  4. RockPro64
    5.4k
RockPro64
32 Beiträge 8 Kommentatoren 5.5k Aufrufe
  • C Offline
    Camuri
    HI,
    gestern ist bei mir der RockPro64 per Post gekommen hat den schon irgendjemand zum laufen gebracht mit IoBroker?
    • C Offline
      Camuri
      Also Iobroker läuft schonmal bekomme beim Adapter installieren nur ein Paar Fehler vll kann mir ja jemand helfen. Bild häng ich noch mit dran von der Iobroker installation da kamen auch ein paar Meldungen
      ! $ ./iobroker add alexa2
      ! npm install iobroker.alexa2 –production --prefix "/opt/iobroker" (System call)
      ! gyp
      ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/unix-dgram/.node-gyp"
      ! Traceback (most recent call last):
      ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py", line 13, in <module>import gyp
      ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/init.py", line 8, in <module>import gyp.input
      ! File "/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/pylib/gyp/input.py", line 5, in <module>from compiler.ast import Const
      ! ImportError: No module named compiler.ast
      ! gyp ERR! configure error gyp
      ! ERR! stack
      ! Error: gyp failed with exit code: 1gyp
      ! ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)gyp ERR! stack at emitTwo (events.js:106:13)
      ! gyp ERR! stack at ChildProcess.emit (events.js:191:7)
      ! gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
      ! gyp ERR! System Linux 4.4.132-1075-rockchip-ayufan-ga83beded8524
      ! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
      ! gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
      ! gyp ERR! node -v v6.14.3
      ! gyp ERR! node-gyp -v v3.4.0
      ! gyp ERR! not ok
      ! prebuild-install
      ! WARN install EACCES: permission denied, access '/root/.npm'
      ! gyp
      ! WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.14.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/serialport/.node-gyp"
      ! gyp ERR! stack Error: gyp failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)
      ! gyp ERR! stack at emitTwo (events.js:106:13)
      ! gyp ERR! cwd /opt/iobroker/node_modules/serialport
      ! gyp ERR! not ok
      ! npm
      ! WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: node-gyp rebuild
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 (node_modules/serialport):
      ! npm WARN optional SKIPPING OPTIONAL DEPENDENCY: serialport@6.2.2 install: prebuild-install || node-gyp rebuild
      ! host.rockpro64 install adapter alexa2
      ! npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.alexa2"
      ! got /opt/iobroker/node_modules/iobroker.alexa2/admin
      ! upload [3] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/words.js words.js application/javascript
      ! upload [2] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index_m.html index_m.html text/html
      ! upload [1] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/index.html index.html text/html
      ! upload [0] alexa2.admin /opt/iobroker/node_modules/iobroker.alexa2/admin/alexa.png alexa.png image/png
      ! host.rockpro64 object system.adapter.alexa2 created
      ! host.rockpro64 create instance alexa2
      ! host.rockpro64 object alexa2.0.info.csrf created
      ! host.rockpro64 object alexa2.0.info.cookie created
      ! host.rockpro64 object alexa2.0.info.connection created
      ! host.rockpro64 object alexa2.0.info created
      ! host.rockpro64 object system.adapter.alexa2.0.outputCount created
      ! host.rockpro64 object system.adapter.alexa2.0.inputCount created
      ! host.rockpro64 object system.adapter.alexa2.0.uptime created
      ! host.rockpro64 object system.adapter.alexa2.0.memRss created
      ! host.rockpro64 object system.adapter.alexa2.0.memHeapTotal created
      ! host.rockpro64 object system.adapter.alexa2.0.memHeapUsed created
      ! host.rockpro64 object system.adapter.alexa2.0.connected created
      ! host.rockpro64 object system.adapter.alexa2.0.alive created
      ! host.rockpro64 object system.adapter.alexa2.0 created
      ! process exited with code 0</module></module></module></module></module></module>
        Hab am Handy nur quergelesen.
        Für mich sieht alles OK aus.
        Läuft es denn nicht?
        Rainer
        • C Offline
          Camuri
          bis jetzt läuft alles nur mein Backup bekomm ich vom kleinen Rock64 nicht rein.
            Warum nicht?
            • Lenny.CBL Offline
              Lenny.CBL Offline
              Lenny.CB
              habe auch grad den RockPro64 am wickel…
              soll das bei der Installation wirklich so aussehen?
              gyp ERR! stack Error: `gyp` failed with exit code: 1gyp ERR! stack at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:305:16)
              gyp ERR! not ok
                Das svheint mir ein üblicher Ausschnitt aus der Serialport Installation zu sein.
                Die Installation fertiger pakete scheitert weil nicht existent, dann werden sie selbst neu kompiliert.
                Gruß Rainer
                • Lenny.CBL Offline
                  Lenny.CBL Offline
                  Lenny.CB
                  @Homoran:
                  Gruß Rainer `
                  hmmm. ok… wenn ich ERR sehen wird mir immer gleich komisch... OK mache ich weiter.
                  • Lenny.CBL Offline
                    Lenny.CBL Offline
                    Lenny.CB
                    Backup drin und läuft soweit…
                    cool finde ich: 983_neu.jpg
                      aleks-83
                      Ich bin auch schwer an dem RockPro64 interessiert.
                      Welche Variante habt ihr? 2GB, 4GB? (Lenny vermutlich 4GB)
                      Wieviel eMMC?
                      Ich denke an den 4GB mit 64GB eMMC.
                      Habt ihr aktive Kühlung mitbestellt? Direkt bei pine gekauft?
                      = Dell Optiplex Micro - 10GB RAM - 200GB SSD - Debian VM =
                      = Node.js v20.19.6 = NPM 10.8.2 = JS Controller 7.0.7 =
                      Ubiquiti UAP-AC-LR - UAP-AC-Lite - Synology DS716+II - Fritz!Box 7490
                      Glasfaser 400
                      • I Offline
                        I Offline
                        intruder7
                        Moin,
                        hab den RockPro mit 4 GB, 64GB emmc und passiver Kühlung. Hab dort allerdings erstmal nur android drauf. ioBroker läuft noch auf dem kleinen Rock64 mit 4GB . Dort bisher aber wie am Schnürchen.
                        Gruß Maik
                        • I Offline
                          I Offline
                          intruder7
                          achso… und direkt bei PINE bestellt
                            aleks-83
                            Ah ok, Danke.
                            Weißt du wie es mit image backups aussieht?
                            Ich betreibe meinen Pi aktuell mit einem OS auf USB Stick.
                            So wird keine SD Card mehr belastet und ich kann den Pi jederzeit einfach runterfahren, stick abziehen am PC ein .img backup per DiskImager machen und fertig.
                            • Wie kann ich ein backup von nem eMMC machen? (per "dd"?)
                            • Oder kann ich hier problemlos wieder meinen USB Stick als OS Partition nutzen?
                            • Und den eMMC dann evtl als Zusatzspeicher?
                            • Hat jemand Erfahrung mit der Playbox und eingebettetem 7" LCD Screen?
                            Glasfaser 400
                            • Lenny.CBL Offline
                              Lenny.CBL Offline
                              Lenny.CB
                              @aleks-83:
                              Welche Variante habt ihr? 2GB, 4GB? (Lenny vermutlich 4GB) ` richtig, 4GB
                              @aleks-83:
                              Wieviel eMMC? ` ich habe nur 16GB bestellt, bei mir hängt noch ne SSD dran
                              @aleks-83:
                              Habt ihr aktive Kühlung mitbestellt? ` ja, habe ich. Wird aber momentan nicht vom Image unterstützt.
                              @aleks-83:
                              Direkt bei pine gekauft? ` jupp, musste zum Glück nicht zum Zoll.
                              @aleks-83:
                              Wie kann ich ein backup von nem eMMC machen? ` iobroker.backitup | ist ganz einfach
                              • I Offline
                                I Offline
                                intruder7
                                @aleks-83:
                                Ah ok, Danke.
                                • Hat jemand Erfahrung mit der Playbox und eingebettetem 7" LCD Screen? `
                                ich nutze nur den eMMC und keine sd. Image aufspielen und backup mache ich über den USB Adapter. Gibt es auch bei Pine für nen Appel und nen Ei. ;-)
                                • RöstkartoffelR Offline
                                  Röstkartoffel
                                  @intruder7:
                                  ich nutze nur den eMMC und keine sd. Image aufspielen und backup mache ich über den USB Adapter. Gibt es auch bei Pine für nen Appel und nen Ei. ;-) `
                                  Hallo intruder7.
                                  Heißt das, dass du den eMMC zwecks kompletten Backup vom Rock64 abziehst, auf den Adapter steckst, das BackupImage machst und dann den emmC wieder auf den Rock64 steckst?
                                  NUC7i3BNH mit Proxmox und ioBroker (VM Debian Buster), Raspi3 (Slave Smartmeter für eHZ easymeter), Hardware CCU2, SMA SB5000TL-21
                                  • I Offline
                                    I Offline
                                    intruder7
                                    Hey natürlich nicht. Ich habe nach der ganzen ioBroker Installation ein Backup der eMMC gemacht. Im normalen Betrieb lasse ich automatisiert Backups mit Hilfe des Backitup Adapter auf mein NAS erstellen.
                                    Wenn ich hier den Rock64 Teil so quer gelesen habe, vermute ich dass niemand diesen USB Adapter hat. Ganz oft ist hier die Rede von diesem nand-sata-install. Die Möglichkeit der Installation mittels des USB Adapter ist doch viel einfacher. Zumal der echt kaum was kostet, $4,99 glaub ich
                                      Röstkartoffel
                                      Danke für die Info.
                                      Genau so habe ich das auch gemacht und sichere die Installation über den Backitup Adapter.
                                      Und den eMMC USB-Adapter habe ich auch. Wenn man erst einmal ein paar Tage damit verbracht hat, das Image auf die SD Karte zu schreiben und es dann doch nicht funktioniert, ohne eingesetzte SD zu booten, ging es mir danach mit dem USB-Adapter irgendwie zu einfach. :D
                                        aleks-83
                                        Das hört sich interessant an…
                                        Aber wie funktioniert das?
                                        Der USB Adapter hat ja ein "männliches" USB Ende.
                                        • Kann ich ihn dann über ne USB Verlängerung direkt am PC anschließen und ein Backup machen?
                                        • Schaut der Adapter aus dem Gehäuse raus?
                                        • bleibt er immer eingesteckt? (Wenn man kein eMMC nutzt, sondern USB boot)
                                        Edit:
                                        Achso… Mit dem Adapter kann man ein backup des eMMC Flash Speichers machen :lol:
                                        Nicht aber den RockPro am PC anschließen. Gecheckt !
                                        Aber wie kann ich dann ein image backup machen?
                                        Indem man den eMMC von der RockPro Platine löst, ihn per USB Adapter am PC sichert!?
                                        Und dann auf die gleiche Weise wieder zurückspielen?
                                        Alles mit Win32DiskImager?
                                        Glasfaser 400
                                        • I Offline
                                          I Offline
                                          intruder7
                                          @aleks-83:
                                          Alles mit Win32DiskImager? `
                                          genau so schaut es aus ;-)
