  4. Fehlermeldungen Java Skript
    5.8k
5 Beiträge 3 Kommentatoren 1.2k Aufrufe
    Realleachim
    Hallo!
    Ich habe mir Javaskript installiert, erhalte vom Adapter aber nur Fehlermeldungen. Woran kann das liegen?
    host.raspberrypi	2018-11-23 10:05:32.330	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi	2018-11-23 10:05:32.330	error	instance system.adapter.javascript.0 terminated with code 1 ()
    host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at tryModuleLoad (module.js:505:12)
    host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Module.load (module.js:565:32)
    host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    host.raspberrypi	2018-11-23 10:05:32.330	error	Caught by controller[0]: at Module._compile (module.js:652:30)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:22:28
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at require (internal/module.js:11:18)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Module.require (module.js:596:17)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Function.Module._load (module.js:474:25)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: Error: Cannot find module 'coffee-compiler'
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: ^
    host.raspberrypi	2018-11-23 10:05:32.329	error	Caught by controller[0]: throw err;
    host.raspberrypi	2018-11-23 10:05:32.328	error	Caught by controller[0]: module.js:549
    host.raspberrypi	2018-11-23 10:05:30.175	info	instance system.adapter.javascript.0 started with pid 2476
    host.raspberrypi	2018-11-23 10:05:00.143	info	Restart adapter system.adapter.javascript.0 because enabled
    host.raspberrypi	2018-11-23 10:05:00.142	error	instance system.adapter.javascript.0 terminated with code 1 ()
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at tryModuleLoad (module.js:505:12)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module.load (module.js:565:32)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module._compile (module.js:652:30)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3427:3)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:22:28
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2018-11-23 10:05:00.142	error	by controller[0]: at Module.require (module.js:596:17)
    Caught	2018-11-23 10:05:00.141	error	by controller[0]: at Function.Module._load (module.js:474:25)
    Caught	2018-11-23 10:05:00.141	error	by controller[0]: at Function.Module._resolveFilename (module.js:547:15)
    Caught	2018-11-23 10:05:00.141	error	by controller[0]: Error: Cannot find module 'coffee-compiler'
    Caught	2018-11-23 10:05:00.141	error	by controller[0]: ^
    Caught	2018-11-23 10:05:00.141	error	by controller[0]: throw err;
    Caught	2018-11-23 10:05:00.140	error	by controller[0]: module.js:549
    host.raspberrypi	2018-11-23 10:04:57.939	info	instance system.adapter.javascript.0 started with pid 2470
    host.raspberrypi	2018-11-23 10:04:57.906	info	object change system.adapter.javascript.0</anonymous></anonymous>
    In der IO Broker Übersicht steht:
    raspberrypi
    Plattform: linux
    RAM: 927.1 MB
    Node.js: v8.11.1
    NPM: 1.4.21
      dna909
      Installiere bitte mal eine neuere npm-Version.
      1.4.21 ist ja schon ein bissel sehr alt :lol:
      dna909
      Intel NUC7PJYH mit Proxmox, Odroid U2, CCU2, Philips Hue, ESP8266, Xiaomi Robot, Google Chromecast Audio, Instar 6012HD, Bosch HNG6764S6
        Realleachim
        Habe alles gestern erst aufgesetzt. Per SSH auf den Raspberry schalten. Und wie sind da die Befehle?
        • AlCalzoneA Offline
          AlCalzoneA Offline
          AlCalzone
          @Realleachim:
          Habe alles gestern erst aufgesetzt. Per SSH auf den Raspberry schalten. Und wie sind da die Befehle? `
          npm i -g npm
          möglicherweise muss <u>sudo</u> davor.
            Realleachim
            Jetzt funktioniert es. Habe nun Version 6.4.1
            Habe genau nach Tutorial gearbeitet. Keine Ahnung was da passiert ist.
            Danke!
