  4. Kaco Blueplanet NX3 M2->RS485 TO POE ETH an Modbus Problem
    5.1k
31 Beiträge 6 Kommentatoren 5.0k Aufrufe 6 Beobachtet
  • wendy2702W wendy2702
    Jetzt noch das Register bei Holding und nicht Input eintragen, wie im Beispiel aus dem Link, und haken bei "Abfrage".
    Dann mal log bitte.
    stronoff
    @wendy2702
    v6.3.5
    2424
    Log-Größe: 299.8 KB
    Zeit
    Nachricht
    modbus.1
    	2023-03-12 10:22:06.962	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:22:06.961	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:22:05.964	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:22:05.964	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:22:05.963	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:22:05.961	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:22:05.960	error	Client in error state.
    modbus.1
    	2023-03-12 10:22:05.960	error	Request timed out.
    modbus.1
    	2023-03-12 10:22:05.959	warn	Error: undefined
    modbus.1
    	2023-03-12 10:22:00.958	debug	[DevID_3/holdingRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:22:00.958	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:22:00.957	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:21:00.954	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:21:00.953	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:20:59.958	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:20:59.958	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:20:59.957	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:20:59.955	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:20:59.954	error	Client in error state.
    modbus.1
    	2023-03-12 10:20:59.953	error	Request timed out.
    modbus.1
    	2023-03-12 10:20:59.952	warn	Error: undefined
    modbus.1
    	2023-03-12 10:20:54.950	debug	[DevID_3/holdingRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:20:54.950	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:20:54.948	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:54.945	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:54.944	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:19:53.950	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:19:53.949	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:19:53.948	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:19:53.945	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:19:53.944	error	Client in error state.
    modbus.1
    	2023-03-12 10:19:53.943	error	Request timed out.
    modbus.1
    	2023-03-12 10:19:53.942	warn	Error: undefined
    modbus.1
    	2023-03-12 10:19:48.934	debug	[DevID_3/holdingRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:19:48.933	debug	Initialization of scale factors done!
    modbus.1
    	2023-03-12 10:19:48.931	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:19:48.930	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:48.652	debug	Remove old object modbus.1.inputRegisters.40072_Amps
    modbus.1
    	2023-03-12 10:19:48.598	debug	Add holdingRegisters.40072_Amps: {"_id":"holdingRegisters.40072_Amps","type":"state","common":{"name":"Amps","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":40072,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.1
    	2023-03-12 10:19:48.597	debug	Initialize Objects for holdingRegs: [{"_address":"40072","name":"Amps","description":"Amps","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40072,"deviceId":3,"id":"holdingRegisters.40072_Amps"}]
    modbus.1
    	2023-03-12 10:19:48.596	debug	Initialize Objects for inputRegs: []
    modbus.1
    	2023-03-12 10:19:48.595	debug	Initialize Objects for coils: []
    modbus.1
    	2023-03-12 10:19:48.595	debug	Initialize Objects for disInputs: []
    modbus.1
    	2023-03-12 10:19:48.380	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.23
    modbus.1
    	2023-03-12 10:19:47.900	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.1
    	2023-03-12 10:19:47.748	debug	States connected to redis: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:19:47.669	debug	States create User PubSub Client
    modbus.1
    	2023-03-12 10:19:47.667	debug	States create System PubSub Client
    modbus.1
    	2023-03-12 10:19:47.644	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:19:47.598	debug	Objects connected to redis: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:19:47.590	debug	Objects client initialize lua scripts
    modbus.1
    	2023-03-12 10:19:47.516	debug	Objects create User PubSub Client
    modbus.1
    	2023-03-12 10:19:47.514	debug	Objects create System PubSub Client
    modbus.1
    	2023-03-12 10:19:47.512	debug	Objects client ready ... initialize now
    modbus.1
    	2023-03-12 10:19:47.456	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:19:42.915	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.1
    	2023-03-12 10:19:42.914	debug	Plugin sentry destroyed
    modbus.1
    	2023-03-12 10:19:42.913	info	terminating
    modbus.1
    	2023-03-12 10:19:42.910	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:19:42.908	info	Got terminate signal TERMINATE_YOURSELF
    modbus.1
    	2023-03-12 10:19:18.533	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:18.532	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:19:17.539	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:19:17.538	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:19:17.537	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:19:17.533	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:19:17.532	error	Client in error state.
    modbus.1
    	2023-03-12 10:19:17.531	error	Request timed out.
    modbus.1
    	2023-03-12 10:19:17.530	warn	Error: undefined
    modbus.1
    	2023-03-12 10:19:12.523	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:19:12.522	debug	Initialization of scale factors done!
    modbus.1
    	2023-03-12 10:19:12.519	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:19:12.518	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:12.206	debug	Add holdingRegisters.40072_Amps: {"_id":"holdingRegisters.40072_Amps","type":"state","common":{"name":"Amps","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":40072,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.1
    	2023-03-12 10:19:12.206	debug	Initialize Objects for holdingRegs: [{"_address":"40072","name":"Amps","description":"Amps","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40072,"deviceId":3,"id":"holdingRegisters.40072_Amps"}]
    modbus.1
    	2023-03-12 10:19:12.205	debug	Add inputRegisters.40072_Amps: {"_id":"inputRegisters.40072_Amps","type":"state","common":{"name":"Amps","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"A"},"native":{"regType":"inputRegs","address":40072,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1}}
    modbus.1
    	2023-03-12 10:19:12.204	debug	Initialize Objects for inputRegs: [{"_address":"40072","deviceId":3,"name":"Amps","description":"Amps","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":40072,"id":"inputRegisters.40072_Amps"}]
    modbus.1
    	2023-03-12 10:19:12.204	debug	Initialize Objects for coils: []
    modbus.1
    	2023-03-12 10:19:12.203	debug	Initialize Objects for disInputs: []
    modbus.1
    	2023-03-12 10:19:12.009	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.23
    modbus.1
    	2023-03-12 10:19:11.576	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.1
    	2023-03-12 10:19:11.449	debug	States connected to redis: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:19:11.370	debug	States create User PubSub Client
    modbus.1
    	2023-03-12 10:19:11.368	debug	States create System PubSub Client
    modbus.1
    	2023-03-12 10:19:11.344	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:19:11.300	debug	Objects connected to redis: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:19:11.291	debug	Objects client initialize lua scripts
    modbus.1
    	2023-03-12 10:19:11.216	debug	Objects create User PubSub Client
    modbus.1
    	2023-03-12 10:19:11.214	debug	Objects create System PubSub Client
    modbus.1
    	2023-03-12 10:19:11.211	debug	Objects client ready ... initialize now
    modbus.1
    	2023-03-12 10:19:11.152	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:19:06.520	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.1
    	2023-03-12 10:19:06.520	debug	Plugin sentry destroyed
    modbus.1
    	2023-03-12 10:19:06.518	info	terminating
    modbus.1
    	2023-03-12 10:19:06.515	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:19:06.513	info	Got terminate signal TERMINATE_YOURSELF
    modbus.1
    	2023-03-12 10:19:01.898	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:19:01.897	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:19:00.904	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:19:00.904	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:19:00.903	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:19:00.898	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:19:00.896	error	Client in error state.
    modbus.1
    	2023-03-12 10:19:00.896	error	Request timed out.
    modbus.1
    	2023-03-12 10:19:00.895	warn	Error: undefined
    modbus.1
    	2023-03-12 10:18:55.888	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:18:55.887	debug	Initialization of scale factors done!
    modbus.1
    	2023-03-12 10:18:55.885	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:18:55.884	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:18:55.579	debug	Add holdingRegisters.40072_Amps: {"_id":"holdingRegisters.40072_Amps","type":"state","common":{"name":"Amps","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"A"},"native":{"regType":"holdingRegs","address":40072,"deviceId":3,"type":"int16le","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.1
    	2023-03-12 10:18:55.578	debug	Initialize Objects for holdingRegs: [{"_address":"40072","name":"Amps","description":"Amps","unit":"A","type":"int16le","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":40072,"deviceId":3,"id":"holdingRegisters.40072_Amps"}]
    modbus.1
    	2023-03-12 10:18:55.578	debug	Add inputRegisters.40072_Amps: {"_id":"inputRegisters.40072_Amps","type":"state","common":{"name":"Amps","role":"level","type":"number","read":true,"write":false,"def":0,"unit":"A"},"native":{"regType":"inputRegs","address":40072,"deviceId":3,"type":"uint16be","len":1,"offset":0,"factor":1}}
    modbus.1
    	2023-03-12 10:18:55.576	debug	Initialize Objects for inputRegs: [{"_address":"40072","deviceId":3,"name":"Amps","description":"Amps","unit":"A","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","cw":"","isScale":"","address":40072,"id":"inputRegisters.40072_Amps"}]
    modbus.1
    	2023-03-12 10:18:55.576	debug	Initialize Objects for coils: []
    modbus.1
    	2023-03-12 10:18:55.575	debug	Initialize Objects for disInputs: []
    modbus.1
    	2023-03-12 10:18:55.369	info	starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.23
    modbus.1
    	2023-03-12 10:18:54.876	debug	Plugin sentry Initialize Plugin (enabled=true)
    modbus.1
    	2023-03-12 10:18:54.752	debug	States connected to redis: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:18:54.706	debug	States create User PubSub Client
    modbus.1
    	2023-03-12 10:18:54.703	debug	States create System PubSub Client
    modbus.1
    	2023-03-12 10:18:54.639	debug	Redis States: Use Redis connection: 127.0.0.1:9000
    modbus.1
    	2023-03-12 10:18:54.590	debug	Objects connected to redis: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:18:54.581	debug	Objects client initialize lua scripts
    modbus.1
    	2023-03-12 10:18:54.501	debug	Objects create User PubSub Client
    modbus.1
    	2023-03-12 10:18:54.499	debug	Objects create System PubSub Client
    modbus.1
    	2023-03-12 10:18:54.497	debug	Objects client ready ... initialize now
    modbus.1
    	2023-03-12 10:18:54.436	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
    modbus.1
    	2023-03-12 10:18:49.962	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    modbus.1
    	2023-03-12 10:18:49.961	debug	Plugin sentry destroyed
    modbus.1
    	2023-03-12 10:18:49.960	info	terminating
    modbus.1
    	2023-03-12 10:18:49.956	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:18:49.954	info	Got terminate signal TERMINATE_YOURSELF
    modbus.1
    	2023-03-12 10:17:50.318	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:17:50.318	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:17:49.322	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:17:49.321	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:17:49.321	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:17:49.319	warn	Poll error count: 10 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:17:49.319	error	Client in error state.
    modbus.1
    	2023-03-12 10:17:49.318	error	Request timed out.
    modbus.1
    	2023-03-12 10:17:49.318	warn	Error: undefined
    modbus.1
    	2023-03-12 10:17:44.317	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:17:44.316	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:17:44.315	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:16:44.313	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:16:44.313	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:16:43.323	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:16:43.322	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:16:43.322	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:16:43.314	warn	Poll error count: 9 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:16:43.313	error	Client in error state.
    modbus.1
    	2023-03-12 10:16:43.313	error	Request timed out.
    modbus.1
    	2023-03-12 10:16:43.312	warn	Error: undefined
    modbus.1
    	2023-03-12 10:16:38.311	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:16:38.310	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:16:38.309	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:15:38.307	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:15:38.307	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:15:37.311	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:15:37.311	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:15:37.310	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:15:37.308	warn	Poll error count: 8 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:15:37.307	error	Client in error state.
    modbus.1
    	2023-03-12 10:15:37.307	error	Request timed out.
    modbus.1
    	2023-03-12 10:15:37.306	warn	Error: undefined
    modbus.1
    	2023-03-12 10:15:32.304	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:15:32.303	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:15:32.302	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:14:32.299	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:14:32.299	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:14:31.303	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:14:31.303	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:14:31.302	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:14:31.300	warn	Poll error count: 7 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:14:31.299	error	Client in error state.
    modbus.1
    	2023-03-12 10:14:31.299	error	Request timed out.
    modbus.1
    	2023-03-12 10:14:31.298	warn	Error: undefined
    modbus.1
    	2023-03-12 10:14:26.297	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:14:26.296	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:14:26.296	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:13:26.292	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:13:26.292	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:13:25.300	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:13:25.299	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:13:25.299	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:13:25.293	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:13:25.292	error	Client in error state.
    modbus.1
    	2023-03-12 10:13:25.291	error	Request timed out.
    modbus.1
    	2023-03-12 10:13:25.291	warn	Error: undefined
    modbus.1
    	2023-03-12 10:13:20.288	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:13:20.288	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:13:20.287	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:12:20.284	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:12:20.283	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:12:19.287	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:12:19.286	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:12:19.286	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:12:19.284	warn	Poll error count: 5 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:12:19.283	error	Client in error state.
    modbus.1
    	2023-03-12 10:12:19.283	error	Request timed out.
    modbus.1
    	2023-03-12 10:12:19.282	warn	Error: undefined
    modbus.1
    	2023-03-12 10:12:14.281	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:12:14.280	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:12:14.279	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:11:14.277	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:11:14.276	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:11:13.280	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:11:13.280	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:11:13.280	debug	Socket closed with error
    modbus.1
    	2023-03-12 10:11:13.277	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
    modbus.1
    	2023-03-12 10:11:13.276	error	Client in error state.
    modbus.1
    	2023-03-12 10:11:13.276	error	Request timed out.
    modbus.1
    	2023-03-12 10:11:13.275	warn	Error: undefined
    modbus.1
    	2023-03-12 10:11:08.274	debug	[DevID_3/inputRegs] Poll address 40072 - 1 registers
    modbus.1
    	2023-03-12 10:11:08.273	debug	[DevID_3] Poll start ---------------------
    modbus.1
    	2023-03-12 10:11:08.273	info	Connected to slave 192.168.1.97
    modbus.1
    	2023-03-12 10:10:08.270	info	Disconnected from slave 192.168.1.97
    modbus.1
    	2023-03-12 10:10:08.269	debug	Closing client on purpose.
    modbus.1
    	2023-03-12 10:10:07.275	debug	Cleaning up request fifo.
    modbus.1
    	2023-03-12 10:10:07.275	debug	Clearing timeout of the current request.
    modbus.1
    	2023-03-12 10:10:07.274	debug	Socket closed with error
    • S stronoff
      @wendy2702
      v6.3.5
      2424
      Log-Größe: 299.8 KB
      Zeit
      Nachricht
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      modbus.1
      wendy2702W Offline
      wendy2702W Offline
      @stronoff Hm,
      die Auswahl Anzahl Bits im Waveshare mit "8" ist ja nirgendwo dokumentiert, könnte also falsch sein.
      Wie ist die Verbindung zwischen Waveshare und Kaco aufgebaut?
        @stronoff Hm,
        stronoff
        schrieb am zuletzt editiert von stronoff
        @wendy2702
        Der Elektriker hat ein Patch Kabel aufgeschnitten und den Stecker am Kaco eingesteckt und PIN1 und 2 am Waveshare "verschraubt".
        Der Waveshare blinkt auch immer "Active" wenn am Kaco die Kommunikations LED blinkt.
        • S stronoff
          @wendy2702
          wendy2702W Offline
          wendy2702W Offline
          @stronoff wäre ein Versuch wert am Waveshare mal zu tauschen.
          S 3 Antworten Letzte Antwort
            stronoff
            @wendy2702
            Habe ich auch schon überlegt.
            Werd's mal probieren.
              stronoff
              @wendy2702
              Danke Dir auf jeden Fall schon mal für Deine Unterstützung!
                stronoff
                @wendy2702
                Heute war der Elektriker da und ich konnte das erste Mal hinter die Abdeckung sehen ;-)
                Wir haben die Anschlüsse "durchgepiepst" und es war erst mal alles so, wie es gemäß Kaco Beschreibung sein sollte:
                Mir fiel allerdings auf, dass die Ummantelung des Netzwerkkabels nicht am Waveshare angeschlossen war. Laut Elektriker unrelevant, ich wollte es aber trotzdem austesten und habe daher die Ummantelung (siehe Pfeile) anbringen lassen:
                Ich habe die Anschlüsse daher jetzt erstmal nicht tauschen lassen. Ich kann leider erst am Samstag und Sonntag wieder testen. Wenn's nicht funktioniert, würde ich als nächstes 485A und 485B tauschen.
                Was meinst Du? Ist die Verkabelung soweit OK oder ist aus Deiner Sicht ein Fehler vorhanden?
                In der Anleitung stand noch was von einem Abschlusswiderstand.
                Ist das für meine Verkabelung relevant? Laut Elektriker nicht, ich werde daraus aber nicht schlüssig...
                • S stronoff
                  @wendy2702
                  wendy2702W Offline
                  wendy2702W Offline
                  @stronoff Weiss nicht wie lang das Kabel zwischen Waveshare und Kaco ist aber eigentlich reichen dann zwei drähte.
                  Ich habe bei mir ca. 1m dazwischen, alte IYSTY Kabel und davon ein Adernpaar genommen.
                    stronoff
                    @wendy2702
                    Ist bei mir auch nur ein Meter.
                    Werde morgen und am Sonntag weiter testen...
                    • wierer-sigiW Offline
                      wierer-sigi
                      Hallo in die Runde,
                      seit Ihr mit der installation weiter gekommen, und läuft diese Lösung mit KACO und iobroker?
                      Überlege auch den KACO 10 NX2 mit Waveshare in den Iobroker zu bekommen, gefällt mir besser als mit Shelly EM3 und Zangen auszulesen.
                      • wierer-sigiW wierer-sigi
                        Hallo in die Runde,
                        @wierer-sigi warum in zwei Threads?
                        wierer-sigiW 1 Antwort Letzte Antwort
                          wierer-sigi
                          @homoran sagte in Kaco Blueplanet NX3 M2->RS485 TO POE ETH an Modbus Problem:
                          Sorry - hatte erst wegen der Anbindung zur direkten Anbindung via Modbus Adapter im iobroker gefragt. Dann aber in diesem Teil erfahren das dies direkt wohl nicht klappt aber über in diesen Thread beschriebenen Waveshare RS485 TO POE adapter doch eine Möglichkeit gibt.
                            Mitch23
                            @wierer-sigi
                            Der Kaco WR lässt sich direkt abfragen, wenn eine WLAN-Verbindung eingerichtet ist. Ein RS485 Adapter auf TCP ist nicht nötig. Die Einstellung habe ich in deinem anderen Thread gepostet.
                            • M Mitch23
                              @wierer-sigi
                              jvkronenberg78
                              @mitch23 sagte in Kaco Blueplanet NX3 M2->RS485 TO POE ETH an Modbus Problem:
                              @wierer-sigi
                              Hi, ich nutze den WLAN Stick von Kaco. Kannst du mir sagen, wie ich per WLAN die Daten in den ioBroker bekomme? Habe keinen Adapter dafür gefunden, oder verstehe ich dich da falsch?
