  4. Influxdb2 Backitup
    5.4k
Influxdb2 Backitup
214 Beiträge 7 Kommentatoren 30.8k Aufrufe 5 Beobachtet
  • Marc BergM Marc Berg
    @damrak2022
    die eckigen Klammern weglassen🎶
    Damrak2022D Offline
    Damrak2022D Offline
    Damrak2022
    #102
    @marc-berg Hatte es mir fast gedacht
    Andy@homebridge:~ $ influx config create -a -n default2 -u http://localhost:8086 -t AfcFU5cPIn5N_D8HEk_FBSDHFkPARR1atQ7woh-JFzwLTCeSp_2JS4zla7GN95RH4EtMCg8snxfPEncXS4hUjg== -o Andy
    Active	Name		URL			Org
    *	default2	http://localhost:8086	Andy
    Active	Name		URL			Org
    Andy@homebridge:~ $ influx auth list
    ID			Description	Token												User Name	User ID			Permissions
    0b12b565e7eaf000	Andys Token1	AfcFU5cPIn5N_D8HEk_FBSDHFkPARR1atQ7woh-JFzwLTCeSp_2JS4zla7GN95RH4EtMCg8snxfPEncXS4hUjg==	damrak2022	0b09ca124d0f4000	[read:orgs/ccb7770acd56eb54/annotations write:orgs/ccb7770acd56eb54/annotations read:orgs/ccb7770acd56eb54/authorizations write:orgs/ccb7770acd56eb54/authorizations read:orgs/ccb7770acd56eb54/buckets write:orgs/ccb7770acd56eb54/buckets read:orgs/ccb7770acd56eb54/checks write:orgs/ccb7770acd56eb54/checks read:orgs/ccb7770acd56eb54/dashboards write:orgs/ccb7770acd56eb54/dashboards read:orgs/ccb7770acd56eb54/dbrp write:orgs/ccb7770acd56eb54/dbrp read:orgs/ccb7770acd56eb54/documents write:orgs/ccb7770acd56eb54/documents read:orgs/ccb7770acd56eb54/labels write:orgs/ccb7770acd56eb54/labels read:orgs/ccb7770acd56eb54/notebooks write:orgs/ccb7770acd56eb54/notebooks read:orgs/ccb7770acd56eb54/notificationEndpoints write:orgs/ccb7770acd56eb54/notificationEndpoints read:orgs/ccb7770acd56eb54/notificationRules write:orgs/ccb7770acd56eb54/notificationRules read:/orgs/ccb7770acd56eb54 read:orgs/ccb7770acd56eb54/remotes write:orgs/ccb7770acd56eb54/remotes read:orgs/ccb7770acd56eb54/replications write:orgs/ccb7770acd56eb54/replications read:orgs/ccb7770acd56eb54/scrapers write:orgs/ccb7770acd56eb54/scrapers read:orgs/ccb7770acd56eb54/secrets write:orgs/ccb7770acd56eb54/secrets read:orgs/ccb7770acd56eb54/sources write:orgs/ccb7770acd56eb54/sources read:orgs/ccb7770acd56eb54/tasks write:orgs/ccb7770acd56eb54/tasks read:orgs/ccb7770acd56eb54/telegrafs write:orgs/ccb7770acd56eb54/telegrafs read:/users/0b09ca124d0f4000 write:/users/0b09ca124d0f4000 read:orgs/ccb7770acd56eb54/variables write:orgs/ccb7770acd56eb54/variables read:orgs/ccb7770acd56eb54/views write:orgs/ccb7770acd56eb54/views]
    Andy@homebridge:~ $
    Eigentlich sieht das so aus:
    Mit besten Grüßen
    Andy
    • Damrak2022D Damrak2022
      Active	Name		URL			Org
      Active	Name		URL			Org
      Andy@homebridge:~ $
      Marc BergM Offline
      Marc BergM Offline
      Marc Berg
      #103
      @damrak2022 sagte in Influxdb2 Backitup:
      Yup, da fehlt der Operator Token. Also bitte die Anlietung von @simatec zum Anlegen durchführen
        Damrak2022D Offline
        Damrak2022D Offline
        Damrak2022
        #104
        @marc-berg Okay, erstmal danke
        Mit besten Grüßen
        Andy
        • Damrak2022D Offline
          Damrak2022D Offline
          Damrak2022
          #105
          @marc-berg Das sieht dann so aus und der Token steht schon die ganze Zeit im Backitup Adapter
          Andy@homebridge:~ $ influx auth list -t AfcFU5cPIn5N_D8HEk_FBSDHFkPARR1atQ7woh-JFzwLTCeSp_2JS4zla7GN95RH4EtMCg8snxfPEncXS4hUjg== --json
          		"id": "0b12b565e7eaf000",
          		"description": "Andys Token1",
          		"token": "AfcFU5cPIn5N_D8HEk_FBSDHFkPARR1atQ7woh-JFzwLTCeSp_2JS4zla7GN95RH4EtMCg8snxfPEncXS4hUjg==",
          		"status": "active",
          		"userName": "damrak2022",
          		"userID": "0b09ca124d0f4000",
          		"permissions": [
          			"read:orgs/ccb7770acd56eb54/annotations",
          			"write:orgs/ccb7770acd56eb54/annotations",
          			"read:orgs/ccb7770acd56eb54/authorizations",
          			"write:orgs/ccb7770acd56eb54/authorizations",
          			"read:orgs/ccb7770acd56eb54/buckets",
          			"write:orgs/ccb7770acd56eb54/buckets",
          			"read:orgs/ccb7770acd56eb54/checks",
          			"write:orgs/ccb7770acd56eb54/checks",
          			"read:orgs/ccb7770acd56eb54/dashboards",
          			"write:orgs/ccb7770acd56eb54/dashboards",
          			"read:orgs/ccb7770acd56eb54/dbrp",
          			"write:orgs/ccb7770acd56eb54/dbrp",
          			"read:orgs/ccb7770acd56eb54/documents",
          			"write:orgs/ccb7770acd56eb54/documents",
          			"read:orgs/ccb7770acd56eb54/labels",
          			"write:orgs/ccb7770acd56eb54/labels",
          			"read:orgs/ccb7770acd56eb54/notebooks",
          			"write:orgs/ccb7770acd56eb54/notebooks",
          			"read:orgs/ccb7770acd56eb54/notificationEndpoints",
          			"write:orgs/ccb7770acd56eb54/notificationEndpoints",
          			"read:orgs/ccb7770acd56eb54/notificationRules",
          			"write:orgs/ccb7770acd56eb54/notificationRules",
          			"read:/orgs/ccb7770acd56eb54",
          			"read:orgs/ccb7770acd56eb54/remotes",
          			"write:orgs/ccb7770acd56eb54/remotes",
          			"read:orgs/ccb7770acd56eb54/replications",
          			"write:orgs/ccb7770acd56eb54/replications",
          			"read:orgs/ccb7770acd56eb54/scrapers",
          			"write:orgs/ccb7770acd56eb54/scrapers",
          			"read:orgs/ccb7770acd56eb54/secrets",
          			"write:orgs/ccb7770acd56eb54/secrets",
          			"read:orgs/ccb7770acd56eb54/sources",
          			"write:orgs/ccb7770acd56eb54/sources",
          			"read:orgs/ccb7770acd56eb54/tasks",
          			"write:orgs/ccb7770acd56eb54/tasks",
          			"read:orgs/ccb7770acd56eb54/telegrafs",
          			"write:orgs/ccb7770acd56eb54/telegrafs",
          			"read:/users/0b09ca124d0f4000",
          			"write:/users/0b09ca124d0f4000",
          			"read:orgs/ccb7770acd56eb54/variables",
          			"write:orgs/ccb7770acd56eb54/variables",
          			"read:orgs/ccb7770acd56eb54/views",
          			"write:orgs/ccb7770acd56eb54/views"
          Andy@homebridge:~ $
          Habe ich hier einen Denkfehler? oder warum habe ich weiterhin die Fehlermeldung beim Backup. Vor allem ist ja der All Access Token identisch mit dem, welchen ich angezeigt bekomme.
          Und wenn ich den Test durchlaufen lasse, lande ich bei exakt demselben Fehler:
          Andy@homebridge:~ $ influx backup --bucket DBANDY1 --host http://192.168.178.24:8086 -t AfcFU5cPIn5N_D8HEk_FBSDHFkPARR1atQ7woh-JFzwLTCeSp_2JS4zla7GN95RH4EtMCg8snxfPEncXS4hUjg== "/tmp/influx-test"
          2023/04/19 22:46:54 INFO: Downloading metadata snapshot
          Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
          Andy@homebridge:~ $
          Es wäre toll, wenn Du mir hier bitte noch weiterhelfen könntest, damit endlich mein Backitup funktioniert.
          Mit besten Grüßen
          Andy
          • mickymM Offline
            mickymM Offline
            mickym
            #106
            So ich habe Deinen Fehler nachvollzogen und es ist wirklich so, dass EIN AllAccess Token NICHT ausreichend ist.
            Wenn Du Dir die Web-Seite zum influxDB Backup anschaust:
            https://docs.influxdata.com/influxdb/v2.7/backup-restore/backup/
            ist zwingend das ROOT-Token zu nehmen, was man bei der ersten Installation vergeben musste:
            2023-04-19 23:55:52.679 - info: backitup.0 (9931) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
            2023-04-19 23:55:52.699 - info: backitup.0 (9931) [iobroker] backup was activated at 02:40 every 1 day(s)
            2023-04-19 23:55:56.427 - error: backitup.0 (9931) [iobroker/influxDB] Error: Command failed: influx backup --bucket iobroker -t 6bJ3RgGg5jfdd_WQUHu_LTmEFDYFMDg_-MfXuLZWTZqY3UdXONSlecYWLYUIOZIAl7xVqAGr6NE01W0MWgq34Q== "/opt/iobroker/backups/influxDB_2023_04_19-23_55_56_backupiobroker"
            2023-04-19 23:55:56.428 - error: backitup.0 (9931) [iobroker/influxDB] 2023/04/19 23:55:56 INFO: Downloading metadata snapshot
            2023-04-19 23:55:56.428 - error: backitup.0 (9931) [iobroker/influxDB] Error: failed to backup metadata: failed to download metadata snapshot: InfluxDB OSS-only command failed: 401 Unauthorized: read:authorizations is unauthorized
            2023-04-19 23:55:56.428 - error: backitup.0 (9931) [iobroker] Error: Command failed: influx backup --bucket iobroker -t 6bJ3RgGg5jfdd_WQUHu_LTmEFDYFMDg_-MfXuLZWTZqY3UdXONSlecYWLYUIOZIAl7xVqAGr6NE01W0MWgq34Q== "/opt/iobroker/backups/influxDB_2023_04_19-23_55_56_backupiobroker"
            2023-04-19 23:58:40.252 - info: host.MWDebian stopInstance system.adapter.backitup.0 (force=false, process=true)
            2023-04-19 23:58:40.256 - info: backitup.0 (9931) Got terminate signal TERMINATE_YOURSELF
            2023-04-19 23:58:40.257 - info: backitup.0 (9931) cleaned everything up...
            2023-04-19 23:58:40.257 - info: backitup.0 (9931) terminating
            2023-04-19 23:58:40.257 - info: backitup.0 (9931) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            2023-04-19 23:58:40.295 - info: host.MWDebian stopInstance system.adapter.backitup.0 send kill signal
            2023-04-19 23:58:40.769 - info: host.MWDebian instance system.adapter.backitup.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2023-04-19 23:58:43.328 - info: host.MWDebian instance system.adapter.backitup.0 started with pid 9989
            2023-04-19 23:58:43.656 - info: backitup.0 (9989) starting. Version 2.6.16 in /opt/iobroker/node_modules/iobroker.backitup, node: v16.19.1, js-controller: 4.0.24
            2023-04-19 23:58:43.680 - info: backitup.0 (9989) [iobroker] backup was activated at 02:40 every 1 day(s)
            Um 23:55:52 mit fehlerhaftem Token, 23.58:43 ohne Fehler.
            Backups der Influx-DB wurde erstellt:
            • mickymM mickym
              Damrak2022D Offline
              Damrak2022D Offline
              Damrak2022
              #107
              @mickym Ich habe es eben nochmal mit dem Token versucht den ich abgespeichert hatte:
              influx auth list -t KESElQpj7-pjE4OmD8m0ubKfQe2O7YiGDvAyhrr4JC8upFHQs-_9s_77vr_X2RosScq13_b6Pm9U30n_D6zX0A== —json
              Error: unknown command "—json" for "list"
              Nur ist der nicht mehr in der Influx, da habe ich die gelöscht und einen neuen All Access Token angelegt, der ja wohl nicht zu gebrauchen ist.
              Die Influx Verbindung geht allerdings
              Sieht wohl nicht gut aus.
              Mit besten Grüßen
              Andy
                mickymM Offline
                mickymM Offline
                mickym
                #108
                @damrak2022 Warte mal ich schau mal ob es mit einem geklonten root Token geht. Ja das geht. :)
                Suche Dir das root-Token unter deinen Tokens raus und klick auf das Zahnrad zum Klonen:
                Das funktioniert. (Würde ich mir dann aber ganz heilig abspeichern. ;)
                • mickymM mickym
                  Damrak2022D Offline
                  Damrak2022D Offline
                  Damrak2022
                  #109
                  @mickym Ich habe doch anscheinend keinen mehr. Ich habe nur noch einen All Access Token
                  Mit besten Grüßen
                  Andy
                  • mickymM mickym
                    Damrak2022D Offline
                    Damrak2022D Offline
                    Damrak2022
                    #110
                    @mickym Und wenn ich den klone sieht das. so aus:
                    Mit besten Grüßen
                    Andy
                      mickymM Offline
                      mickymM Offline
                      mickym
                      #111
                      @damrak2022
                      Na dann musst Du die aber selbst gelöscht haben!!!! -
                      Schau mal ob Du nach unten blättern kannst. Hast Du Dich auch als root User angemeldet?
                        mickymM Offline
                        mickymM Offline
                        mickym
                        #112
                        Na das kann es nicht sein, das ja erst am 19./20. erstellt.
                        • mickymM mickym
                          Damrak2022D Offline
                          Damrak2022D Offline
                          Damrak2022
                          #113
                          @mickym Das ist nur der geklonte All Access Token. Ich habe ja einen Token gespeichert, bei dem ich mir ziemlich sicher bin, das dies der root token ist. Bevor ich neu installiere, was müsste ich mit dem root jetzt genau machen?
                          Mit besten Grüßen
                          Andy
                            mickymM Offline
                            mickymM Offline
                            mickym
                            #114
                            @damrak2022 Na aber es hilft ja nichts, wenn das anscheinend in Deinem ganzen System nicht mehr ist. Die Frage ist, warum ist das Token in der Influx nicht mehr sichtbar?
                            Gib mal auf der Kommandozeile
                            influx user list
                            ein
                            • mickymM mickym
                              influx user list
                              ein
                              Damrak2022D Offline
                              Damrak2022D Offline
                              Damrak2022
                              #115
                              @mickym sagte in Influxdb2 Backitup:
                              influx user list
                              Andy@homebridge:~ $ influx user list
                              ID			Name
                              0b09ca124d0f4000	damrak2022
                              Andy@homebridge:~ $
                              Mit besten Grüßen
                              Andy
                                influx user list
                                ID			Name
                                Andy@homebridge:~ $
                                mickymM Offline
                                mickymM Offline
                                mickym
                                #116
                                @damrak2022 Na OK - dann ist das Dein einziger User und wahrscheinlich auch Dein root User.
                                Hast Du denn tokens gelöscht????
                                • mickymM mickym
                                  Damrak2022D Offline
                                  Damrak2022D Offline
                                  Damrak2022
                                  #117
                                  @mickym Ja leider
                                  Mit besten Grüßen
                                  Andy
                                    @mickym Ja leider
                                    mickymM Offline
                                    mickymM Offline
                                    mickym
                                    #118
                                    @mickym Ja leider
                                    Ja gibt zwar hier einen Artikel: https://github.com/influxdata/influxdb/issues/17329
                                    Aber in diesem Fall wird Dir nichts anderes übrig bleiben, als neu zu installieren. Deine ganze InfluxDB ist in meinen Augen mit Deinen gelöschten Tokens nicht brauchbar.
                                    • mickymM mickym
                                      @mickym Ja leider
                                      Damrak2022D Offline
                                      Damrak2022D Offline
                                      Damrak2022
                                      #119
                                      @mickym Wir können gleich aufhören.
                                      Ich habe mal das gemacht:
                                      Andy@homebridge:~ $ influx auth list --user damrak2022
                                      Andy@homebridge:~ $
                                      Mit diesem Befehl kann man angeblich den Admin token auslesen. Nur ist das halt eigentlich der All Access Token
                                      Mit besten Grüßen
                                      Andy
                                        Andy@homebridge:~ $
                                        mickymM Offline
                                        mickymM Offline
                                        mickym
                                        #120
                                        @damrak2022 Nochmal das Token muss ja auch in der Weboberfläche sichtbar sein.
                                        Wenn Du kein Token mehr hast, das zum Installationsdatum erstellt wurde - vergiss es!!! - Meine Meinung. Ich seh das auch in allen Artikel auf GitHub zu diesem Thema.
                                        • mickymM mickym
                                          Damrak2022D Offline
                                          Damrak2022D Offline
                                          Damrak2022
                                          #121
                                          @mickym Okay, danke
                                          Mit besten Grüßen
                                          Andy
