  4. Rolladen/Beschattung Blockly
    5.8k
3 Beiträge 3 Kommentatoren 974 Aufrufe
  • totocotonioT Offline
    totocotonio
    ich habe mir folgendes einfaches Blockly zusammen geklickt.
    Es funktioniert aber nicht.
    Kann mir einer der Spezis vielleicht sagen wo ich da meinen Fehler eingebaut habe.
    Hier der export
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="comment" id="025W,vKkAw^{oaLn#?{k" x="-837" y="-412"><field name="COMMENT">Kommentar</field>
        <next><block type="on" id="[A/^r*g:1xbUF4OHUqj!"><field name="OID">weatherunderground.0.current.temp_c</field>
            <statement name="STATEMENT"><block type="controls_if" id="3drE2#7[?4(6%Xl(F)w{"><value name="IF0"><block type="time_compare" id="p9/4|1%s,,A;/BQ,-#:f"><mutation end_time="true"></mutation>
                    <field name="OPTION">between</field>
                    <field name="START_TIME">10:00</field>
                    <field name="END_TIME">20:00</field></block></value>
                <statement name="DO0"><block type="controls_if" id="h|_NPlK@BJ=P!NR|r:7?"><mutation elseif="1"></mutation>
                    <value name="IF0"><block type="logic_operation" id="a.h`?p4?W/ZJii{yjRh+"><field name="OP">AND</field>
                        <value name="A"><block type="logic_compare" id="_5H;+jU5l.Au2K(7t=Wa"><field name="OP">GT</field>
                            <value name="A"><block type="get_value" id="r2V7h0ipiGV;W(~TB+12"><field name="ATTR">val</field>
                                <field name="OID">weatherunderground.0.current.temp_c</field></block></value>
                            <value name="B"><block type="math_number" id="f;T3}6D]Xg/6z260.`fg"><field name="NUM">23</field></block></value></block></value>
                        <value name="B"><block type="logic_compare" id="[8q+*CXWXyNrL-.rf#=H"><field name="OP">GT</field>
                            <value name="A"><block type="get_value" id="Gu88%e*lsH7=Q;Y.1j@w"><field name="ATTR">val</field>
                                <field name="OID">hm-rpc.0.NEQ1296140.1.BRIGHTNESS</field></block></value>
                            <value name="B"><block type="math_number" id="#KxsJQ{}yh1V9@Zyo2Vm"><field name="NUM">200</field></block></value></block></value></block></value>
                    <statement name="DO0"><block type="controls_if" id="7`4r`m*8qqH~w~4#QUcG"><value name="IF0"><block type="logic_compare" id=",`.,.AiYaFHV[0~WOCMc"><field name="OP">EQ</field>
                            <value name="A"><block type="get_value" id="CMXy.LP)L^.q*v!6YT=6"><field name="ATTR">val</field>
                                <field name="OID">hm-rpc.0.OEQ0429874.1.STATE</field></block></value>
                            <value name="B"><block type="logic_boolean" id="MUtE)Y_XPETBvb+7}vq1"><field name="BOOL">FALSE</field></block></value></block></value>
                        <statement name="DO0"><block type="control" id="iU@~#H2;bcdlY?QvL.zW"><mutation delay_input="false"></mutation>
                            <field name="OID">hm-rpc.0.OEQ0259191.1.LEVEL</field>
                            <value name="VALUE"><block type="math_number" id="NvWqI9{*hSbI1n)KL6-O"><field name="NUM">70</field></block></value>
                            <next><block type="control" id="XfjVm;;_1E[KES{?5X=u"><mutation delay_input="false"></mutation>
                                <field name="OID">hm-rpc.0.OEQ0259579.1.LEVEL</field>
                                <value name="VALUE"><block type="math_number" id="[ai%|D3-NYC/Jd/Y^DK2"><field name="NUM">50</field></block></value>
                                <next><block type="control" id="V]@n=;yFN7a}DGZ%cW~*"><mutation delay_input="false"></mutation>
                                    <field name="OID">hm-rpc.0.OEQ0050030.1.LEVEL</field>
                                    <value name="VALUE"><block type="math_number" id="ryu24Si)|b~Je*]^nEP9"><field name="NUM">50</field></block></value></block></next></block></next></block></statement>
                        <next><block type="debug" id="c;B/43|A-AlvB+wjwUBQ"><field name="Severity">debug</field>
                            <value name="TEXT"><shadow type="text" id="67^Q=Kd)fij7+o3m0(Rj"><field name="TEXT">Beschattung</field></shadow></value></block></next></block></statement>
                    <value name="IF1"><block type="logic_operation" id="#)WrPdx|S5eU||f8*;oW"><field name="OP">AND</field>
                        <value name="A"><block type="logic_compare" id="CP|Rw%pNYH2USxJNN+Xv"><field name="OP">LTE</field>
                            <value name="A"><block type="get_value" id="}PHqqS!AGZndv2+LrgZn"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="4d/|k5M/gMH2j8TORCX4"><field name="NUM">23</field></block></value></block></value>
                        <value name="B"><block type="logic_compare" id="uYkP3l;t~jhh9`a;chw!"><field name="OP">LT</field>
                            <value name="A"><block type="get_value" id="%je[;-7K~=s#oTV*+dYm"><field name="ATTR">val</field>
                            <value name="B"><block type="math_number" id="RU(0%J;QuQa)+6{@RMTT"><field name="NUM">210</field></block></value></block></value></block></value>
                    <statement name="DO1"><block type="control" id="?:(?jC@rtT;t1){oI[2|"><mutation delay_input="false"></mutation>
                        <value name="VALUE"><block type="math_number" id="y%/y_!2m}M!fSr=Lek+J"><field name="NUM">100</field></block></value>
                        <next><block type="control" id="t:nPDB`(UW1*JK[LZZ^;"><mutation delay_input="false"></mutation>
                            <value name="VALUE"><block type="math_number" id="#kpwOsrwW;N)NF.{Rf0B"><field name="NUM">100</field></block></value>
                            <next><block type="control" id="]UAA`SjHrzIrapR]}gb~"><mutation delay_input="false"></mutation>
                                <value name="VALUE"><block type="math_number" id="^E9nzjSRk6-Vho8*E%YV"><field name="NUM">100</field></block></value></block></next></block></next></block></statement></block></statement></block></statement></block></next></block></xml>
    Gruß Totocotonio
    Bin noch Anfänger in Sachen IO-Broker und lerne gerne dazu. :P
    • AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      Auf den ersten Blick sehe ich kein Problem. Füg dir am besten innerhalb jeder Bedingung mal einen Debug-Block ein, damit du siehst, was aufgerufen wird und was nicht. Eventuell erkennst du dann schon dein Problem.
        Ralf.Grum
        Ich bin noch anfänger oder Leihe,
        Aber hebt das „sonst falls „nicht den ersten Block komplett aus für die Urzeit?
        Gruß Ralf
