sill resolveWithNewModule socketwatch
    [      ............] | diffTrees: sill install generateActionsToTake
    [       ...........] | diffTrees: sill install generateActionsToTake
    [         .........] | extract:iobroker.amazon-dash: sill doParallel extract 2
    [         .........] \ extract:iobroker.amazon-dash: sill doParallel extract 2
    npm WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    [           .......] / remove:socketwatcher: sill doReverseSerial remove 2
    [           .......] - remove:iobroker.amazon-dash: sill vacuum-fs quitting bec
    > socketwatcher@0.3.0 install /opt/iobroker/node_modules/socketwatcher
    > node-gyp rebuild
    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.12.0"
    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
    make: Verzeichnis /opt/iobroker/node_modules/socketwatcher/build wird betreten
      CXX(target) Release/obj.target/socketwatcher/socket_watcher.o
    ../socket_watcher.cpp: In static member function static void SocketWatcher::Callback(uv_poll_t*, int, int):
    ../socket_watcher.cpp:77:60: warning: v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*) is deprecated [-Wdeprecated-declarations]
       Nan::MakeCallback(watcher->handle(), callback, argc, argv);
    In file included from ../socket_watcher.hpp:8:0,
                     from ../socket_watcher.cpp:5:
    ../../nan/nan.h:958:46: note: declared here
       NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
      SOLINK_MODULE(target) Release/obj.target/socketwatcher.node
      COPY Release/socketwatcher.node
    make: Verzeichnis /opt/iobroker/node_modules/socketwatcher/build wird verlassen
    iobroker.inst@1.1.2 /opt/iobroker
       pcap@2.1.0
         socketwatcher@0.3.0  (git+https://github.com/bytzdev/node-socketwatcher.git#d252d3f8c45f565a0a48ebd155d4f9e4666798d9)</v8::value></v8::value></v8::function></v8::object></v8::value>
    und OHNE sudo so
    [..................] / loadIdealTree:loadAllDepsIntoIdealTree: sill install loa
    [..................] \ loadRequestedDeps: sill install loadAllDepsIntoIdealTree
    [..................] / fetchMetadata: verb afterAdd /home/pi/.npm/iobroker.amaz
    [..................] - fetchMetadata: verb afterAdd /home/pi/.npm/iobroker.amaz
    [..................] \ fetchMetadata: verb afterAdd /home/pi/.npm/iobroker.amaz
    [..................] | fetchMetadata: verb afterAdd /home/pi/.npm/iobroker.amaz
    [..................] / loadDep:socketwatcher: sill resolveWithNewModule pcap@2.
    [   ...............] - loadRequestedDeps: sill resolveWithNewModule socketwatch
    [      ............] / diffTrees: sill install generateActionsToTake
    [       ...........] / diffTrees: sill install generateActionsToTake
    [         .........] / extract:iobroker.amazon-dash: sill doParallel extract 2
    > iobroker.amazon-dash@0.2.9 preinstall /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
    E: Sperrdatei /var/lib/dpkg/lock konnte nicht ge\F6ffnet werden. - open (13: Keine Berechtigung)
    E: Sperren des Administrationsverzeichnisses (/var/lib/dpkg/) nicht m\F6glich, sind Sie root?
    [           .......] | remove:iobroker.amazon-dash: sill vacuum-fs quitting bec
    [            ......] \ install:iobroker.amazon-dash: sill doSerial install 2
    > node-gyp rebuild
       pcap@2.1.0
    Bei keiner der Varinaten läuft der Adapter danach. Kann mir jemand helfen ?
    • apollon77A Offline
      Und warum installierst du nicht per Admin?
      Gesendet vom Handy …
      • K Offline
        kaschperle83
        Da gib es auch Fehlermeldungen.
        Gesendet aus Hessen.
        • K Offline
          kaschperle83
          Jetzt läuft es. Keine Ahnung warum.
          • C Offline
            Cliff
            Ich hänge mich jetzt einfach einmal an diesen Thread.
            leider habe ich wieder einmal massive Probleme mit dem Amazon-Dash.
            Es ist wieder die übliche Meldung wegen der falschen Nodejs Version.
            > controller[0]: the module (for instance, usingnpm rebuildornpm install`).
            Caught 2018-12-15 15:02:36.102 error by controller[0]: NODE_MODULE_VERSION 57. Please try re-compiling or re-installing
            Caught 2018-12-15 15:02:36.101 error by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires `
            ich habe den Dash- Button nun schon dreimal erfolgreich ans Laufen bekommen. nach kleineren Eingriffen geht dann mal wieder nichts.
            Nach der Aktion mit den neuen Clud- Adaptern lief er nicht, liess sich dann aber nach eingem hin- und her doch zur Funktion bringen.
            Nun war ich so frech und habe nur den Raspi gebootet. zack - geht er wieder nicht.
            Habe jetzt schon so ziemlich alles durch (Bis hin zur harten Deinstallation - Ordner des Adapters gelöscht).
            NPM rebuild bringt leider gar nichts.
            Ich kriege das Ding zum Verrecken nicht ans Laufen.
            Derzeit bei mir
            nodejs -v : v8.11.1
            node -v : v6.10.3
            npm -v : 5.7.1
            IoBroker selber meckert etwas über NodeJs 10 ????
            Aktuell kann ich leider keine 'exakten' Fehlermeldungen einstellen da das ganze System lagt und ich keinen Zugriff habe (Nur Putty).
            Steuerung selber läuft aber…
            • C Offline
              Cliff
              Hat sich erledigt. Läuft wieder…
                Allodo
                Bei mir funktioniert es derzeit auch nicht, egal ob über Admin, Console, Katze mit den 2 Githubs :(
                $ ./iobroker add amazon-dash --host odroidc2
                NPM version: 6.4.1
                npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call)
                WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
                ! E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
                ! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::Callback(uv_poll_t*, int, int)':../socket_watcher.cpp:77:60: warning: 'v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value)' is deprecated [-Wdeprecated-declarations]
                ! In file included from ../socket_watcher.hpp:8:0, from ../socket_watcher.cpp:5:
                ../../nan/nan.h:959:46: note: declared here
                NAN_DEPRECATED inline v8::Local v8::valueMakeCallback(
                ! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directorycompilation terminated.
                ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1
                gyp
                ERR! build error
                gyp
                ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
                gyp ERR! stack at emitTwo (events.js:126:13)
                gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                gyp ERR! stack
                at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp ERR! System Linux 4.18.8-odroidc2
                gyp
                ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap
                gyp ERR! node -v v8.14.0
                ! gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok
                ! npm
                ERR! code ELIFECYCLE
                npm ERR! errno 1
                npm ERR! pcap@2.1.0 install: node-gyp rebuildnpm ERR!
                Exit status 1npm ERR!
                npm ERR! Failed at the pcap@2.1.0 install script.
                npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_47_14_394Z-debug.log
                ! host.odroidc2 install adapter amazon-dash
                NPM version: 6.4.1
                gyp
                ERR! build error
                gyp
                gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                ! gyp ERR! System Linux 4.18.8-odroidc2gyp
                ! npm
                ERR! code ELIFECYCLEnpm
                ERR! errno 1
                npm ERR! pcap@2.1.0 install: node-gyp rebuildnpm ERR! Exit status 1
                ! npm ERR! npm ERR! Failed at the pcap@2.1.0 install script.
                ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_48_21_762Z-debug.log
                NPM version: 6.4.1
                , int, int)':../socket_watcher.cpp:77:60: warning: 'v8::Local v8::valueNan::MakeCallback(v8::Localv8::object, v8::Localv8::function, int, v8::Localv8::value*)' is deprecated [-Wdeprecated-declarations]
                gyp
                ERR! build error
                gyp
                gyp
                ERR! not ok
                npm
                ERR! errno 1
                npm
                npm ERR!
                npm ERR!
                Failed at the pcap@2.1.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_49_25_637Z-debug.log
                ERROR: host.odroidc2 Cannot install amazon-dash
                ERROR: process exited with code 13</v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value>
                  der_timo
                  Hallo, ich klinke mich auch mal mit ein…
                  Adapter installieren klappt nach einigem hin und her. Aber er wird nicht grün. Oder tut er das nur wenn der Button gedrückt wurde? Aber selbst dann tut er es nicht.
                  Fehlermeldungen bekomme ich nun übrigens keine mehr während der Installation. Kann ich sonst noch wo prüfen woran es liegen könnte?
                  Gruß,
                  Timo
                    @Allodo:
                    ! $ ./iobroker add amazon-dash --host odroidc2 NPM version: 6.4.1 npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call) WARNING: apt does not have a stable CLI interface. Use with caution in scripts. ! E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root? ! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::Callback(uv_poll_t*, int, int)':../socket_watcher.cpp:77:60: warning: 'v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)' is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(watcher->handle(), callback, argc, argv); ^ ! In file included from ../socket_watcher.hpp:8:0, from ../socket_watcher.cpp:5: ../../nan/nan.h:959:46: note: declared here NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback( ^ ! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directorycompilation terminated. ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23) gyp ERR! stack at emitTwo (events.js:126:13) gyp ERR! stack at ChildProcess.emit (events.js:214:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)gyp ERR! System Linux 4.18.8-odroidc2 gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap gyp ERR! node -v v8.14.0 ! gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok ! npm ERR! code ELIFECYCLE npm ERR! errno 1 npm ERR! pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1npm ERR! npm ERR! Failed at the pcap@2.1.0 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_47_14_394Z-debug.log ! host.odroidc2 install adapter amazon-dash NPM version: 6.4.1 npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call) WARNING: apt does not have a stable CLI interface. Use with caution in scripts. ! E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root? ! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::Callback(uv_poll_t*, int, int)':../socket_watcher.cpp:77:60: warning: 'v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)' is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(watcher->handle(), callback, argc, argv); ^ ! In file included from ../socket_watcher.hpp:8:0, from ../socket_watcher.cpp:5: ../../nan/nan.h:959:46: note: declared here NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback( ^ ! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directorycompilation terminated. ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23) gyp ERR! stack at emitTwo (events.js:126:13) gyp ERR! stack at ChildProcess.emit (events.js:214:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12) ! gyp ERR! System Linux 4.18.8-odroidc2gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap gyp ERR! node -v v8.14.0 ! gyp ERR! node-gyp -v v3.8.0gyp ERR! not ok ! npm ERR! code ELIFECYCLEnpm ERR! errno 1 npm ERR! pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1 ! npm ERR! npm ERR! Failed at the pcap@2.1.0 install script. npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_48_21_762Z-debug.log ! host.odroidc2 install adapter amazon-dash NPM version: 6.4.1 npm install iobroker.amazon-dash --production --save --prefix "/opt/iobroker" (System call) WARNING: apt does not have a stable CLI interface. Use with caution in scripts. ! E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root? ! ../socket_watcher.cpp: In static member function 'static void SocketWatcher::Callback(uv_poll_t*, int, int)':../socket_watcher.cpp:77:60: warning: 'v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)' is deprecated [-Wdeprecated-declarations] Nan::MakeCallback(watcher->handle(), callback, argc, argv); ^ ! In file included from ../socket_watcher.hpp:8:0, from ../socket_watcher.cpp:5: ../../nan/nan.h:959:46: note: declared here NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback( ^ ! ../pcap_binding.cc:2:23: fatal error: pcap/pcap.h: No such file or directorycompilation terminated. ! make: *** [Release/obj.target/pcap_binding/pcap_binding.o] Error 1 gyp ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23) gyp ERR! stack at emitTwo (events.js:126:13) gyp ERR! stack at ChildProcess.emit (events.js:214:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12) ! gyp ERR! System Linux 4.18.8-odroidc2gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/pcap gyp ERR! node -v v8.14.0 gyp ERR! node-gyp -v v3.8.0 gyp ERR! not ok npm ERR! code ELIFECYCLEnpm ERR! errno 1 npm ERR! pcap@2.1.0 install: `node-gyp rebuild`npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the pcap@2.1.0 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above. ! npm ERR! A complete log of this run can be found in:npm ERR! /home/iobroker/.npm/_logs/2018-12-27T15_49_25_637Z-debug.log ! host.odroidc2 install adapter amazon-dash ERROR: host.odroidc2 Cannot install amazon-dash ERROR: process exited with code 13</v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value> `
                    Entweder den add Befehl von oben manuell mit sudo ausführen oder siehe readme vom Adapter die nötigen Linux Pakete selbst vorher installieren. Da fehlt das pcap Linux Paket.
                      @der_timo:
                      Gruß,
                      Timo `
                      Wenn er nicht grün wird stehen an sich im log irgendwelche Meldungen. Was steht denn im iobroker log wenn du die instanz startest?
                        Siegfried
                        Forum Testing
                        meine Meldungen:
                        amazon-dash.0 2018-12-27 20:54:26.226 info terminating
                        amazon-dash.0 2018-12-27 20:54:26.213 info cleaned everything up…
                        amazon-dash.0 2018-12-27 20:54:26.213 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                        amazon-dash.0 2018-12-27 20:54:26.213 error at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at Adapter.emit (events.js:208:7)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at emitNone (events.js:106:13)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
                        amazon-dash.0 2018-12-27 20:54:26.213 error at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
                        amazon-dash.0 2018-12-27 20:54:26.213 error Error: socket: Operation not permitted
                        amazon-dash.0 2018-12-27 20:54:26.213 error uncaught exception: socket: Operation not permitted
                        amazon-dash.0 2018-12-27 20:54:26.205 info starting pcap session on default interface
                        amazon-dash.0 2018-12-27 20:54:26.202 info starting. Version 0.3.1 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.15.0
                        amazon-dash.0 2018-12-27 20:54:26.086 info States connected to redis: 127.0.0.1:6379</anonymous></anonymous>
                          der_timo
                          host.raspberrypi 2018-12-27 20:49:48.475 info Restart adapter system.adapter.amazon-dash.0 because enabled
                          host.raspberrypi 2018-12-27 20:49:48.475 error instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                          Caught 2018-12-27 20:49:48.474 error by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
                          Caught 2018-12-27 20:49:48.473 error by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                          Caught 2018-12-27 20:49:48.473 error by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                          Caught 2018-12-27 20:49:48.472 error by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                          Caught 2018-12-27 20:49:48.471 error by controller[0]: at Adapter.emit (events.js:208:7)
                          Caught 2018-12-27 20:49:48.470 error by controller[0]: at emitNone (events.js:106:13)
                          Caught 2018-12-27 20:49:48.469 error by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
                          Caught 2018-12-27 20:49:48.469 error by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                          Caught 2018-12-27 20:49:48.468 error by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:123:12)
                          Caught 2018-12-27 20:49:48.468 error by controller[0]: at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:49:39)
                          Caught 2018-12-27 20:49:48.456 error by controller[0]: Error: socket: Operation not permitted
                          host.raspberrypi 2018-12-27 20:49:30.635 info instance system.adapter.amazon-dash.0 started with pid 12745
                          host.raspberrypi 2018-12-27 20:49:00.605 info Restart adapter system.adapter.amazon-dash.0 because enabled</anonymous></anonymous>
                            Allodo
                            Danke , ich habe dies jetzt mit "sudo apt-get install libpcap-dev" nachinstalliert und jetzt wurde der Adapter einwandfrei installiert :)
                            Bei mir wird er allerdings auch nicht grün :(
                            host.odroidc2 2018-12-28 08:38:41.601 error instance system.adapter.amazon-dash.0 terminated with code 0 (OK)
                            host.odroidc2 2018-12-28 08:38:41.601 error Caught by controller[0]: at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:787:25)
                            host.odroidc2 2018-12-28 08:38:41.601 error Caught by controller[0]: at createInstancesObjects (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:748:13)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:788:29
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at initAdapter (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4990:18)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at Adapter.emit (events.js:208:7)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at emitNone (events.js:106:13)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at Adapter. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:43:5)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at main (/opt/iobroker/node_modules/iobroker.amazon-dash/main.js:78:29)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at Object.exports.createSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:123:12)
                            host.odroidc2 2018-12-28 08:38:41.600 error Caught by controller[0]: at new PcapSession (/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:49:39)</anonymous></anonymous>
                              Bei den anderen mit „Operation not permitted“ Sicht mal damit im Forum. Das sind Rechteprobleme
                                Allodo
                                Mit dieser Problemlösung ging es dann bei mir und der Dash Button wird richtig erkannt und der Datenpunkt wird eingetragen: https://www.forum.iobroker.net/viewtopic.php?t=12091
