  4. EspHome Adapter kann nicht mehr compilieren
12 Beiträge 4 Kommentatoren 801 Aufrufe 4 Beobachtet
  • W Offline
    W Offline
    WolfgangFB
    Ich wollte ein neues Device programmieren und jetzt kommt:
    INFO Generating C++ source...
    INFO Compiling app...
    Processing esp32-083af28e375c (board: nodemcu-32s; framework: arduino; platform: platformio/espressif32 @ 5.2.0)
    HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
     - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch3
    warning: Calling missing SConscript without error is deprecated.
    Transition by adding must_exist=False to SConscript calls.
    Missing SConscript '/home/iobroker/.platformio/packages/framework-arduinoespressif32/tools/platformio-build.py'
    File "/home/iobroker/.platformio/platforms/espressif32/builder/frameworks/arduino.py", line 41, in <module>
    LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
    Library Manager: Installing FS
    Warning! Could not find the package with 'FS' requirements for your system 'linux_armv7l'
    Library Manager: Installing Update
    Warning! Could not find the package with 'Update' requirements for your system 'linux_armv7l'
    Library Manager: Installing ESPmDNS
    Warning! Could not find the package with 'ESPmDNS' requirements for your system 'linux_armv7l'
    Library Manager: Installing Wire
    Warning! Could not find the package with 'Wire' requirements for your system 'linux_armv7l'
    Dependency Graph
    |-- AsyncTCP-esphome @ 1.2.2
    |-- WiFi @ 1.2.7
    |-- ESPAsyncWebServer-esphome @ 2.1.0
    |-- DNSServer @ 1.1.0
    |-- ArduinoJson @ 6.18.5
    Compiling .pioenvs/esp32-083af28e375c/src/esphome/components/ads1115/ads1115.cpp.o
    Compiling .pioenvs/esp32-083af28e375c/src/esphome/components/api/api_connection.cpp.o
    Compiling .pioenvs/esp32-083af28e375c/src/esphome/components/api/api_frame_helper.cpp.o
    Compiling .pioenvs/esp32-083af28e375c/src/esphome/components/api/api_pb2.cpp.o
    In file included from src/esphome/components/sensor/sensor.h:3,
                     from src/esphome/components/ads1115/ads1115.h:4,
                     from src/esphome/components/ads1115/ads1115.cpp:1:
    src/esphome/core/log.h:14:10: fatal error: esp_err.h: No such file or directory
    * Looking for esp_err.h dependency? Check our library registry!
    * CLI  > platformio lib search "header:esp_err.h"
    * Web  > https://registry.platformio.org/search?q=header:esp_err.h
     #include <esp_err.h>
    compilation terminated.
    In file included from src/esphome/components/socket/socket.h:5,
                     from src/esphome/components/api/api_frame_helper.h:13,
                     from src/esphome/components/api/api_connection.h:3,
                     from src/esphome/components/api/api_connection.cpp:1:
    src/esphome/components/socket/headers.h:116:10: fatal error: sys/ioctl.h: No such file or directory
     #include <sys/ioctl.h>
                     from src/esphome/components/api/api_frame_helper.cpp:1:
    In file included from src/esphome/components/api/proto.h:4,
                     from src/esphome/components/api/api_pb2.h:5,
                     from src/esphome/components/api/api_pb2.cpp:3:
    *** [.pioenvs/esp32-083af28e375c/src/esphome/components/api/api_pb2.cpp.o] Error 1
    *** [.pioenvs/esp32-083af28e375c/src/esphome/components/api/api_frame_helper.cpp.o] Error 1
    *** [.pioenvs/esp32-083af28e375c/src/esphome/components/ads1115/ads1115.cpp.o] Error 1
    *** [.pioenvs/esp32-083af28e375c/src/esphome/components/api/api_connection.cpp.o] Error 1
    ========================= [FAILED] Took 38.35 seconds =========================
    Wie bekomme ich das repariert?
    • W WolfgangFB
      Dependency Graph
      |-- WiFi @ 1.2.7
      Ahnungsbefreit
      @wolfgangfb Installier mal neu von GitHub
      W 1 Antwort Letzte Antwort
      • A Ahnungsbefreit
        W Offline
        W Offline
        WolfgangFB
        @ahnungsbefreit sagte in EspHome Adapter kann nicht mehr compilieren:
        Das war das erste was ich gemacht habe. Hat nichts gebracht. IO-Broker und Raspi auch nue gestartet.
        • W WolfgangFB
          @wolfgangfb
          Gibt es da eine Datei?
          find "/usr/lib/" -iname "EXTERNALLY*"
            @wolfgangfb
            W Offline
            W Offline
            WolfgangFB
            @thomas-braun sagte in EspHome Adapter kann nicht mehr compilieren:
            @wolfgangfb
            Nein, da kommt kein Ergebnis:
            pi@raspberrypi:/opt/iobroker $ find "/usr/lib/" -iname "EXTERNALLY*"
            Aber auf eiem zweitn pi auf dem ESPHome läuft gibt es diese Datei auch nicht.
            • Thomas BraunT Online
              @wolfgangfb
              python --version
              apt policy python3-pip-whl python3-full
              pipx esphome
              sagt?
                @wolfgangfb
                python --version
                pipx esphome
                sagt?
                W Offline
                W Offline
                WolfgangFB
                @wolfgangfb
                python --version
                pipx esphome
                sagt?
                Auf beiden pi Rechnern das gleiche:
                pi@raspberrypi:/opt/iobroker $ python --version
                Python 3.9.2
                whl python3-full
                pipx esphomepi@raspberrypi:/opt/iobroker $ apt policy python3-pip-whl python3-full
                python3-full:
                  Installiert:           (keine)
                  Installationskandidat: 3.9.2-3
                  Versionstabelle:
                     3.9.2-3 500
                N: Paket python3-pip-whl kann nicht gefunden werden.
                pi@raspberrypi:/opt/iobroker $ pipx esphome
                -bash: pipx: Kommando nicht gefunden.
                • W WolfgangFB
                  @wolfgangfb
                  python --version
                  pipx esphome
                  sagt?
                  Python 3.9.2
                  whl python3-full
                  python3-full:
                    Versionstabelle:
                       3.9.2-3 500
                  @wolfgangfb sagte in EspHome Adapter kann nicht mehr compilieren:
                  python3-full
                  Installier das mal.
                    python3-full
                    Installier das mal.
                    W Offline
                    W Offline
                    WolfgangFB
                    python3-full
                    Installier das mal.
                    pipx esphomePython 3.9.2
                    python3-full:
                      Installiert:           3.9.2-3
                      Versionstabelle:
                     *** 3.9.2-3 500
                    Ich habe übrigens gerade festgestellt, dass das Problem nur beim compilieren von ESP32 Code auftritt, ESP8266 funktioniert.
                      smarthome2020
                      Gibt es mittlerweile eine Lösung ? Habe das gleiche Problem .
                      • W Offline
                        W Offline
                        WolfgangFB
                        @smarthome2020
                        Hallo, leider habe ich keine Lösung. Es beruigt mich, dass ich nciht alleine mit diesem Problem bin (scheint also nicht an mir zu liegen), aber ich vermute dass das einfach so bleibt weil dieser Adapter eben leider nicht mehr weiter entwickelt wird. Schade.
                        • W WolfgangFB
                          @smarthome2020
                          smarthome2020
                          @wolfgangfb
                          Ja, leider . War dabei so praktisch :) nun muss ich einen Umweg über die Konsole von Windows gehen . Ist deutlich mühsamer als nun. Kann ich nicht mehr so bequem erledigen wie zuvor .
                          82.9k
