  4. Simple Web Adapter Installations Error
    5.4k
9 Beiträge 3 Kommentatoren 1.6k Aufrufe
  • V Offline
    V Offline
    vlink
    Wollte gerade ein Update machen für den ioBroker simple Web Adapter von Version
    1.2.0 auf 1.2.1.
    Leider erscheinen nur Fehler:
    $ ./iobroker upgrade web
    host.Homeserver Adapter "system.adapter.web.0" is stopped.
    npm install iobroker.web –production --prefix "C:/ioBroker" (System call)
    gyp
    ERR! configure error
    gyp ERR! stack Error: Can't find Python executable "python", you can set the PYTHON env variable.gyp ERR!
    stack at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:116:14)gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:71:11
    gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\ioBroker\node_modules\iobroker.web\node_modules\bufferutil
    gyp ERR! node -v v5.0.0
    gyp ERR! node-gyp -v v3.0.3
    gyp ERR! not ok
    npm ERR! Windows_NT 6.1.7601
    npm ERR! argv "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.web" "--production" "--prefix" "C:/ioBroker"npm ERR! node v5.0.0
    npm ERR! npm v3.3.6
    npm ERR! code ELIFECYCLE
    npm ERR! bufferutil@1.2.1 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the bufferutil@1.2.1 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the bufferutil package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuild
    npm ERR! You can get their info via:
    npm ERR! npm owner ls bufferutil
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! C:\Windows\system32\npm-debug.log
    ERROR: host.Homeserver Cannot install iobroker.web: 1
    Kann mir jemand helfen was hier falsch läuft?
    Merci!
    • V Offline
      V Offline
      vlink
      Welche nodejs Version wird eigentlich von ioBroker unterstützt?
      Hatte die 0.10.35 ursprünglich und dann mal auf die 5.0 aktualisiert.
      Oder geht das ansich gar nicht mit 5.0 ?
      • BluefoxB Offline
        BluefoxB Offline
        Ich muss sagen, ich habe 0 Zeit es zu prüfen.
        ich sitze immer noch mit 0.12.x
        • coyoteC Offline
          coyoteC Offline
          coyote
          Denke das liegt an der node-js Version, bekomme auch diese Fehler nachddem ich mal zu der 4.x.x gewechselt habe, seit dem kann ich auch den Harmony Adapter nicht mehr installieren. Ich muss demnächst, wenn ich mal Zeit hab, mal iobroker komplett neu installieren.
          • V Offline
            V Offline
            vlink
            kein thema
            da steckt auch richtig arbeit drin .. ich dachte mir version 5 ist verfügbar - also updaten
            nur irgendwie geht dann einiges nicht mehr
            bin jetzt wieder auf 0.10.35 und scheint wieder alles zu gehen
            • V Offline
              V Offline
              vlink
              neuinstallation hat bei mir nichts gebracht
              egal was ich unternommen habe mit nodejs 5 ging einiges nicht mehr
              habe jetzt alles deinstalliert und scheinbar nur mit 0.10.35 läuft alles
              Lasse ich es erstmal
              Dachte wenn es bei nodejs von 0.10.x auf 5.0 geht muss ja einiges neu / verbessert sein ;)
              • V Offline
                V Offline
                vlink
                @coyote
                wenn du iobroker neu installieren willst .. wie schaffst du es die bisherige config zu übernehmen?
                ich habe jede menge installiert und konfigurierte adapter und mehrere VIS views
                kann man die einfach sichern und wieder einspielen?
                Danke!
                • coyoteC Offline
                  coyoteC Offline
                  coyote
                  Klar, das meinte ich eigentlich auch mit neu installieren, also nicht die neuen node-js nehmen.
                  Hmm, verrate mir mal wie du die node-js Version entfernt hast und zurück zur alten bist, das würde mir ja eigentlich auch reichen.
                  Dann könnte ich mir das neu aufsetzen vorerst sparen.
                  Zum Sichern und wieder einspielen gibts hier schon verschieden Threads, ich habe aber selbst noch keine Sicherung wiederhergestellt.
                  Meine zweite Speicherkarte ist gestern erst gekommen und wenn ich mal Zeit hab, wollte ich mal bisschen mit nem Backup testen
                  • V Offline
                    V Offline
                    vlink
                    ich hatte mir vom programm verzeichnis (läuft bei mir auf einem windows home server) von nodejs von der jeweils installierten version eine kopie gemacht. Dann iobroker dienst beendet und das aktive nodejs verzeichnis mit der alten version überschrieben und iobroker dienst wieder gestartet.
                    Hab bis jetzt nichts entdeckt was damit nicht läuft
