  4. MQTT-Adapter - Grundsatzfragen
    5.8k
28 Beiträge 5 Kommentatoren 14.5k Aufrufe 1 Beobachtet
    Mann bin ich blind.
    Ich hatte da nachgesehen, aber das Zahnrad nicht angeklickt :(
    Das ist doch nur für history :oops: :oops:
    Ok, dann teste ich mal
      Will nicht so ganz.
      host.Keller-RasPi2 2017-09-07 19:14:49.850 info Restart adapter system.adapter.mqtt-client.0 because enabled
      host.Keller-RasPi2 2017-09-07 19:14:49.850 error instance system.adapter.mqtt-client.0 terminated with code 0 (OK)
      mqtt-client.0 2017-09-07 19:14:49.826 error TypeError: Cannot read property 'topic' of undefined at Socket. (/opt/iobroker/node_modules/iobroker.mqtt-client/client.js:119:92) at Socket.onack (/opt/iobroker/node_modules/socket
      mqtt-client.0 2017-09-07 19:14:49.824 error uncaught exception: Cannot read property 'topic' of undefined
      smartmeter.0 2017-09-07 19:14:47.702 info Received 10 values, 3 updated
      mqtt-client.0 2017-09-07 19:14:47.175 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v6.11.1
      host.Keller-RasPi2 2017-09-07 19:14:43.065 info instance system.adapter.mqtt-client.0 started with pid 1495
      smartmeter.0 2017-09-07 19:14:31.742 info Received 10 values, 3 updated
      smartmeter.0 2017-09-07 19:14:15.707 info Received 10 values, 3 updated
      host.Keller-RasPi2 2017-09-07 19:14:13.050 info Restart adapter system.adapter.mqtt-client.0 because enabled
      host.Keller-RasPi2 2017-09-07 19:14:13.050 error instance system.adapter.mqtt-client.0 terminated with code 0 (OK)
      mqtt-client.0 2017-09-07 19:14:13.018 error TypeError: Cannot read property 'topic' of undefined at Socket. (/opt/iobroker/node_modules/iobroker.mqtt-client/client.js:119:92) at Socket.onack (/opt/iobroker/node_modules/socket
      mqtt-client.0 2017-09-07 19:14:13.015 error uncaught exception: Cannot read property 'topic' of undefined
      mqtt-client.0 2017-09-07 19:14:12.457 info starting. Version 0.3.0 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v6.11.1
      host.Keller-RasPi2 2017-09-07 19:14:08.297 info instance system.adapter.mqtt-client.0 started with pid 1434
      smartmeter.0 2017-09-07 19:13:59.716 info Received 10 values, 3 updated
      smartmeter.0 2017-09-07 19:13:43.752 info Received 10 values, 3 updated
      host.Keller-RasPi2 2017-09-07 19:13:38.280 info Restart adapter system.adapter.mqtt-client.0 because enabled
      host.Keller-RasPi2 2017-09-07 19:13:38.279 error instance system.adapter.mqtt-client.0 terminated with code 0 (OK)
      mqtt-client.0 2017-09-07 19:13:38.260 info terminating
      mqtt-client.0 2017-09-07 19:13:38.244 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
      mqtt-client.0 2017-09-07 19:13:38.244 error at Socket. (/opt/iobroker/node_modules/iobroker.mqtt-client/client.js:119:92)
      mqtt-client.0 2017-09-07 19:13:38.244 error TypeError: Cannot read property 'topic' of undefined
      mqtt-client.0 2017-09-07 19:13:38.242 error uncaught exception: Cannot read property 'topic' of undefined
      Habe einen State aktiviert und die subscriptions und den prefix aus der Konfig herausgenommen.
       ![144_adapter_mqtt_client_states.jpg](/assets/uploads/files/144_adapter_mqtt_client_states.jpg)
      Muss ssl eingeschaltet sein, oder kann ich das erst mal ohne versuchen? Bei Zugriff auf "nicht localhost"?
      • P Offline
        Pman
        Puh, das Topic, zu dem publishen willst hat sehr viele Sonderzeichen, änder dies doch mal in etwas einfaches, was nur aus Buchstaben und den Trennern "/" besteht. Vielleicht geht da etwas kaputt.
          Auch damit noch:
          host.Keller-RasPi2 2017-09-07 19:44:13.175 error instance system.adapter.mqtt-client.0 terminated with code 0 (OK)
          mqtt-client.0 2017-09-07 19:44:13.155 info terminating
          mqtt-client.0 2017-09-07 19:44:13.136 error at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Decoder.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:134:20)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Decoder. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Manager.Emitter.emit (/opt/iobroker/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Manager. (/opt/iobroker/node_modules/component-bind/index.js:21:15)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
          mqtt-client.0 2017-09-07 19:44:13.136 error at Socket. (/opt/iobroker/node_modules/iobroker.mqtt-client/client.js:119:92)
          mqtt-client.0 2017-09-07 19:44:13.136 error TypeError: Cannot read property 'topic' of undefined
          mqtt-client.0 2017-09-07 19:44:13.134 error uncaught exception: Cannot read property 'topic' of undefined
          • P Offline
            Pman
            Ich sehe grad, dass auf npm nur Version 0.3.0 ist, auf Github schon 0.3.2 und da gibt es genau für diesen Fehler einen Fix.
              Danke!
              Installation läuft.
              Bis gleich
                Danke soweit!
                jetzt wird die Ampel grün und es kommt (von unten nach oben!):
                mqtt-client.0	2017-09-07 19:58:25.685	info	connected to broker
                mqtt-client.0	2017-09-07 19:58:25.549	info	Try to connect to mqtt://192.168.138.74:1883?clientId=KellerPi
                mqtt-client.0	2017-09-07 19:58:25.468	info	starting. Version 0.3.2 in /opt/iobroker/node_modules/iobroker.mqtt-client, node: v6.11.1
                mqtt-client.0	2017-09-07 19:58:25.186	info	States connected to redis: 192.168.138.53:6379
                host.Keller-RasPi2	2017-09-07 19:58:21.229	info	instance system.adapter.mqtt-client.0 started with pid 5389
                Dann habe ich es wohl falsch verstanden mit broker und client.
                im broker habe ich den Smartmeter-Verbrauch (noch) nicht.
                Aber alle mqtt-Werte, die sich bereits auf dem broker tummeln jetzt auch im client.
                  Irgendwie bin ich doch noch nicht bereit für mqtt :(
                  Unmittelbar nach meinem letzten post ging die Ampel beim client auf gelb und die Daten wurden nicht aktualisiert, nur bei einem restart des mqtt-client.
                  Nachdem ich dann den mqtt-client ungerechtfertigterweise des Unheils schuldigen verdächtigte, hatte ich den mqtt-Adapter, konfiguriert als client, installiert, dort das selbe. (Nur zusätzlich noch mehr ungewolltes).
                  Also wieder den client installiert, aber keine Spontanheilung.
                  Zusätzlich noch die on connect und last will Daten eingegeben, und siehe da, das funktioniert, im Broker wird der client, auch bei gelber Ampel als verbunden angezeigt.
                  Bei deaktivierung erscheint im Broker beim Status jedoch [object][object], nach reaktivierung steht dort [KellerPi][online].
                  Bleiben für mich noch zwei Hauptfragen:
                  • Was kann ich noch testen, damit die Verbindung konstant bestehen bleibt, und die Daten fließen
                  • Wie kann ich die topics festlegen, die gesendet werden sollen, sowie die Richtung?
                  • kmxakK Offline
                    kmxakK Offline
                    kmxak
                    Also das mit der gelben Ampel ist normal.. Hatte nun tagelang einen Wemos mit den Temperatursensoren aktiv und trotz gelb alles lief.
                    korrigiert mich wenn ich falsch liege bin ja auch noch anfänger
                    Glaube der Client muss als erstes ein Topic erstellen sonst wird das nix. Das geht auch unter Windows (hatte einen Beitrag für den Sonoff POW geschrieben wie).
                    Das der Client alle bekannten Topics empfängt ist normal meine ich. Glaube aber das könnte man auch einschränken?!
                    MQTT ist für Anfänger echt schwer zu verstehen ich leide mit dir :lol:
                    Zu der ersten Hauptfrage ich hatte ja die Temperaturen vom Wemos geloggt und einen Flot erstellt die Daten wurden ja per MQTT übertragen und ich hatte im Flot viele Datenpunke. Es scheint zumindest stabil zu arbeiten selbst wenn der Adapter gelb ist.
                    Zum Testen hatte ich mal https://shiftr.io/ benutzt kam da aber nicht weiter. Das war noch gaaanz an meinem Anfang. Probier es ggf mal.
                    Gruß Alex
                    • P Offline
                      Pman
                      Also ich kann jetzt erstmal nur für den mqtt-client sprechen.
                      Der sollte von sich aus eigentlich gar nichts empfangen vom Broker, wenn man in der Adapter-Konfig keine allgemeinen Subscribes erstellt hat.
                      Nun kann man bei Objekten im Admin eine Synchronisation mit dem Broker herstellen. Dies geht nur in Senderichtung zum Broker (publish) oder auch in Empfangsrichtung vom Broker (subscribe).
                      "als Objekt" senden solltest du erstmal nicht verwenden. Dabei wird nicht nur der Wert, sondern der gesamte State (timestamp usw.) als JSON gesendet.
                      • P Offline
                        Pman
                        Ich habe jetzt nochmal mit Version 0.3.2 des mqtt-client Adapters getestet. Dazu habe ich am Rechner ein mosquitto Broker gestartet, ohne jede Konfiguration, kein SSL.
                        Im MQTT-Client nur IP und Client-ID konfiguriert.
                        Adapter verbindet und springt sofort auf Grün.
                        Verbindung mit SSL zu einem Broker bei cloudmqtt.com ist auch kein Problem und die Ampel wird auch grün.
                        Es scheint bei euch also noch ein grundsätzlicheres Problem zu geben mit dem Adapter.
                          Kann die Ursache auch im mqtt Adapter auf dem Tinkerboard liegen, der hier ja als Broker dient?
                          Dort trägt sich der client ordnungsgemäß ein, sendet die Daten einmalig.
                          ich denke dass bei dem ersten connect die Ampel auch längere Zeit auf grün war. Damals hatte der client auch alle mqtt.0 Daten des Brokers gezogen.
                          Daher noch einmal die allgemeine Frage.
                          Wie und wo muss ein client ind oder broker konfiguriert werden um Daten von einem Raspi zu einem Tinker zu schicken?
                          • P Offline
                            Pman
                            Du brauchst dafür nur den MQTT-Client.
                            Ich habe noch einen Verdacht. Kannst du mal den Adapter komplett deinstallieren und dann nochmal 0.3.2 neu installieren? Ist jetzt auch auf npm.
                              @Pman:
                              Kannst du mal den Adapter komplett deinstallieren und dann nochmal 0.3.2 neu installieren? `
                              Das hatte ich gestern sowieso gemacht, allerdings zwischenzeitlich den mqtt Adapter installiert.
                              Werde ich trotzdem heute nochmal machen.
                                @Pman:
                                Ich habe noch einen Verdacht `
                                Was hast du getan?
                                ich habe alles gleich gemacht, wie bei meinen ersten Gehversuchen.
                                Jetzt läuft es (fast) so, wie es sein soll.
                                client ist grün und auf dem broker kommt der ausgewählte State an, und wird aktualisiert.
                                lediglich werden auch States vom broker-Tinkerboard auf dem client subscribed, wohl weil ich im MQTT-Adapter unter
                                MQTT Einstellungen
                                Maske für Bekanntgeben von eigenen States:
                                mqtt.0.*
                                eingeben musste, weil sonst dort irgendetwas mit States aus dem Tankerkönig Adapter kollidierte.
                                Dann kann ich ja weiter forschen ;-)
                                • P Offline
                                  Pman
                                  Wofür nutzt du den MQTT-Adapter?
                                    @Pman:
                                    Wofür nutzt du den MQTT-Adapter? `
                                    Damit ich die Doku schreiben kann ;-)
                                    Der UseCase:
                                    Im Moment habe ich eine produktive ioBroker Umgebung bestehend aus einem Cubietruck als Master und einem Pi2 als Slave im Keller, auf dem der Smartmeter-Adapter meinen Stromzähler ausliest. Diese Werte konnte ich bisher nur in der Produktivumgebung verwenden. In allen Testumgebungen hatte ich keinen Zugriff auf die Smartmeter-Werte. Die Werte vom Solar-Wechselrichter hingegen konnte ich auf beliebig vielen Testsystemen auch gleichzeitig auswerten.
                                    Wie gesagt war ich von dem Vortrag von hobbyquaker dermaßen fasziniert, dass ich es immer schon mal probieren wollte. Der erste Schritt kam dann, dass ich (ebenfalls ohne Ahnung davon) über den LuftgüteThread zu zwei Teensy-LC kam, die Raumdaten per MQTT an eine Testinstallation schickten.
                                    Genau an diese Installation wollte ich jetzt auch weitere Daten senden, und durch die Limitierung der smartmeter-Werte auf einen RasPi bot sich das an. Das Ergebnis ist SUPER!!!
                                    Seit eben habe ich alle möglichen Werte zur Verfügung. Außerdem Werte, die auf dem Raspi per js gerechnet werden, müssen auf dem Tinker nicht nochmal gerechnet werden, sondern werden einfach mit ausgelesen.
                                    Außerdem wächst die Non-Homematic-Gemeinde bei ioBroker, da bin ich gerade dabei nach Möglichkeiten zu suchen ein Einsteigertutorial für non-HM User zu schreiben.
                                    Arduino / WeMos und Co. sind da oft verbreitet, und da bietet sich auch MQTT als Thema an.
                                    • P Offline
                                      Pman
                                      Sieht super aus, musst natürlich irgendwie die beiden Adapter trennen in der Doku, da man in der Regel eher nur einen von beiden benötigt.
                                        @Pman:
                                        musst natürlich irgendwie die beiden Adapter trennen in der Doku `
                                        Klar, gibt ja zwei Dokus, für jeden Adapter eine.
                                        @Pman:
                                        da man in der Regel eher nur einen von beiden benötigt. `
                                        Und da hänge ich gerade beim Spielen fest - na nicht ganz.
                                        Wenn ich es jetzt alles richtig verstanden habe sieht eine mqtt-Struktur z.B. so aus.
                                        Meine erste Stufe:
                                        Tinker1 = Broker; hier laufen alle Daten zusammen. Die clients geben ihn als host an.
                                        Teensy Gästezimmer (client) sendet seine Daten zum Broker, Daten werden dort verarbeitet und visualisiert
                                        Teensy Arcade (client) sendet seine Daten zum Broker, Daten werden dort verarbeitet und visualisiert
                                        Jetziger Ausbau:
                                        RasPi Keller (client) sendet seine Daten zum Broker, Daten werden dort verarbeitet und visualisiert
                                        und gaaanz aktueller Test
                                        Tinker 2 (meine cloud TestInstallation - hier will ich natürlich möglichst auch alles sehen) ebenfalls client.
                                        nur wie bekomme ich die Daten hierhin zum Visualisieren:
                                        einfach beim MQTT-Adapter unter MQTT-Einstellungen als publish-Maske /smartmeter* eingegeben brachte nur einzelne Datenpunkte
                                        Änderung in /smartmeter/0/* brachte einen weiteren.
                                        Erst die Änderung im MQTT-Client bei der subscriptions-Maske ebenfalls smartmeter/* eingeben erzeugte erst eine gelbe Ampel und nach restart des Adapters läuft es jetzt.
                                        Das war viel Try and Error (Macht mir nichts), aber wie ist es denn richtig?
                                        • P Offline
                                          Pman
                                          Den MQTT Adapter brauchst du eigentlich grundsätzlich nur wenn du einen Broker erstellen willst. der Adapter kann auch als Client funktionieren, insbesondere, wenn du nur subscriben willst aber keine (einzelnen) States publishen.
                                          Wenn du ioBroker nicht als MQTT-Broker nutzen willst müsste jedoch der MQTT-Client Adapter besser passen. Insbesondere weil man publish/subscribe eben PRO STATE einstellen kann.
                                          Es gibt nun zwei Wege, um Datenpunkte vom MQTT-Broker nach ioBroker zu bekommen.
                                          1.
                                          Du verknüpfst EINEN in ioBroker vorhandenen State mit dem EINEM Topic auf dem MQTT-Broker. Das wäre der Weg über die Einstellung über das Zahnrad im Admin. Du hast dann je nach Einstellung (publish/subscribe) eine Einwege- oder Zweiwegesynchronisation. Wenn du State-Änderungen im ioBroker auch zum MQTT-Broker senden möchtest, musst du auch publish für diesen State aktivieren.
                                          2.
                                          Du hast im ioBroker keine passenden States und möchtest Topics oder ganze Topicbäume vom MQTT-Broker subscriben. In diesem Fall stellst du bei den MQTT-Client Adaptereinstellungen unter Subscriptions eine Kommaseparierte Liste von Topics (ggf. mit Wildcard) ein. In deinem Fall wäre das ACHTUNG "/smartmeter/0/#". Auch nutzt man normalerweise keine Leading Slashes in MQTT, wenn du allerdings dorthin publishst musst du es auch hier beim subscriben angeben. So weit ich weiß sind "/1/2" und "1/2" nämlich wirklich unterschiedliche Topics. Mehr dazu und Wildcards unter MQTT hier:
                                          http://www.hivemq.com/blog/mqtt-essenti … -practices
                                          Was passiert wenn du hier ein Topic/Topic-Baum einträgst: Unter mqtt-client.0.* werden zu allen empfangenen Topics automatisch passende States angelegt und für diese wird automatisch der 1-Wege-Sync aktiviert. Danach verhält es sich wie bei 1. beschrieben. Du kannst zum testen auch einfach mal "$SYS/#" eintragen, dort veröffentlicht der MQTT-Broker normalerweise einige eigene Metriken.
