  4. RING Adapter Verbindet sich nicht mehr
    5.4k
41 Beiträge 5 Kommentatoren 2.2k Aufrufe 4 Beobachtet
  • M michihorn
    Hallo ich nutze seit Jahren den RING Adapter in allen Versionen, aktuell 3.3.0. Der kontaktete bis heute auch mein Ring Konto einwandfrei. Nun gibt es im Log folgende Fehlermeldungen:
    ring.0
    Zeit
    silly
    Nachricht
    ring.0
    2023-05-16 20:12:49.954	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ring.0
    2023-05-16 20:12:49.953	info	terminating
    ring.0
    2023-05-16 20:12:49.946	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.946	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:49.945	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.945	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:49.940	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.939	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:49.938	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.938	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:49.927	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.927	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:49.926	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:49.925	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:46.960	info	Recieved new Refresh Token. Will use the new one until the token in config gets changed
    ring.0
    2023-05-16 20:12:46.482	info	Initializing Api Client
    ring.0
    2023-05-16 20:12:46.397	info	starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.ring, node: v18.12.0, js-controller: 4.0.24
    ring.0
    2023-05-16 20:12:10.097	warn	Error Updating State cocoa_96839166.History.kind to motion: DB closed
    ring.0
    2023-05-16 20:12:10.096	warn	Error Updating State cocoa_96839166.History.history_url to xxxxxd1: DB closed
    ring.0
    2023-05-16 20:12:10.095	warn	Error Updating State cocoa_96839166.History.created_at to 2023-05-16T12:12:52Z: DB closed
    ring.0
    2023-05-16 20:12:10.093	warn	Error Updating State doorbell_90474299.History.kind to motion: DB closed
    ring.0
    2023-05-16 20:12:10.091	warn	Error Updating State doorbell_90474299.History.history_url to https://fxxxxxxxxxxf: DB closed
    ring.0
    2023-05-16 20:12:10.090	warn	Error Updating State doorbell_90474299.History.created_at to 2023-05-16T17:47:55Z: DB closed
    ring.0
    2023-05-16 20:12:10.089	warn	Error Updating State doorbell_21502358.History.kind to motion: DB closed
    ring.0
    2023-05-16 20:12:10.066	warn	Error Updating State doorbell_21502358.History.history_url to https://xxxxxxxxx: DB closed
    ring.0
    2023-05-16 20:12:10.065	warn	Error Updating State doorbell_21502358.History.created_at to 2023-05-16T04:31:10Z: DB closed
    ring.0
    2023-05-16 20:12:10.059	warn	Error Updating State cocoa_96839166.Events.motion to false: DB closed
    ring.0
    2023-05-16 20:12:10.045	warn	get state error: Connection is closed.
    ring.0
    2023-05-16 20:12:10.044	warn	Could not perform strict object check of state ring.0.cocoa_96839166.Events.motion: DB closed
    ring.0
    2023-05-16 20:12:09.970	warn	Error Updating State doorbell_90474299.Events.motion to false: DB closed
    ring.0
    2023-05-16 20:12:09.965	warn	Error Updating State doorbell_21502358.Events.motion to false: DB closed
    ring.0
    2023-05-16 20:12:09.961	warn	redis get ring.0.cocoa_96839166.Events.motion, error - Connection is closed.
    ring.0
    2023-05-16 20:12:09.955	warn	get state error: Connection is closed.
    ring.0
    2023-05-16 20:12:09.954	warn	get state error: Connection is closed.
    ring.0
    2023-05-16 20:12:09.922	warn	redis get ring.0.doorbell_90474299.Events.motion, error - Connection is closed.
    ring.0
    2023-05-16 20:12:09.921	warn	redis get ring.0.doorbell_21502358.Events.motion, error - Connection is closed.
    ring.0
    2023-05-16 20:12:09.385	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.385	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:09.384	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.382	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:09.369	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.368	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:09.365	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.365	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:09.359	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
    ring.0
    2023-05-16 20:12:09.358	info	terminating
    ring.0
    2023-05-16 20:12:09.350	error	Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.349	error	TypeError: Cannot read properties of undefined (reading 'battery_percentage') at OwnRingCamera.updateHealthObject (/opt/iobroker/node_modules/iobroker.ring/build/lib/ownRingCamera.js:369:52) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
    ring.0
    2023-05-16 20:12:09.348	error	unhandled promise rejection: Cannot read properties of undefined (reading 'battery_percentage')
    ring.0
    2023-05-16 20:12:09.348	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    ring.0
    2023-05-16 20:12:06.391	info	Recieved new Refresh Token. Will use the new one until the token in config gets changed
    ring.0
    2023-05-16 20:12:05.870	info	Initializing Api Client
    ring.0
    2023-05-16 20:12:05.804	info	starting. Version 3.3.0 in /opt/iobroker/node_modules/iobroker.ring, node: v18.12.0, js-controller: 4.0.24
    ring.0
    2023-05-16 20:11:29.695	warn	Error Updating State doorbell_90474299.Events.motion to false: DB closed
    ring.0
    2023-05-16 20:11:29.694	warn	Error Updating State doorbell_21502358.History.created_at to 2023-05-16T04:31:10Z: DB closed
    ring.0
    2023-05-16 20:11:29.694	warn	Error Updating State doorbell_21502358.Events.motion to false: DB closed
    ring.0
    2023-05-16 20:11:29.693	warn	Error Updating State cocoa_96839166.History.history_url to https://xxxxxx: DB closed
    ring.0
    2023-05-16 20:11:29.693	warn	Error Updating State cocoa_96839166.History.created_at to 2023-05-16T12:12:52Z: DB closed
    ring.0
    2023-05-16 20:11:29.693	warn	Error Updating State cocoa_96839166.History.kind to motion: DB closed
    ring.0
    2023-05-16 20:11:29.692	warn	Error Updating State doorbell_90474299.History.kind to motion: DB closed
    Mein Android App läuft einwandfrei, auch per Web-Anwendung habe ich Zugriff auf meine Kameras.
    Hat jemand ein ähnliches Problem?
    Michael
    @michihorn
    Auf einem System mit allen installiertenn Updates fällt die Fehlersuche leichter. Halt die Kiste aktuell!
      @michihorn
      michihorn
      @thomas-braun Moin Thomas, ich habe keine offenen Updates
      GlasfaserG Thomas BraunT 2 Antworten Letzte Antwort
      • M michihorn
        ring.0
        Zeit
        silly
        Nachricht
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        ring.0
        Michael
        GlasfaserG Offline
        GlasfaserG Offline
        @michihorn sagte in RING Adapter Verbindet sich nicht mehr:
        Error Updating State cocoa_96839166.History.history_url to https://filestore
        Bitte Lösche den Link .
        Ich sehe damit Gartenhäuser / Schrebergarten !!!!
        • M michihorn
          GlasfaserG Offline
          GlasfaserG Offline
          node: v18.12.0,
          • M michihorn
            @michihorn
            Aber 100%.
            Alleine deine nodejs ist schon nicht aktuell. Ich vermute der Rest ist auch nicht frisch.
            sudo apt update
            sagt?
            • GlasfaserG Glasfaser
              michihorn
              @glasfaser Danke
                @michihorn
                Aber 100%.
                sudo apt update
                sagt?
                michihorn
                @thomas-braun sagte in RING Adapter Verbindet sich nicht mehr:
                @michihorn
                Aber 100%.
                sudo apt update
                sagt?
                Ach so, ich dachte Du meinst die Adapter im IOBroker
                • M michihorn
                  @michihorn
                  Aber 100%.
                  sudo apt update
                  sagt?
                  @michihorn
                  Nein, ich spreche immer vom Gesamten. Muss natürlich alles auf Stand gehalten werden.
                    michihorn
                    @michihorn
                    Ich habe etwas Angst meine Installation beim Update zu schrotten, macht der node.js 18.12.0 so einen großen Unterschied zum empfohlenen 18.16.0?
                    • M michihorn
                      @michihorn
                      @michihorn
                      Updates sind einzuspielen. Alle und immer.
                        @michihorn
                        michihorn
                        schrieb am zuletzt editiert von michihorn
                        @michihorn
                        • M michihorn
                          @michihorn
                          @michihorn
                          Siehste, da liegt auch einiges im Argen.
                          Die yarn.list (oder wie die auch immer heißt) löschen. Findet sich in /etc/apt/sources.list.d/
                          Dann die 76 geschluderten Updates einspielen, Kiste danach sauber neustarten.
                            @michihorn
                            michihorn
                            @thomas-braun Die sources.list lässt sich nicht löschen,
                            Updates habe ich laufen lassen, der node.js ist nun auf 18.16.0
                            -1
                            • M michihorn
                              @michihorn
                              Die sollst du ja auch nicht löschen, sondern die zu yarn gehörige .list-Datei.
                              Braucht root-Rechte, also mit sudo voran.
                                @michihorn
                                michihorn
                                @thomas-braun Alles Erledigt,
                                der Fehler bleibt beim RING Adapter wie vorher
                                • M michihorn
                                  @michihorn
                                  Auch den reboot der Kiste?
                                    @michihorn
                                    michihorn
                                    @thomas-braun ja klar . Kompletter Neustart des kleinen PI4
                                    • M michihorn
                                      @michihorn
                                      Dann haste ja jetzt eine stabile Basis.
                                      iob diag
                                      sagt?
                                        @michihorn
                                        iob diag
                                        sagt?
                                        michihorn
                                        @thomas-braun diag kennt er nicht
                                        • M michihorn
                                          @michihorn
                                          iob stop
                                          iob fix
                                          iob start
                                          iob diag
