  4. Probleme mit Hue Adapter, Lampe spielt verrückt
3 Beiträge 2 Kommentatoren 1.4k Aufrufe
  • coyoteC Offline
    coyoteC Offline
    coyote
    Habe seit gestern Probleme mit einer Hue Lampe, diese spielt völlig verrückt.
    Angefangen hat es als ich den Colorpicker geöffnet habe, seit dem sieht mein Log so aus:
    hue-0	2016-01-10 10:12:29	info	final lightState: {"bri":254,"on":true,"xy":"0.168,0.041","r":78,"g":0,"b":254,"colormode":"xy","level":100}
    hue-0	2016-01-10 10:12:29	error	error: Api Error: Internal error, 404
    hue-0	2016-01-10 10:12:28	info	final lightState: {"bri":254,"on":true,"xy":"0.168,0.041","r":78,"g":0,"b":254,"colormode":"xy","level":100}
    hue-0	2016-01-10 10:12:28	error	error: Api Error: parameter, xy, is not modifiable. Device is set to off.
    hue-0	2016-01-10 10:12:28	info	final lightState: {"bri":0,"on":false,"xy":"0.4246283246985445,0.48639754012045605","r":0,"g":0,"b":0,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:27	error	error: Api Error: Internal error, 404
    hue-0	2016-01-10 10:12:27	info	final lightState: {"bri":254,"on":true,"xy":"0.28582285613574954,0.27468199800257","r":206,"g":207,"b":254,"colormode":"xy","level":100}
    hue-0	2016-01-10 10:12:26	error	error: Api Error: parameter, xy, is not modifiable. Device is set to off.
    hue-0	2016-01-10 10:12:26	info	final lightState: {"bri":0,"on":false,"xy":"0.32272672086556803,0.3290229095590792","r":0,"g":0,"b":0,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:26	error	error: Api Error: Internal error, 404
    hue-0	2016-01-10 10:12:26	info	final lightState: {"bri":248,"on":true,"xy":"0.322726720865568,0.32902290955907926","r":251,"g":251,"b":251,"colormode":"xy","level":98}
    hue-0	2016-01-10 10:12:25	info	final lightState: {"bri":248,"on":true,"xy":"0.322726720865568,0.32902290955907926","r":251,"g":251,"b":251,"colormode":"xy","level":98}
    hue-0	2016-01-10 10:12:24	error	error: Api Error: Internal error, 404
    hue-0	2016-01-10 10:12:24	info	final lightState: {"bri":241,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":248,"g":248,"b":248,"colormode":"xy","level":95}
    hue-0	2016-01-10 10:12:23	info	final lightState: {"bri":241,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":248,"g":248,"b":248,"colormode":"xy","level":95}
    hue-0	2016-01-10 10:12:20	info	final lightState: {"bri":225,"on":true,"xy":"0.32272672086556803,0.3290229095590792","r":241,"g":241,"b":241,"colormode":"xy","level":89}
    hue-0	2016-01-10 10:12:18	info	final lightState: {"bri":193,"on":true,"xy":"0.322726720865568,0.32902290955907926","r":225,"g":225,"b":225,"colormode":"xy","level":76}
    hue-0	2016-01-10 10:12:16	info	final lightState: {"bri":137,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":193,"g":193,"b":193,"colormode":"xy","level":54}
    hue-0	2016-01-10 10:12:15	info	final lightState: {"bri":64,"on":true,"xy":"0.322726720865568,0.32902290955907926","r":137,"g":137,"b":137,"colormode":"xy","level":25}
    hue-0	2016-01-10 10:12:14	info	final lightState: {"bri":13,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":64,"g":64,"b":64,"colormode":"xy","level":5}
    hue-0	2016-01-10 10:12:13	info	final lightState: {"bri":1,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":13,"g":13,"b":13,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:13	info	final lightState: {"bri":64,"on":true,"xy":"0.2860125078445264,0.2750581405583107","r":134,"g":136,"b":167,"colormode":"xy","level":25}
    hue-0	2016-01-10 10:12:12	info	final lightState: {"bri":13,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":64,"g":64,"b":64,"colormode":"xy","level":5}
    hue-0	2016-01-10 10:12:12	info	final lightState: {"bri":1,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":13,"g":13,"b":13,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:11	info	final lightState: {"bri":13,"on":true,"xy":"0.32272672086556803,0.32902290955907926","r":64,"g":64,"b":64,"colormode":"xy","level":5}
    hue-0	2016-01-10 10:12:10	info	final lightState: {"bri":1,"on":true,"xy":"0.32241806179396454,0.32854622317205606","r":13,"g":13,"b":13,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:09	info	final lightState: {"bri":1,"on":true,"xy":"0.3249069532671572,0.33239001327317214","r":13,"g":13,"b":12,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:09	info	final lightState: {"bri":1,"on":true,"xy":"0.32459238780772154,0.3319042051886675","r":13,"g":13,"b":12,"colormode":"xy","level":0}
    hue-0	2016-01-10 10:12:08	info	final lightState: {"bri":1,"on":true,"xy":"0.2855238531272912,0.2740889753691277","r":12,"g":12,"b":18,"colormode":"xy","level":0}
    Bekomme es nicht mehr geändert.
    Habe schon den Adapter und ioBroker komplett neu gestartet. Den Adapter komplett deinstalliert. Cache gelöscht.
    Auch mit nem Script die Hue Lampe ausschalten, Werte ändern oder auch eine Szene starten brachten keinen Erfolg.
    Es werden immer wieder die Werte wie im log geschrieben und ich weiß nicht wo die Werte her geholt werden.
    Starte ich eine Szene mit dem Script von Pman (glaub ich) z.B. "Wald" wird diese gestartet, doch zwischendurch werden immer wieder andere Werte (wie im log) geschrieben.
    Was kann ich noch machen, um das wieder weg zu bekommen? Die 3 anderen Lampen funktionieren ohne Probleme.
    Gruß Frank
    • coyoteC Offline
      coyoteC Offline
      coyote
      Nach einigen Stunden, seltsame wunderheilung.
      Funktioniert wieder als sei nichts gewesen, die Werte erscheinen auch nicht mehr im log.
      Werde bei gelegenheit versuchen den Fehler nochmal zu reproduzieren
      1148_2018-12-11-export.txt
      • Dr. BakteriusD Offline
        Dr. Bakterius
        Ich grabe diesen alten Thread noch einmal aus weil ich ein sehr ähnliches Problem habe.
        In unregelmäßigen Abständen passiert es, dass wenn ich eine Hue-Lampe oder Leuchte mit mehreren Lampen schalte, diese unkontrolliert ein- und ausgeht. Kommt einer Lichtorgel sehr nahe. :P Auch in VIS findet ein wildes "Flackern" (Schalten) statt. Die Systemlast geht deutlich hoch und im Log finden sich schnell hunderte folgender Einträge:
        error: hue.0 error: Api Error: Internal error, 404
        Der Spuk endet meist erst wenn ioBroker neu gestartet wird.
        Woran kann das liegen? Hat das jemand anderer auch schon beobachtet? Ich habe ein Pollintervall von 1 Sek. eingestellt. Ist das zu kurz?
