  4. Javascript Instanz verbindet sich nicht mit dem Host
    6.4k
4 Beiträge 4 Kommentatoren 2.9k Aufrufe
    djtale2003
    ich habe eine Javascript Instanz mit nur 2 Scripten am Laufen. Im Reiter Instanzen ist der Punkt davor aber Rot: Verbunden mit Host: falsch Lebenszeichen: falsch
    Was ist hier los?
    javascript.0 2018-11-04 20:04:37.309 error at Zlib.callback (zlib.js:650:5)
    javascript.0 2018-11-04 20:04:37.309 error at TransformState.afterTransform (_stream_transform.js:54:12)
    javascript.0 2018-11-04 20:04:37.309 error at afterTransform (_stream_transform.js:79:3)
    javascript.0 2018-11-04 20:04:37.309 error at WritableState.onwrite (_stream_writable.js:90:5)
    javascript.0 2018-11-04 20:04:37.309 error at onwrite (_stream_writable.js:378:7)
    javascript.0 2018-11-04 20:04:37.309 error at afterWrite (_stream_writable.js:387:3)
    javascript.0 2018-11-04 20:04:37.309 error at _inflate.flush (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:386:7)
    javascript.0 2018-11-04 20:04:37.309 error at _decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:306:9)
    javascript.0 2018-11-04 20:04:37.309 error at perMessageDeflate.decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:349:40)
    javascript.0 2018-11-04 20:04:37.309 error at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
    javascript.0 2018-11-04 20:04:37.309 error at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
    javascript.0 2018-11-04 20:04:37.309 error at WebSocket.emit (events.js:188:7)
    javascript.0 2018-11-04 20:04:37.309 error at emitOne (events.js:96:13)
    javascript.0 2018-11-04 20:04:37.309 error at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
    javascript.0 2018-11-04 20:04:37.309 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
    javascript.0 2018-11-04 20:04:37.309 error at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0 2018-11-04 20:04:37.309 error at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0 2018-11-04 20:04:37.309 error at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:37.309 error at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
    javascript.0 2018-11-04 20:04:37.309 error at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
    javascript.0 2018-11-04 20:04:37.309 error at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:37.309 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:37.309 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
    javascript.0 2018-11-04 20:04:37.309 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    javascript.0 2018-11-04 20:04:37.309 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:37.309 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:37.309 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    javascript.0 2018-11-04 20:04:37.309 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:37.309 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:37.309 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    javascript.0 2018-11-04 20:04:37.309 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    javascript.0 2018-11-04 20:04:37.309 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:488:41)
    javascript.0 2018-11-04 20:04:37.309 error at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3253:20)
    javascript.0 2018-11-04 20:04:37.309 error at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3204:41)
    javascript.0 2018-11-04 20:04:37.309 error at Object.fromSource (/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js:31:38)
    javascript.0 2018-11-04 20:04:37.309 error TypeError: coffee.helpers.prettyErrorMessage is not a function
    javascript.0 2018-11-04 20:04:37.309 error uncaught exception: coffee.helpers.prettyErrorMessage is not a function
    javascript.0 2018-11-04 20:04:03.813 error at Zlib.callback (zlib.js:650:5)
    javascript.0 2018-11-04 20:04:03.813 error at TransformState.afterTransform (_stream_transform.js:54:12)
    javascript.0 2018-11-04 20:04:03.813 error at afterTransform (_stream_transform.js:79:3)
    javascript.0 2018-11-04 20:04:03.813 error at WritableState.onwrite (_stream_writable.js:90:5)
    javascript.0 2018-11-04 20:04:03.813 error at onwrite (_stream_writable.js:378:7)
    javascript.0 2018-11-04 20:04:03.813 error at afterWrite (_stream_writable.js:387:3)
    javascript.0 2018-11-04 20:04:03.813 error at _inflate.flush (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:386:7)
    javascript.0 2018-11-04 20:04:03.813 error at _decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/PerMessageDeflate.js:306:9)
    javascript.0 2018-11-04 20:04:03.813 error at perMessageDeflate.decompress (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:349:40)
    javascript.0 2018-11-04 20:04:03.813 error at Receiver.dataMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/Receiver.js:389:14)
    javascript.0 2018-11-04 20:04:03.813 error at Receiver._receiver.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/WebSocket.js:141:47)
    javascript.0 2018-11-04 20:04:03.813 error at WebSocket.emit (events.js:188:7)
    javascript.0 2018-11-04 20:04:03.813 error at emitOne (events.js:96:13)
    javascript.0 2018-11-04 20:04:03.813 error at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/ws/lib/EventTarget.js:99:16)
    javascript.0 2018-11-04 20:04:03.813 error at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transports/websocket.js:147:10)
    javascript.0 2018-11-04 20:04:03.813 error at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0 2018-11-04 20:04:03.813 error at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0 2018-11-04 20:04:03.813 error at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:03.813 error at WS. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:273:10)
    javascript.0 2018-11-04 20:04:03.813 error at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/engine.io-client/lib/socket.js:456:14)
    javascript.0 2018-11-04 20:04:03.813 error at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:03.813 error at Socket. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:03.813 error at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:335:16)
    javascript.0 2018-11-04 20:04:03.813 error at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-parser/index.js:251:12)
    javascript.0 2018-11-04 20:04:03.813 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:03.813 error at Decoder. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:03.813 error at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:345:8)
    javascript.0 2018-11-04 20:04:03.813 error at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0 2018-11-04 20:04:03.813 error at Manager. <anonymous>(/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0 2018-11-04 20:04:03.813 error at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:244:12)
    javascript.0 2018-11-04 20:04:03.813 error at Socket.onack (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:319:9)
    javascript.0 2018-11-04 20:04:03.813 error at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.javascript/javascript.js:488:41)
    javascript.0 2018-11-04 20:04:03.813 error at load (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3253:20)
    javascript.0 2018-11-04 20:04:03.813 error at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:3204:41)
    javascript.0 2018-11-04 20:04:03.813 error at Object.fromSource (/opt/iobroker/node_modules/coffee-compiler/coffee-compiler.js:31:38)
    javascript.0 2018-11-04 20:04:03.813 error TypeError: coffee.helpers.prettyErrorMessage is not a function
    javascript.0 2018-11-04 20:04:03.812 error uncaught exception: coffee.helpers.prettyErrorMessage is not a function</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
      RappiRN
      Läuft denn der Adapter, wenn die Skripte angehalten sind? Lief er schonmal? Ich kann im log nichts Brauchbares erkennen.
      Enrico
      • apollon77A Offline
        Sind es coffeescript Skripte? Wenn ja zeig bitte mal die Skripte. Es gibt nicht viele die Coffeescript nutzen, ggf ein Bug ..- ?!
          BeautyBoyBob
          Hattest du dein Problem hier gelöst? Wenn ja, wie?
