  4. Jqui-mfd Licht Anzeige: Frage
2 Beiträge 2 Kommentatoren 790 Aufrufe
    stephan2k
    ich setze u.a. jqui-mfd ein um Lichter an / aus zu schalten, bzw. um mir den Status anzeigen zu lassen.
    Leider habe ich ein Problem und brauch eure Hilfe:
    Die Farbe der Anzeige soll weiß sein, wenn das Licht nicht an ist. Wenn es an ist, soll es gelb sein.
    Aktuell wird das Icon nicht angezeigt, wenn es aus ist. Gelb ist es, wenn es an ist.
    Kann mir hier jemand helfen? Was muss ich ändern, damit es weiß angezeigt wird?
    [{"tpl":"tplMfdLightCtrl","data":{"oid":"hue.0.mcclaneLight.Steinwand.on","g_fixed":false,"g_visibility":false,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":"==","visibility-val":1,"visibility-groups-action":"hide","asButton":false,"signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"iconColor10":"yellow","iconColor9":"yellow","iconColor8":"yellow","iconColor7":"yellow","iconColor6":"yellow","iconColor5":"yellow","iconColor4":"yellow","iconColor3":"yellow","iconColor2":"yellow","iconColor1":"yellow","iconColor0":"white","invert_icon":false},"style":{"left":"119px","top":"113px","width":"60px","height":"60px"},"widgetSet":"jqui-mfd"}]
    • coyoteC Offline
      coyoteC Offline
      coyote
      Hey,
      das kann so nicht funktionieren, da du den Hue Datenpunkt "*.on" verwendest. Dieser gibt "true/false" zurück, also funktionieren deine Prozentangaben vom svg nicht.
      Ist die Frage wie du es jetzt haben willst. Schätze du wolltest das Icon gelb haben, sobald deine Lampe >=1% (z.B. Helligkeit) ausgibt.
      Der "on" Datenpunkt wird true wenn die Hue Lampe eingeschaltet wird, egal welche Helligkeit. Also könntest du bei dem Datenpunkt bleiben und nimmst ein anderes widget mit dem du nur "true/false" abfragst oder du nimmst einen anderen Datenpunkt z.B. *.level oder *.bri, dann kannst du bei dem widget bleiben.
