  4. Tuya Adapter / Google Home / Alias
6 Beiträge 3 Kommentatoren 456 Aufrufe 2 Beobachtet
  • Horst BöttcherH Offline
    Horst Böttcher
    schrieb am zuletzt editiert von Horst Böttcher
    Ich habe eigentlich keine Probleme mit dem Tuya Adapter und der HAMA WLAN Steckdosenleiste
    Wenn ich direkt im System Schalte geht es
    Sobald ich ich die Steckdose
    Google einbinde wird diese Steckdose nicht geschalten
    Datenpunkte
    Datenpunkte Alias
    iodot
    iot.0
    2023-01-28 22:42:30.430	error	[GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: [object Object]
    iot.0
    2023-01-28 22:42:30.254	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:42:30.253	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:42:30.253	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:41:26.016	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:41:26.015	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:41:26.013	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:36.588	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:36.587	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:36.583	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:34.345	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:34.344	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:31:34.343	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:33.439	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:33.438	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:33.437	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:30.104	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:30.103	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:30:30.102	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    coronavirus-statistics.0
    2023-01-28 22:30:12.625	warn	This object will not be created in future versions. Please report this to the developer.
    2023-01-28 22:30:12.619	warn	Object coronavirus-statistics.0.countryTranslator is invalid: Default value has to be type "string" but received type "number"
    iot.0
    2023-01-28 22:29:16.079	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:29:16.078	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:29:16.078	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:29:13.783	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:29:13.782	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:29:13.782	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:28:40.075	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:28:40.075	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    iot.0
    2023-01-28 22:28:40.074	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
    ioBroker auf Proxmox (Debian) auf LENOVO PC Thinkcentre als Produktivsystem
    • Horst BöttcherH Horst Böttcher
      Datenpunkte
      Datenpunkte Alias
      iodot
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      iot.0
      haselchenH Offline
      haselchenH Offline
      haselchen
      @horst-böttcher
      Was sagt dir die erste Meldung aus dem Log?
      Horst BöttcherH 1 Antwort Letzte Antwort
      • haselchenH haselchen
        @horst-böttcher
        Horst Böttcher
        @haselchen ja aber andere Geräte lassen sich schalten
          wendy2702W Online
          wendy2702W Online
          @horst-böttcher Steht ja noch mehr im log dem man mal nachgehen kann
            Horst Böttcher
            @wendy2702
            hab jetzt den iodot neu gestartet
            iot.0
            16489	2023-01-29 00:14:21.461	error	[GHOME] Url Key error. Google Request and Response are working. But device states are not reported automatically. If you have pro license please try to delete iot.0.certs: [object Object]
            iot.0
            16489	2023-01-29 00:14:21.078	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor_2 is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
            iot.0
            16489	2023-01-29 00:14:21.075	warn	[GHOME] alias.0.Räume.PC_Raum.Monitor is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
            iot.0
            16489	2023-01-29 00:14:21.074	warn	[GHOME] alias.0.Räume.PC_Raum.Mischpult is ignored because the property smartName is false or ignore. To use this state again, remove the property smartName in Object explorer or add it manually under Google Devices
            iot.0
            16489	2023-01-29 00:14:21.071	info	[GHOME] hm-rpc.1.00201A49979BA4.0 is auto added with type info.
            iot.0
            16489	2023-01-29 00:14:21.038	info	[GHOME] hm-rpc.1.00201D89898A49.0 is auto added with type info.
            iot.0
            16489	2023-01-29 00:14:21.005	info	[GHOME] hm-rpc.1.00201D898A2D9B.0 is auto added with type info.
            iot.0
            16489	2023-01-29 00:14:20.974	info	[GHOME] hm-rpc.1.00201A49979BA3.0 is auto added with type info.
            iot.0
            16489	2023-01-29 00:14:20.942	info	[GHOME] tuya.0.bfcd718cf024850462lvpc is auto added with type rgbSingle.
            iot.0
            16489	2023-01-29 00:14:20.893	info	[GHOME] tuya.0.bf8d212970881e6ba7tg4b is auto added with type rgbSingle.
            iot.0
            16489	2023-01-29 00:14:20.840	info	[GHOME] tuya.0.bf5239791bbba6aa62s30f is auto added with type dimmer.
            iot.0
            16489	2023-01-29 00:14:20.798	info	[GHOME] tuya.0.bf46c4d4d81b4cc7c8tzju is auto added with type rgbSingle.
            iot.0
            16489	2023-01-29 00:14:20.746	info	[GHOME] tapo.0.80237BDF56F45FAFCF08DC41984695061EBBFC11 is auto added with type info.
            iot.0
            16489	2023-01-29 00:14:20.692	info	[GHOME] deconz.0.Lights.8 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.633	info	[GHOME] deconz.0.Lights.6 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.573	info	[GHOME] deconz.0.Lights.26 is auto added with type hue.
            iot.0
            16489	2023-01-29 00:14:20.507	info	[GHOME] deconz.0.Lights.19 is auto added with type dimmer.
            iot.0
            16489	2023-01-29 00:14:20.445	info	[GHOME] deconz.0.Lights.18 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.377	info	[GHOME] deconz.0.Lights.17 is auto added with type dimmer.
            iot.0
            16489	2023-01-29 00:14:20.316	info	[GHOME] deconz.0.Lights.16 is auto added with type dimmer.
            iot.0
            16489	2023-01-29 00:14:20.256	info	[GHOME] deconz.0.Lights.12 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.194	info	[GHOME] deconz.0.Lights.11 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.118	info	[GHOME] deconz.0.Lights.10 is auto added with type ct.
            iot.0
            16489	2023-01-29 00:14:20.028	info	[GHOME] hm-rpc.1.00201A49979BA3 is auto added with type thermostat.
            iot.0
            16489	2023-01-29 00:14:19.945	info	[GHOME] hm-rpc.1.00201A49979BA4 is auto added with type thermostat.
            iot.0
            16489	2023-01-29 00:14:19.855	info	[GHOME] hm-rpc.1.00201D89898A49 is auto added with type thermostat.
            iot.0
            16489	2023-01-29 00:14:19.780	info	[GHOME] hm-rpc.1.00201D898995A3 is auto added with type thermostat.
            iot.0
            16489	2023-01-29 00:14:19.679	info	[GHOME] hm-rpc.1.00201D898A2D9B is auto added with type thermostat.
            iot.0
            16489	2023-01-29 00:14:15.285	info	Connection changed: connect
            iot.0
            16489	2023-01-29 00:14:14.760	info	Connecting with a18wym7vjdl22g.iot.eu-west-1.amazonaws.com
            iot.0
            16489	2023-01-29 00:14:14.608	info	starting. Version 1.14.3 in /opt/iobroker/node_modules/iobroker.iot, node: v16.19.0, js-controller: 4.0.24
            iot.0
            23961	2023-01-29 00:14:09.027	info	Terminated (NO_ERROR): Without reason
            iot.0
            23961	2023-01-29 00:14:09.025	info	terminating
            iot.0
            23961	2023-01-29 00:14:08.968	info	Got terminate signal TERMINATE_YOURSELF
            iot.0
            23961	2023-01-29 00:14:08.920	info	Connection lost
            iot.0
            23961	2023-01-29 00:14:08.919	info	Connection changed: disconnect
            iot.0
            23961	2023-01-29 00:14:08.833	info	Adapter is disabled => stop
            log tuya adapter
            tuya.0
            17942	2023-01-29 00:16:59.095	info	bf5239791bbba6aa62s30f: Error on Reconnect (3): connect EHOSTUNREACH 192.168.178.44:6668
            tuya.0
            17942	2023-01-29 00:16:52.775	info	24300621c4dd5715010d: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.136:6668
            tuya.0
            17942	2023-01-29 00:16:49.652	info	24300621c4dd5715010d Init with IP=192.168.178.136, Key=51a95c7c6026834f, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:49.652	info	24300621c4dd5715010d: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:49.015	info	bfa2eb540d42e6ed554vx7: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.126:6668
            tuya.0
            17942	2023-01-29 00:16:48.549	info	bfe7090bfb7be477fbbhbf: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:48.547	info	bfe7090bfb7be477fbbhbf Init with IP=192.168.178.21, Key=fad4b890ba736b14, Version=3.4
            tuya.0
            17942	2023-01-29 00:16:48.547	info	bfe7090bfb7be477fbbhbf: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:47.814	info	bfe738f15da8902f970vq3: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.123:6668
            tuya.0
            17942	2023-01-29 00:16:47.155	info	bfcd718cf024850462lvpc Init with IP=192.168.178.25, Key=9a66834513c9c841, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:47.154	info	bfcd718cf024850462lvpc: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:45.888	info	bfa2eb540d42e6ed554vx7 Init with IP=192.168.178.126, Key=73b552eabe5fb0ce, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:45.887	info	bfa2eb540d42e6ed554vx7: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:44.657	info	bfe738f15da8902f970vq3 Init with IP=192.168.178.123, Key=9770535830190f5d, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:44.656	info	bfe738f15da8902f970vq3: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:43.498	info	80570248500291110eda: Do not connect locally to device
            tuya.0
            17942	2023-01-29 00:16:43.262	info	bf46c4d4d81b4cc7c8tzju: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:43.244	info	bf46c4d4d81b4cc7c8tzju Init with IP=192.168.178.40, Key=066b80368f33a56b, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:43.243	info	bf46c4d4d81b4cc7c8tzju: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:41.841	info	bf8d212970881e6ba7tg4b: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:41.741	info	bf8d212970881e6ba7tg4b Init with IP=192.168.178.47, Key=c9daded07638d5eb, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:41.741	info	bf8d212970881e6ba7tg4b: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:40.284	info	4530056170039f4b4878 Init with IP=192.168.178.33, Key=5f3bb9bc9e7bf216, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:40.282	info	4530056170039f4b4878: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:38.945	info	bf1aec7f869553102efdcw Init with IP=192.168.178.43, Key=b129837a29e595c2, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:38.945	info	bf1aec7f869553102efdcw: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:37.705	info	60034685500291106f69 Init with IP=192.168.178.23, Key=4793e058bdf0238a, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:37.704	info	60034685500291106f69: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:36.445	info	3327114024a1600da844 Init with IP=192.168.178.26, Key=4f633c7296eddc43, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:36.444	info	3327114024a1600da844: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:35.975	info	bf5239791bbba6aa62s30f: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.44:6668
            tuya.0
            17942	2023-01-29 00:16:35.495	info	bfa2eb540d42e6ed554vx7: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.126:6668
            tuya.0
            17942	2023-01-29 00:16:35.338	info	bfe738f15da8902f970vq3: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.123:6668
            tuya.0
            17942	2023-01-29 00:16:35.300	info	80570248500291110eda: Do not connect locally to device
            tuya.0
            17942	2023-01-29 00:16:35.268	info	24300621c4dd5715010d: Error on Reconnect (1): connect EHOSTUNREACH 192.168.178.136:6668
            tuya.0
            17942	2023-01-29 00:16:35.167	info	4530056170039f47f981 Init with IP=192.168.178.28, Key=35284d802222c9ff, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:35.166	info	4530056170039f47f981: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:34.808	error	Login for MQTT failed: TypeError: Cannot destructure property 'access_token' of 'res.result' as it is undefined.
            tuya.0
            17942	2023-01-29 00:16:32.878	info	Listen for encrypted local Tuya devices on port 6667
            tuya.0
            17942	2023-01-29 00:16:32.877	info	Listen for local Tuya devices on port 6666
            tuya.0
            17942	2023-01-29 00:16:32.407	info	Try to sync devices from Cloud using stored cloud credentials
            tuya.0
            17942	2023-01-29 00:16:32.396	info	Existing devices initialized
            tuya.0
            17942	2023-01-29 00:16:32.389	info	bf5239791bbba6aa62s30f Init with IP=192.168.178.44, Key=2deb3949c5b6c236, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.388	info	bf5239791bbba6aa62s30f: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.384	info	4530056170039f4b4878 Init with IP=192.168.178.33, Key=5f3bb9bc9e7bf216, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.383	info	4530056170039f4b4878: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.380	info	bfa2eb540d42e6ed554vx7 Init with IP=192.168.178.126, Key=73b552eabe5fb0ce, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.379	info	bfa2eb540d42e6ed554vx7: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.346	info	bfe7090bfb7be477fbbhbf Init with IP=192.168.178.21, Key=fad4b890ba736b14, Version=3.4
            tuya.0
            17942	2023-01-29 00:16:32.346	info	bfe7090bfb7be477fbbhbf: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.332	info	bf8d212970881e6ba7tg4b Init with IP=192.168.178.47, Key=c9daded07638d5eb, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.323	info	bf8d212970881e6ba7tg4b: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.254	info	bf4c81722d03ef45d2rfki: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.243	info	bf46c4d4d81b4cc7c8tzju Init with IP=192.168.178.40, Key=066b80368f33a56b, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.243	info	bf46c4d4d81b4cc7c8tzju: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.241	info	4530056170039f47f981 Init with IP=192.168.178.28, Key=35284d802222c9ff, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.240	info	4530056170039f47f981: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.239	info	7163075570039f3b64a6: Do not connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.212	info	80570248500291110eda: Do not connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.184	info	bfe738f15da8902f970vq3 Init with IP=192.168.178.123, Key=9770535830190f5d, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.183	info	bfe738f15da8902f970vq3: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.179	info	60034685500291106f69 Init with IP=192.168.178.23, Key=4793e058bdf0238a, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.178	info	60034685500291106f69: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.175	info	3327114024a1600da844 Init with IP=192.168.178.26, Key=4f633c7296eddc43, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.174	info	3327114024a1600da844: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.165	info	bf1aec7f869553102efdcw Init with IP=192.168.178.43, Key=b129837a29e595c2, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.164	info	bf1aec7f869553102efdcw: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.152	info	bfcd718cf024850462lvpc Init with IP=192.168.178.25, Key=9a66834513c9c841, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.151	info	bfcd718cf024850462lvpc: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:32.097	info	24300621c4dd5715010d Init with IP=192.168.178.136, Key=51a95c7c6026834f, Version=3.3
            tuya.0
            17942	2023-01-29 00:16:32.093	info	24300621c4dd5715010d: Connect locally to device
            tuya.0
            17942	2023-01-29 00:16:29.959	info	starting. Version 3.13.0 in /opt/iobroker/node_modules/iobroker.tuya, node: v16.19.0, js-controller: 4.0.24
            tuya.0
            23497	2023-01-29 00:16:20.283	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
            tuya.0
            23497	2023-01-29 00:16:20.281	info	terminating
            tuya.0
            23497	2023-01-29 00:16:18.958	info	Got terminate signal TERMINATE_YOURSELF
            tuya.0
            23497	2023-01-29 00:16:17.275	info	Got terminate signal TERMINATE_YOURSELF
            tuya.0
            23497	2023-01-29 00:15:19.814	info	4530056170039f47f981 Init with IP=192.168.178.28, Key=35284d802222c9ff, Version=3.3
            tuya.0
            23497	2023-01-29 00:15:19.812	info	4530056170039f47f981: Connect locally to device
            tuya.0
            23497	2023-01-29 00:11:16.155	info	4530056170039f4b4878 Init with IP=192.168.178.33, Key=5f3bb9bc9e7bf216, Version=3.3
            tuya.0
            23497	2023-01-29 00:11:16.154	info	4530056170039f4b4878: Connect locally to device
            tuya.0
            23497	2023-01-29 00:07:01.185	info	4530056170039f4b4878 Init with IP=192.168.178.33, Key=5f3bb9bc9e7bf216, Version=3.3
            tuya.0
            23497	2023-01-29 00:07:01.184	info	4530056170039f4b4878: Connect locally to device
            tuya.0
            23497	2023-01-29 00:03:25.382	info	60034685500291106f69 Init with IP=192.168.178.23, Key=4793e058bdf0238a, Version=3.3
            tuya.0
            23497	2023-01-29 00:03:25.381	info	60034685500291106f69: Connect locally to device
            tuya.0
            23497	2023-01-29 00:02:26.194	info	4530056170039f4b4878 Init with IP=192.168.178.33, Key=5f3bb9bc9e7bf216, Version=3.3
            tuya.0
            23497	2023-01-29 00:02:26.184	info	4530056170039f4b4878: Connect locally to device
              @wendy2702
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              iot.0
              log tuya adapter
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              tuya.0
              wendy2702W Online
              wendy2702W Online
              @horst-böttcher sagte in Tuya Adapter / Google Home / Alias:
              EHOSTUNREACH
              Geräte bzw. Geräte nicht erreichbar.
              Kenne aber TUYA und deren Netzwerk Topologie und -funktionsweise nicht. Kann also nicht viel helfen.
              Das mit dem State mal probiert?
