  4. JS installation Error 243 ELIFECYCLE
    5.4k
8 Beiträge 4 Kommentatoren 2.1k Aufrufe
  • F Offline
    Flumi
    bin noch relativ neu was ioBroker angeht aber habe es einfach mal auf meinen Raspberry gepackt und wollte so mit Alexa ein paar Sachen steuern. Nun habe ich versucht JS zu installieren und leider diesen Fehler bekommen:
    root@Nas-Server:~# npm install iobroker.javascript --production --save --prefix "/opt/iobroker"
    npm WARN deprecated coffee-script@1.12.7: CoffeeScript on NPM has moved to "coffeescript" (no hyphen)
    > iobroker.javascript@4.0.1 postinstall /opt/iobroker/node_modules/iobroker.javascript
    > node ./install/installTypings.js
    installing NodeJS typings...
    npm ERR! path /root/.npm/_logs
    npm ERR! code EACCES
    npm ERR! errno -13
    npm ERR! syscall scandir
    npm ERR! Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!  { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
    npm ERR!   stack: 'Error: EACCES: permission denied, scandir \'/root/.npm/_logs\'',
    npm ERR!   errno: -13,
    npm ERR!   code: 'EACCES',
    npm ERR!   syscall: 'scandir',
    npm ERR!   path: '/root/.npm/_logs' }
    npm ERR!
    npm ERR! The operation was rejected by your operating system.
    npm ERR! It is likely you do not have the permissions to access this file as the current user
    npm ERR!
    npm ERR! If you believe this might be a permissions issue, please double-check the
    npm ERR! permissions of the file and its containing directories, or try running
    npm ERR! the command again as root/Administrator (though this is not recommended).
    glob error { Error: EACCES: permission denied, scandir '/root/.npm/_logs'
      errno: -13,
      code: 'EACCES',
      syscall: 'scandir',
    npm ERR! path /root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be
    npm ERR! errno -13
    npm ERR! syscall open
    npm ERR! Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!  { Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'
    npm ERR!   cause:
    npm ERR!      syscall: 'open',
    npm ERR!      path: '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be' },
    npm ERR!   isOperational: true,
    npm ERR!   stack: 'Error: EACCES: permission denied, open \'/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be\'',
    npm ERR!
    npm ERR!
    npm ERR! code ELIFECYCLE
    npm ERR! errno 243
    npm ERR! iobroker.javascript@4.0.1 postinstall: `node ./install/installTypings.js`
    npm ERR! Exit status 243
    npm ERR!
    npm ERR! Failed at the iobroker.javascript@4.0.1 postinstall script.
    npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR!     /root/.npm/_logs/2018-12-03T17_39_56_958Z-debug.log
    So wie ich das sehe sagt er was von Rechten. Allerdings läuft ioBroker standardmäßig doch als root und auch wenn ich über die Konsole über root versuche zu Installieren bekomme ich den Error. Vielleicht habt ihr ja noch eine Idee. Die .log habe ich angehangen.
    12226_2018-12-03t17_39_56_958z-debug.log
    • Homer.J.H Offline
      Homer.J.H Offline
      Homer.J.
      Versuch es mal hiermit.
      ! cd /opt/iobroker
      ! npm install iobroker.javascript@4.0.1
      ! iobroker update javascript
      • F Offline
        Flumi
        Vielen Dank hat geholfen funktioniert jetzt!
          Moditril
          habe einen quasi ähnlichen Fehler und die hier dargestellte Lösung hat bei mir leider nicht funktioniert.
          Bei Eingabe von
           npm install iobroker.javascript@4.0.2
          erscheint der ganz unten dargestellte Code im Terminal. Habe es auch schon mit
          ````und````
          ````sowie über das WEBui von ioBroker probiert.
          Weiß jemand Rat?
          root@HomePi:/opt/iobroker# npm install iobroker.javascript@4.0.2
          npm ERR! errno -13
          npm ERR! stack: 'Error: EACCES: permission denied, scandir '/root/.npm/_logs'',
          npm ERR!
          npm ERR!
          errno: -13,
          code: 'EACCES',
          syscall: 'scandir',
          npm ERR! errno -13
          npm ERR! cause:
          npm ERR! stack: 'Error: EACCES: permission denied, open '/root/.npm/_cacache/index-v5/fc/ee/fc3e1dd6706bd557d2840d92ff10cdd6928b92fb8c46d2195dfbd8d4b2be'',
          npm ERR!
          npm ERR!
          npm ERR! errno 243
          npm ERR! iobroker.javascript@4.0.2 postinstall: node ./install/installTypings.js
          npm ERR!
          npm ERR! Failed at the iobroker.javascript@4.0.2 postinstall script.
            Moditril
            Hab in der Zwischenzeit eine neue frische Installation von ioBroker nach der neuen Anleitung auf einer neuen SD durchgeführt. Jetzt funktionierte es ohne Probleme.
            Keine Ahnung wo das Problem lag, aber läuft jetzt.
            • AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @Moditril:
              Keine Ahnung wo das Problem lag, aber läuft jetzt. `
              ==> viewtopic.php?f=17&t=19209
                Moditril
                Ach, super. Besten Dank für den Link. Wieder was gelernt…
                Gesendet von meinem Pixel 2 mit Tapatalk
                  AlCalzoneA Offline
                  AlCalzone
                  Bzw. in deinem Fall schien es daran zu liegen, dass du als Root angemeldet warst. Dann wird bei einigen Adaptern die –unsafe-perm Option nötig. Beim JavaScript-Adapter kam es ohne die Option einem Problem mit einem Paket-Skript - sollte in der nächsten Version gefixt sein.
