  4. JSON.stringify zerlegen
    5.8k
11 Beiträge 3 Kommentatoren 3.0k Aufrufe
  • Lenny.CBL Offline
    Lenny.CBL Offline
    Lenny.CB
    komme grad nicht weiter und bräuchte mal einen Tipp.
    ich mache einen "request.get" und bekomme mit JSON.stringify(body) folgendes Ergebnis.
    body: {"000147619644":{"ident":{"type":{"key_localized":"Devicetype","value_raw":1,"value_localized":"Washing Machine"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000147619644","fabIndex":"11","techType":"WMV963","matNumber":"10499100","swids":["3814","25105","25117","20163","3627","20242","25042","25043","25026","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.45"}},"state":{"status":{"value_raw":1,"value_localized":"Off","key_localized":"State"},"programType":{"value_raw":0,"value_localized":"","key_localized":"Programme"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Phase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":true},"light":0,"elapsedTime":[0,0],"spinningSpeed":0,"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Drying level"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Power Level"}}}}
    Hier will ich nun nach einzelnen Schlüsselwörtern suchen und die Keys dazu speichern.
    Komme hier grad nicht mehr klar.
    • paul53P Offline
      Normalerweise wird in body ein JSON-String geliefert, den man per JSON.parse(body) in ein Objekt wandeln muss.
      Den http://jsonviewer.stack.hu/ kennst Du ?
      • apollon77A Offline
        Wenn aber das Stringify so aussieht wie oben dann ist das schon ein in ein Objekt geparstes JSON, kann also direkt verwendet werden …
        • Lenny.CBL Offline
          Lenny.CBL Offline
          Lenny.CB
          @paul53:
          Den http://jsonviewer.stack.hu/ kennst Du ? ` Das ist nen bissel komisch…
          Das ist son ein "3er-ping-pong"
          1. Code per request.post abfragen. Was ich brauche hole ich mit: JSON.stringify(response.header)
          2. Token per request.post holen.
          Was ich brauche hole ich mit: JSON.parse(body)
          3. Divices holen
          Was ich brauche hole ich mit: JSON.stringify(body)
          Den link schaue ich mir mal an.
          • Lenny.CBL Offline
            Lenny.CBL Offline
            Lenny.CB
            @apollon77:
            Wenn aber das Stringify so aussieht wie oben dann ist das schon ein in ein Objekt geparstes JSON, kann also direkt verwendet werden … ` Und genau da fehlts mir… schon viel gelesen und probiert, nix geklappt.
            • paul53P Offline
              @Lenny.CB:
              3. Divices holen
              Was ich brauche hole ich mit: JSON.stringify(body) `
              Was nun ? Einfach testen mit
              log('Typ body: ' + typeof body);
              • Lenny.CBL Offline
                Lenny.CBL Offline
                Lenny.CB
                @paul53:
                @Lenny.CB:
                3. Divices holen
                genau wie ich geschrieben habe.
                Beim Token (request.post) kommt ein "Typ body Token: string" zurück,
                Beim Device (request.get) kommt ein "Typ body Device: object" zurück. Warum auch immer.
                Mit der Token-Antwort komme ich zurecht. Da hole ich das raus mit:
                let obj = JSON.parse(body);
                access_token = obj.access_token;
                Nur wenn halt ein Objekt zurück kommt, komme ich nicht klar. Schaut auch irgendwie "verschachtelt" aus.
                • paul53P Offline
                  @Lenny.CB:
                  Nur wenn halt ein Objekt zurück kommt, komme ich nicht klar. Schaut auch irgendwie "verschachtelt" aus. `
                  Ist es das Objekt aus dem ersten Beitrag ? Im JSON-Viewer sieht es so aus (ohne "body: "):
                  Der Zugriff auf z.B. state.status.value_raw würde so erfolgen:
                  var status_value_raw = obj["000147619644"].state.status.value_raw;
                  • Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    @paul53:
                    Ist es das Objekt aus dem ersten Beitrag ? ` ja korrekt
                    @paul53:
                    dabei bekomme ich folgenden Fehler:
                    javascript.2 TypeError: Cannot read property 'status' of undefined at Request._callback (script.js.Testscripte.Miele_Abfrage:94:57) at Request.self.callback (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:185:22) at emitTwo (events.js:106:13) at Request.emit (events.js:191:7) at Request. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1161:10) at emitOne (events.js:96:13) at Request.emit (events.js:188:7) at IncomingMessage. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/request/request.js:1083:12) at IncomingMessage.g (events.js:292:16) at emitNone (events.js:91:20)
                    Caught by controller[0]: at Request._callback (script.js.Testscripte.Miele_Abfrage:94:57)
                    • paul53P Offline
                      @Lenny.CB:
                      dabei bekomme ich folgenden Fehler: `
                      • Lenny.CBL Offline
                        Lenny.CBL Offline
                        Lenny.CB
                        wenn ich das so aufbaue:var obj = {"000147619644":{"ident":{"type":{"key_localized":"Devicetype","value_raw":1,"value_localized":"Washing Machine"},"deviceName":"","deviceIdentLabel":{"fabNumber":"000147619644","fabIndex":"11","techType":"WMV963","matNumber":"10499100","swids":["3814","25105","25117","20163","3627","20242","25042","25043","25026","2971","20166"]},"xkmIdentLabel":{"techType":"XKM3100W","releaseVersion":"02.45"}},"state":{"status":{"value_raw":1,"value_localized":"Off","key_localized":"State"},"programType":{"value_raw":0,"value_localized":"","key_localized":"Programme"},"programPhase":{"value_raw":256,"value_localized":"","key_localized":"Phase"},"remainingTime":[0,0],"startTime":[0,0],"targetTemperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"temperature":[{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"},{"value_raw":-32768,"value_localized":null,"unit":"Celsius"}],"signalInfo":false,"signalFailure":false,"signalDoor":false,"remoteEnable":{"fullRemoteControl":true,"smartGrid":true},"light":0,"elapsedTime":[0,0],"spinningSpeed":0,"dryingStep":{"value_raw":null,"value_localized":"","key_localized":"Drying level"},"ventilationStep":{"value_raw":null,"value_localized":"","key_localized":"Power Level"}}}}; log(obj["000147619644"].state.status.value_raw);klappte es bei mir auch.````
                        16:07:36.884 [info] javascript.2 script.js.Testscripte.Miele_device_test: 1
                        Habe heut Morgen noch etwas versucht und wieder mal gesehen, dass ich mir selbst ins Knie geschossen habe. Is halt so wenn man nicht wirklich weiß was im kopierten Code passiert (Quasi wie immer :shock: ) Muss hier noch weiter lernen. :ugeek:
                        hier mal der Code:````
                        function Device_Abfrage () {
                                request.get    ({
                                                url: 'https://api.mcs3.miele.com/v1/devices/',
                                                // json: true,
                                                headers: {'Authorization': 'Bearer xxxxxxxx86816993400b8b44xxxxxxxx'}
                                                function (error, response, body) {
                                                log('Device_statusCode: ' + response.statusCode);
                                                log('body: ' + body);
                                                log('Device_error: ' + error);
                                                log('Typ body Device: ' + typeof body);
                                                var obj = JSON.parse(body);
                        Device_Abfrage ();
                        ich hatte "json: true" mitgegeben. Antwort kam das als Objekt zurück. Konnte es aber nicht mit JSON.stringify verarbeiten.
                        "json: true" auskommentiert, schon kam ein String zurück den ich mit JSON.parse bearbeiten konnte.
                        @paul53, danke für den Denkanstoß!
