  4. Unklare Fehlermeldung
    1.7k
7 Beiträge 5 Kommentatoren 480 Aufrufe
    Marty56
    Ich bekommen alle 2-3 Tage folgende Fehlermeldung und habe keine Idee, was ich dagegen machen könnte.
    Hat jemand einen Tip für mich?
    host.raspberrypi	2018-06-20 15:35:59.664	error	instance system.adapter.javascript.0 terminated with code 0 (OK)
    Caught	2018-06-20 15:35:59.664	error	by controller[1]: port: '8087' }
    Caught	2018-06-20 15:35:59.664	error	by controller[1]: host: 'undefined',
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: hostname: 'undefined',
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: syscall: 'getaddrinfo',
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: errno: 'ENOTFOUND',
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: code: 'ENOTFOUND',
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
    Caught	2018-06-20 15:35:59.663	error	by controller[1]: at errnoException (dns.js:28:10)
    Caught	2018-06-20 15:35:59.662	error	by controller[1]: { Error: getaddrinfo ENOTFOUND undefined undefined:8087
    Caught	2018-06-20 15:35:59.662	error	by controller[0]: port: '8087' }
    Caught	2018-06-20 15:35:59.662	error	by controller[0]: host: 'undefined',
    Caught	2018-06-20 15:35:59.661	error	by controller[0]: hostname: 'undefined',
    Caught	2018-06-20 15:35:59.660	error	by controller[0]: syscall: 'getaddrinfo',
    Caught	2018-06-20 15:35:59.660	error	by controller[0]: errno: 'ENOTFOUND',
    Caught	2018-06-20 15:35:59.660	error	by controller[0]: code: 'ENOTFOUND',
    Caught	2018-06-20 15:35:59.659	error	by controller[0]: at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:76:26)
    Caught	2018-06-20 15:35:59.658	error	by controller[0]: at errnoException (dns.js:28:10)
    Caught	2018-06-20 15:35:59.649	error	by controller[0]: { Error: getaddrinfo ENOTFOUND undefined undefined:8087
    javascript.0	2018-06-20 15:35:59.572	error	uncaught exception: getaddrinfo ENOTFOUND undefined undefined:8087
    HW:NUC (16 GB Ram)
    OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
    • apollon77A Offline
      Scheinbar macht eines deiner JavaScript Skripte einen DNS lookup oder sowas und der schlägt fehl. Ein Fehler den du in deinem Skript abfangen solltest.
      • AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        Muss nicht zwangsläufig ein DNS Lookup sein. HTTP requests (z.B. mit dem "request"-Modul) greifen intern darauf zurück.
        • ? Offline
          Hmmm….
          sieht wie schon beschrieben nach einem DNS Fehler aus.
          Wenn ein dedizierter DNS Server hier verwendet wird, sollte der Endknoten auch in der Reverse Lookup Zone sein.
          UX Systeme sind das etwas empfindlich.
          Wäre hilfreich zu wissen ob das Script die IP Adresse, den Netbios oder den FQDN des Endknotens verwendet....
          Bester Test einfach vom Host wo IoBroker läuft ein Ping und Nslookup auf das Ziel zu machen.
          My 2 Cents
          Equilora aka Harald
          • StabilostickS Offline
            Stabilostick
            Hat das was mit Amazon Dash-Buttons zu tun?
              Marty56
              Ich mache explizt keinen DNS Lookup.
              Aber vielleicht liegt es an dem Zugriff auf eine Website via HTTP, die ich anschließend parse.
              Danke fürs Feedback.
              HW:NUC (16 GB Ram)
                Marty56
                Ich habe noch eine andere Fehlermeldung, die ich zwar dem Telegram Adapter zuordnen kann, bei der ich aber auch keine Idee habe, was ich tun kann.
                telegram.0	2018-06-21 03:36:15.522	error
                <center>nginx/1.12.2</center>
                <center>
                # 502 Bad Gateway
                </center>
                telegram.0	2018-06-21 03:36:15.522	error	<title>502 Bad Gateway</title>
                telegram.0	2018-06-21 03:36:15.522	error	polling_error:EPARSE, EPARSE: Error parsing response:
                DIese Fehlermeldung kommt immer einmal am Tag in der Nacht.
                HW:NUC (16 GB Ram)
