  4. BackitUp NAS Error Speedport Smart 4
    5.5k
91 Beiträge 4 Kommentatoren 10.8k Aufrufe 3 Beobachtet
  • N noidea
    user@iobroker:~$ sudo apt update
    [sudo] password for user:
    Hit:1 https://repos.influxdata.com/debian jammy InRelease
    Hit:2 https://deb.nodesource.com/node_16.x jammy InRelease
    Hit:3 http://archive.ubuntu.com/ubuntu jammy InRelease
    Get:4 http://archive.ubuntu.com/ubuntu jammy-updates InRelease [114 kB]
    Get:5 http://archive.ubuntu.com/ubuntu jammy-security InRelease [110 kB]
    Get:6 http://archive.ubuntu.com/ubuntu jammy-updates/main amd64 Packages [831 kB]
    Get:7 http://archive.ubuntu.com/ubuntu jammy-updates/restricted amd64 Packages [566 kB]
    Get:8 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages [785 kB]
    Get:9 http://archive.ubuntu.com/ubuntu jammy-updates/universe amd64 c-n-f Metadata [14.6 kB]
    Fetched 2422 kB in 2s (1226 kB/s)
    Reading package lists... Done
    61 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: https://repos.influxdata.com/debian/dists/jammy/InRelease: Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details.
    user@iobroker:~$
    @noidea sagte in BackitUp NAS Error Speedport Smart 4:
    War mir fast klar. Auch Update-Stau.
    Alles updaten.
    N 1 Antwort Letzte Antwort
      Alles updaten.
      N Offline
      N Offline
      noidea
      Das mach ich mit,richtig?
      apt update
      • N noidea
        apt update
        @noidea
        Zuerst das influx-Repo korrigieren.
        https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden/22
        Dann
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
          @noidea
          Dann
          iob stop
          sudo apt update
          sudo reboot
          N Offline
          N Offline
          noidea
          Hab jetzt alles uptodate, aber nachwievor die gleiche Fehlermeldung
          Started iobroker ...
          [DEBUG] [mount] start with {"mountType":"CIFS","type":"storage","source":"local","mount":"//192.168.2.1","debugging":true,"fileDir":"/opt/iobroker/iobroker-data/backitup","wakeOnLAN":false,"macAd":"20:DE:20:DE:20:DE","wolTime":"25","smb":"vers=1.0","sudo":true,"cifsDomain":"WORKGROUP","clientInodes":false,"deleteOldBackup":false,"ownDir":false,"dir":"/SanDisk-USBExtremePro/Backup/Speedport","dirMinimal":"sharename/backupDir","user":"speedport","pass":"****","ignoreErrors":false}
          [DEBUG] [mount] - noserverino option: false
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
          [DEBUG] [mount] - first mount attempt with smb option failed. try next mount attempt without smb option ...
          [DEBUG] [mount] - cifs-mount command: "sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups"
          [ERROR] [mount] - [undefined Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
          mount error: Server abruptly closed the connection.
          This can happen if the server does not support the SMB version you are trying to use.
          The default SMB version recently changed from SMB1 to SMB2.1 and above. Try mounting with vers=1.0.
          mount error(112): Host is down
          Refer to the mount.cifs(8) manual page (e.g. man mount.cifs) and kernel log messages (dmesg)
          [ERROR] [mount] - Error: Command failed: sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
          • N noidea
            @noidea
            smbclient -L 192.168.2.1 -U speedport
            Und
            ls -lA /opt/iobroker/backups
              @noidea
              Und
              N Offline
              N Offline
              noidea
              schrieb am zuletzt editiert von noidea
              user@iobroker:~$ smbclient -L 192.168.2.1 -U speedport
              Password for [WORKGROUP\speedport]:
                      Sharename       Type      Comment
                      speedport       Disk
                      IPC$            IPC       IPC Service (Speedport Smart 4 Typ A File-Server)
              Reconnecting with SMB1 for workgroup listing.
                      Server               Comment
                      Workgroup            Master
                      WORKGROUP            SPEEDPORT
              user@iobroker:~$ ls -lA /opt/iobroker/backups
              total 5416
              -rw-rw-r--+ 1 iobroker iobroker    5423 Jan 22 18:36 grafana_2023_01_22-18_36_10_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker    5420 Jan 22 19:59 grafana_2023_01_22-19_59_31_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker  141185 Jan 22 18:36 influxDB_2023_01_22-18_36_08_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker  143345 Jan 22 19:59 influxDB_2023_01_22-19_59_29_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker 2563931 Jan 22 18:36 iobroker_2023_01_22-18_36_04_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker 2563010 Jan 22 19:59 iobroker_2023_01_22-19_59_25_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker    4691 Jan 22 18:36 jarvis.0_2023_01_22-18_36_15_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker    4691 Jan 22 19:59 jarvis.0_2023_01_22-19_59_36_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker   41159 Jan 22 18:36 javascripts_2023_01_22-18_36_15_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker   41157 Jan 22 19:59 javascripts_2023_01_22-19_59_36_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker    2685 Jan 22 18:36 zigbee.0_2023_01_22-18_36_09_backupiobroker.tar.gz
              -rw-rw-r--+ 1 iobroker iobroker    2681 Jan 22 19:59 zigbee.0_2023_01_22-19_59_30_backupiobroker.tar.gz
              user@iobroker:~$
              Der Ordner backups ist wieder voll. Muss ich wieder leeren,oder?
              Hab jetzt alles in dem Ordner gelöscht
              • N noidea
                        speedport       Disk
                        Server               Comment
                        Workgroup            Master
                        WORKGROUP            SPEEDPORT
                total 5416
                user@iobroker:~$
                Ja.
                sudo -u iobroker rm /opt/iobroker/backups/*
                Versuch mal von Hand zu mounten:
                  Ja.
                  N Offline
                  N Offline
                  noidea
                  user@iobroker:/$ sudo mount -t cifs -o username=speedport,password=****,domain=WORKGROUP,rw,uid=iobroker,gid=iobroker,file_mode=0777,dir_mode=0777,vers=1.0 //192.168.2.1/SanDisk-USBExtremePro/Backup/Speedport /opt/iobroker/backups
                  mount error(13): Permission denied
                  user@iobroker:/$
                  • N noidea
                    user@iobroker:/$
                    #66
                    @noidea
                    Passwort muss natürlich ersetzt werden.
                    • N noidea
                      user@iobroker:/$
                      #67
                      Permission denied
                      passt!
                      hast du Sonderzeichen im passwort? versteht der Speedport das?
                        Permission denied
                        passt!
                        N Offline
                        N Offline
                        noidea
                        #68
                        Ich Blödmann. Natürlich muss ich das Passwort ersetzen. Sorry...
                        Retrying with upper case share name
                        mount error(6): No such device or address
                        user@iobroker:/$
                        Jetzt kommt diese Meldung.
                        Ich habe keine Sonderzeichen im Passwort. Zum Testen ein einfaches Wort mit zwei Zahlen dahinter
                        • N noidea
                          user@iobroker:/$
                          #69
                          dmesg -T | tail -n 20
                            N Offline
                            N Offline
                            noidea
                            #70
                            user@iobroker:/$ dmesg -T | tail -n 20
                            dmesg: read kernel buffer failed: Operation not permitted
                            user@iobroker:/$ ```
                            code_text
                            • N noidea
                              code_text
                              #71
                              @noidea
                              sudo dmesg -T | tail -n 20
                                @noidea
                                N Offline
                                N Offline
                                noidea
                                #72
                                user@iobroker:/$ sudo dmesg -T | tail -n 20
                                [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -6
                                [Sun Jan 22 19:57:12 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
                                [Sun Jan 22 19:57:12 2023] CIFS: VFS: cifs_mount failed w/return code = -112
                                [Sun Jan 22 20:08:09 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                [Sun Jan 22 20:08:09 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                [Sun Jan 22 20:08:09 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
                                [Sun Jan 22 20:08:09 2023] CIFS: Status code returned 0xc000006d NT_STATUS_LOGON_FAILURE
                                [Sun Jan 22 20:08:09 2023] CIFS: VFS: \\192.168.2.1 Send error in SessSetup = -13
                                [Sun Jan 22 20:08:09 2023] CIFS: VFS: cifs_mount failed w/return code = -13
                                [Sun Jan 22 20:10:33 2023] Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                [Sun Jan 22 20:10:33 2023] CIFS: VFS: Use of the less secure dialect vers=1.0 is not recommended unless required for access to very old servers
                                [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SanDisk-USBExtremePro
                                [Sun Jan 22 20:10:33 2023] CIFS: VFS: cifs_mount failed w/return code = -6
                                [Sun Jan 22 20:10:33 2023] CIFS: Attempting to mount \\192.168.2.1\SANDISK-USBEXTREMEPRO
                                user@iobroker:/$
                                • N noidea
                                  user@iobroker:/$
                                  #73
                                  sudo apt update
                                  apt policy cifs-utils
                                  N 2 Antworten Letzte Antwort
                                  • N noidea
                                    user@iobroker:/$
                                    #74
                                    Attempting to mount \192.168.2.1\SanDisk-USBExtremePro
                                    heisst der share nicht anders?
                                    siehe unzitierbaren Screenshot
                                      sudo apt update
                                      N Offline
                                      N Offline
                                      noidea
                                      #75
                                      Ich werde das morgen nach der Arbeit machen, weil ich gerade böse Blicke ernte und den Haussegen wahren muss 😥
                                      Ich werde dann morgen direkt das Nachreichen.
                                      Aber ich wollte mich auf jeden Fall schonmal Bedanken für die ganze Mühe,die Du/Ihr euch gebt und vor allem nicht die Geduld zu verlieren. Ich kann mir vorstellen wir frustrierend es manchmal sein kann.
                                      Also: Vielen vielen Dank,einen schönen Abend noch an alle und hoffentlich bis morgen
                                      • N noidea
                                        #76
                                        @noidea
                                        Notiz für mich:
                                           RETURN CODES
                                           mount has the following return codes (the bits can be ORed):
                                           0      success
                                           1      incorrect invocation or permissions
                                           2      system error (out of memory, cannot fork, no more loop devices)
                                           4      internal mount bug
                                           8      user interrupt
                                           16     problems writing or locking /etc/mtab
                                           32     mount failure
                                           64     some mount succeeded
                                        • N noidea
                                          #77
                                          @noidea
                                          Klopf mal den Server ab:
                                          nmap -p445 --script smb-protocols 192.168.2.1
                                          nmap -p139 --script smb-protocols 192.168.2.1
                                          nmap ggf. nachinstallieren.
