  4. Growatt exception: Error: {"result":3}
    5.4k
81 Beiträge 3 Kommentatoren 10.2k Aufrufe 3 Beobachtet
  • N nobbiman
    @wendy2702
    WLAN abgeschaltet
    ip a
    ergibt:
    pi@iobroker-pi:~ $ ip a
    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
        inet 127.0.0.1/8 scope host lo
           valid_lft forever preferred_lft forever
        inet6 ::1/128 scope host
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
        link/ether e4:5f:01:a4:ad:f2 brd ff:ff:ff:ff:ff:ff
        inet 192.168.2.146/24 brd 192.168.2.255 scope global dynamic noprefixroute eth0
           valid_lft 863702sec preferred_lft 755702sec
        inet6 fd00::3e0a:160b:48e1:5cbf/64 scope global dynamic mngtmpaddr noprefixroute
           valid_lft 7199sec preferred_lft 3599sec
        inet6 fe80::4bce:c165:ef80:5d3d/64 scope link
    Jetzt hängt mein ioBroker ..... nicht mehr!
    wendy2702W Online
    wendy2702W Online
    #71
    @nobbiman sagte in Growatt exception: Error: {"result":3}:
    Hing auch vorher nicht. Hat nur daten in ein logfile geschrieben.
    Hat sich was am Growatt geändert?
    Sonst jetzt nochmal loggen.
    N 1 Antwort Letzte Antwort
    • wendy2702W wendy2702
      N Offline
      N Offline
      nobbiman
      #72
      @wendy2702
      growatt.0
      	2023-02-02 15:58:06.565	error	Growatt exception: Error: {"result":3}
      growatt.0
      	2023-02-02 15:56:05.180	error	Growatt exception: Error: {"result":3}
      growatt.0
      	2023-02-02 15:56:04.227	info	starting. Version 2.0.0 in /opt/iobroker/node_modules/iobroker.growatt, node: v16.19.0, js-controller: 4.0.24
      host.iobroker-pi
      	2023-02-02 15:56:01.975	info	instance system.adapter.growatt.0 started with pid 1385
      host.iobroker-pi
      	2023-02-02 15:55:59.417	info	instance system.adapter.growatt.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      host.iobroker-pi
      	2023-02-02 15:55:58.897	info	stopInstance system.adapter.growatt.0 send kill signal
      growatt.0
      	2023-02-02 15:55:58.830	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      growatt.0
      	2023-02-02 15:55:58.828	info	terminating
      growatt.0
      	2023-02-02 15:55:58.826	info	Got terminate signal TERMINATE_YOURSELF
      host.iobroker-pi
      	2023-02-02 15:55:58.818	info	stopInstance system.adapter.growatt.0 (force=false, process=true)
      admin.0
      	2023-02-02 15:54:48.829	info	==> Connected system.user.admin from ::ffff:192.168.2.144
      • N nobbiman
        @wendy2702
        growatt.0
        growatt.0
        growatt.0
        host.iobroker-pi
        host.iobroker-pi
        host.iobroker-pi
        growatt.0
        growatt.0
        growatt.0
        host.iobroker-pi
        admin.0
        wendy2702W Online
        wendy2702W Online
        #73
        @nobbiman OK. Steht zwar nicht mehr auf Debug aber scheinbar gleicher Fehler.
        Dann tcpdump auf dem Interface starten, Adapter neu starten, tcpdump mit "ctrl+c" stoppen, file vom pi laden und mit wireshark schauen oder das file hier posten.
          N Offline
          N Offline
          nobbiman
          #74
          @wendy2702
          Ich sehe da gar nichts, hoffentlich du!
          EDIT: File gelöscht da möglicherweise Sensible Daten enthalten.
          • N nobbiman
            @wendy2702
            N Offline
            N Offline
            nobbiman
            schrieb am zuletzt editiert von nobbiman
            #75
            @wendy2702 Danke!
            • N nobbiman
              @wendy2702 Danke!
              wendy2702W Online
              wendy2702W Online
              #76
              @nobbiman Mögliche Ursache können die Meldungen über "TCP of a reassembled PDU" sein.
              Da sind schon auffällig viele. Der Grüne Bereich zeigt das anmelden per http und dann wechsel auf https.
              Danach sollten der Login durch sein, zumindest sehe ich keinen Fehler.
              Dann kommen die ganzen oben erwähnten Meldungen welche dazu führen könnten das der Adapter ein Problem hat.
              Falls Growatt eventuell weitere Server betreibt mal einen anderen probieren.
                N Offline
                N Offline
                nobbiman
                #77
                @wendy2702
                Ich gehe mal auf die Suche
                • N nobbiman
                  @wendy2702
                  wendy2702W Online
                  wendy2702W Online
                  #78
                  @nobbiman Nur noch um dein eigenes Netzwerk ausschließen zu können.
                  PI drekt an die FB
                  FB mal neu starten
                  N 2 Antworten Letzte Antwort
                    PI drekt an die FB
                    FB mal neu starten
                    N Offline
                    N Offline
                    nobbiman
                    #79
                    @wendy2702
                    Hilft leider auch nicht 😧
                      PI drekt an die FB
                      FB mal neu starten
                      N Offline
                      N Offline
                      nobbiman
                      #80
                      @wendy2702
                      Ich fasse es nicht! Nachdem ich heute ein issue bei github geöffnet habe und nochmals auf den Adapter schaue - ... ist der doch tatsächlich grün!
                      Im Log finde ich zwar ähnliche Meldungen, aber er verbindet 😕
                      growatt.0
                      	2023-02-03 17:47:04.960	debug	Growatt time for parseData : 64ms
                      growatt.0
                      	2023-02-03 17:47:04.895	debug	Growatt time for allPlantData : 506ms
                      growatt.0
                      	2023-02-03 17:47:04.845	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.665	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.620	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.559	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.513	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.465	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.389	debug	Enter lifeSignCallback 600000ms
                      growatt.0
                      	2023-02-03 17:47:04.389	debug	Growatt isConnected() : true
                      growatt.0
                      growatt.0
                      	2023-02-03 17:47:04.388	debug	Enter growattData, Param: sessionHold:true
                      growatt.0
                      	2023-02-03 17:46:34.989	debug	Leave growattData :601ms
                      Ich schau mal wie es weitergeht, bin zunächst aber mal erfreut - ich werde berichten!
                      Was bedeuten denn die Meldungen?
                      • N nobbiman
                        @wendy2702
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        growatt.0
                        wendy2702W Online
                        wendy2702W Online
                        #81
                        @nobbiman keine Ahnung. Ist was von deren API.
