  4. [Gelöst] Amazon-Dash Adapter läuft nicht
    6.1k
11 Beiträge 2 Kommentatoren 1.1k Aufrufe
    piri78
    Hey leute,
    Ich schaffe es irgendwie nicht, dass meine Amazon-Dash Adapter läuft.
    In den loge habe ich immer folgende Fehlermeldung:
    amazon-dash.0 2018-07-26 19:28:14.909 info starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v6.14.2
    amazon-dash.0 2018-07-26 19:28:14.760 info States connected to redis: 127.0.0.1:6379
    amazon-dash.0 2018-07-26 19:28:14.749 debug statesDB connected
    amazon-dash.0 2018-07-26 19:28:14.703 debug objectDB connected
    amazon-dash.0 2018-07-26 19:28:14.592 error at Object.Module._extensions..js (module.js:586:10)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Module._compile (module.js:577:32)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Object. <anonymous>(/opt/iobroker/node_modules/pcap/pcap.js:3:21)
    amazon-dash.0 2018-07-26 19:28:14.592 error at require (internal/module.js:20:19)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Module.require (module.js:504:17)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Function.Module._load (module.js:445:3)
    amazon-dash.0 2018-07-26 19:28:14.592 error at tryModuleLoad (module.js:453:12)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Module.load (module.js:494:32)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Object.Module._extensions..node (module.js:604:18)
    amazon-dash.0 2018-07-26 19:28:14.592 error at Error (native)
    amazon-dash.0 2018-07-26 19:28:14.592 error Error: Module version mismatch. Expected 48, got 57.
    amazon-dash.0 2018-07-26 19:28:14.580 error uncaught exception: Module version mismatch. Expected 48, got 57.
    amazon-dash.0 2018-07-26 19:27:43.113 info terminating
    amazon-dash.0 2018-07-26 19:27:42.924 info starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v6.14.2
    Anscheinen passt irgendeine Version nicht - aber ich habe keine Ahnung welche….
    node -v
    v6.14.2
    nodejs -v
    v6.14.2
    npm -v
    4.6.1
    Besten Dank Grüße Martin</anonymous>
    • StabilostickS Offline
      Stabilostick
      Ach menno, der Adapter läuft nicht unter Windows. Warum wird die Installation trotzdem gestartet?
      $ ./iobroker add amazon-dash
      NPM version: 6.1.0
      npm install iobroker.amazon-dash --production --save --prefix "C:/dev/iobroker" (System call)
      Der Befehl "apt-get" ist entweder falsch geschrieben oder
      konnte nicht gefunden werden.
      Der Befehl "true" ist entweder falsch geschrieben oder
      npm
       ERR! code ELIFECYCLEnpm ERR! errno 1
      npm ERR! iobroker.amazon-dash@0.2.9 preinstall: `apt-get install libpcap-dev -y || true`npm ERR!
       Exit status 1npm ERR!
      npm ERR! Failed at the iobroker.amazon-dash@0.2.9 preinstall script.
      npm
      ERR! This is probably not a problem with npm. There is likely additional logging output above.
      host.ARBEITSZIMMER install adapter amazon-dash
      NPM version: 6.1.0
        Stabilostick
        Tschuldigung wenn ich Deinen Thread etwas kapere. Ich wollte Dir helfen, komme aber nicht mal über die Installatiion des Dash-Buttons hinaus.
        Plattform: raspi
        User: pi
        Der ioBroker läuft als Dienst über init.d und wird als root gestart.
        chmod 777 auf den Ordner /opt/iobroker
        Zuerst fehlte git beim Adapter-installieren. Schnell mit
        sudo apt-get install git
        git nachinstalliert.
        Jetzt erhalte ich den folgenden Fehler:
        npm install iobroker.amazon-dash --production --prefix "/opt/iobroker" (System call)
        npm
         ERR! code 128
        npm
         ERR! Command failed: /usr/bin/git submodule update -q --init --recursivenpm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-debca703': Keine Berechtigung
        npm ERR!
        npm ERR! A complete log of this run can be found in:npm ERR!     /root/.npm/_logs/2018-07-26T18_03_11_213Z-debug.log
        host.iobrokerpi install adapter amazon-dash
        npm
         ERR! code 128
        npm
         ERR!
        npm
        ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-2b7aaa4f': Keine Berechtigung
        npm ERR!
        npm
         ERR!
         ERR!
             /root/.npm/_logs/2018-07-26T18_03_32_064Z-debug.log
        npm
         ERR! code 128
        npm
        npm ERR!
         fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-3b90f06e': Keine Berechtigung
        npm ERR!
        npm
         ERR!
         ERR!     /root/.npm/_logs/2018-07-26T18_03_52_890Z-debug.log
        ERROR: host.iobrokerpi Cannot install amazon-dash
        ERROR: process exited with code 13
        Was nun?
          Stabilostick
          So, bin jetzt von npm 6.2.0 auf npm 4.6.1 gewechselt. Jetzt gibt es einen vernünftigen Fehler.
          npm
           WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/.staging/iobroker.amazon-dash-eb5038e9
          gyp
           WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.11.3"
          gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/socketwatcher/.node-gyp"
          Satire: Klaaar, root hat keinen Zugriff auf /root/
          Wird der apt-get -Befehl etwa nicht im Kontext von root ausgeführt?
            Stabilostick
            So, nächster Akt.
            Nachdem alles so schön klar in der Fehlermeldung ausgführt war, quickfix mit
            sudo apt-get install libpcap-dev
            auf der Kommandozeile aufgerufen. Dannach wieder das Setup im Admin gestartet. Am Anfang ähnliche Fehler –-> nee, <u>WARNUNGEN</u>:
            npm
            gyp
            WARN
            gyp
             WARN
            ../socket_watcher.cpp: In static member function ‘static void SocketWatcher::Callback(uv_poll_t*, int, int)’:../socket_watcher.cpp:77:60: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
               Nan::MakeCallback(watcher->handle(), callback, argc, argv);
            In file included from ../socket_watcher.hpp:8:0,
                             from ../socket_watcher.cpp:5:
            ../../nan/nan.h:929:46: note: declared here
               NAN_DEPRECATED inline v8::Local <v8::value>MakeCallback(
            gyp
             WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/8.11.3"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/pcap/.node-gyp"
            ../pcap_session.cc: In static member function ‘static void PcapSession::PacketReady(u_char*, const pcap_pkthdr*, const u_char*)’:../pcap_session.cc:85:102: warning: ‘v8::Local <v8::value>Nan::MakeCallback(v8::Local<v8::object>, v8::Local<v8::function>, int, v8::Local<v8::value>*)’ is deprecated [-Wdeprecated-declarations]
                 Nan::MakeCallback(Nan::GetCurrentContext()->Global(), Nan::New(session->packet_ready_cb), 0, NULL);
            In file included from ../pcap_session.h:4:0,
                             from ../pcap_session.cc:7:
            npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.amazon-dash"
            npm WARN lifecycle iobroker.amazon-dash@0.2.9~preinstall: cannot run in wd %s %s (wd=%s) iobroker.amazon-dash@0.2.9 apt-get install libpcap-dev -y || true /opt/iobroker/node_modules/iobroker.amazon-dash
            gyp
            gyp
            WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/socketwatcher/.node-gyp"
            In file included from ../socket_watcher.hpp:8:0,                 from ../socket_watcher.cpp:5:
            gyp
            WARN
            gyp
            WARN EACCES
             attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/.node-gyp"
            In file included from ../pcap_session.h:4:0,                 from ../pcap_session.cc:7:
            got /opt/iobroker/node_modules/iobroker.amazon-dash/admin
            upload [2] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/words.js words.js application/javascript
            upload [1] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/index.html index.html text/html
            upload [0] amazon-dash.admin /opt/iobroker/node_modules/iobroker.amazon-dash/admin/amazon-dash.png amazon-dash.png image/png
            host.iobrokerpi object system.adapter.amazon-dash created
            host.iobrokerpi create instance amazon-dash
            host.iobrokerpi object system.adapter.amazon-dash.0.outputCount created
            host.iobrokerpi object system.adapter.amazon-dash.0.inputCount created
            host.iobrokerpi object system.adapter.amazon-dash.0.uptime created
            host.iobrokerpi object system.adapter.amazon-dash.0.memRss created
            host.iobrokerpi object system.adapter.amazon-dash.0.memHeapTotal created
            host.iobrokerpi object system.adapter.amazon-dash.0.memHeapUsed created
            host.iobrokerpi object system.adapter.amazon-dash.0.connected created
            host.iobrokerpi object system.adapter.amazon-dash.0.alive created
            host.iobrokerpi object system.adapter.amazon-dash.0 created
            process exited with code 0</v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value></v8::value></v8::value></v8::function></v8::object></v8::value>
            Warnung ist gut, da KEIN Fehler. ;-)
            Naja, jetzt hat er die Instanz angelegt. Muss das alles so sein?
              Stabilostick
              Was mich zum Fazit bringt:
              <size size="200">Anleitung vorher lesen!</size>
              ` > <size size="150">Steps</size>
              1. Install libpcap-dev
              2. Pair your Dash-Adapter within the Amazon App but don't select a product!
              Just quit the installation procedure at the product selection tab.
              Otherwise you'll order every time a product ;) German instructions.
              3. Hit the dash button (should be white first, then flashing red) `
                Stabilostick
                Was mich wieder zurück zum ersten Posting bringt:
                Bei mir sieht der Start des Adapters so aus:
                2018-07-26 20:26:44.581 - info: host.iobrokerpi instance system.adapter.amazon-dash.0 started with pid 15283
                2018-07-26 20:26:45.902 - info: amazon-dash.0 starting. Version 0.2.9 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v8.11.3
                2018-07-26 20:26:45.917 - info: amazon-dash.0 starting pcap session on default interface
                Wenn ich keine MAC-Adressen hinterlegt habe, war es das auch schon.
                  Stabilostick
                  Als Erkenntnis würde ich sagen, dass Du ein Versionsproblem hast.
                  Begründung: uncaught exception: Module version mismatch. Expected 48, got 57.
                  Und zwar bei der Datei: –> var binding = require("./build/Release/pcap_binding");
                  Wie hast Du installiert? Hast Du es auch so wie ich gemacht? (oder die Anleitung befolgt :P )
                    piri78
                    Also…. du kaperst nicht meinen Beitrag - Danke für deine Unterstützung.
                    Ich verwende auch den Raspi 3 - also kein Windows....
                    Installiert hätte ich es nach anleitung....
                    Adatper installiert
                    sudo apt-get install libpcap-dev (ohne sudo hatte ich immer eine Fehlermeldung bekommen)
                    Dann wollte ich den Dash Button Pairen - nach Amazon anleitung.
                    Der Adapter ist aber immer bei mir rot - eben mit obiger Fehlermeldung. Mein Problem ist, dass ich nicht weiß, welche Version von welchem Programm ihm nicht schmeckt....
                      piri78
                      Juhuuuu Adapter ist Grün - danke für den Denkanstoß!
                      in der Datei /opt/iobroker/node_modules/pcap/pcap.js konnte ich nun sehen was ihm nicht gefällt.
                      1. Problem:
                      ==> npm install pcap
                      2. Problem
                      var SocketWatcher = require("socketwatcher").SocketWatcher;
                      ==> npm install socketwatcher
                      Und schon ist der Adapter grün!
                        Stabilostick
                        Super! Fügst Du Bitte noch ein [Gelöst] im Titel des ersten Beitrags hinzu? Danke! ;)
                        Jetzt muss ich nur noch meine Dash-Buttons finden…
