  4. Paradigma SystaService LAN ModBus Kommunikation?
    5.1k
paradigmasystaservice lanmodbus
23 Beiträge 7 Kommentatoren 4.4k Aufrufe 6 Beobachtet
    acidsubway
    doch noch was hinbekommen
    :D
    loboL 1 Antwort Letzte Antwort
    • A acidsubway
      :D
      loboL Offline
      loboL Offline
      lobo
      @acidsubway
      Hi, könntest du mal bitte deine modbus adapter einstellungen teilen?
      Ich seh bei mir im log nur:
      modbus.0	2021-02-03 23:54:44.937	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:54:44.937	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:54:36.144	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
      modbus.0	2021-02-03 23:53:44.900	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:53:44.900	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:52:44.865	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:52:44.865	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:51:44.830	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:51:44.829	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:50:44.794	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:50:44.793	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:49:44.760	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:49:44.759	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:48:53.966	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
      modbus.0	2021-02-03 23:48:44.724	info	(60626) Disconnected from slave 192.168.30.27
      modbus.0	2021-02-03 23:48:44.723	info	(60626) Connected to slave 192.168.30.27
      modbus.0	2021-02-03 23:48:09.537	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
      modbus.0	2021-02-03 23:48:00.814	info	(60626) List of port: [{"path":"/dev/ttyS0"}]
      modbus.0	2021-02-03 23:47:44.688	info	(60626) Disconnected from slave 192.168.30.27
      • loboL lobo
        @acidsubway
        acidsubway
        @lobo
        2021-02-07 19_53_29-instances - ioBroker.jpg 2021-02-07 19_53_20-instances - ioBroker.jpg 2021-02-07 19_53_10-instances - ioBroker.jpg
        • A acidsubway
          @lobo
          MarcusF
          @acidsubway Hallo ich habe die gleiche Ausgangslage bekomme aber anscheinend keine Daten rein.
          gibt es noch was spezielles zu beachten? Danke und Gruß
          • M MarcusF
            MarcusF
            @marcusf Ergänzung anscheinen verliert mein Adapter die Verbindung
            R 1 Antwort Letzte Antwort
            • M MarcusF
              ReinWei
              @marcusf Ich bekomme den Systa_II Regler im Frühjahr geliefert und möchte diesen auch über ModBus an IOBroker anbinden. Gibt es zu Deinem Problem eine Lösung oder weitere Informationen? Danke und Gruß
              • R ReinWei
                MarcusF
                @reinwei Hallo ReinWei, leider habe ich hier selbst noch keine Lösung gefunden. Und eine Antwort oder Hilfestellung bisher auch nicht. Gruß Marcus
                wendy2702W R 2 Antworten Letzte Antwort
                • M MarcusF
                  wendy2702W Offline
                  wendy2702W Offline
                  @marcusf Ist das ein TCP Modbus device oder hängt da ein Adapter zwischen?
                  Stelle das Loggen mal auf Debug und poste die Ausgabe als Text in Code Tags </>
                  M 2 Antworten Letzte Antwort
                  • M MarcusF
                    ReinWei
                    @marcusf Hast du dieses Dokument?TH-3000_V1.1_0321_SystaComfort_II_CompactC_Modbus_Informationen_B_Fhw.pdf
                    • wendy2702W wendy2702
                      MarcusF
                      @wendy2702 Vielen Dank für deine Antwort.
                      das Log findest du unten.
                      Zur Info: Ich habe eine SystaComfort der ersten generation und das SystaService Lan Module am Bus der SystaComfort angeschlossen. Des weiteren hängt an dem Bus die SystaSolar (I) und ein SystaAqua II
                      Vielen Dank für die Unterstützung
                      Marcus
                      Mit der Software SystaService V. 1.60
                      SystaService 1.60 Log
                      11:59 4:08:400 - 0.000: 0F 04 01 00 00 E5
                      11:59 4:08:410 - 0.010: 10 02 05 00
                      11:59 4:08:490 - 0.080: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:08:510 - 0.020: 0F 04 01 00 00 E5
                      11:59 4:08:600 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:08:620 - 0.020: 0F 04 01 00 00 E5
                      11:59 4:08:710 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:08:730 - 0.020: 0F 04 01 00 00 E5
                      11:59 4:08:820 - 0.090: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:08:840 - 0.020: 0F 04 01 00 00 E5
                      11:59 4:08:850 - 0.010: 15 01 02
                      11:59 4:08:930 - 0.080: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:08:950 - 0.020: 0F 04 01 00 00 E5
                      11:59 4:08:970 - 0.020: 0B 10 10 12 08 29 01 02 07 02 58 01 FC 01 01 D5 02 06
                      11:59 4:09:000 - 0.030: 0B 11 10 00 01 A7 00 00 00 00 00 00 00 01 01 F2 02 02 02
                      11:59 4:09:050 - 0.050: 0F 22 04 00 53 6F 20 31 32 3A 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:060 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:070 - 0.010: 0B 01 13
                      11:59 4:09:120 - 0.050: FC 24 0B 01 01 A7 01 18 01 6C FE D9 00 00 02 00 02 0F 12 08 29 01 00 00 00 00 00 00 00 01 01 F2 22 00 00 00 00 00
                      11:59 4:09:210 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:220 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:230 - 0.010: 23 01 D0
                      11:59 4:09:320 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:330 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:430 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:440 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:450 - 0.010: 11 02 05 00
                      11:59 4:09:540 - 0.090: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:550 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:650 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:660 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:760 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:770 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:870 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:880 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:09:980 - 0.100: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      11:59 4:09:990 - 0.010: 0F 04 01 00 00 E5
                      11:59 4:10:010 - 0.020: 14 09 10 02 D8 20 ED 02 44 01 01
                      11:59 4:10:030 - 0.020: 14 08 10 00 01 02 58 02 00 04
                      11:59 4:10:090 - 0.060: 0F 22 04 00 53 6F 20 31 32 20 30 38 20 20 2D 31 2C 34 B0 43 50 72 6F 67 2E 20 31 20 48 65 69 7A 65 6E 20 20
                      < **ioBroker Log mit Debug für Modbus**
                      2023-01-29 12:02:45.729 - info: host.buanet-iobroker stopInstance system.adapter.modbus.0 send kill signal
                      2023-01-29 12:02:46.279 - info: host.buanet-iobroker instance system.adapter.modbus.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-01-29 12:02:46.802 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:47.219 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:02:48.769 - info: host.buanet-iobroker instance system.adapter.modbus.0 started with pid 20930
                      2023-01-29 12:02:48.990 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:49.121 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:02:50.099 - debug: modbus.0 (20930) Redis Objects: Use Redis connection: 127.0.0.1:9001
                      2023-01-29 12:02:50.151 - debug: modbus.0 (20930) Objects client ready ... initialize now
                      2023-01-29 12:02:50.154 - debug: modbus.0 (20930) Objects create System PubSub Client
                      2023-01-29 12:02:50.155 - debug: modbus.0 (20930) Objects create User PubSub Client
                      2023-01-29 12:02:50.184 - debug: modbus.0 (20930) Objects client initialize lua scripts
                      2023-01-29 12:02:50.191 - debug: modbus.0 (20930) Objects connected to redis: 127.0.0.1:9001
                      2023-01-29 12:02:50.217 - debug: modbus.0 (20930) Redis States: Use Redis connection: 127.0.0.1:9000
                      2023-01-29 12:02:50.226 - debug: modbus.0 (20930) States create System PubSub Client
                      2023-01-29 12:02:50.228 - debug: modbus.0 (20930) States create User PubSub Client
                      2023-01-29 12:02:50.240 - debug: modbus.0 (20930) States connected to redis: 127.0.0.1:9000
                      2023-01-29 12:02:50.278 - debug: modbus.0 (20930) Plugin sentry Initialize Plugin (enabled=true)
                      2023-01-29 12:02:50.606 - info: modbus.0 (20930) starting. Version 5.0.11 in /opt/iobroker/node_modules/iobroker.modbus, node: v16.18.1, js-controller: 4.0.23
                      2023-01-29 12:02:50.891 - debug: modbus.0 (20930) Initialize Objects for disInputs: []
                      2023-01-29 12:02:50.892 - debug: modbus.0 (20930) Initialize Objects for coils: []
                      2023-01-29 12:02:50.892 - debug: modbus.0 (20930) Initialize Objects for inputRegs: [{"_address":77,"deviceId":1,"name":"Test","description":"Test","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":77,"id":"inputRegisters.1.77_Test"},{"_address":4002,"name":"SpeichertempOben","description":"Speicher oben TW","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":true,"isScale":false,"address":4002,"deviceId":1,"id":"inputRegisters.1.4002_SpeichertempOben"},{"_address":4003,"name":"","description":"Solar Vorlauf","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4003,"deviceId":1,"id":"inputRegisters.1.4003"},{"_address":4012,"name":"","description":"Volumenstrom VF","unit":"l/min","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4012,"deviceId":1,"id":"inputRegisters.1.4012"},{"_address":4013,"name":"","description":"Solar Rücklauf","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4013,"deviceId":1,"id":"inputRegisters.1.4013"},{"_address":4016,"name":"","description":"Außentemperatur Kollector","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4016,"deviceId":1,"id":"inputRegisters.1.4016"},{"_address":4018,"name":"","description":"Temperatur Kollerktor","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4018,"deviceId":1,"id":"inputRegisters.1.4018"},{"_address":4027,"name":"","description":"Kollektorleistung","unit":"KW","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4027,"deviceId":1,"id":"inputRegisters.1.4027"}]
                      2023-01-29 12:02:50.894 - debug: modbus.0 (20930) Add inputRegisters.1.77_Test: {"_id":"inputRegisters.1.77_Test","type":"state","common":{"name":"Test","role":"value","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":77,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.894 - debug: modbus.0 (20930) Add inputRegisters.1.4002_SpeichertempOben: {"_id":"inputRegisters.1.4002_SpeichertempOben","type":"state","common":{"name":"Speicher oben TW","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4002,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.895 - debug: modbus.0 (20930) Add inputRegisters.1.4003: {"_id":"inputRegisters.1.4003","type":"state","common":{"name":"Solar Vorlauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4003,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.895 - debug: modbus.0 (20930) Add inputRegisters.1.4012: {"_id":"inputRegisters.1.4012","type":"state","common":{"name":"Volumenstrom VF","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"l/min"},"native":{"regType":"inputRegs","address":4012,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.896 - debug: modbus.0 (20930) Add inputRegisters.1.4013: {"_id":"inputRegisters.1.4013","type":"state","common":{"name":"Solar Rücklauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4013,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.897 - debug: modbus.0 (20930) Add inputRegisters.1.4016: {"_id":"inputRegisters.1.4016","type":"state","common":{"name":"Außentemperatur Kollector","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4016,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.897 - debug: modbus.0 (20930) Add inputRegisters.1.4018: {"_id":"inputRegisters.1.4018","type":"state","common":{"name":"Temperatur Kollerktor","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4018,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.898 - debug: modbus.0 (20930) Add inputRegisters.1.4027: {"_id":"inputRegisters.1.4027","type":"state","common":{"name":"Kollektorleistung","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"KW"},"native":{"regType":"inputRegs","address":4027,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1}}
                      2023-01-29 12:02:50.899 - debug: modbus.0 (20930) Initialize Objects for holdingRegs: [{"_address":4004,"name":"","description":"Sollwert Einspeisen Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":false,"isScale":"","address":4004,"deviceId":1,"id":"holdingRegisters.1.4004"},{"_address":4006,"name":"","description":"Maximal Temperatur Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4006,"deviceId":1,"id":"holdingRegisters.1.4006"},{"_address":4010,"name":"","description":"Solargewinn Tag","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4010,"deviceId":1,"id":"holdingRegisters.1.4010"},{"_address":4012,"name":"","description":"Solargewinn Gesamt","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4012,"deviceId":1,"id":"holdingRegisters.1.4012"}]
                      2023-01-29 12:02:50.899 - debug: modbus.0 (20930) Add holdingRegisters.1.4004: {"_id":"holdingRegisters.1.4004","type":"state","common":{"name":"Sollwert Einspeisen Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4004,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                      2023-01-29 12:02:50.900 - debug: modbus.0 (20930) Add holdingRegisters.1.4006: {"_id":"holdingRegisters.1.4006","type":"state","common":{"name":"Maximal Temperatur Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4006,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                      2023-01-29 12:02:50.900 - debug: modbus.0 (20930) Add holdingRegisters.1.4010: {"_id":"holdingRegisters.1.4010","type":"state","common":{"name":"Solargewinn Tag","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4010,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                      2023-01-29 12:02:50.901 - debug: modbus.0 (20930) Add holdingRegisters.1.4012: {"_id":"holdingRegisters.1.4012","type":"state","common":{"name":"Solargewinn Gesamt","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4012,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                      2023-01-29 12:02:50.993 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:51.421 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:02:51.915 - info: modbus.0 (20930) Connected to slave 192.168.0.186
                      2023-01-29 12:02:51.916 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:02:51.918 - debug: modbus.0 (20930) Initialization of scale factors done!
                      2023-01-29 12:02:51.919 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:02:51.936 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:02:52.869 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:52.938 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:02:52.943 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:02:53.835 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:02:54.946 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:02:54.950 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:02:54.971 - info: smartmeter.0 (511) Received 7 values, 2 updated
                      2023-01-29 12:02:56.667 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:02:57.057 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:58.004 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:02:58.004 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:02:58.016 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:02:58.948 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:02:59.017 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:02:59.025 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:02:59.227 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:00.841 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:01.025 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:01.032 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:01.391 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:03.129 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:03.337 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:04.084 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:04.085 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:04.088 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:05.013 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:05.089 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:05.097 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:05.394 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:06.898 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:07.100 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:07.104 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:07.735 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:08.988 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:10.008 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:10.156 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:10.156 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:10.160 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:10.873 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:11.160 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:11.168 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:12.142 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:12.970 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:13.170 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:13.175 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:14.401 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:15.056 - info: smartmeter.0 (511) Received 7 values, 2 updated
                      2023-01-29 12:03:16.227 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:16.228 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:16.230 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:16.614 - info: smartmeter.1 (526) Received 10 values, 2 updated
                      2023-01-29 12:03:16.941 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:17.231 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:17.239 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:18.831 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:18.884 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:19.241 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:19.246 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:21.011 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:21.023 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:22.296 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:22.297 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:22.302 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:22.866 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:23.127 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:23.302 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:23.311 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:24.897 - info: smartmeter.0 (511) Received 7 values, 2 updated
                      2023-01-29 12:03:25.232 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:25.312 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:25.317 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:26.782 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:27.536 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:28.371 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:28.371 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:28.374 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:29.084 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:29.374 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:29.382 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:29.887 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:30.965 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:31.384 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:31.389 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      2023-01-29 12:03:32.208 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:32.848 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:34.442 - debug: modbus.0 (20930) [DevID_1] Poll start ---------------------
                      2023-01-29 12:03:34.442 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 - 1 registers
                      2023-01-29 12:03:34.446 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 77 DONE
                      2023-01-29 12:03:34.572 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:35.151 - info: smartmeter.0 (511) Received 7 values, 2 updated
                      2023-01-29 12:03:35.446 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 - 27 registers
                      2023-01-29 12:03:35.454 - debug: modbus.0 (20930) [DevID_1/inputRegs] Poll address 4002 DONE
                      2023-01-29 12:03:36.866 - info: smartmeter.0 (511) Received 7 values, 3 updated
                      2023-01-29 12:03:36.877 - info: smartmeter.1 (526) Received 10 values, 3 updated
                      2023-01-29 12:03:37.457 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 - 10 registers
                      2023-01-29 12:03:37.462 - debug: modbus.0 (20930) [DevID_1/holdingRegs] Poll address 4004 DONE
                      wendy2702W G 2 Antworten Letzte Antwort
                      • R ReinWei
                        MarcusF
                        @reinwei Danke für das Dokument, schaue ich mir mal an, mal sehen ob ich damit weiter kommen. Habe allerdings eine SystaComfort der ersten generation in verbindung mit dem SysService LAN Interface welches ich über den modbus Adapter grundsätzlich verbinden kann.
                        Danke und Gruß
                        Marcus
                          MarcusF
                          @wendy2702
                          Hier nochmal das Log für den Modbus Adapter aus ioBroker irgendwie habe ich das mit den Tags im ersten Reply nicht rein bekommen.
                          modbus.0
                          2023-01-29 12:26:12.709	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                          modbus.0
                          2023-01-29 12:26:12.702	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                          modbus.0
                          2023-01-29 12:26:11.701	debug	[DevID_1/inputRegs] Poll address 77 DONE
                          modbus.0
                          2023-01-29 12:26:11.699	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                          modbus.0
                          2023-01-29 12:26:11.698	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2023-01-29 12:26:08.644	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                          modbus.0
                          2023-01-29 12:26:08.639	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                          modbus.0
                          2023-01-29 12:26:06.637	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                          modbus.0
                          2023-01-29 12:26:06.629	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                          modbus.0
                          2023-01-29 12:26:05.628	debug	[DevID_1/inputRegs] Poll address 77 DONE
                          modbus.0
                          2023-01-29 12:26:05.616	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                          modbus.0
                          2023-01-29 12:26:05.614	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2023-01-29 12:26:02.561	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                          modbus.0
                          2023-01-29 12:26:02.557	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                          modbus.0
                          2023-01-29 12:26:00.554	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                          modbus.0
                          2023-01-29 12:26:00.547	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                          modbus.0
                          2023-01-29 12:25:59.545	debug	[DevID_1/inputRegs] Poll address 77 DONE
                          modbus.0
                          2023-01-29 12:25:59.542	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                          modbus.0
                          2023-01-29 12:25:59.541	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2023-01-29 12:25:56.489	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                          modbus.0
                          2023-01-29 12:25:56.483	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                          modbus.0
                          2023-01-29 12:25:54.482	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                          modbus.0
                          2023-01-29 12:25:54.474	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                          modbus.0
                          2023-01-29 12:25:53.473	debug	[DevID_1/inputRegs] Poll address 77 DONE
                          modbus.0
                          2023-01-29 12:25:53.461	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                          modbus.0
                          2023-01-29 12:25:53.461	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2023-01-29 12:25:50.408	debug	[DevID_1/holdingRegs] Poll address 4004 DONE
                          modbus.0
                          2023-01-29 12:25:50.403	debug	[DevID_1/holdingRegs] Poll address 4004 - 10 registers
                          modbus.0
                          2023-01-29 12:25:48.400	debug	[DevID_1/inputRegs] Poll address 4002 DONE
                          modbus.0
                          2023-01-29 12:25:48.395	debug	[DevID_1/inputRegs] Poll address 4002 - 27 registers
                          modbus.0
                          2023-01-29 12:25:47.392	debug	[DevID_1/inputRegs] Poll address 77 DONE
                          modbus.0
                          2023-01-29 12:25:47.375	debug	[DevID_1/inputRegs] Poll address 77 - 1 registers
                          modbus.0
                          2023-01-29 12:25:47.374	debug	Initialization of scale factors done!
                          modbus.0
                          2023-01-29 12:25:47.372	debug	[DevID_1] Poll start ---------------------
                          modbus.0
                          2023-01-29 12:25:47.371	info	Connected to slave 192.168.0.186
                          modbus.0
                          2023-01-29 12:25:47.012	debug	Add holdingRegisters.1.4012: {"_id":"holdingRegisters.1.4012","type":"state","common":{"name":"Solargewinn Gesamt","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4012,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                          modbus.0
                          2023-01-29 12:25:47.012	debug	Add holdingRegisters.1.4010: {"_id":"holdingRegisters.1.4010","type":"state","common":{"name":"Solargewinn Tag","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"kWh"},"native":{"regType":"holdingRegs","address":4010,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                          modbus.0
                          2023-01-29 12:25:47.011	debug	Add holdingRegisters.1.4006: {"_id":"holdingRegisters.1.4006","type":"state","common":{"name":"Maximal Temperatur Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4006,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                          modbus.0
                          2023-01-29 12:25:47.011	debug	Add holdingRegisters.1.4004: {"_id":"holdingRegisters.1.4004","type":"state","common":{"name":"Sollwert Einspeisen Wärmesenke 1","role":"value","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":4004,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":0.1,"poll":true}}
                          modbus.0
                          2023-01-29 12:25:47.010	debug	Initialize Objects for holdingRegs: [{"_address":4004,"name":"","description":"Sollwert Einspeisen Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":false,"isScale":"","address":4004,"deviceId":1,"id":"holdingRegisters.1.4004"},{"_address":4006,"name":"","description":"Maximal Temperatur Wärmesenke 1","unit":"°C","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4006,"deviceId":1,"id":"holdingRegisters.1.4006"},{"_address":4010,"name":"","description":"Solargewinn Tag","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4010,"deviceId":1,"id":"holdingRegisters.1.4010"},{"_address":4012,"name":"","description":"Solargewinn Gesamt","unit":"kWh","type":"uint32be","len":2,"factor":0.1,"offset":0,"formula":"","role":"value","room":"","poll":true,"wp":"","cw":"","isScale":"","address":4012,"deviceId":1,"id":"holdingRegisters.1.4012"}]
                          modbus.0
                          2023-01-29 12:25:47.010	debug	Add inputRegisters.1.4027: {"_id":"inputRegisters.1.4027","type":"state","common":{"name":"Kollektorleistung","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"KW"},"native":{"regType":"inputRegs","address":4027,"deviceId":1,"type":"uint32be","len":2,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.009	debug	Add inputRegisters.1.4018: {"_id":"inputRegisters.1.4018","type":"state","common":{"name":"Temperatur Kollerktor","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4018,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.008	debug	Add inputRegisters.1.4016: {"_id":"inputRegisters.1.4016","type":"state","common":{"name":"Außentemperatur Kollector","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4016,"deviceId":1,"type":"int16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.007	debug	Add inputRegisters.1.4013: {"_id":"inputRegisters.1.4013","type":"state","common":{"name":"Solar Rücklauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4013,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.007	debug	Add inputRegisters.1.4012: {"_id":"inputRegisters.1.4012","type":"state","common":{"name":"Volumenstrom VF","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"l/min"},"native":{"regType":"inputRegs","address":4012,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.006	debug	Add inputRegisters.1.4003: {"_id":"inputRegisters.1.4003","type":"state","common":{"name":"Solar Vorlauf","role":"value","type":"number","read":true,"write":false,"def":0,"unit":"°C"},"native":{"regType":"inputRegs","address":4003,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.005	debug	Add inputRegisters.1.4002_SpeichertempOben: {"_id":"inputRegisters.1.4002_SpeichertempOben","type":"state","common":{"name":"Speicher oben TW","role":"value.temperature","type":"number","read":true,"write":false,"def":0,"unit":"*C"},"native":{"regType":"inputRegs","address":4002,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.005	debug	Add inputRegisters.1.77_Test: {"_id":"inputRegisters.1.77_Test","type":"state","common":{"name":"Test","role":"value","type":"number","read":true,"write":false,"def":0,"unit":""},"native":{"regType":"inputRegs","address":77,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1}}
                          modbus.0
                          2023-01-29 12:25:47.003	debug	Initialize Objects for inputRegs: [{"_address":77,"deviceId":1,"name":"Test","description":"Test","unit":"","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":77,"id":"inputRegisters.1.77_Test"},{"_address":4002,"name":"SpeichertempOben","description":"Speicher oben TW","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value.temperature","room":"","cw":true,"isScale":false,"address":4002,"deviceId":1,"id":"inputRegisters.1.4002_SpeichertempOben"},{"_address":4003,"name":"","description":"Solar Vorlauf","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4003,"deviceId":1,"id":"inputRegisters.1.4003"},{"_address":4012,"name":"","description":"Volumenstrom VF","unit":"l/min","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4012,"deviceId":1,"id":"inputRegisters.1.4012"},{"_address":4013,"name":"","description":"Solar Rücklauf","unit":"*C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4013,"deviceId":1,"id":"inputRegisters.1.4013"},{"_address":4016,"name":"","description":"Außentemperatur Kollector","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4016,"deviceId":1,"id":"inputRegisters.1.4016"},{"_address":4018,"name":"","description":"Temperatur Kollerktor","unit":"°C","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4018,"deviceId":1,"id":"inputRegisters.1.4018"},{"_address":4027,"name":"","description":"Kollektorleistung","unit":"KW","type":"uint32be","len":2,"factor":1,"offset":0,"formula":"","role":"value","room":"","cw":true,"isScale":false,"address":4027,"deviceId":1,"id":"inputRegisters.1.4027"}]
                          modbus.0
                          2023-01-29 12:25:47.003	debug	Initialize Objects for coils: []
                          MOD EDIT: LOG IN CODE TAGS </> GESETZT
                          • Thomas BraunT Online
                            @marcusf sagte in Paradigma SystaService LAN ModBus Kommunikation?:
                            Dann schau dir im vom Mod für dich editierten Beitrag an wie es richtig gemacht wird. Tipp: Die Steuerzeichen bekommst du mit dem </> Icon serviert.
                            • M MarcusF
                              Marcus
                              wendy2702W Offline
                              wendy2702W Offline
                              IOB läuft im Container ?
                              Ist der Port 502 durchgereicht nach aussen?
                                MarcusF
                                @thomas-braun Vielen Dank hatte ich versucht doch das Log wurde im ersten Post nicht gespeichert. Versuche es beim nächsten mal. Gruß Marcus
                                  MarcusF
                                  IUwendy2702 Hallo Wendy2702, ja läuft im Container auf meiner Synology. Ich habe den Port jetzt nochmal durchgereicht, doch das bringt keine Veränderung. Der Verbindungstatus war vorher auch wie im Bild.
                                  In den Objectdaten wir die Verbindung auch ausgegebenScreenshot 2023-01-30 084156.jpg
                                  info/connection = true
                                  Danke für die Unterstützung
                                  Marcus
                                  • M MarcusF
                                    Marcus
                                    wendy2702W Offline
                                    wendy2702W Offline
                                    @marcusf Mal was ganz triviales, hast du mal anderen Browser versucht oder den Cache gelöscht bzw. Forced Reload?
                                    Welchen Zeitstempel haben die Objekte?
                                      MarcusF
                                      @wendy2702 Hallo Wendy2702, auch mit anderen Browsern oder force Reload gibt es keinen Unterschied. Ich habe den Objectbaum mal gelöscht und nach neustart des Adapters wurden alle neu angelegt. Einen Zeitstemple habe ich nicht direkt gefunden, kann nur vermuten, dass er sich im TS Json des objects verbirgt.
                                      Gruß Marcus
                                      • M MarcusF
                                        Gruß Marcus
                                        wendy2702W Offline
                                        wendy2702W Offline
                                        @marcusf Zeitstempel sieht man wenn man mit der Maus langsam ueber das Objekt faehrt.
                                        Kannst du mal alle bis auf einen Register loeschen.
                                        Und zeig doch mal deine Register als Screenshot.
                                        Und beantworte mal diese Frage: https://forum.iobroker.net/post/930606
                                        • M MarcusF
                                          Marcus
                                          glitzi
                                          @marcusf
                                          kannst du mir die Software in Version 1.6 bereitstellen? ich haben noch Version 1,56
