  4. Homekit yahka kann nicht installiert werden
9 Beiträge 4 Kommentatoren 941 Aufrufe
    saeft_2003
    immer wenn ich verusche homekit zu installieren bricht er mit dem code 13 ab. Könnt ihr mir vielleicht weiterhelfen?
    ! obroker 2018-04-16 20:46:44.557 info exit 13
    ! iobroker 2018-04-16 20:46:44.542 error host.raspberrypi Cannot install yahka
    ! iobroker 2018-04-16 20:46:44.539 info host.raspberrypi install adapter yahka
    ! iobroker 2018-04-16 20:46:44.496 info npm ERR! code 1
    ! iobroker 2018-04-16 20:46:44.496 info Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! iobroker 2018-04-16 20:46:44.494 info npm ERR!
    ! iobroker 2018-04-16 20:46:44.484 info
    ! iobroker 2018-04-16 20:46:44.355 info npm ERR! There is likely additional logging output above.
    ! iobroker 2018-04-16 20:46:44.353 info npm owner ls mdns
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR!
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! Or if that isn't available, you can get their info via:
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! npm bugs mdns
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! You can get information on how to open an issue for this project with:
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! node-gyp rebuild
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! Tell the author that this fails on your system:
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! not with npm itself.
    ! iobroker 2018-04-16 20:46:44.350 info npm ERR! If you do, this is most likely a problem with the mdns package,
    ! iobroker 2018-04-16 20:46:44.350 info ERR! Failed at the mdns@2.3.4 install script 'node-gyp rebuild'.npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! iobroker 2018-04-16 20:46:44.343 info npm
    ! iobroker 2018-04-16 20:46:44.343 info npm ERR!
    ! iobroker 2018-04-16 20:46:44.343 info npm ERR! Exit status 1
    ! iobroker 2018-04-16 20:46:44.343 info npm ERR! mdns@2.3.4 install: node-gyp rebuild
    ! iobroker 2018-04-16 20:46:44.343 info npm ERR! npm v3.10.10npm ERR! code ELIFECYCLE
    ! iobroker 2018-04-16 20:46:44.337 info npm ERR! node v6.13.0
    ! iobroker 2018-04-16 20:46:44.326 info ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.yahka" "–production" "--save" "--prefix" "/opt/iobroker"
    ! iobroker 2018-04-16 20:46:44.324 info npm
    ! iobroker 2018-04-16 20:46:44.316 info npm WARN optional SKIPPING OPTIONAL DEPENDENCY: not found: git
    ! iobroker 2018-04-16 20:46:44.309 info WARN optional SKIPPING OPTIONAL DEPENDENCY: acme-v2@git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master (node_modules/greenlock/node_modules/acme-v2):
    ! iobroker 2018-04-16 20:46:44.307 info npm
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! not ok
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! node-gyp -v v3.4.0
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! node -v v6.13.0
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! iobroker 2018-04-16 20:46:29.837 info gyp ERR! System Linux 4.9.59-v7+
    ! iobroker 2018-04-16 20:46:29.837 info stack at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    ! iobroker 2018-04-16 20:46:29.827 info gyp ERR!
    ! iobroker 2018-04-16 20:46:29.824 info ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:106:13)
    ! iobroker 2018-04-16 20:46:29.815 info Error: make failed with exit code: 2gyp
    ! iobroker 2018-04-16 20:46:29.812 info stack
    ! iobroker 2018-04-16 20:46:29.810 info ERR!
    ! iobroker 2018-04-16 20:46:29.808 info gyp
    ! iobroker 2018-04-16 20:46:29.796 info
    ! iobroker 2018-04-16 20:46:29.784 info build error
    ! iobroker 2018-04-16 20:46:29.780 info ERR!
    ! iobroker 2018-04-16 20:46:29.777 info
    ! iobroker 2018-04-16 20:46:29.769 info gyp
    ! iobroker 2018-04-16 20:46:29.752 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    ! iobroker 2018-04-16 20:46:28.091 info compilation terminated.
    ! iobroker 2018-04-16 20:46:28.091 info ^
    ! iobroker 2018-04-16 20:46:28.091 info #include
    ! iobroker 2018-04-16 20:46:28.091 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    ! iobroker 2018-04-16 20:45:55.629 info ERR! git clone –template=/root/.npm/_git-remotes/_templates --mirror https://git.coolaj86.com/coolaj86/acme-v2.js.git /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-maste
    ! iobroker 2018-04-16 20:45:55.626 info git clone --template=/root/.npm/_git-remotes/_templates --mirror https://git.coolaj86.com/coolaj86/acme-v2.js.git /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-master-ae
    ! iobroker 2018-04-16 20:45:55.623 info ERR!
    ! iobroker 2018-04-16 20:45:55.621 info
    ! iobroker 2018-04-16 20:45:55.620 info npm
    ! iobroker 2018-04-16 20:45:55.565 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! iobroker 2018-04-16 20:45:55.565 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! iobroker 2018-04-16 20:45:55.565 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! iobroker 2018-04-16 20:45:55.565 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! iobroker 2018-04-16 20:45:55.565 info addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master resetting remote /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-master-ae01e5d2 because o
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! iobroker 2018-04-16 20:45:55.563 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! iobroker 2018-04-16 20:45:55.563 info addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! iobroker 2018-04-16 20:45:55.555 info
    ! iobroker 2018-04-16 20:45:55.552 info WARN
    ! iobroker 2018-04-16 20:45:55.550 info
    ! iobroker 2018-04-16 20:45:55.546 info npm
    ! iobroker 2018-04-16 20:45:18.732 info npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! iobroker 2018-04-16 20:45:18.729 info NPM version: 3.10.10
    ! iobroker 2018-04-16 20:45:11.075 info host.raspberrypi install adapter yahka
    ! iobroker 2018-04-16 20:45:11.036 info npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! iobroker 2018-04-16 20:45:11.034 info
    ! iobroker 2018-04-16 20:45:10.795 info npm ERR! There is likely additional logging output above.
    ! iobroker 2018-04-16 20:45:10.795 info npm ERR! npm owner ls mdns
    ! iobroker 2018-04-16 20:45:10.795 info ERR! npm bugs mdnsnpm ERR! Or if that isn't available, you can get their info via:
    ! iobroker 2018-04-16 20:45:10.793 info npm
    ! iobroker 2018-04-16 20:45:10.793 info npm ERR! You can get information on how to open an issue for this project with:
    ! iobroker 2018-04-16 20:45:10.793 info npm ERR! node-gyp rebuild
    ! iobroker 2018-04-16 20:45:10.793 info npm ERR! Tell the author that this fails on your system:
    ! iobroker 2018-04-16 20:45:10.793 info ERR! If you do, this is most likely a problem with the mdns package,npm ERR! not with npm itself.
    ! iobroker 2018-04-16 20:45:10.791 info
    ! iobroker 2018-04-16 20:45:10.789 info npm
    ! iobroker 2018-04-16 20:45:10.789 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! iobroker 2018-04-16 20:45:10.789 info npm ERR! Failed at the mdns@2.3.4 install script 'node-gyp rebuild'.
    ! iobroker 2018-04-16 20:45:10.789 info npm ERR! Exit status 1
    ! iobroker 2018-04-16 20:45:10.789 info npm ERR! mdns@2.3.4 install: node-gyp rebuild
    ! iobroker 2018-04-16 20:45:10.789 info npm ERR! code ELIFECYCLE
    ! iobroker 2018-04-16 20:45:10.786 info npm ERR! npm v3.10.10
    ! iobroker 2018-04-16 20:45:10.786 info ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--save" "--prefix" "/opt/iobroker"npm ERR! node v6.13.0
    ! iobroker 2018-04-16 20:45:10.784 info npm
    ! iobroker 2018-04-16 20:45:10.781 info ERR! Linux 4.9.59-v7+
    ! iobroker 2018-04-16 20:45:10.780 info npm
    ! iobroker 2018-04-16 20:45:10.774 info WARN optional SKIPPING OPTIONAL DEPENDENCY: acme-v2@git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master (node_modules/greenlock/node_modules/acme-v2):npm WARN optional SKIPPING OPTIONAL DEPEN
    ! iobroker 2018-04-16 20:45:10.772 info npm
    ! iobroker 2018-04-16 20:44:55.209 info gyp ERR! not ok
    ! iobroker 2018-04-16 20:44:55.209 info gyp ERR! node-gyp -v v3.4.0
    ! iobroker 2018-04-16 20:44:55.209 info gyp ERR! node -v v6.13.0
    ! iobroker 2018-04-16 20:44:55.209 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
    ! iobroker 2018-04-16 20:44:55.209 info gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    ! iobroker 2018-04-16 20:44:55.209 info ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)gyp ERR! System Linux 4.9.59-v7+
    ! iobroker 2018-04-16 20:44:55.202 info stack at ChildProcess.emit (events.js:191:7)gyp
    ! iobroker 2018-04-16 20:44:55.199 info ERR!
    ! iobroker 2018-04-16 20:44:55.196 info stack at emitTwo (events.js:106:13)gyp
    ! iobroker 2018-04-16 20:44:55.194 info stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR!
    ! iobroker 2018-04-16 20:44:55.190 info ERR!
    ! iobroker 2018-04-16 20:44:55.188 info stack Error: make failed with exit code: 2gyp
    ! iobroker 2018-04-16 20:44:55.186 info ERR!
    ! iobroker 2018-04-16 20:44:55.183 info gyp
    ! iobroker 2018-04-16 20:44:55.168 info ERR! build error
    ! iobroker 2018-04-16 20:44:55.162 info
    ! iobroker 2018-04-16 20:44:55.155 info gyp
    ! iobroker 2018-04-16 20:44:55.146 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    ! iobroker 2018-04-16 20:44:53.963 info compilation terminated.
    ! iobroker 2018-04-16 20:44:53.963 info ^
    ! iobroker 2018-04-16 20:44:53.963 info #include
    ! iobroker 2018-04-16 20:44:53.963 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    ! iobroker 2018-04-16 20:43:41.844 info localhost.daplie.me-certificates@1.3.5: this package has been deprecated
    ! iobroker 2018-04-16 20:43:41.840 info WARN deprecated
    ! iobroker 2018-04-16 20:43:41.839 info npm
    ! iobroker 2018-04-16 20:43:41.720 info ERR! git clone –template=/root/.npm/_git-remotes/_templates --mirror https://git.coolaj86.com/coolaj86/acme-v2.js.git /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-mast
    ! iobroker 2018-04-16 20:43:41.718 info npm
    ! iobroker 2018-04-16 20:43:41.611 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! iobroker 2018-04-16 20:43:41.611 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! iobroker 2018-04-16 20:43:41.611 info at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! iobroker 2018-04-16 20:43:41.604 info npm WARN addRemoteGit
    ! iobroker 2018-04-16 20:43:41.604 info at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master resetting remote /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-master-ae01e5d2 because o
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! iobroker 2018-04-16 20:43:41.597 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! iobroker 2018-04-16 20:43:41.597 info addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! iobroker 2018-04-16 20:43:41.594 info WARN
    ! iobroker 2018-04-16 20:43:41.590 info Error: not found: gitnpm
    ! iobroker 2018-04-16 20:43:41.588 info WARN addRemoteGit
    ! iobroker 2018-04-16 20:43:41.585 info npm
    ! iobroker 2018-04-16 20:43:03.793 info npm install iobroker.yahka --production --save --prefix "/opt/iobroker" (System call)
    ! iobroker 2018-04-16 20:43:03.791 info NPM version: 3.10.10
    ! iobroker 2018-04-16 20:43:02.422 info host.raspberrypi install adapter yahka
    ! iobroker 2018-04-16 20:43:02.342 info npm ERR! code 1
    ! iobroker 2018-04-16 20:43:02.342 info npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
    ! iobroker 2018-04-16 20:43:02.339 info
    ! iobroker 2018-04-16 20:43:02.219 info There is likely additional logging output above.
    ! iobroker 2018-04-16 20:43:02.217 info npm owner ls mdnsnpm ERR!
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR!
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! Or if that isn't available, you can get their info via:
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! npm bugs mdns
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! You can get information on how to open an issue for this project with:
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! node-gyp rebuild
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! Tell the author that this fails on your system:
    ! iobroker 2018-04-16 20:43:02.211 info npm ERR! If you do, this is most likely a problem with the mdns package,npm ERR! not with npm itself.
    ! iobroker 2018-04-16 20:43:02.208 info npm ERR! Make sure you have the latest version of node.js and npm installed.
    ! iobroker 2018-04-16 20:43:02.208 info npm ERR! Failed at the mdns@2.3.4 install script 'node-gyp rebuild'.
    ! iobroker 2018-04-16 20:43:02.208 info npm ERR! Exit status 1
    ! iobroker 2018-04-16 20:43:02.208 info npm ERR! mdns@2.3.4 install: node-gyp rebuild
    ! iobroker 2018-04-16 20:43:02.208 info ERR! code ELIFECYCLE
    ! iobroker 2018-04-16 20:43:02.205 info npm
    ! iobroker 2018-04-16 20:43:02.205 info ERR! node v6.13.0npm ERR! npm v3.10.10
    ! iobroker 2018-04-16 20:43:02.203 info npm
    ! iobroker 2018-04-16 20:43:02.195 info ERR! Linux 4.9.59-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.yahka" "--production" "--save" "--prefix" "/opt/iobroker"
    ! iobroker 2018-04-16 20:43:02.193 info npm
    ! iobroker 2018-04-16 20:43:02.187 info WARN optional SKIPPING OPTIONAL DEPENDENCY: acme-v2@git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master (node_modules/greenlock/node_modules/acme-v2):npm WARN optional SKIPPING OPTIONAL DEPEN
    ! iobroker 2018-04-16 20:43:02.185 info npm
    ! iobroker 2018-04-16 20:42:46.968 info gyp ERR! not ok
    ! iobroker 2018-04-16 20:42:46.968 info gyp ERR! node-gyp -v v3.4.0
    ! iobroker 2018-04-16 20:42:46.968 info gyp ERR! node -v v6.13.0
    ! iobroker 2018-04-16 20:42:46.968 info command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdns
    ! iobroker 2018-04-16 20:42:46.958 info ERR!
    ! iobroker 2018-04-16 20:42:46.957 info gyp
    ! iobroker 2018-04-16 20:42:46.955 info System Linux 4.9.59-v7+
    ! iobroker 2018-04-16 20:42:46.954 info gyp ERR!
    ! iobroker 2018-04-16 20:42:46.952 info at ChildProcess.emit (events.js:191:7)gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    ! iobroker 2018-04-16 20:42:46.946 info stack
    ! iobroker 2018-04-16 20:42:46.941 info ERR!
    ! iobroker 2018-04-16 20:42:46.940 info ERR! stack at emitTwo (events.js:106:13)gyp
    ! iobroker 2018-04-16 20:42:46.932 info gyp
    ! iobroker 2018-04-16 20:42:46.932 info ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    ! iobroker 2018-04-16 20:42:46.925 info gyp
    ! iobroker 2018-04-16 20:42:46.915 info ERR! build error
    ! iobroker 2018-04-16 20:42:46.908 info gyp
    ! iobroker 2018-04-16 20:42:46.906 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
    ! iobroker 2018-04-16 20:42:45.905 info compilation terminated.
    ! iobroker 2018-04-16 20:42:45.903 info ^
    ! iobroker 2018-04-16 20:42:45.903 info #include
    ! iobroker 2018-04-16 20:42:45.903 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
    ! iobroker 2018-04-16 20:41:54.981 info npm ERR! git clone –template=/root/.npm/_git-remotes/_templates --mirror https://git.coolaj86.com/coolaj86/acme-v2.js.git /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-m
    ! iobroker 2018-04-16 20:41:54.893 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' }
    ! iobroker 2018-04-16 20:41:54.893 info WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/acce
    ! iobroker 2018-04-16 20:41:54.888 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16npm
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit git+https://git.coolaj86.com/coolaj86/acme-v2.js.git#master resetting remote /root/.npm/_git-remotes/git-https-git-coolaj86-com-coolaj86-acme-v2-js-git-master-ae01e5d2 because o
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15)
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    ! iobroker 2018-04-16 20:41:54.878 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    ! iobroker 2018-04-16 20:41:54.878 info WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29)npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16
    ! iobroker 2018-04-16 20:41:54.871 info WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19)npm
    ! iobroker 2018-04-16 20:41:54.862 info npm
    ! iobroker 2018-04-16 20:41:54.862 info WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12)
    ! iobroker 2018-04-16 20:41:54.853 info npm
    • eumatsE Offline
      eumatsE Offline
      eumats
      Schon mal hier geschaut: https://github.com/jensweigele/ioBroker … leshooting
        saeft_2003
        Ja auf der seite war ich schon. Den Befehl
        sudo apt-get install libavahi-compat-libdnssd-dev
        habe ich ausgeführt aber geändert hat es nichts. Was unter troubelshooting steht, da habe ich mich noch nicht rangewagt…
        • apollon77A Offline
          git musst Du auch noch installieren (apt-get install git)
            saeft_2003
            Apt-get install git habe ich gemacht, leider kam noch der gleiche fehler…
            Jetzt habe ich node.js aktualisiert von 6.13 auf 8.11 und jetzt kommt egal welchen adapter ich installieren will:
            Fertig mit Fehler!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            Da das nicht so aussagekräftig ist wollte ich euch fragen ob ich etwas falsch gemacht habe?
              @saeft_2003:
              Jetzt habe ich node.js aktualisiert von 6.13 auf 8.11 `
              und nicht auf die mitgelieferte npm-Version geachtet.
              Wahrscheinlich 5.6.0 und muss >=5.7.1 sein, aktuell 5.8.0
              Rainer
                saeft_2003
                @Homoran:
                @saeft_2003:
                Rainer `
                Hallo Rainer,
                das hab ich jetzt gemacht und jetzt versucht er yahka wieder zu installieren es kommt aber wieder der Code 13. Die Einträge im Logbuch sehen aber anders aus.
                ! iobroker 2018-04-18 16:13:55.768 info exit 13
                ! iobroker 2018-04-18 16:13:55.759 error host.raspberrypi Cannot install yahka
                ! iobroker 2018-04-18 16:13:55.757 info host.raspberrypi install adapter yahka
                ! iobroker 2018-04-18 16:13:55.728 info npm ERR! /root/.npm/_logs/2018-04-18T14_13_55_674Z-debug.log
                ! iobroker 2018-04-18 16:13:55.728 info npm ERR! A complete log of this run can be found in:
                ! iobroker 2018-04-18 16:13:55.647 info npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                ! iobroker 2018-04-18 16:13:55.647 info npm ERR! Failed at the mdns@2.3.4 install script.
                ! iobroker 2018-04-18 16:13:55.647 info npm ERR! mdns@2.3.4 install: node-gyp rebuildnpm ERR! Exit status 1
                ! iobroker 2018-04-18 16:13:55.641 info npm ERR! errno 1
                ! iobroker 2018-04-18 16:13:55.639 info npm ERR! code ELIFECYCLE
                ! iobroker 2018-04-18 16:13:49.229 info node-gyp -v v3.6.2gyp ERR! not ok
                ! iobroker 2018-04-18 16:13:49.226 info gyp ERR!
                ! iobroker 2018-04-18 16:13:49.226 info gyp ERR! node -v v8.11.1
                ! iobroker 2018-04-18 16:13:49.226 info ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/mdns
                ! iobroker 2018-04-18 16:13:49.225 info gyp ERR! System Linux 4.9.59-v7+gyp
                ! iobroker 2018-04-18 16:13:49.223 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                ! iobroker 2018-04-18 16:13:49.223 info gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                ! iobroker 2018-04-18 16:13:49.223 info gyp ERR! stack at emitTwo (events.js:126:13)
                ! iobroker 2018-04-18 16:13:49.223 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
                ! iobroker 2018-04-18 16:13:49.219 info ERR! build error
                ! iobroker 2018-04-18 16:13:49.218 info
                ! iobroker 2018-04-18 16:13:49.216 info gyp
                ! iobroker 2018-04-18 16:13:49.210 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                ! iobroker 2018-04-18 16:13:48.854 info compilation terminated.
                ! iobroker 2018-04-18 16:13:48.854 info ^
                ! iobroker 2018-04-18 16:13:48.854 info #include
                ! iobroker 2018-04-18 16:13:48.854 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                ! iobroker 2018-04-18 16:12:52.557 info NPM version: 5.8.0npm install iobroker.yahka –production --save --prefix "/opt/iobroker" (System call)
                ! iobroker 2018-04-18 16:12:51.354 info host.raspberrypi install adapter yahka
                ! iobroker 2018-04-18 16:12:51.326 info npm ERR! /root/.npm/_logs/2018-04-18T14_12_50_982Z-debug.log
                ! iobroker 2018-04-18 16:12:51.326 info npm ERR! A complete log of this run can be found in:
                ! iobroker 2018-04-18 16:12:50.953 info npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                ! iobroker 2018-04-18 16:12:50.953 info npm ERR! Failed at the mdns@2.3.4 install script.
                ! iobroker 2018-04-18 16:12:50.953 info npm ERR! mdns@2.3.4 install: node-gyp rebuildnpm ERR! Exit status 1
                ! iobroker 2018-04-18 16:12:50.945 info npm ERR! errno 1
                ! iobroker 2018-04-18 16:12:50.943 info npm ERR! code ELIFECYCLE
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! not ok
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! node-gyp -v v3.6.2
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! node -v v8.11.1
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! System Linux 4.9.59-v7+
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! stack at emitTwo (events.js:126:13)
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
                ! iobroker 2018-04-18 16:12:44.611 info gyp ERR! stack Error: make failed with exit code: 2
                ! iobroker 2018-04-18 16:12:44.611 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1gyp ERR! build error
                ! iobroker 2018-04-18 16:12:41.793 info compilation terminated.
                ! iobroker 2018-04-18 16:12:41.793 info ^
                ! iobroker 2018-04-18 16:12:41.793 info #include
                ! iobroker 2018-04-18 16:12:41.793 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                ! iobroker 2018-04-18 16:11:42.903 info npm install iobroker.yahka –production --save --prefix "/opt/iobroker" (System call)
                ! iobroker 2018-04-18 16:11:42.902 info NPM version: 5.8.0
                ! iobroker 2018-04-18 16:11:40.400 info host.raspberrypi install adapter yahka
                ! iobroker 2018-04-18 16:11:40.334 info npm ERR! A complete log of this run can be found in:npm ERR! /root/.npm/_logs/2018-04-18T14_11_40_240Z-debug.log
                ! iobroker 2018-04-18 16:11:40.333 info
                ! iobroker 2018-04-18 16:11:40.217 info Failed at the mdns@2.3.4 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
                ! iobroker 2018-04-18 16:11:40.211 info npm ERR!
                ! iobroker 2018-04-18 16:11:40.211 info npm ERR! Exit status 1
                ! iobroker 2018-04-18 16:11:40.211 info npm ERR! mdns@2.3.4 install: node-gyp rebuild
                ! iobroker 2018-04-18 16:11:40.211 info npm ERR! code ELIFECYCLEnpm ERR! errno 1
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! not ok
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! node-gyp -v v3.6.2
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! node -v v8.11.1
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! cwd /opt/iobroker/node_modules/mdns
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! System Linux 4.9.59-v7+
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! stack at ChildProcess.emit (events.js:214:7)
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! stack at emitTwo (events.js:126:13)
                ! iobroker 2018-04-18 16:11:33.551 info gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/npm-lifecycle/node_modules/node-gyp/lib/build.js:258:23)
                ! iobroker 2018-04-18 16:11:33.551 info ERR! build error gyp ERR! stack Error: make failed with exit code: 2
                ! iobroker 2018-04-18 16:11:33.535 info gyp
                ! iobroker 2018-04-18 16:11:33.525 info make: *** [Release/obj.target/dns_sd_bindings/src/dns_sd.o] Fehler 1
                ! iobroker 2018-04-18 16:11:32.348 info compilation terminated.
                ! iobroker 2018-04-18 16:11:32.348 info ^
                ! iobroker 2018-04-18 16:11:32.348 info #include
                ! iobroker 2018-04-18 16:11:32.348 info In file included from ../src/dns_sd.cpp:1:0:../src/mdns.hpp:32:20: fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden
                ! iobroker 2018-04-18 16:10:29.836 info npm install iobroker.yahka –production --save --prefix "/opt/iobroker" (System call)
                ! iobroker 2018-04-18 16:10:28.862 info NPM version: 5.8.0
                ! iobroker 2018-04-18 16:10:26.041 info add yahka
                Kannst du mir sagen an was es liegt?
                  @saeft_2003:
                  Kannst du mir sagen an was es liegt? `
                  Leider nein, da kenne och mich zu wenig aus.
                  Aber ihm fehlt etwas.
                  @saeft_2003:
                  fatal error: dns_sd.h: Datei oder Verzeichnis nicht gefunden `
                  Gruß Rainer
                  • eumatsE Offline
                    eumatsE Offline
                    eumats
                    Google hat bei dem Fehler (dns_sd.h) folgendes ausgespuckt.
                    sudo apt-get install build-essential libavahi-compat-libdnssd-dev git
