  4. Fire Tablet Jarvis aktualisiert sich nicht
    5.4k
vis
66 Beiträge 3 Kommentatoren 9.2k Aufrufe 4 Beobachtet
  • T technodj23
    @thomas-braun sagte in Fire Tablet Jarvis aktualisiert sich nicht:
    iob diag
    Skript v.2023-01-02
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.1
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     19:22:50 up  2:58,  1 user,  load average: 4.44, 4.56, 2.89
    CPU threads: 4
    *** Time and Time Zones ***
    Sat Jan 21 18:22:50 UTC 2023
    Sat Jan 21 19:22:50 CET 2023
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           3.8G        1.5G        1.3G        8.0M        995M        2.6G
    Swap:           99M          0B         99M
    Total:         3.9G        1.5G        1.4G
             3838 M total memory
             1550 M used memory
              480 M active memory
             1799 M inactive memory
             1292 M free memory
              241 M buffer memory
              754 M swap cache
               99 M total swap
                0 M used swap
               99 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4       29G   18G   11G  62% /
    devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
    tmpfs          tmpfs     1.9G  8.5M  1.9G   1% /run
    tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
    /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
    Messages in dmesg:
    [Sat Jan 21 16:24:06 2023] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:19:63:BE vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=6c586e13-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
    [Sat Jan 21 16:24:07 2023] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [Sat Jan 21 16:24:07 2023] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [Sat Jan 21 16:24:09 2023] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    TARGET        SOURCE         FSTYPE OPTIONS
    /             /dev/mmcblk0p2 ext4   rw,noatime
    |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    1.5G    /var/
    1.3G    /var/cache
    1.2G    /var/cache/apt/archives
    1.2G    /var/cache/apt
    176M    /var/lib
    /opt/iobroker/backups:
    4.9G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    1.8G    /opt/iobroker/iobroker-data/
    1.5G    /opt/iobroker/iobroker-data/files
    960M    /opt/iobroker/iobroker-data/files/vis-2-beta
    900M    /opt/iobroker/iobroker-data/files/vis-2-beta/static
    898M    /opt/iobroker/iobroker-data/files/vis-2-beta/static/js
    27M     /opt/iobroker/iobroker-data/files/material/static/js/2.73100bd6.chunk.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a81e98bd.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.a256af99.js.map
    19M     /opt/iobroker/iobroker-data/files/vis-2-beta/static/js/main.61f47814.js.map
    19M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    /usr/local/bin/npx              6.13.4
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         14.21.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
            500 https://archive.raspbian.org/raspbian buster/main armhf Packages
    Temp directories causing npm8 problem: 843
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.24
    admin:          6.3.5
    javascript:     6.1.4
    npm ERR! code ELSPROBLEMS
    npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
    npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
    npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
    npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
    npm ERR! invalid: iobroker.jarvis@3.1.3-beta.4 /opt/iobroker/node_modules/iobroker.jarvis
    npm ERR! invalid: iobroker.vis-2-beta@ /opt/iobroker/node_modules/iobroker.vis-2-beta
    npm ERR! extraneous: is-nan@1.3.2 /opt/iobroker/node_modules/is-nan
    npm ERR! extraneous: jsonata@1.8.6 /opt/iobroker/node_modules/jsonata
    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
    npm ERR! extraneous: typescript@4.7.4 /opt/iobroker/node_modules/typescript
    npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
    npm ERR! invalid: web-terminal@0.7.0 /opt/iobroker/node_modules/web-terminal
    npm ERR!     /home/pi/.npm/_logs/2023-01-21T18_23_14_864Z-debug-0.log
    Adapters from github:   1
    Adapter State
    + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
    + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
    + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
      system.adapter.echarts.0                : echarts               : raspberrypi4-iob                         - disabled
      system.adapter.fahrplan.0               : fahrplan              : raspberrypi4-iob                         - disabled
      system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         -  enabled
    + system.adapter.fullybrowser.0           : fullybrowser          : raspberrypi4-iob                         -  enabled
      system.adapter.habpanel.0               : habpanel              : raspberrypi4-iob                         -  enabled
    + system.adapter.history.0                : history               : raspberrypi4-iob                         -  enabled
    + system.adapter.hmip.0                   : hmip                  : raspberrypi4-iob                         -  enabled
      system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : raspberrypi4-iob                         -  enabled
      system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4-iob                         -  enabled
      system.adapter.influxdb.0               : influxdb              : raspberrypi4-iob                         - disabled, port: 8086
    + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
    + system.adapter.iot.0                    : iot                   : raspberrypi4-iob                         -  enabled
      system.adapter.iqontrol.0               : iqontrol              : raspberrypi4-iob                         - disabled
      system.adapter.jarvis.0                 : jarvis                : raspberrypi4-iob                         -  enabled
    + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
      system.adapter.material.0               : material              : raspberrypi4-iob                         -  enabled
      system.adapter.mobile.0                 : mobile                : raspberrypi4-iob                         - disabled
    + system.adapter.moma.0                   : moma                  : raspberrypi4-iob                         -  enabled
    + system.adapter.net-tools.0              : net-tools             : raspberrypi4-iob                         -  enabled
    + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
    + system.adapter.pushover.0               : pushover              : raspberrypi4-iob                         -  enabled
      system.adapter.pushsafer.0              : pushsafer             : raspberrypi4-iob                         - disabled
    + system.adapter.shelly.0                 : shelly                : raspberrypi4-iob                         -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.sonoff.0                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1881, bind: 192.168.178.50
      system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iob                         - disabled
    + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
    + system.adapter.tuya.0                   : tuya                  : raspberrypi4-iob                         -  enabled
      system.adapter.vis-2-beta.0             : vis-2-beta            : raspberrypi4-iob                         -  enabled
      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4-iob                         -  enabled
      system.adapter.vis-history.0            : vis-history           : raspberrypi4-iob                         -  enabled
      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4-iob                         -  enabled
      system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4-iob                         -  enabled
      system.adapter.vis-material-advanced.0  : vis-material-advanced : raspberrypi4-iob                         -  enabled
      system.adapter.vis-metro.0              : vis-metro             : raspberrypi4-iob                         -  enabled
      system.adapter.vis-players.0            : vis-players           : raspberrypi4-iob                         -  enabled
      system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4-iob                         -  enabled
      system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4-iob                         -  enabled
      system.adapter.vis-weather.0            : vis-weather           : raspberrypi4-iob                         -  enabled
      system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         -  enabled
    + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/ttyACM0
    + instance is alive
    ioBroker-Repositories
    Active repo(s): stable
    Installed ioBroker-Instances
    Used repository: stable
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "asuswrt"      : 1.0.1    , installed 1.0.1
    Adapter    "backitup"     : 2.5.10   , installed 2.5.10
    Adapter    "cloud"        : 4.3.0    , installed 4.3.0
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "fahrplan"     : 1.2.2    , installed 1.2.2
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
    Adapter    "habpanel"     : 0.5.0    , installed 0.5.0
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "hmip"         : 1.20.0   , installed 1.20.0
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "icons-fatcow-hosting": 0.1.0, installed 0.1.0
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.14.2   , installed 1.14.2
    Adapter    "iqontrol"     : 2.0.0    , installed 2.0.1
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.3-beta.4
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Adapter    "material"     : 1.1.2    , installed 1.3.0
    Adapter    "mihome"       : 1.4.0    , installed 1.4.0
    Adapter    "moma"         : 1.2.9    , installed 1.2.9
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "sayit"        : 1.12.3   , installed 1.12.6
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "tuya"         : 3.12.1   , installed 3.12.1
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
    Adapter    "wled"         : 0.6.7    , installed 0.6.7
    Adapter    "zigbee"       : 1.8.10   , installed 1.8.10
    Objects and States
    Objects:        8490
    States:         7084
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    Hit:1 http://archive.raspberrypi.org/debian buster InRelease
    Hit:2 https://repos.influxdata.com/debian buster InRelease
    Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
    Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Hit:5 https://archive.raspbian.org/raspbian buster InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Err:4 https://packages.grafana.com/oss/deb stable InRelease
    Reading package lists...
    Pending Updates: 132
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          13210      652/dnsmasq
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18448      659/sshd
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      109        18494      641/influxd
    tcp        0      0 192.168.178.50:1881     0.0.0.0:*               LISTEN      1001       102359     13287/io.sonoff.0
    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      0          13204      635/mosquitto
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       102133     13136/iobroker.js-c
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       102126     13136/iobroker.js-c
    tcp6       0      0 :::53                   :::*                    LISTEN      0          13212      652/dnsmasq
    tcp6       0      0 :::8086                 :::*                    LISTEN      109        17652      641/influxd
    tcp6       0      0 :::22                   :::*                    LISTEN      0          17605      659/sshd
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        17664      632/grafana-server
    tcp6       0      0 :::1883                 :::*                    LISTEN      0          13205      635/mosquitto
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       102197     13154/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       104620     13421/io.web.0
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14777      361/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       103137     13362/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       103138     13362/io.tuya.0
    udp        0      0 0.0.0.0:33310           0.0.0.0:*                           108        14779      361/avahi-daemon: r
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       104454     13309/io.shelly.0
    udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          13209      652/dnsmasq
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          16271      628/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        14778      361/avahi-daemon: r
    udp6       0      0 :::60424                :::*                                108        14780      361/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          16282      628/dhcpcd
    udp6       0      0 :::53                   :::*                                0          13211      652/dnsmasq
    2023-01-21 19:22:29.652  - error: host.raspberrypi4-iob Caught by controller[0]:     at Function.Module._load (node:internal/modules/cjs/loader:878:12)
    2023-01-21 19:22:29.652  - error: host.raspberrypi4-iob Caught by controller[0]:     at Module.require (node:internal/modules/cjs/loader:1067:19) {
    2023-01-21 19:22:29.652  - error: host.raspberrypi4-iob Caught by controller[0]:   code: 'MODULE_NOT_FOUND',
    2023-01-21 19:22:29.653  - error: host.raspberrypi4-iob Caught by controller[0]:   requireStack: [
    2023-01-21 19:22:29.653  - error: host.raspberrypi4-iob Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.jarvis/lib/server.js',
    2023-01-21 19:22:29.653  - error: host.raspberrypi4-iob Caught by controller[0]:     '/opt/iobroker/node_modules/iobroker.jarvis/jarvis.js'
    2023-01-21 19:22:29.653  - error: host.raspberrypi4-iob Caught by controller[0]:   ]
    2023-01-21 19:22:29.653  - error: host.raspberrypi4-iob Caught by controller[0]: }
    2023-01-21 19:22:29.654  - error: host.raspberrypi4-iob instance system.adapter.jarvis.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    2023-01-21 19:22:29.654  - info: host.raspberrypi4-iob Adapter system.adapter.jarvis.0 needs rebuild and will be restarted afterwards.
    2023-01-21 19:22:29.654  - info: host.raspberrypi4-iob system.adapter.jarvis.0 will be rebuilt
    2023-01-21 19:22:31.279  - error: host.raspberrypi4-iob iobroker npm-install: host.raspberrypi4-iob Unknown packetName vis-2-beta. Please install packages from outside the repository using npm!
    2023-01-21 19:22:32.342  - info: host.raspberrypi4-iob iobroker npm-install: exit 12
    2023-01-21 19:22:33.344  - warn: host.raspberrypi4-iob adapter "jarvis" seems to be installed for a different version of Node.js. Trying to rebuild it... 2 attempt
    2023-01-21 19:22:33.345  - info: host.raspberrypi4-iob iobroker rebuild
    2023-01-21 19:22:34.849  - info: host.raspberrypi4-iob iobroker npm-rebuild: Rebuilding native modules ...
    2023-01-21 19:23:02.561  - info: sayit.0 (17328) starting. Version 1.12.6 in /opt/iobroker/node_modules/iobroker.sayit, node: v16.19.0, js-controller: 4.0.24
    2023-01-21 19:23:02.564  - info: sayit.0 (17328) Install process. Upload files and stop.
    2023-01-21 19:23:02.566  - info: sayit.0 (17328) Upload announce mp3 files
    2023-01-21 19:23:02.691  - info: sayit.0 (17328) stopping...
    2023-01-21 19:23:03.204  - info: sayit.0 (17328) Terminated (NO_ERROR): Without reason
    2023-01-21 19:23:03.824  - info: sayit.0 (17328) stopping...
    2023-01-21 19:23:04.230  - info: vis.0 (17398) starting. Version 1.4.15 in /opt/iobroker/node_modules/iobroker.vis, node: v16.19.0, js-controller: 4.0.24
    2023-01-21 19:23:04.586  - info: vis.0 (17398) vis license is OK.
    2023-01-21 19:23:08.135  - info: vis.0 (17398) Terminated (NO_ERROR): Without reason
    @technodj23 sagte in Fire Tablet Jarvis aktualisiert sich nicht:
    /usr/local/bin/npx
    Falsch installiert in der Vergangenheit.
    sudo rm /usr/local/bin/npx
    Und warum ist der Kram so riesig?
    Zu Temp directories causing npm8 problem: 843
    for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
    Zum Grafana-Repo:
    https://forum.iobroker.net/topic/62040/linux-debian-grafana-repo-muss-aktualisiert-werden
    Und wenn das alles korrigiert ist:
    Dein Buster ist tot und muss durch Bullseye ersetzt werden.
      /usr/local/bin/npx
      Zum Grafana-Repo:
      technodj23
      Und das ist wahrscheinlich nicht so einfach? Komplett neu aufsetzen, bzw. was ist der Nachteil wenn ich auf Buster bleibe?
      Thomas BraunT 3 Antworten Letzte Antwort
      • T technodj23
        @technodj23
        Bei einem sauberen Alt-System ist das einfach:
        https://forum.iobroker.net/topic/47213/upgrade-von-debian-10-buster-auf-11-bullseye
        Dein System muss zuvor aber auf eine stabile Basis gesetzt werden.
        • T technodj23
          Das ist keine Option, der Buster ist tot, lebt nicht mehr, wird nicht mehr unterstützt, exitus, aus und vorbei. Tot.
          • T technodj23
            @technodj23
            Liegt da eigentlich noch mehr herum?
            ls -lA /usr/local/bin/
            T 2 Antworten Letzte Antwort
              @technodj23
              technodj23
              Leider immer noch das:
              admin:          6.3.5
              javascript:     6.1.4
              npm ERR!     /home/pi/.npm/_logs/2023-01-21T20_14_38_482Z-debug-0.log
                @technodj23
                technodj23
                @technodj23
                pi@raspberrypi4-iob:~ $ ls -lA /usr/local/bin/
                insgesamt 0
                • T technodj23
                  @technodj23
                  insgesamt 0
                  @technodj23
                  iobroker update
                    @technodj23
                    iobroker update
                    technodj23
                    @thomas-braun ändert nichts.
                    • T technodj23
                      @technodj23
                      Ich muss die Ausgabe dazu sehen.
                        @technodj23
                        technodj23
                        pi@raspberrypi4-iob:~ $ iobroker update
                        • T technodj23
                          @technodj23
                          cd /opt/iobroker
                          npm ls web-terminal
                            @technodj23
                            cd /opt/iobroker
                            npm ls web-terminal
                            technodj23
                            npm ls web-terminal
                            pi@raspberrypi4-iob:/opt/iobroker $ npm ls web-terminal
                            iobroker.inst@2.0.3 /opt/iobroker
                            └── web-terminal@0.7.0 invalid: "https://github.com/rabchev/web-terminal/tarball/96a63a11149e3e535752db45208e3c80a3c47b77" from the root project
                            npm ERR!     /home/iobroker/.npm/_logs/2023-01-21T20_32_47_448Z-debug-0.log
                            • T technodj23
                              npm ls web-terminal
                              web-terminal
                              cd /opt/iobroker
                              npm uninstall web-terminal
                                web-terminal
                                cd /opt/iobroker
                                technodj23
                                @thomas-braun jetzt erreiche ich die Oberfläche nicht mehr. Soll das so sein?
                                • T technodj23
                                  @technodj23
                                  cd /opt/iobroker
                                  npm ls
                                  iobroker status
                                  iobroker list instances
                                    @technodj23
                                    cd /opt/iobroker
                                    npm ls
                                    iobroker status
                                    technodj23
                                    schrieb am zuletzt editiert von technodj23
                                    @thomas-braun npm ls
                                    npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                    npm ERR! extraneous: @alcalzone/jsonl-db@2.5.3 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                    npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
                                    npm ERR! extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                    npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
                                    npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
                                    npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                                    npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                    npm ERR! extraneous: @derhuerst/br2nl@1.0.0 /opt/iobroker/node_modules/@derhuerst/br2nl
                                    npm ERR! extraneous: @derhuerst/round-robin-scheduler@1.0.4 /opt/iobroker/node_modules/@derhuerst/round-robin-scheduler
                                    npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/drive
                                    npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
                                    npm ERR! extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
                                    npm ERR! extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
                                    npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                    npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                    npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                    npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                    npm ERR! extraneous: @iobroker/db-states-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-file
                                    npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                    npm ERR! extraneous: @iobroker/db-states-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-redis
                                    npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                    npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                    npm ERR! extraneous: @iobroker/js-controller-common-db@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                    npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                    npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                    npm ERR! extraneous: @iobroker/plugin-sentry@1.2.0 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                    npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
                                    npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
                                    npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                    npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation
                                    npm ERR! extraneous: @material/base@ /opt/iobroker/node_modules/@material/base
                                    npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button
                                    npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card
                                    npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density
                                    npm ERR! extraneous: @material/dom@ /opt/iobroker/node_modules/@material/dom
                                    npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation
                                    npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting
                                    npm ERR! extraneous: @material/ripple@ /opt/iobroker/node_modules/@material/ripple
                                    npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl
                                    npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape
                                    npm ERR! extraneous: @material/switch@ /opt/iobroker/node_modules/@material/switch
                                    npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme
                                    npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target
                                    npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography
                                    npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                    npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                    npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                    npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                    npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                    npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                    npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                    npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                    npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                    npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                    npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
                                    npm ERR! extraneous: @root/asn1@ /opt/iobroker/node_modules/@root/asn1
                                    npm ERR! extraneous: @root/csr@ /opt/iobroker/node_modules/@root/csr
                                    npm ERR! extraneous: @root/encoding@ /opt/iobroker/node_modules/@root/encoding
                                    npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                                    npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
                                    npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
                                    npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
                                    npm ERR! extraneous: @root/pem@ /opt/iobroker/node_modules/@root/pem
                                    npm ERR! extraneous: @root/request@1.9.2 /opt/iobroker/node_modules/@root/request
                                    npm ERR! extraneous: @root/x509@ /opt/iobroker/node_modules/@root/x509
                                    npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
                                    npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
                                    npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                                    npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                                    npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                    npm ERR! extraneous: @sentry/types@7.31.1 /opt/iobroker/node_modules/@sentry/types
                                    npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                    npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                                    npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                                    npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
                                    npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
                                    npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
                                    npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
                                    npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
                                    npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
                                    npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
                                    npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
                                    npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
                                    npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                                    npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
                                    npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                                    npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                    npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
                                    npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                    npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                    npm ERR! extraneous: @tuyapi/cloud@ /opt/iobroker/node_modules/@tuyapi/cloud
                                    npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                    npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                    npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                    npm ERR! extraneous: @types/cors@2.8.13 /opt/iobroker/node_modules/@types/cors
                                    npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
                                    npm ERR! extraneous: @types/http-proxy@1.17.9 /opt/iobroker/node_modules/@types/http-proxy
                                    npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/@types/iobroker
                                    npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                    npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
                                    npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                                    npm ERR! extraneous: @types/retry@0.12.0 /opt/iobroker/node_modules/@types/retry
                                    npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                    npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                    npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                    npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/accepts
                                    npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
                                    npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals
                                    npm ERR! extraneous: acorn-walk@7.2.0 /opt/iobroker/node_modules/acorn-walk
                                    npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
                                    npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
                                    npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/agent-base
                                    npm ERR! extraneous: agentkeepalive@4.2.1 /opt/iobroker/node_modules/agentkeepalive
                                    npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                    npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                                    npm ERR! extraneous: alexa-cookie2@ /opt/iobroker/node_modules/alexa-cookie2
                                    npm ERR! extraneous: alexa-remote2@ /opt/iobroker/node_modules/alexa-remote2
                                    npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                    npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                    npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
                                    npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                    npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                    npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                    npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                    npm ERR! extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
                                    npm ERR! extraneous: arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/arraybuffer.slice
                                    npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                    npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/asn1
                                    npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
                                    npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                                    npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
                                    npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/asynckit
                                    npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
                                    npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
                                    npm ERR! extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
                                    npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-sdk
                                    npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
                                    npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/aws4
                                    npm ERR! extraneous: axios@ /opt/iobroker/node_modules/axios
                                    npm ERR! extraneous: b4a@ /opt/iobroker/node_modules/b4a
                                    npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
                                    npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                    npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                    npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/base64-arraybuffer
                                    npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                    npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
                                    npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                    npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
                                    npm ERR! extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
                                    npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
                                    npm ERR! extraneous: bindings@1.2.1 /opt/iobroker/node_modules/bindings
                                    npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
                                    npm ERR! extraneous: blob@0.0.4 /opt/iobroker/node_modules/blob
                                    npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                    npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
                                    npm ERR! extraneous: bonjour@3.5.0 /opt/iobroker/node_modules/bonjour
                                    npm ERR! extraneous: bower@ /opt/iobroker/node_modules/bower
                                    npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                                    npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
                                    npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime
                                    npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
                                    npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                    npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
                                    npm ERR! extraneous: buffer-indexof@1.1.1 /opt/iobroker/node_modules/buffer-indexof
                                    npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/buffer
                                    npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
                                    npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
                                    npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                    npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                    npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                    npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                                    npm ERR! extraneous: call-bind@1.0.2 /opt/iobroker/node_modules/call-bind
                                    npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
                                    npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
                                    npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
                                    npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                    npm ERR! extraneous: capture-stack-trace@1.0.2 /opt/iobroker/node_modules/capture-stack-trace
                                    npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
                                    npm ERR! extraneous: castv2-client@1.2.0 /opt/iobroker/node_modules/castv2-client
                                    npm ERR! extraneous: castv2@ /opt/iobroker/node_modules/castv2
                                    npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
                                    npm ERR! extraneous: char-spinner@1.0.1 /opt/iobroker/node_modules/char-spinner
                                    npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                    npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
                                    npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                    npm ERR! extraneous: ci-info@3.7.1 /opt/iobroker/node_modules/ci-info
                                    npm ERR! extraneous: cipher-base@1.0.4 /opt/iobroker/node_modules/cipher-base
                                    npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
                                    npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                    npm ERR! extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                    npm ERR! extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                    npm ERR! extraneous: coap-packet@0.1.14 /opt/iobroker/node_modules/coap-packet
                                    npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
                                    npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                                    npm ERR! extraneous: coiot-coap@ /opt/iobroker/node_modules/coiot-coap
                                    npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                    npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                    npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                    npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                    npm ERR! extraneous: color@4.2.3 /opt/iobroker/node_modules/color
                                    npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                    npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
                                    npm ERR! extraneous: commander@6.2.1 /opt/iobroker/node_modules/commander
                                    npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
                                    npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                                    npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/component-emitter
                                    npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                                    npm ERR! extraneous: compress-json@ /opt/iobroker/node_modules/compress-json
                                    npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                    npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                    npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                    npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
                                    npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                    npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                    npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                    npm ERR! extraneous: content-type@1.0.4 /opt/iobroker/node_modules/content-type
                                    npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
                                    npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
                                    npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
                                    npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/core-util-is
                                    npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                    npm ERR! extraneous: country-data@0.0.31 /opt/iobroker/node_modules/country-data
                                    npm ERR! extraneous: create-hash@1.2.0 /opt/iobroker/node_modules/create-hash
                                    npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
                                    npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
                                    npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                    npm ERR! extraneous: crypto-js@4.0.0 /opt/iobroker/node_modules/crypto-js
                                    npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
                                    npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/cssom
                                    npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                    npm ERR! extraneous: currency-symbol-map@2.2.0 /opt/iobroker/node_modules/currency-symbol-map
                                    npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                    npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
                                    npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                    npm ERR! extraneous: data-urls@3.0.2 /opt/iobroker/node_modules/data-urls
                                    npm ERR! extraneous: date-fns@ /opt/iobroker/node_modules/date-fns
                                    npm ERR! extraneous: debounce@1.2.1 /opt/iobroker/node_modules/debounce
                                    npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
                                    npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
                                    npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                                    npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                    npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                    npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                    npm ERR! extraneous: deep-equal@ /opt/iobroker/node_modules/deep-equal
                                    npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                    npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                    npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                    npm ERR! extraneous: define-properties@1.1.4 /opt/iobroker/node_modules/define-properties
                                    npm ERR! extraneous: delay@5.0.0 /opt/iobroker/node_modules/delay
                                    npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/delayed-stream
                                    npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                    npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                    npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
                                    npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                    npm ERR! extraneous: detect-libc@2.0.1 /opt/iobroker/node_modules/detect-libc
                                    npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
                                    npm ERR! extraneous: dijkstrajs@1.0.2 /opt/iobroker/node_modules/dijkstrajs
                                    npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
                                    npm ERR! extraneous: dns-equal@1.0.0 /opt/iobroker/node_modules/dns-equal
                                    npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
                                    npm ERR! extraneous: dns-txt@2.0.2 /opt/iobroker/node_modules/dns-txt
                                    npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/domexception
                                    npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                    npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                    npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
                                    npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                    npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                    npm ERR! extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                    npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
                                    npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                    npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
                                    npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                    npm ERR! extraneous: encode-utf8@1.0.3 /opt/iobroker/node_modules/encode-utf8
                                    npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                    npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                    npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                                    npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
                                    npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
                                    npm ERR! extraneous: entities@ /opt/iobroker/node_modules/entities
                                    npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                                    npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                    npm ERR! extraneous: es-set-tostringtag@2.0.1 /opt/iobroker/node_modules/es-set-tostringtag
                                    npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                    npm ERR! extraneous: es-to-primitive@ /opt/iobroker/node_modules/es-to-primitive
                                    npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                    npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                    npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
                                    npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                    npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/escodegen
                                    npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                                    npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                                    npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                    npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                    npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                    npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                    npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
                                    npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
                                    npm ERR! extraneous: evilscan@ /opt/iobroker/node_modules/evilscan
                                    npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
                                    npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                    npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                                    npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
                                    npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
                                    npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
                                    npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
                                    npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
                                    npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                    npm ERR! extraneous: fast-fifo@1.1.0 /opt/iobroker/node_modules/fast-fifo
                                    npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast-json-stable-stringify
                                    npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                    npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                    npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                    npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                    npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                    npm ERR! extraneous: fetch-enhanced@5.0.2 /opt/iobroker/node_modules/fetch-enhanced
                                    npm ERR! extraneous: fetch-ponyfill@7.1.0 /opt/iobroker/node_modules/fetch-ponyfill
                                    npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream-rotator
                                    npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
                                    npm ERR! extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                    npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
                                    npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                    npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
                                    npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                    npm ERR! extraneous: follow-redirects@1.15.2 /opt/iobroker/node_modules/follow-redirects
                                    npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                    npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
                                    npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                    npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                    npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                    npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                    npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                    npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                    npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                    npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                    npm ERR! extraneous: ftp-response-parser@1.0.1 /opt/iobroker/node_modules/ftp-response-parser
                                    npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                    npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
                                    npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/function.prototype.name
                                    npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                    npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/gauge
                                    npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/gaxios
                                    npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
                                    npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                                    npm ERR! extraneous: get-intrinsic@1.2.0 /opt/iobroker/node_modules/get-intrinsic
                                    npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                    npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                    npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                    npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                    npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                    npm ERR! extraneous: glob@7.2.3 /opt/iobroker/node_modules/glob
                                    npm ERR! extraneous: globalthis@ /opt/iobroker/node_modules/globalthis
                                    npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                    npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                    npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                    npm ERR! extraneous: google-polyline@1.0.3 /opt/iobroker/node_modules/google-polyline
                                    npm ERR! extraneous: google-tts-api@2.0.2 /opt/iobroker/node_modules/google-tts-api
                                    npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
                                    npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
                                    npm ERR! extraneous: got@ /opt/iobroker/node_modules/got
                                    npm ERR! extraneous: gps-distance@0.0.4 /opt/iobroker/node_modules/gps-distance
                                    npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
                                    npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
                                    npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
                                    npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
                                    npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                    npm ERR! extraneous: hafas-client@ /opt/iobroker/node_modules/hafas-client
                                    npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
                                    npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/har-validator
                                    npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                    npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
                                    npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                                    npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
                                    npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
                                    npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/has-proto
                                    npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/has-symbols
                                    npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/has-tostringtag
                                    npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                    npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
                                    npm ERR! extraneous: hash-base@3.1.0 /opt/iobroker/node_modules/hash-base
                                    npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                    npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
                                    npm ERR! extraneous: hex-rgb@4.3.0 /opt/iobroker/node_modules/hex-rgb
                                    npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/hosted-git-info
                                    npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                    npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                    npm ERR! extraneous: http-cache-semantics@4.1.0 /opt/iobroker/node_modules/http-cache-semantics
                                    npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                    npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-proxy
                                    npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                    npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/http-proxy-middleware
                                    npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
                                    npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
                                    npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
                                    npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/http2-wrapper
                                    npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/https-proxy-agent
                                    npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                    npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
                                    npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                    npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                    npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
                                    npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                    npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
                                    npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                    npm ERR! extraneous: influx@4.2.3 /opt/iobroker/node_modules/influx
                                    npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/inherits
                                    npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                                    npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
                                    npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
                                    npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                    npm ERR! invalid: iobroker.alexa2@ /opt/iobroker/node_modules/iobroker.alexa2
                                    npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                    npm ERR! invalid: iobroker.cloud@ /opt/iobroker/node_modules/iobroker.cloud
                                    npm ERR! invalid: iobroker.daswetter@ /opt/iobroker/node_modules/iobroker.daswetter
                                    npm ERR! invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                    npm ERR! invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                    npm ERR! invalid: iobroker.fahrplan@ /opt/iobroker/node_modules/iobroker.fahrplan
                                    npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                    npm ERR! invalid: iobroker.habpanel@ /opt/iobroker/node_modules/iobroker.habpanel
                                    npm ERR! invalid: iobroker.history@ /opt/iobroker/node_modules/iobroker.history
                                    npm ERR! invalid: iobroker.hmip@ /opt/iobroker/node_modules/iobroker.hmip
                                    npm ERR! invalid: iobroker.hue-extended@ /opt/iobroker/node_modules/iobroker.hue-extended
                                    npm ERR! invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                    npm ERR! invalid: iobroker.icons-mfd-svg@ /opt/iobroker/node_modules/iobroker.icons-mfd-svg
                                    npm ERR! invalid: iobroker.influxdb@ /opt/iobroker/node_modules/iobroker.influxdb
                                    npm ERR! invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                    npm ERR! invalid: iobroker.iot@ /opt/iobroker/node_modules/iobroker.iot
                                    npm ERR! invalid: iobroker.iqontrol@ /opt/iobroker/node_modules/iobroker.iqontrol
                                    npm ERR! extraneous: iobroker.jarvis@ /opt/iobroker/node_modules/iobroker.jarvis
                                    npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                    npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                    npm ERR! invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                    npm ERR! invalid: iobroker.mihome@ /opt/iobroker/node_modules/iobroker.mihome
                                    npm ERR! invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                    npm ERR! invalid: iobroker.moma@ /opt/iobroker/node_modules/iobroker.moma
                                    npm ERR! invalid: iobroker.net-tools@ /opt/iobroker/node_modules/iobroker.net-tools
                                    npm ERR! invalid: iobroker.ping@ /opt/iobroker/node_modules/iobroker.ping
                                    npm ERR! invalid: iobroker.pushover@ /opt/iobroker/node_modules/iobroker.pushover
                                    npm ERR! invalid: iobroker.pushsafer@ /opt/iobroker/node_modules/iobroker.pushsafer
                                    npm ERR! invalid: iobroker.sayit@ /opt/iobroker/node_modules/iobroker.sayit
                                    npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
                                    npm ERR! invalid: iobroker.simple-api@ /opt/iobroker/node_modules/iobroker.simple-api
                                    npm ERR! invalid: iobroker.socketio@ /opt/iobroker/node_modules/iobroker.socketio
                                    npm ERR! invalid: iobroker.sonoff@ /opt/iobroker/node_modules/iobroker.sonoff
                                    npm ERR! invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                    npm ERR! invalid: iobroker.telegram@ /opt/iobroker/node_modules/iobroker.telegram
                                    npm ERR! invalid: iobroker.text2command@ /opt/iobroker/node_modules/iobroker.text2command
                                    npm ERR! invalid: iobroker.trashschedule@ /opt/iobroker/node_modules/iobroker.trashschedule
                                    npm ERR! invalid: iobroker.tuya@ /opt/iobroker/node_modules/iobroker.tuya
                                    npm ERR! extraneous: iobroker.type-detector@1.1.1 /opt/iobroker/node_modules/iobroker.type-detector
                                    npm ERR! invalid: iobroker.vis-history@ /opt/iobroker/node_modules/iobroker.vis-history
                                    npm ERR! invalid: iobroker.vis-justgage@ /opt/iobroker/node_modules/iobroker.vis-justgage
                                    npm ERR! invalid: iobroker.vis-material-advanced@ /opt/iobroker/node_modules/iobroker.vis-material-advanced
                                    npm ERR! invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                    npm ERR! invalid: iobroker.vis-players@ /opt/iobroker/node_modules/iobroker.vis-players
                                    npm ERR! invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                    npm ERR! invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                    npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                    npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                    npm ERR! invalid: iobroker.wled@ /opt/iobroker/node_modules/iobroker.wled
                                    npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                                    npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
                                    npm ERR! invalid: iobroker.zigbee@ /opt/iobroker/node_modules/iobroker.zigbee
                                    npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                    npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
                                    npm ERR! extraneous: ipaddr.js@2.0.1 /opt/iobroker/node_modules/ipaddr.js
                                    npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                                    npm ERR! extraneous: is-array-buffer@3.0.1 /opt/iobroker/node_modules/is-array-buffer
                                    npm ERR! extraneous: is-arrayish@0.3.2 /opt/iobroker/node_modules/is-arrayish
                                    npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                    npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                    npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                    npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                    npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                    npm ERR! extraneous: is-core-module@2.11.0 /opt/iobroker/node_modules/is-core-module
                                    npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                    npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                    npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                    npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                    npm ERR! extraneous: is-nan@ /opt/iobroker/node_modules/is-nan
                                    npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                    npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                    npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/is-number
                                    npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
                                    npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                    npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                    npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                    npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
                                    npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                    npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                    npm ERR! extraneous: is-typed-array@1.1.10 /opt/iobroker/node_modules/is-typed-array
                                    npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
                                    npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
                                    npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                    npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                    npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/isarray
                                    npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
                                    npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
                                    npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/jmespath
                                    npm ERR! extraneous: js-sdsl@4.1.4 /opt/iobroker/node_modules/js-sdsl
                                    npm ERR! extraneous: js-sha512@0.8.0 /opt/iobroker/node_modules/js-sha512
                                    npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
                                    npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                    npm ERR! extraneous: jsftp@2.1.3 /opt/iobroker/node_modules/jsftp
                                    npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                    npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                                    npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                    npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
                                    npm ERR! extraneous: json-schema@0.4.0 /opt/iobroker/node_modules/json-schema
                                    npm ERR! extraneous: json-stable-stringify@ /opt/iobroker/node_modules/json-stable-stringify
                                    npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
                                    npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
                                    npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                    npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
                                    npm ERR! extraneous: jsonify@0.0.1 /opt/iobroker/node_modules/jsonify
                                    npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
                                    npm ERR! extraneous: jsprim@1.4.2 /opt/iobroker/node_modules/jsprim
                                    npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                    npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                    npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                    npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
                                    npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
                                    npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                    npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                    npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                    npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
                                    npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
                                    npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
                                    npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
                                    npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                    npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                    npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                    npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                                    npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                    npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
                                    npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/locate-path
                                    npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                    npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                    npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
                                    npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                    npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                    npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                    npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                    npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                    npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                    npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                    npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                    npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/lodash
                                    npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
                                    npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
                                    npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
                                    npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                    npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                    npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                    npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
                                    npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                    npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                    npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
                                    npm ERR! extraneous: md5.js@1.3.5 /opt/iobroker/node_modules/md5.js
                                    npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                    npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
                                    npm ERR! extraneous: mdns@2.7.2 /opt/iobroker/node_modules/mdns
                                    npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                    npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                    npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
                                    npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                    npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/micromatch
                                    npm ERR! extraneous: mime-db@ /opt/iobroker/node_modules/mime-db
                                    npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/mime-types
                                    npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
                                    npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
                                    npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                    npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
                                    npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
                                    npm ERR! extraneous: minipass@4.0.0 /opt/iobroker/node_modules/minipass
                                    npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                    npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
                                    npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                    npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/mkdirp
                                    npm ERR! extraneous: moment-timezone@ /opt/iobroker/node_modules/moment-timezone
                                    npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
                                    npm ERR! extraneous: mqtt-connection@ /opt/iobroker/node_modules/mqtt-connection
                                    npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
                                    npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                    npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
                                    npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                                    npm ERR! extraneous: multicast-dns@6.2.3 /opt/iobroker/node_modules/multicast-dns
                                    npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                    npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
                                    npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
                                    npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                    npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
                                    npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
                                    npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                    npm ERR! extraneous: netmask@ /opt/iobroker/node_modules/netmask
                                    npm ERR! extraneous: node-abi@3.31.0 /opt/iobroker/node_modules/node-abi
                                    npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
                                    npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                                    npm ERR! extraneous: node-fetch@2.6.8 /opt/iobroker/node_modules/node-fetch
                                    npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                    npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
                                    npm ERR! extraneous: node-ical@0.15.3 /opt/iobroker/node_modules/node-ical
                                    npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                    npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                    npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                                    npm ERR! extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                    npm ERR! extraneous: node-schedule@ /opt/iobroker/node_modules/node-schedule
                                    npm ERR! extraneous: node-ssdp@ /opt/iobroker/node_modules/node-ssdp
                                    npm ERR! extraneous: node-telegram-bot-api@ /opt/iobroker/node_modules/node-telegram-bot-api
                                    npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                    npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
                                    npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                    npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                                    npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                    npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                    npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
                                    npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                    npm ERR! extraneous: number-allocator@1.0.12 /opt/iobroker/node_modules/number-allocator
                                    npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                                    npm ERR! extraneous: nwsapi@ /opt/iobroker/node_modules/nwsapi
                                    npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
                                    npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                    npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
                                    npm ERR! extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                    npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
                                    npm ERR! extraneous: object-is@ /opt/iobroker/node_modules/object-is
                                    npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
                                    npm ERR! extraneous: object-scan@ /opt/iobroker/node_modules/object-scan
                                    npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
                                    npm ERR! extraneous: ohash@1.0.0 /opt/iobroker/node_modules/ohash
                                    npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                    npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
                                    npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                    npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                    npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
                                    npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                    npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
                                    npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
                                    npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                    npm ERR! extraneous: oui@ /opt/iobroker/node_modules/oui
                                    npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                    npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                    npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                    npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/p-locate
                                    npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                    npm ERR! extraneous: p-queue@6.6.2 /opt/iobroker/node_modules/p-queue
                                    npm ERR! extraneous: p-retry@4.6.2 /opt/iobroker/node_modules/p-retry
                                    npm ERR! extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                    npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-timeout
                                    npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                    npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
                                    npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
                                    npm ERR! extraneous: parse-listing@1.1.3 /opt/iobroker/node_modules/parse-listing
                                    npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                    npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
                                    npm ERR! extraneous: parseqs@0.0.5 /opt/iobroker/node_modules/parseqs
                                    npm ERR! extraneous: parseuri@0.0.5 /opt/iobroker/node_modules/parseuri
                                    npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
                                    npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                    npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
                                    npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
                                    npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
                                    npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                    npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
                                    npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                    npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                    npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                    npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
                                    npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                    npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
                                    npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
                                    npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                    npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/picomatch
                                    npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
                                    npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
                                    npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                                    npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
                                    npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
                                    npm ERR! extraneous: pngjs@ /opt/iobroker/node_modules/pngjs
                                    npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
                                    npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                    npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                    npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                    npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
                                    npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
                                    npm ERR! extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                    npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                    npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                    npm ERR! extraneous: psl@ /opt/iobroker/node_modules/psl
                                    npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                    npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/punycode
                                    npm ERR! extraneous: pushover-notifications@ /opt/iobroker/node_modules/pushover-notifications
                                    npm ERR! extraneous: pushsafer-notifications@0.1.9 /opt/iobroker/node_modules/pushsafer-notifications
                                    npm ERR! extraneous: qjobs@1.2.0 /opt/iobroker/node_modules/qjobs
                                    npm ERR! extraneous: qrcode@ /opt/iobroker/node_modules/qrcode
                                    npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
                                    npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
                                    npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
                                    npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                    npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                    npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
                                    npm ERR! extraneous: randomatic@3.1.1 /opt/iobroker/node_modules/randomatic
                                    npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                    npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
                                    npm ERR! extraneous: raw-body@2.5.1 /opt/iobroker/node_modules/raw-body
                                    npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                    npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
                                    npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
                                    npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                    npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                    npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                    npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                    npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                    npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
                                    npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                    npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                    npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                    npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.prototype.flags
                                    npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                    npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
                                    npm ERR! extraneous: request-promise-native@1.0.9 /opt/iobroker/node_modules/request-promise-native
                                    npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                                    npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
                                    npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/require-directory
                                    npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                                    npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
                                    npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                    npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
                                    npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                    npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                    npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                    npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                    npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/rfdc
                                    npm ERR! extraneous: rgb-hex@3.0.0 /opt/iobroker/node_modules/rgb-hex
                                    npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                    npm ERR! extraneous: ripemd160@2.0.2 /opt/iobroker/node_modules/ripemd160
                                    npm ERR! extraneous: rrule@2.7.1 /opt/iobroker/node_modules/rrule
                                    npm ERR! extraneous: rsa-compat@1.9.4 /opt/iobroker/node_modules/rsa-compat
                                    npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
                                    npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
                                    npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
                                    npm ERR! extraneous: safe-stable-stringify@2.4.2 /opt/iobroker/node_modules/safe-stable-stringify
                                    npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                    npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/sax
                                    npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes
                                    npm ERR! extraneous: semaphore@1.1.0 /opt/iobroker/node_modules/semaphore
                                    npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                    npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
                                    npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
                                    npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                    npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                                    npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                    npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                    npm ERR! extraneous: sha.js@2.4.11 /opt/iobroker/node_modules/sha.js
                                    npm ERR! extraneous: sharp@ /opt/iobroker/node_modules/sharp
                                    npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
                                    npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
                                    npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
                                    npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
                                    npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
                                    npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                    npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                    npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                    npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
                                    npm ERR! extraneous: slugg@1.2.1 /opt/iobroker/node_modules/slugg
                                    npm ERR! extraneous: socket.io-adapter@2.4.0 /opt/iobroker/node_modules/socket.io-adapter
                                    npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/socket.io-client
                                    npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/socket.io-parser
                                    npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
                                    npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                    npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-keys-recursive
                                    npm ERR! extraneous: sort-keys@4.2.0 /opt/iobroker/node_modules/sort-keys
                                    npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
                                    npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
                                    npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
                                    npm ERR! extraneous: spdx-correct@3.1.1 /opt/iobroker/node_modules/spdx-correct
                                    npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                                    npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
                                    npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-license-ids
                                    npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                    npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
                                    npm ERR! extraneous: ssh2-streams@ /opt/iobroker/node_modules/ssh2-streams
                                    npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
                                    npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                    npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                    npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                    npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                                    npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                    npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
                                    npm ERR! extraneous: streamsearch@ /opt/iobroker/node_modules/streamsearch
                                    npm ERR! extraneous: streamx@2.13.2 /opt/iobroker/node_modules/streamx
                                    npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/string_decoder
                                    npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/string-width
                                    npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string.prototype.trimend
                                    npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/string.prototype.trimstart
                                    npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                    npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
                                    npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
                                    npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                    npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                    npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                    npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                    npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                    npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                    npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
                                    npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
                                    npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
                                    npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
                                    npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                    npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/text-table
                                    npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
                                    npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
                                    npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                    npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                    npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
                                    npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
                                    npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                    npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                    npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/tough-cookie
                                    npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/tr46
                                    npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
                                    npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/tslib
                                    npm ERR! extraneous: tunnel-agent@0.6.0 /opt/iobroker/node_modules/tunnel-agent
                                    npm ERR! extraneous: tuyapi@ /opt/iobroker/node_modules/tuyapi
                                    npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                    npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                    npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                    npm ERR! extraneous: typed-array-length@1.0.4 /opt/iobroker/node_modules/typed-array-length
                                    npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
                                    npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                    npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
                                    npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/ultron
                                    npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                    npm ERR! extraneous: underscore@ /opt/iobroker/node_modules/underscore
                                    npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
                                    npm ERR! extraneous: unorm@1.6.0 /opt/iobroker/node_modules/unorm
                                    npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                    npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
                                    npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                    npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
                                    npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                    npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
                                    npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
                                    npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
                                    npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
                                    npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/uuid
                                    npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                                    npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                    npm ERR! extraneous: vbb-parse-line@1.0.0 /opt/iobroker/node_modules/vbb-parse-line
                                    npm ERR! extraneous: vbb-parse-ticket@0.2.1 /opt/iobroker/node_modules/vbb-parse-ticket
                                    npm ERR! extraneous: vbb-short-station-name@1.0.1 /opt/iobroker/node_modules/vbb-short-station-name
                                    npm ERR! extraneous: vbb-stations@ /opt/iobroker/node_modules/vbb-stations
                                    npm ERR! extraneous: vbb-translate-ids@4.0.0 /opt/iobroker/node_modules/vbb-translate-ids
                                    npm ERR! extraneous: verror@1.10.0 /opt/iobroker/node_modules/verror
                                    npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
                                    npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/w3c-hr-time
                                    npm ERR! extraneous: w3c-xmlserializer@3.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                    npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                    npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                    npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                    npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                    npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                    npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                    npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                    npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/whatwg-url
                                    npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                    npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
                                    npm ERR! extraneous: which-typed-array@1.1.9 /opt/iobroker/node_modules/which-typed-array
                                    npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
                                    npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                    npm ERR! extraneous: winston-daily-rotate-file@4.7.1 /opt/iobroker/node_modules/winston-daily-rotate-file
                                    npm ERR! extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                    npm ERR! extraneous: winston-syslog@ /opt/iobroker/node_modules/winston-syslog
                                    npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
                                    npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
                                    npm ERR! extraneous: wol@1.0.7 /opt/iobroker/node_modules/wol
                                    npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                                    npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
                                    npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                    npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
                                    npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
                                    npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                    npm ERR! extraneous: xml2js@0.4.19 /opt/iobroker/node_modules/xml2js
                                    npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                                    npm ERR! extraneous: xmlbuilder@ /opt/iobroker/node_modules/xmlbuilder
                                    npm ERR! extraneous: xmlchars@ /opt/iobroker/node_modules/xmlchars
                                    npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
                                    npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                    npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                                    npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
                                    npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                    npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/yargs-parser
                                    npm ERR! invalid: yargs@ /opt/iobroker/node_modules/yargs
                                    npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
                                    npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
                                    npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
                                    npm ERR! extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                    npm ERR!     /home/iobroker/.npm/_logs/2023-01-21T21_53_52_781Z-debug-0.log
                                    T Thomas BraunT 2 Antworten Letzte Antwort
                                    • T technodj23
                                      @thomas-braun npm ls
                                      npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                      npm ERR! extraneous: @alcalzone/jsonl-db@2.5.3 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                      npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
                                      npm ERR! extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                      npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
                                      npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
                                      npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                                      npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                      npm ERR! extraneous: @derhuerst/br2nl@1.0.0 /opt/iobroker/node_modules/@derhuerst/br2nl
                                      npm ERR! extraneous: @derhuerst/round-robin-scheduler@1.0.4 /opt/iobroker/node_modules/@derhuerst/round-robin-scheduler
                                      npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/drive
                                      npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
                                      npm ERR! extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
                                      npm ERR! extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
                                      npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                      npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                      npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                      npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                      npm ERR! extraneous: @iobroker/db-states-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-file
                                      npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                      npm ERR! extraneous: @iobroker/db-states-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-redis
                                      npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                      npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                      npm ERR! extraneous: @iobroker/js-controller-common-db@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                      npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                      npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                      npm ERR! extraneous: @iobroker/plugin-sentry@1.2.0 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                      npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
                                      npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
                                      npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                      npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation
                                      npm ERR! extraneous: @material/base@ /opt/iobroker/node_modules/@material/base
                                      npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button
                                      npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card
                                      npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density
                                      npm ERR! extraneous: @material/dom@ /opt/iobroker/node_modules/@material/dom
                                      npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation
                                      npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting
                                      npm ERR! extraneous: @material/ripple@ /opt/iobroker/node_modules/@material/ripple
                                      npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl
                                      npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape
                                      npm ERR! extraneous: @material/switch@ /opt/iobroker/node_modules/@material/switch
                                      npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme
                                      npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target
                                      npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography
                                      npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                      npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                      npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                      npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                      npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                      npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                      npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                      npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                      npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                      npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                      npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
                                      npm ERR! extraneous: @root/asn1@ /opt/iobroker/node_modules/@root/asn1
                                      npm ERR! extraneous: @root/csr@ /opt/iobroker/node_modules/@root/csr
                                      npm ERR! extraneous: @root/encoding@ /opt/iobroker/node_modules/@root/encoding
                                      npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                                      npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
                                      npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
                                      npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
                                      npm ERR! extraneous: @root/pem@ /opt/iobroker/node_modules/@root/pem
                                      npm ERR! extraneous: @root/request@1.9.2 /opt/iobroker/node_modules/@root/request
                                      npm ERR! extraneous: @root/x509@ /opt/iobroker/node_modules/@root/x509
                                      npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
                                      npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
                                      npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                                      npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                                      npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                      npm ERR! extraneous: @sentry/types@7.31.1 /opt/iobroker/node_modules/@sentry/types
                                      npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                      npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                                      npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                                      npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
                                      npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
                                      npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
                                      npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
                                      npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
                                      npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
                                      npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
                                      npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
                                      npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
                                      npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                                      npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
                                      npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                                      npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                      npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
                                      npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                      npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                      npm ERR! extraneous: @tuyapi/cloud@ /opt/iobroker/node_modules/@tuyapi/cloud
                                      npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                      npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                      npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                      npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                      npm ERR! extraneous: @types/cors@2.8.13 /opt/iobroker/node_modules/@types/cors
                                      npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
                                      npm ERR! extraneous: @types/http-proxy@1.17.9 /opt/iobroker/node_modules/@types/http-proxy
                                      npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/@types/iobroker
                                      npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                      npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
                                      npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                      npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                                      npm ERR! extraneous: @types/retry@0.12.0 /opt/iobroker/node_modules/@types/retry
                                      npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                      npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                      npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                      npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                      npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/accepts
                                      npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
                                      npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals
                                      npm ERR! extraneous: acorn-walk@7.2.0 /opt/iobroker/node_modules/acorn-walk
                                      npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
                                      npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
                                      npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/agent-base
                                      npm ERR! extraneous: agentkeepalive@4.2.1 /opt/iobroker/node_modules/agentkeepalive
                                      npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                      npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                                      npm ERR! extraneous: alexa-cookie2@ /opt/iobroker/node_modules/alexa-cookie2
                                      npm ERR! extraneous: alexa-remote2@ /opt/iobroker/node_modules/alexa-remote2
                                      npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                      npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                      npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
                                      npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                      npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                      npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                      npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                      npm ERR! extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
                                      npm ERR! extraneous: arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/arraybuffer.slice
                                      npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                      npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/asn1
                                      npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
                                      npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                                      npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
                                      npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/asynckit
                                      npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
                                      npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
                                      npm ERR! extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
                                      npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-sdk
                                      npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
                                      npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/aws4
                                      npm ERR! extraneous: axios@ /opt/iobroker/node_modules/axios
                                      npm ERR! extraneous: b4a@ /opt/iobroker/node_modules/b4a
                                      npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
                                      npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                      npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                      npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/base64-arraybuffer
                                      npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                      npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
                                      npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                      npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
                                      npm ERR! extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
                                      npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
                                      npm ERR! extraneous: bindings@1.2.1 /opt/iobroker/node_modules/bindings
                                      npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
                                      npm ERR! extraneous: blob@0.0.4 /opt/iobroker/node_modules/blob
                                      npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                      npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
                                      npm ERR! extraneous: bonjour@3.5.0 /opt/iobroker/node_modules/bonjour
                                      npm ERR! extraneous: bower@ /opt/iobroker/node_modules/bower
                                      npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                                      npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
                                      npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime
                                      npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
                                      npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                      npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
                                      npm ERR! extraneous: buffer-indexof@1.1.1 /opt/iobroker/node_modules/buffer-indexof
                                      npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/buffer
                                      npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
                                      npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
                                      npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                      npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                      npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                      npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                                      npm ERR! extraneous: call-bind@1.0.2 /opt/iobroker/node_modules/call-bind
                                      npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
                                      npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
                                      npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
                                      npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                      npm ERR! extraneous: capture-stack-trace@1.0.2 /opt/iobroker/node_modules/capture-stack-trace
                                      npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
                                      npm ERR! extraneous: castv2-client@1.2.0 /opt/iobroker/node_modules/castv2-client
                                      npm ERR! extraneous: castv2@ /opt/iobroker/node_modules/castv2
                                      npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
                                      npm ERR! extraneous: char-spinner@1.0.1 /opt/iobroker/node_modules/char-spinner
                                      npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                      npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
                                      npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                      npm ERR! extraneous: ci-info@3.7.1 /opt/iobroker/node_modules/ci-info
                                      npm ERR! extraneous: cipher-base@1.0.4 /opt/iobroker/node_modules/cipher-base
                                      npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
                                      npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                      npm ERR! extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                      npm ERR! extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                      npm ERR! extraneous: coap-packet@0.1.14 /opt/iobroker/node_modules/coap-packet
                                      npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
                                      npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                                      npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                      npm ERR! extraneous: coiot-coap@ /opt/iobroker/node_modules/coiot-coap
                                      npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                      npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                      npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                      npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                      npm ERR! extraneous: color@4.2.3 /opt/iobroker/node_modules/color
                                      npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                      npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
                                      npm ERR! extraneous: commander@6.2.1 /opt/iobroker/node_modules/commander
                                      npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
                                      npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                                      npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/component-emitter
                                      npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                                      npm ERR! extraneous: compress-json@ /opt/iobroker/node_modules/compress-json
                                      npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                      npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                      npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                      npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
                                      npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                      npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                      npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                      npm ERR! extraneous: content-type@1.0.4 /opt/iobroker/node_modules/content-type
                                      npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
                                      npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
                                      npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
                                      npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/core-util-is
                                      npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                      npm ERR! extraneous: country-data@0.0.31 /opt/iobroker/node_modules/country-data
                                      npm ERR! extraneous: create-hash@1.2.0 /opt/iobroker/node_modules/create-hash
                                      npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
                                      npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
                                      npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                      npm ERR! extraneous: crypto-js@4.0.0 /opt/iobroker/node_modules/crypto-js
                                      npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
                                      npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/cssom
                                      npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                      npm ERR! extraneous: currency-symbol-map@2.2.0 /opt/iobroker/node_modules/currency-symbol-map
                                      npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                      npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
                                      npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                      npm ERR! extraneous: data-urls@3.0.2 /opt/iobroker/node_modules/data-urls
                                      npm ERR! extraneous: date-fns@ /opt/iobroker/node_modules/date-fns
                                      npm ERR! extraneous: debounce@1.2.1 /opt/iobroker/node_modules/debounce
                                      npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
                                      npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
                                      npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                                      npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                      npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                      npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                      npm ERR! extraneous: deep-equal@ /opt/iobroker/node_modules/deep-equal
                                      npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                      npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                      npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                      npm ERR! extraneous: define-properties@1.1.4 /opt/iobroker/node_modules/define-properties
                                      npm ERR! extraneous: delay@5.0.0 /opt/iobroker/node_modules/delay
                                      npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/delayed-stream
                                      npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                      npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                      npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
                                      npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                      npm ERR! extraneous: detect-libc@2.0.1 /opt/iobroker/node_modules/detect-libc
                                      npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
                                      npm ERR! extraneous: dijkstrajs@1.0.2 /opt/iobroker/node_modules/dijkstrajs
                                      npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
                                      npm ERR! extraneous: dns-equal@1.0.0 /opt/iobroker/node_modules/dns-equal
                                      npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
                                      npm ERR! extraneous: dns-txt@2.0.2 /opt/iobroker/node_modules/dns-txt
                                      npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/domexception
                                      npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                      npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                      npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
                                      npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                      npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                      npm ERR! extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                      npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
                                      npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                      npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
                                      npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                      npm ERR! extraneous: encode-utf8@1.0.3 /opt/iobroker/node_modules/encode-utf8
                                      npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                      npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                      npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                                      npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
                                      npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
                                      npm ERR! extraneous: entities@ /opt/iobroker/node_modules/entities
                                      npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                                      npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                      npm ERR! extraneous: es-set-tostringtag@2.0.1 /opt/iobroker/node_modules/es-set-tostringtag
                                      npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                      npm ERR! extraneous: es-to-primitive@ /opt/iobroker/node_modules/es-to-primitive
                                      npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                      npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                      npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
                                      npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                      npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/escodegen
                                      npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                                      npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                                      npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                      npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                      npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                      npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                      npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
                                      npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
                                      npm ERR! extraneous: evilscan@ /opt/iobroker/node_modules/evilscan
                                      npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
                                      npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                      npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                                      npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
                                      npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
                                      npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
                                      npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
                                      npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
                                      npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                      npm ERR! extraneous: fast-fifo@1.1.0 /opt/iobroker/node_modules/fast-fifo
                                      npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast-json-stable-stringify
                                      npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                      npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                      npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                      npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                      npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                      npm ERR! extraneous: fetch-enhanced@5.0.2 /opt/iobroker/node_modules/fetch-enhanced
                                      npm ERR! extraneous: fetch-ponyfill@7.1.0 /opt/iobroker/node_modules/fetch-ponyfill
                                      npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream-rotator
                                      npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
                                      npm ERR! extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                      npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
                                      npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                      npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
                                      npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                      npm ERR! extraneous: follow-redirects@1.15.2 /opt/iobroker/node_modules/follow-redirects
                                      npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                      npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
                                      npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                      npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                      npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                      npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                      npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                      npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                      npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                      npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                      npm ERR! extraneous: ftp-response-parser@1.0.1 /opt/iobroker/node_modules/ftp-response-parser
                                      npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                      npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
                                      npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/function.prototype.name
                                      npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                      npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/gauge
                                      npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/gaxios
                                      npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
                                      npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                                      npm ERR! extraneous: get-intrinsic@1.2.0 /opt/iobroker/node_modules/get-intrinsic
                                      npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                      npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                      npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                      npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                      npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                      npm ERR! extraneous: glob@7.2.3 /opt/iobroker/node_modules/glob
                                      npm ERR! extraneous: globalthis@ /opt/iobroker/node_modules/globalthis
                                      npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                      npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                      npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                      npm ERR! extraneous: google-polyline@1.0.3 /opt/iobroker/node_modules/google-polyline
                                      npm ERR! extraneous: google-tts-api@2.0.2 /opt/iobroker/node_modules/google-tts-api
                                      npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
                                      npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
                                      npm ERR! extraneous: got@ /opt/iobroker/node_modules/got
                                      npm ERR! extraneous: gps-distance@0.0.4 /opt/iobroker/node_modules/gps-distance
                                      npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
                                      npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
                                      npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
                                      npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
                                      npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                      npm ERR! extraneous: hafas-client@ /opt/iobroker/node_modules/hafas-client
                                      npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
                                      npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/har-validator
                                      npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                      npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
                                      npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                                      npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
                                      npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
                                      npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/has-proto
                                      npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/has-symbols
                                      npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/has-tostringtag
                                      npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                      npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
                                      npm ERR! extraneous: hash-base@3.1.0 /opt/iobroker/node_modules/hash-base
                                      npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                      npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
                                      npm ERR! extraneous: hex-rgb@4.3.0 /opt/iobroker/node_modules/hex-rgb
                                      npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/hosted-git-info
                                      npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                      npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                      npm ERR! extraneous: http-cache-semantics@4.1.0 /opt/iobroker/node_modules/http-cache-semantics
                                      npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                      npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-proxy
                                      npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                      npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/http-proxy-middleware
                                      npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
                                      npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
                                      npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
                                      npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/http2-wrapper
                                      npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/https-proxy-agent
                                      npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                      npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
                                      npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                      npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                      npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
                                      npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                      npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
                                      npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                      npm ERR! extraneous: influx@4.2.3 /opt/iobroker/node_modules/influx
                                      npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/inherits
                                      npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                                      npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
                                      npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
                                      npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                      npm ERR! invalid: iobroker.alexa2@ /opt/iobroker/node_modules/iobroker.alexa2
                                      npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                      npm ERR! invalid: iobroker.cloud@ /opt/iobroker/node_modules/iobroker.cloud
                                      npm ERR! invalid: iobroker.daswetter@ /opt/iobroker/node_modules/iobroker.daswetter
                                      npm ERR! invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                      npm ERR! invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                      npm ERR! invalid: iobroker.fahrplan@ /opt/iobroker/node_modules/iobroker.fahrplan
                                      npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                      npm ERR! invalid: iobroker.habpanel@ /opt/iobroker/node_modules/iobroker.habpanel
                                      npm ERR! invalid: iobroker.history@ /opt/iobroker/node_modules/iobroker.history
                                      npm ERR! invalid: iobroker.hmip@ /opt/iobroker/node_modules/iobroker.hmip
                                      npm ERR! invalid: iobroker.hue-extended@ /opt/iobroker/node_modules/iobroker.hue-extended
                                      npm ERR! invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                      npm ERR! invalid: iobroker.icons-mfd-svg@ /opt/iobroker/node_modules/iobroker.icons-mfd-svg
                                      npm ERR! invalid: iobroker.influxdb@ /opt/iobroker/node_modules/iobroker.influxdb
                                      npm ERR! invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                      npm ERR! invalid: iobroker.iot@ /opt/iobroker/node_modules/iobroker.iot
                                      npm ERR! invalid: iobroker.iqontrol@ /opt/iobroker/node_modules/iobroker.iqontrol
                                      npm ERR! extraneous: iobroker.jarvis@ /opt/iobroker/node_modules/iobroker.jarvis
                                      npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                      npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                      npm ERR! invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                      npm ERR! invalid: iobroker.mihome@ /opt/iobroker/node_modules/iobroker.mihome
                                      npm ERR! invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                      npm ERR! invalid: iobroker.moma@ /opt/iobroker/node_modules/iobroker.moma
                                      npm ERR! invalid: iobroker.net-tools@ /opt/iobroker/node_modules/iobroker.net-tools
                                      npm ERR! invalid: iobroker.ping@ /opt/iobroker/node_modules/iobroker.ping
                                      npm ERR! invalid: iobroker.pushover@ /opt/iobroker/node_modules/iobroker.pushover
                                      npm ERR! invalid: iobroker.pushsafer@ /opt/iobroker/node_modules/iobroker.pushsafer
                                      npm ERR! invalid: iobroker.sayit@ /opt/iobroker/node_modules/iobroker.sayit
                                      npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
                                      npm ERR! invalid: iobroker.simple-api@ /opt/iobroker/node_modules/iobroker.simple-api
                                      npm ERR! invalid: iobroker.socketio@ /opt/iobroker/node_modules/iobroker.socketio
                                      npm ERR! invalid: iobroker.sonoff@ /opt/iobroker/node_modules/iobroker.sonoff
                                      npm ERR! invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                      npm ERR! invalid: iobroker.telegram@ /opt/iobroker/node_modules/iobroker.telegram
                                      npm ERR! invalid: iobroker.text2command@ /opt/iobroker/node_modules/iobroker.text2command
                                      npm ERR! invalid: iobroker.trashschedule@ /opt/iobroker/node_modules/iobroker.trashschedule
                                      npm ERR! invalid: iobroker.tuya@ /opt/iobroker/node_modules/iobroker.tuya
                                      npm ERR! extraneous: iobroker.type-detector@1.1.1 /opt/iobroker/node_modules/iobroker.type-detector
                                      npm ERR! invalid: iobroker.vis-2-beta@ /opt/iobroker/node_modules/iobroker.vis-2-beta
                                      npm ERR! invalid: iobroker.vis-history@ /opt/iobroker/node_modules/iobroker.vis-history
                                      npm ERR! invalid: iobroker.vis-justgage@ /opt/iobroker/node_modules/iobroker.vis-justgage
                                      npm ERR! invalid: iobroker.vis-material-advanced@ /opt/iobroker/node_modules/iobroker.vis-material-advanced
                                      npm ERR! invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                      npm ERR! invalid: iobroker.vis-players@ /opt/iobroker/node_modules/iobroker.vis-players
                                      npm ERR! invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                      npm ERR! invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                      npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                      npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                      npm ERR! invalid: iobroker.wled@ /opt/iobroker/node_modules/iobroker.wled
                                      npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                                      npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
                                      npm ERR! invalid: iobroker.zigbee@ /opt/iobroker/node_modules/iobroker.zigbee
                                      npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                      npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
                                      npm ERR! extraneous: ipaddr.js@2.0.1 /opt/iobroker/node_modules/ipaddr.js
                                      npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                                      npm ERR! extraneous: is-array-buffer@3.0.1 /opt/iobroker/node_modules/is-array-buffer
                                      npm ERR! extraneous: is-arrayish@0.3.2 /opt/iobroker/node_modules/is-arrayish
                                      npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                      npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                      npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                      npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                      npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                      npm ERR! extraneous: is-core-module@2.11.0 /opt/iobroker/node_modules/is-core-module
                                      npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                      npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                      npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                      npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                      npm ERR! extraneous: is-nan@ /opt/iobroker/node_modules/is-nan
                                      npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                      npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                      npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/is-number
                                      npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
                                      npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                      npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                      npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                      npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
                                      npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                      npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                      npm ERR! extraneous: is-typed-array@1.1.10 /opt/iobroker/node_modules/is-typed-array
                                      npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
                                      npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
                                      npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                      npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                      npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/isarray
                                      npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
                                      npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
                                      npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/jmespath
                                      npm ERR! extraneous: js-sdsl@4.1.4 /opt/iobroker/node_modules/js-sdsl
                                      npm ERR! extraneous: js-sha512@0.8.0 /opt/iobroker/node_modules/js-sha512
                                      npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
                                      npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                      npm ERR! extraneous: jsftp@2.1.3 /opt/iobroker/node_modules/jsftp
                                      npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                      npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                                      npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                      npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
                                      npm ERR! extraneous: json-schema@0.4.0 /opt/iobroker/node_modules/json-schema
                                      npm ERR! extraneous: json-stable-stringify@ /opt/iobroker/node_modules/json-stable-stringify
                                      npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
                                      npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
                                      npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                      npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
                                      npm ERR! extraneous: jsonify@0.0.1 /opt/iobroker/node_modules/jsonify
                                      npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
                                      npm ERR! extraneous: jsprim@1.4.2 /opt/iobroker/node_modules/jsprim
                                      npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                      npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                      npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                      npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
                                      npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
                                      npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                      npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                      npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                      npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
                                      npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
                                      npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
                                      npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
                                      npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                      npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                      npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                      npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                                      npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                      npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
                                      npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/locate-path
                                      npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                      npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                      npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
                                      npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                      npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                      npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                      npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                      npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                      npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                      npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                      npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                      npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/lodash
                                      npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
                                      npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
                                      npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
                                      npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                      npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                      npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                      npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
                                      npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                      npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                      npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
                                      npm ERR! extraneous: md5.js@1.3.5 /opt/iobroker/node_modules/md5.js
                                      npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                      npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
                                      npm ERR! extraneous: mdns@2.7.2 /opt/iobroker/node_modules/mdns
                                      npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                      npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                      npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
                                      npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                      npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/micromatch
                                      npm ERR! extraneous: mime-db@ /opt/iobroker/node_modules/mime-db
                                      npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/mime-types
                                      npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
                                      npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
                                      npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                      npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
                                      npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
                                      npm ERR! extraneous: minipass@4.0.0 /opt/iobroker/node_modules/minipass
                                      npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                      npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
                                      npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                      npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/mkdirp
                                      npm ERR! extraneous: moment-timezone@ /opt/iobroker/node_modules/moment-timezone
                                      npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
                                      npm ERR! extraneous: mqtt-connection@ /opt/iobroker/node_modules/mqtt-connection
                                      npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
                                      npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                      npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
                                      npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                                      npm ERR! extraneous: multicast-dns@6.2.3 /opt/iobroker/node_modules/multicast-dns
                                      npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                      npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
                                      npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
                                      npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                      npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
                                      npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
                                      npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                      npm ERR! extraneous: netmask@ /opt/iobroker/node_modules/netmask
                                      npm ERR! extraneous: node-abi@3.31.0 /opt/iobroker/node_modules/node-abi
                                      npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
                                      npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                                      npm ERR! extraneous: node-fetch@2.6.8 /opt/iobroker/node_modules/node-fetch
                                      npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                      npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
                                      npm ERR! extraneous: node-ical@0.15.3 /opt/iobroker/node_modules/node-ical
                                      npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                      npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                      npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                                      npm ERR! extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                      npm ERR! extraneous: node-schedule@ /opt/iobroker/node_modules/node-schedule
                                      npm ERR! extraneous: node-ssdp@ /opt/iobroker/node_modules/node-ssdp
                                      npm ERR! extraneous: node-telegram-bot-api@ /opt/iobroker/node_modules/node-telegram-bot-api
                                      npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                      npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
                                      npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                      npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                                      npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                      npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                      npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
                                      npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                      npm ERR! extraneous: number-allocator@1.0.12 /opt/iobroker/node_modules/number-allocator
                                      npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                                      npm ERR! extraneous: nwsapi@ /opt/iobroker/node_modules/nwsapi
                                      npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
                                      npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                      npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
                                      npm ERR! extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                      npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
                                      npm ERR! extraneous: object-is@ /opt/iobroker/node_modules/object-is
                                      npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
                                      npm ERR! extraneous: object-scan@ /opt/iobroker/node_modules/object-scan
                                      npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
                                      npm ERR! extraneous: ohash@1.0.0 /opt/iobroker/node_modules/ohash
                                      npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                      npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
                                      npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                      npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                      npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
                                      npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                      npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
                                      npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
                                      npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                      npm ERR! extraneous: oui@ /opt/iobroker/node_modules/oui
                                      npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                      npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                      npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                      npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/p-locate
                                      npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                      npm ERR! extraneous: p-queue@6.6.2 /opt/iobroker/node_modules/p-queue
                                      npm ERR! extraneous: p-retry@4.6.2 /opt/iobroker/node_modules/p-retry
                                      npm ERR! extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                      npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-timeout
                                      npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                      npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
                                      npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
                                      npm ERR! extraneous: parse-listing@1.1.3 /opt/iobroker/node_modules/parse-listing
                                      npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                      npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
                                      npm ERR! extraneous: parseqs@0.0.5 /opt/iobroker/node_modules/parseqs
                                      npm ERR! extraneous: parseuri@0.0.5 /opt/iobroker/node_modules/parseuri
                                      npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
                                      npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                      npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
                                      npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
                                      npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
                                      npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                      npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
                                      npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                      npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                      npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                      npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
                                      npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                      npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
                                      npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
                                      npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                      npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/picomatch
                                      npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
                                      npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
                                      npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                                      npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
                                      npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
                                      npm ERR! extraneous: pngjs@ /opt/iobroker/node_modules/pngjs
                                      npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
                                      npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                      npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                      npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                      npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
                                      npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
                                      npm ERR! extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                      npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                      npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                      npm ERR! extraneous: psl@ /opt/iobroker/node_modules/psl
                                      npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                      npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/punycode
                                      npm ERR! extraneous: pushover-notifications@ /opt/iobroker/node_modules/pushover-notifications
                                      npm ERR! extraneous: pushsafer-notifications@0.1.9 /opt/iobroker/node_modules/pushsafer-notifications
                                      npm ERR! extraneous: qjobs@1.2.0 /opt/iobroker/node_modules/qjobs
                                      npm ERR! extraneous: qrcode@ /opt/iobroker/node_modules/qrcode
                                      npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
                                      npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
                                      npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
                                      npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                      npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                      npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
                                      npm ERR! extraneous: randomatic@3.1.1 /opt/iobroker/node_modules/randomatic
                                      npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                      npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
                                      npm ERR! extraneous: raw-body@2.5.1 /opt/iobroker/node_modules/raw-body
                                      npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                      npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
                                      npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
                                      npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                      npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                      npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                      npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                      npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                      npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
                                      npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                      npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                      npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                      npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.prototype.flags
                                      npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                      npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
                                      npm ERR! extraneous: request-promise-native@1.0.9 /opt/iobroker/node_modules/request-promise-native
                                      npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                                      npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
                                      npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/require-directory
                                      npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                                      npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
                                      npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                      npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
                                      npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                      npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                      npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                      npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                      npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/rfdc
                                      npm ERR! extraneous: rgb-hex@3.0.0 /opt/iobroker/node_modules/rgb-hex
                                      npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                      npm ERR! extraneous: ripemd160@2.0.2 /opt/iobroker/node_modules/ripemd160
                                      npm ERR! extraneous: rrule@2.7.1 /opt/iobroker/node_modules/rrule
                                      npm ERR! extraneous: rsa-compat@1.9.4 /opt/iobroker/node_modules/rsa-compat
                                      npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
                                      npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
                                      npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
                                      npm ERR! extraneous: safe-stable-stringify@2.4.2 /opt/iobroker/node_modules/safe-stable-stringify
                                      npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                      npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/sax
                                      npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes
                                      npm ERR! extraneous: semaphore@1.1.0 /opt/iobroker/node_modules/semaphore
                                      npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                      npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
                                      npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
                                      npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                      npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                                      npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                      npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                      npm ERR! extraneous: sha.js@2.4.11 /opt/iobroker/node_modules/sha.js
                                      npm ERR! extraneous: sharp@ /opt/iobroker/node_modules/sharp
                                      npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
                                      npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
                                      npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
                                      npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
                                      npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
                                      npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                      npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                      npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                      npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
                                      npm ERR! extraneous: slugg@1.2.1 /opt/iobroker/node_modules/slugg
                                      npm ERR! extraneous: socket.io-adapter@2.4.0 /opt/iobroker/node_modules/socket.io-adapter
                                      npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/socket.io-client
                                      npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/socket.io-parser
                                      npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
                                      npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                      npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-keys-recursive
                                      npm ERR! extraneous: sort-keys@4.2.0 /opt/iobroker/node_modules/sort-keys
                                      npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
                                      npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
                                      npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
                                      npm ERR! extraneous: spdx-correct@3.1.1 /opt/iobroker/node_modules/spdx-correct
                                      npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                                      npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
                                      npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-license-ids
                                      npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                      npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
                                      npm ERR! extraneous: ssh2-streams@ /opt/iobroker/node_modules/ssh2-streams
                                      npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
                                      npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                      npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                      npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                      npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                                      npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                      npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
                                      npm ERR! extraneous: streamsearch@ /opt/iobroker/node_modules/streamsearch
                                      npm ERR! extraneous: streamx@2.13.2 /opt/iobroker/node_modules/streamx
                                      npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/string_decoder
                                      npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/string-width
                                      npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string.prototype.trimend
                                      npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/string.prototype.trimstart
                                      npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                      npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
                                      npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
                                      npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                      npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                      npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                      npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                      npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                      npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                      npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
                                      npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
                                      npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
                                      npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
                                      npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                      npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/text-table
                                      npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
                                      npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
                                      npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                      npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                      npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
                                      npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
                                      npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                      npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                      npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/tough-cookie
                                      npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/tr46
                                      npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
                                      npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/tslib
                                      npm ERR! extraneous: tunnel-agent@0.6.0 /opt/iobroker/node_modules/tunnel-agent
                                      npm ERR! extraneous: tuyapi@ /opt/iobroker/node_modules/tuyapi
                                      npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                      npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                      npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                      npm ERR! extraneous: typed-array-length@1.0.4 /opt/iobroker/node_modules/typed-array-length
                                      npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
                                      npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                      npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
                                      npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/ultron
                                      npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                      npm ERR! extraneous: underscore@ /opt/iobroker/node_modules/underscore
                                      npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
                                      npm ERR! extraneous: unorm@1.6.0 /opt/iobroker/node_modules/unorm
                                      npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                      npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
                                      npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                      npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
                                      npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                      npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
                                      npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
                                      npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
                                      npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
                                      npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/uuid
                                      npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                                      npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                      npm ERR! extraneous: vbb-parse-line@1.0.0 /opt/iobroker/node_modules/vbb-parse-line
                                      npm ERR! extraneous: vbb-parse-ticket@0.2.1 /opt/iobroker/node_modules/vbb-parse-ticket
                                      npm ERR! extraneous: vbb-short-station-name@1.0.1 /opt/iobroker/node_modules/vbb-short-station-name
                                      npm ERR! extraneous: vbb-stations@ /opt/iobroker/node_modules/vbb-stations
                                      npm ERR! extraneous: vbb-translate-ids@4.0.0 /opt/iobroker/node_modules/vbb-translate-ids
                                      npm ERR! extraneous: verror@1.10.0 /opt/iobroker/node_modules/verror
                                      npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
                                      npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/w3c-hr-time
                                      npm ERR! extraneous: w3c-xmlserializer@3.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                      npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                      npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                      npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                      npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                      npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                      npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                      npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                      npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/whatwg-url
                                      npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                      npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
                                      npm ERR! extraneous: which-typed-array@1.1.9 /opt/iobroker/node_modules/which-typed-array
                                      npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
                                      npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                      npm ERR! extraneous: winston-daily-rotate-file@4.7.1 /opt/iobroker/node_modules/winston-daily-rotate-file
                                      npm ERR! extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                      npm ERR! extraneous: winston-syslog@ /opt/iobroker/node_modules/winston-syslog
                                      npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
                                      npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
                                      npm ERR! extraneous: wol@1.0.7 /opt/iobroker/node_modules/wol
                                      npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                                      npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
                                      npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                      npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
                                      npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
                                      npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                      npm ERR! extraneous: xml2js@0.4.19 /opt/iobroker/node_modules/xml2js
                                      npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                                      npm ERR! extraneous: xmlbuilder@ /opt/iobroker/node_modules/xmlbuilder
                                      npm ERR! extraneous: xmlchars@ /opt/iobroker/node_modules/xmlchars
                                      npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
                                      npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                      npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                                      npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
                                      npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                      npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/yargs-parser
                                      npm ERR! invalid: yargs@ /opt/iobroker/node_modules/yargs
                                      npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
                                      npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
                                      npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
                                      npm ERR! extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                      npm ERR!     /home/iobroker/.npm/_logs/2023-01-21T21_53_52_781Z-debug-0.log
                                      technodj23
                                      pi@raspberrypi4-iob:/opt/iobroker $ iobroker status
                                      node:internal/modules/cjs/loader:998
                                        throw err;
                                      Error: Cannot find module './lib/setup'
                                      Require stack:
                                      - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                          at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                          at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                          at Module.require (node:internal/modules/cjs/loader:1067:19)
                                          at require (node:internal/modules/cjs/helpers:103:18)
                                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                                          at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                          at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                          at Module.load (node:internal/modules/cjs/loader:1043:32)
                                          at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                                          at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                        code: 'MODULE_NOT_FOUND',
                                        requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
                                      pi@raspberrypi4-iob:/opt/iobroker $ ^C
                                      pi@raspberrypi4-iob:/opt/iobroker $ iobroker list instances
                                        throw err;
                                      Require stack:
                                      • T technodj23
                                        @thomas-braun npm ls
                                        npm ERR! extraneous: @alcalzone/esbuild-register@2.5.1-1 /opt/iobroker/node_modules/@alcalzone/esbuild-register
                                        npm ERR! extraneous: @alcalzone/jsonl-db@2.5.3 /opt/iobroker/node_modules/@alcalzone/jsonl-db
                                        npm ERR! extraneous: @alcalzone/pak@ /opt/iobroker/node_modules/@alcalzone/pak
                                        npm ERR! extraneous: @alcalzone/proper-lockfile@4.1.3-0 /opt/iobroker/node_modules/@alcalzone/proper-lockfile
                                        npm ERR! extraneous: @apollon/iobroker-tools@0.2.1 /opt/iobroker/node_modules/@apollon/iobroker-tools
                                        npm ERR! extraneous: @colors/colors@ /opt/iobroker/node_modules/@colors/colors
                                        npm ERR! extraneous: @dabh/diagnostics@ /opt/iobroker/node_modules/@dabh/diagnostics
                                        npm ERR! extraneous: @datalust/winston-seq@1.0.2 /opt/iobroker/node_modules/@datalust/winston-seq
                                        npm ERR! extraneous: @derhuerst/br2nl@1.0.0 /opt/iobroker/node_modules/@derhuerst/br2nl
                                        npm ERR! extraneous: @derhuerst/round-robin-scheduler@1.0.4 /opt/iobroker/node_modules/@derhuerst/round-robin-scheduler
                                        npm ERR! extraneous: @googleapis/drive@ /opt/iobroker/node_modules/@googleapis/drive
                                        npm ERR! extraneous: @greenlock/manager@3.1.0 /opt/iobroker/node_modules/@greenlock/manager
                                        npm ERR! extraneous: @influxdata/influxdb-client-apis@ /opt/iobroker/node_modules/@influxdata/influxdb-client-apis
                                        npm ERR! extraneous: @influxdata/influxdb-client@ /opt/iobroker/node_modules/@influxdata/influxdb-client
                                        npm ERR! extraneous: @iobroker/db-base@ /opt/iobroker/node_modules/@iobroker/db-base
                                        npm ERR! extraneous: @iobroker/db-objects-file@ /opt/iobroker/node_modules/@iobroker/db-objects-file
                                        npm ERR! extraneous: @iobroker/db-objects-jsonl@ /opt/iobroker/node_modules/@iobroker/db-objects-jsonl
                                        npm ERR! extraneous: @iobroker/db-objects-redis@ /opt/iobroker/node_modules/@iobroker/db-objects-redis
                                        npm ERR! extraneous: @iobroker/db-states-file@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-file
                                        npm ERR! extraneous: @iobroker/db-states-jsonl@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-jsonl
                                        npm ERR! extraneous: @iobroker/db-states-redis@4.0.24 /opt/iobroker/node_modules/@iobroker/db-states-redis
                                        npm ERR! extraneous: @iobroker/js-controller-adapter@ /opt/iobroker/node_modules/@iobroker/js-controller-adapter
                                        npm ERR! extraneous: @iobroker/js-controller-cli@ /opt/iobroker/node_modules/@iobroker/js-controller-cli
                                        npm ERR! extraneous: @iobroker/js-controller-common-db@4.0.24 /opt/iobroker/node_modules/@iobroker/js-controller-common-db
                                        npm ERR! extraneous: @iobroker/js-controller-common@ /opt/iobroker/node_modules/@iobroker/js-controller-common
                                        npm ERR! extraneous: @iobroker/plugin-base@1.2.1 /opt/iobroker/node_modules/@iobroker/plugin-base
                                        npm ERR! extraneous: @iobroker/plugin-sentry@1.2.0 /opt/iobroker/node_modules/@iobroker/plugin-sentry
                                        npm ERR! extraneous: @iobroker/socket-classes@ /opt/iobroker/node_modules/@iobroker/socket-classes
                                        npm ERR! extraneous: @iobroker/ws-server@2.1.0 /opt/iobroker/node_modules/@iobroker/ws-server
                                        npm ERR! extraneous: @mapbox/node-pre-gyp@ /opt/iobroker/node_modules/@mapbox/node-pre-gyp
                                        npm ERR! extraneous: @material/animation@7.0.0 /opt/iobroker/node_modules/@material/animation
                                        npm ERR! extraneous: @material/base@ /opt/iobroker/node_modules/@material/base
                                        npm ERR! extraneous: @material/button@7.0.0 /opt/iobroker/node_modules/@material/button
                                        npm ERR! extraneous: @material/card@7.0.0 /opt/iobroker/node_modules/@material/card
                                        npm ERR! extraneous: @material/density@7.0.0 /opt/iobroker/node_modules/@material/density
                                        npm ERR! extraneous: @material/dom@ /opt/iobroker/node_modules/@material/dom
                                        npm ERR! extraneous: @material/elevation@7.0.0 /opt/iobroker/node_modules/@material/elevation
                                        npm ERR! extraneous: @material/feature-targeting@7.0.0 /opt/iobroker/node_modules/@material/feature-targeting
                                        npm ERR! extraneous: @material/ripple@ /opt/iobroker/node_modules/@material/ripple
                                        npm ERR! extraneous: @material/rtl@7.0.0 /opt/iobroker/node_modules/@material/rtl
                                        npm ERR! extraneous: @material/shape@7.0.0 /opt/iobroker/node_modules/@material/shape
                                        npm ERR! extraneous: @material/switch@ /opt/iobroker/node_modules/@material/switch
                                        npm ERR! extraneous: @material/theme@7.0.0 /opt/iobroker/node_modules/@material/theme
                                        npm ERR! extraneous: @material/touch-target@7.0.0 /opt/iobroker/node_modules/@material/touch-target
                                        npm ERR! extraneous: @material/typography@7.0.0 /opt/iobroker/node_modules/@material/typography
                                        npm ERR! extraneous: @protobufjs/aspromise@1.1.2 /opt/iobroker/node_modules/@protobufjs/aspromise
                                        npm ERR! extraneous: @protobufjs/base64@1.1.2 /opt/iobroker/node_modules/@protobufjs/base64
                                        npm ERR! extraneous: @protobufjs/codegen@2.0.4 /opt/iobroker/node_modules/@protobufjs/codegen
                                        npm ERR! extraneous: @protobufjs/eventemitter@1.1.0 /opt/iobroker/node_modules/@protobufjs/eventemitter
                                        npm ERR! extraneous: @protobufjs/fetch@1.1.0 /opt/iobroker/node_modules/@protobufjs/fetch
                                        npm ERR! extraneous: @protobufjs/float@1.0.2 /opt/iobroker/node_modules/@protobufjs/float
                                        npm ERR! extraneous: @protobufjs/inquire@1.1.0 /opt/iobroker/node_modules/@protobufjs/inquire
                                        npm ERR! extraneous: @protobufjs/path@1.1.2 /opt/iobroker/node_modules/@protobufjs/path
                                        npm ERR! extraneous: @protobufjs/pool@1.1.0 /opt/iobroker/node_modules/@protobufjs/pool
                                        npm ERR! extraneous: @protobufjs/utf8@1.1.0 /opt/iobroker/node_modules/@protobufjs/utf8
                                        npm ERR! extraneous: @root/acme@ /opt/iobroker/node_modules/@root/acme
                                        npm ERR! extraneous: @root/asn1@ /opt/iobroker/node_modules/@root/asn1
                                        npm ERR! extraneous: @root/csr@ /opt/iobroker/node_modules/@root/csr
                                        npm ERR! extraneous: @root/encoding@ /opt/iobroker/node_modules/@root/encoding
                                        npm ERR! extraneous: @root/greenlock-express@ /opt/iobroker/node_modules/@root/greenlock-express
                                        npm ERR! extraneous: @root/greenlock@ /opt/iobroker/node_modules/@root/greenlock
                                        npm ERR! extraneous: @root/keypairs@ /opt/iobroker/node_modules/@root/keypairs
                                        npm ERR! extraneous: @root/mkdirp@1.0.0 /opt/iobroker/node_modules/@root/mkdirp
                                        npm ERR! extraneous: @root/pem@ /opt/iobroker/node_modules/@root/pem
                                        npm ERR! extraneous: @root/request@1.9.2 /opt/iobroker/node_modules/@root/request
                                        npm ERR! extraneous: @root/x509@ /opt/iobroker/node_modules/@root/x509
                                        npm ERR! extraneous: @sentry/core@ /opt/iobroker/node_modules/@sentry/core
                                        npm ERR! extraneous: @sentry/hub@ /opt/iobroker/node_modules/@sentry/hub
                                        npm ERR! extraneous: @sentry/integrations@ /opt/iobroker/node_modules/@sentry/integrations
                                        npm ERR! extraneous: @sentry/minimal@6.19.7 /opt/iobroker/node_modules/@sentry/minimal
                                        npm ERR! extraneous: @sentry/node@ /opt/iobroker/node_modules/@sentry/node
                                        npm ERR! extraneous: @sentry/types@7.31.1 /opt/iobroker/node_modules/@sentry/types
                                        npm ERR! extraneous: @sentry/utils@ /opt/iobroker/node_modules/@sentry/utils
                                        npm ERR! extraneous: @serialport/binding-mock@10.2.2 /opt/iobroker/node_modules/@serialport/binding-mock
                                        npm ERR! extraneous: @serialport/bindings-cpp@ /opt/iobroker/node_modules/@serialport/bindings-cpp
                                        npm ERR! extraneous: @serialport/bindings-interface@1.2.2 /opt/iobroker/node_modules/@serialport/bindings-interface
                                        npm ERR! extraneous: @serialport/parser-byte-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-byte-length
                                        npm ERR! extraneous: @serialport/parser-cctalk@10.5.0 /opt/iobroker/node_modules/@serialport/parser-cctalk
                                        npm ERR! extraneous: @serialport/parser-delimiter@10.5.0 /opt/iobroker/node_modules/@serialport/parser-delimiter
                                        npm ERR! extraneous: @serialport/parser-inter-byte-timeout@10.5.0 /opt/iobroker/node_modules/@serialport/parser-inter-byte-timeout
                                        npm ERR! extraneous: @serialport/parser-packet-length@10.5.0 /opt/iobroker/node_modules/@serialport/parser-packet-length
                                        npm ERR! extraneous: @serialport/parser-readline@10.5.0 /opt/iobroker/node_modules/@serialport/parser-readline
                                        npm ERR! extraneous: @serialport/parser-ready@10.5.0 /opt/iobroker/node_modules/@serialport/parser-ready
                                        npm ERR! extraneous: @serialport/parser-regex@10.5.0 /opt/iobroker/node_modules/@serialport/parser-regex
                                        npm ERR! extraneous: @serialport/parser-slip-encoder@10.5.0 /opt/iobroker/node_modules/@serialport/parser-slip-encoder
                                        npm ERR! extraneous: @serialport/parser-spacepacket@10.5.0 /opt/iobroker/node_modules/@serialport/parser-spacepacket
                                        npm ERR! extraneous: @serialport/stream@10.5.0 /opt/iobroker/node_modules/@serialport/stream
                                        npm ERR! extraneous: @sindresorhus/is@4.6.0 /opt/iobroker/node_modules/@sindresorhus/is
                                        npm ERR! extraneous: @socket.io/component-emitter@3.1.0 /opt/iobroker/node_modules/@socket.io/component-emitter
                                        npm ERR! extraneous: @szmarczak/http-timer@4.0.6 /opt/iobroker/node_modules/@szmarczak/http-timer
                                        npm ERR! extraneous: @tootallnate/once@2.0.0 /opt/iobroker/node_modules/@tootallnate/once
                                        npm ERR! extraneous: @tuyapi/cloud@ /opt/iobroker/node_modules/@tuyapi/cloud
                                        npm ERR! extraneous: @types/bl@5.1.0 /opt/iobroker/node_modules/@types/bl
                                        npm ERR! extraneous: @types/cacheable-request@6.0.3 /opt/iobroker/node_modules/@types/cacheable-request
                                        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                        npm ERR! extraneous: @types/cookie@0.4.1 /opt/iobroker/node_modules/@types/cookie
                                        npm ERR! extraneous: @types/cors@2.8.13 /opt/iobroker/node_modules/@types/cors
                                        npm ERR! extraneous: @types/http-cache-semantics@4.0.1 /opt/iobroker/node_modules/@types/http-cache-semantics
                                        npm ERR! extraneous: @types/http-proxy@1.17.9 /opt/iobroker/node_modules/@types/http-proxy
                                        npm ERR! extraneous: @types/iobroker@ /opt/iobroker/node_modules/@types/iobroker
                                        npm ERR! extraneous: @types/keyv@3.1.4 /opt/iobroker/node_modules/@types/keyv
                                        npm ERR! extraneous: @types/long@4.0.2 /opt/iobroker/node_modules/@types/long
                                        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                        npm ERR! extraneous: @types/responselike@1.0.0 /opt/iobroker/node_modules/@types/responselike
                                        npm ERR! extraneous: @types/retry@0.12.0 /opt/iobroker/node_modules/@types/retry
                                        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                        npm ERR! extraneous: abab@2.0.6 /opt/iobroker/node_modules/abab
                                        npm ERR! extraneous: abbrev@1.1.1 /opt/iobroker/node_modules/abbrev
                                        npm ERR! extraneous: abort-controller@3.0.0 /opt/iobroker/node_modules/abort-controller
                                        npm ERR! extraneous: accepts@1.3.8 /opt/iobroker/node_modules/accepts
                                        npm ERR! extraneous: acme-http-01-standalone@3.0.5 /opt/iobroker/node_modules/acme-http-01-standalone
                                        npm ERR! extraneous: acorn-globals@6.0.0 /opt/iobroker/node_modules/acorn-globals
                                        npm ERR! extraneous: acorn-walk@7.2.0 /opt/iobroker/node_modules/acorn-walk
                                        npm ERR! extraneous: acorn@ /opt/iobroker/node_modules/acorn
                                        npm ERR! extraneous: after@0.8.2 /opt/iobroker/node_modules/after
                                        npm ERR! extraneous: agent-base@6.0.2 /opt/iobroker/node_modules/agent-base
                                        npm ERR! extraneous: agentkeepalive@4.2.1 /opt/iobroker/node_modules/agentkeepalive
                                        npm ERR! extraneous: ajv@ /opt/iobroker/node_modules/ajv
                                        npm ERR! extraneous: alcalzone-shared@ /opt/iobroker/node_modules/alcalzone-shared
                                        npm ERR! extraneous: alexa-cookie2@ /opt/iobroker/node_modules/alexa-cookie2
                                        npm ERR! extraneous: alexa-remote2@ /opt/iobroker/node_modules/alexa-remote2
                                        npm ERR! extraneous: ansi-regex@5.0.1 /opt/iobroker/node_modules/ansi-regex
                                        npm ERR! extraneous: ansi-styles@4.3.0 /opt/iobroker/node_modules/ansi-styles
                                        npm ERR! extraneous: any-promise@1.3.0 /opt/iobroker/node_modules/any-promise
                                        npm ERR! extraneous: anymatch@3.1.3 /opt/iobroker/node_modules/anymatch
                                        npm ERR! extraneous: aproba@2.0.0 /opt/iobroker/node_modules/aproba
                                        npm ERR! extraneous: are-we-there-yet@2.0.0 /opt/iobroker/node_modules/are-we-there-yet
                                        npm ERR! extraneous: array-flatten@1.1.1 /opt/iobroker/node_modules/array-flatten
                                        npm ERR! extraneous: array.prototype.findindex@ /opt/iobroker/node_modules/array.prototype.findindex
                                        npm ERR! extraneous: arraybuffer.slice@0.0.6 /opt/iobroker/node_modules/arraybuffer.slice
                                        npm ERR! extraneous: arrify@2.0.1 /opt/iobroker/node_modules/arrify
                                        npm ERR! extraneous: asn1@ /opt/iobroker/node_modules/asn1
                                        npm ERR! extraneous: assert-plus@1.0.0 /opt/iobroker/node_modules/assert-plus
                                        npm ERR! extraneous: async-limiter@1.0.1 /opt/iobroker/node_modules/async-limiter
                                        npm ERR! extraneous: async@ /opt/iobroker/node_modules/async
                                        npm ERR! extraneous: asynckit@0.4.0 /opt/iobroker/node_modules/asynckit
                                        npm ERR! extraneous: at-least-node@1.0.0 /opt/iobroker/node_modules/at-least-node
                                        npm ERR! extraneous: available-typed-arrays@1.0.5 /opt/iobroker/node_modules/available-typed-arrays
                                        npm ERR! extraneous: aws-iot-device-sdk@ /opt/iobroker/node_modules/aws-iot-device-sdk
                                        npm ERR! extraneous: aws-sdk@ /opt/iobroker/node_modules/aws-sdk
                                        npm ERR! extraneous: aws-sign2@0.7.0 /opt/iobroker/node_modules/aws-sign2
                                        npm ERR! extraneous: aws4@1.12.0 /opt/iobroker/node_modules/aws4
                                        npm ERR! extraneous: axios@ /opt/iobroker/node_modules/axios
                                        npm ERR! extraneous: b4a@ /opt/iobroker/node_modules/b4a
                                        npm ERR! extraneous: backo2@1.0.2 /opt/iobroker/node_modules/backo2
                                        npm ERR! extraneous: balanced-match@1.0.2 /opt/iobroker/node_modules/balanced-match
                                        npm ERR! extraneous: base-64@1.0.0 /opt/iobroker/node_modules/base-64
                                        npm ERR! extraneous: base64-arraybuffer@0.1.5 /opt/iobroker/node_modules/base64-arraybuffer
                                        npm ERR! extraneous: base64-js@1.5.1 /opt/iobroker/node_modules/base64-js
                                        npm ERR! extraneous: base64id@2.0.0 /opt/iobroker/node_modules/base64id
                                        npm ERR! extraneous: bcrypt-pbkdf@1.0.2 /opt/iobroker/node_modules/bcrypt-pbkdf
                                        npm ERR! extraneous: better-assert@1.0.2 /opt/iobroker/node_modules/better-assert
                                        npm ERR! extraneous: bignumber.js@ /opt/iobroker/node_modules/bignumber.js
                                        npm ERR! extraneous: binary-extensions@2.2.0 /opt/iobroker/node_modules/binary-extensions
                                        npm ERR! extraneous: bindings@1.2.1 /opt/iobroker/node_modules/bindings
                                        npm ERR! extraneous: bl@ /opt/iobroker/node_modules/bl
                                        npm ERR! extraneous: blob@0.0.4 /opt/iobroker/node_modules/blob
                                        npm ERR! extraneous: bluebird@3.7.2 /opt/iobroker/node_modules/bluebird
                                        npm ERR! extraneous: body-parser@ /opt/iobroker/node_modules/body-parser
                                        npm ERR! extraneous: bonjour@3.5.0 /opt/iobroker/node_modules/bonjour
                                        npm ERR! extraneous: bower@ /opt/iobroker/node_modules/bower
                                        npm ERR! extraneous: brace-expansion@1.1.11 /opt/iobroker/node_modules/brace-expansion
                                        npm ERR! extraneous: braces@3.0.2 /opt/iobroker/node_modules/braces
                                        npm ERR! extraneous: browser-process-hrtime@1.0.0 /opt/iobroker/node_modules/browser-process-hrtime
                                        npm ERR! extraneous: buffer-crc32@0.2.13 /opt/iobroker/node_modules/buffer-crc32
                                        npm ERR! extraneous: buffer-equal-constant-time@1.0.1 /opt/iobroker/node_modules/buffer-equal-constant-time
                                        npm ERR! extraneous: buffer-from@1.1.2 /opt/iobroker/node_modules/buffer-from
                                        npm ERR! extraneous: buffer-indexof@1.1.1 /opt/iobroker/node_modules/buffer-indexof
                                        npm ERR! extraneous: buffer@ /opt/iobroker/node_modules/buffer
                                        npm ERR! extraneous: bufferhelper@0.2.1 /opt/iobroker/node_modules/bufferhelper
                                        npm ERR! extraneous: busboy@ /opt/iobroker/node_modules/busboy
                                        npm ERR! extraneous: byte-length@1.0.2 /opt/iobroker/node_modules/byte-length
                                        npm ERR! extraneous: bytes@3.1.2 /opt/iobroker/node_modules/bytes
                                        npm ERR! extraneous: cacheable-lookup@5.0.4 /opt/iobroker/node_modules/cacheable-lookup
                                        npm ERR! extraneous: cacheable-request@7.0.2 /opt/iobroker/node_modules/cacheable-request
                                        npm ERR! extraneous: call-bind@1.0.2 /opt/iobroker/node_modules/call-bind
                                        npm ERR! extraneous: callsite@1.0.0 /opt/iobroker/node_modules/callsite
                                        npm ERR! extraneous: camelcase@3.0.0 /opt/iobroker/node_modules/camelcase
                                        npm ERR! extraneous: canvas@ /opt/iobroker/node_modules/canvas
                                        npm ERR! extraneous: capitalize@2.0.4 /opt/iobroker/node_modules/capitalize
                                        npm ERR! extraneous: capture-stack-trace@1.0.2 /opt/iobroker/node_modules/capture-stack-trace
                                        npm ERR! extraneous: caseless@0.12.0 /opt/iobroker/node_modules/caseless
                                        npm ERR! extraneous: castv2-client@1.2.0 /opt/iobroker/node_modules/castv2-client
                                        npm ERR! extraneous: castv2@ /opt/iobroker/node_modules/castv2
                                        npm ERR! extraneous: cert-info@1.5.1 /opt/iobroker/node_modules/cert-info
                                        npm ERR! extraneous: char-spinner@1.0.1 /opt/iobroker/node_modules/char-spinner
                                        npm ERR! extraneous: charenc@0.0.2 /opt/iobroker/node_modules/charenc
                                        npm ERR! extraneous: chokidar@ /opt/iobroker/node_modules/chokidar
                                        npm ERR! extraneous: chownr@2.0.0 /opt/iobroker/node_modules/chownr
                                        npm ERR! extraneous: ci-info@3.7.1 /opt/iobroker/node_modules/ci-info
                                        npm ERR! extraneous: cipher-base@1.0.4 /opt/iobroker/node_modules/cipher-base
                                        npm ERR! extraneous: cliui@3.2.0 /opt/iobroker/node_modules/cliui
                                        npm ERR! extraneous: clone-response@1.0.3 /opt/iobroker/node_modules/clone-response
                                        npm ERR! extraneous: cloneextend@0.0.3 /opt/iobroker/node_modules/cloneextend
                                        npm ERR! extraneous: cluster-key-slot@1.1.2 /opt/iobroker/node_modules/cluster-key-slot
                                        npm ERR! extraneous: coap-packet@0.1.14 /opt/iobroker/node_modules/coap-packet
                                        npm ERR! extraneous: coap@ /opt/iobroker/node_modules/coap
                                        npm ERR! extraneous: code-point-at@1.1.0 /opt/iobroker/node_modules/code-point-at
                                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                        npm ERR! extraneous: coiot-coap@ /opt/iobroker/node_modules/coiot-coap
                                        npm ERR! extraneous: color-convert@2.0.1 /opt/iobroker/node_modules/color-convert
                                        npm ERR! extraneous: color-name@1.1.4 /opt/iobroker/node_modules/color-name
                                        npm ERR! extraneous: color-string@1.9.1 /opt/iobroker/node_modules/color-string
                                        npm ERR! extraneous: color-support@1.1.3 /opt/iobroker/node_modules/color-support
                                        npm ERR! extraneous: color@4.2.3 /opt/iobroker/node_modules/color
                                        npm ERR! extraneous: colorspace@1.1.4 /opt/iobroker/node_modules/colorspace
                                        npm ERR! extraneous: combined-stream@1.0.8 /opt/iobroker/node_modules/combined-stream
                                        npm ERR! extraneous: commander@6.2.1 /opt/iobroker/node_modules/commander
                                        npm ERR! extraneous: commist@1.1.0 /opt/iobroker/node_modules/commist
                                        npm ERR! extraneous: component-bind@1.0.0 /opt/iobroker/node_modules/component-bind
                                        npm ERR! extraneous: component-emitter@1.2.1 /opt/iobroker/node_modules/component-emitter
                                        npm ERR! extraneous: component-inherit@0.0.3 /opt/iobroker/node_modules/component-inherit
                                        npm ERR! extraneous: compress-json@ /opt/iobroker/node_modules/compress-json
                                        npm ERR! extraneous: compressible@2.0.18 /opt/iobroker/node_modules/compressible
                                        npm ERR! extraneous: compression@1.7.4 /opt/iobroker/node_modules/compression
                                        npm ERR! extraneous: concat-map@0.0.1 /opt/iobroker/node_modules/concat-map
                                        npm ERR! extraneous: concat-stream@1.6.2 /opt/iobroker/node_modules/concat-stream
                                        npm ERR! extraneous: connect-flash@0.1.1 /opt/iobroker/node_modules/connect-flash
                                        npm ERR! extraneous: console-control-strings@1.1.0 /opt/iobroker/node_modules/console-control-strings
                                        npm ERR! extraneous: content-disposition@0.5.4 /opt/iobroker/node_modules/content-disposition
                                        npm ERR! extraneous: content-type@1.0.4 /opt/iobroker/node_modules/content-type
                                        npm ERR! extraneous: cookie-parser@1.4.6 /opt/iobroker/node_modules/cookie-parser
                                        npm ERR! extraneous: cookie-signature@1.0.6 /opt/iobroker/node_modules/cookie-signature
                                        npm ERR! extraneous: cookie@0.4.1 /opt/iobroker/node_modules/cookie
                                        npm ERR! extraneous: core-util-is@1.0.3 /opt/iobroker/node_modules/core-util-is
                                        npm ERR! extraneous: cors@2.8.5 /opt/iobroker/node_modules/cors
                                        npm ERR! extraneous: country-data@0.0.31 /opt/iobroker/node_modules/country-data
                                        npm ERR! extraneous: create-hash@1.2.0 /opt/iobroker/node_modules/create-hash
                                        npm ERR! extraneous: cron-parser@ /opt/iobroker/node_modules/cron-parser
                                        npm ERR! extraneous: cross-spawn@7.0.3 /opt/iobroker/node_modules/cross-spawn
                                        npm ERR! extraneous: crypt@0.0.2 /opt/iobroker/node_modules/crypt
                                        npm ERR! extraneous: crypto-js@4.0.0 /opt/iobroker/node_modules/crypto-js
                                        npm ERR! extraneous: crypto@1.0.1 /opt/iobroker/node_modules/crypto
                                        npm ERR! extraneous: cssom@ /opt/iobroker/node_modules/cssom
                                        npm ERR! extraneous: cssstyle@ /opt/iobroker/node_modules/cssstyle
                                        npm ERR! extraneous: currency-symbol-map@2.2.0 /opt/iobroker/node_modules/currency-symbol-map
                                        npm ERR! extraneous: cycle@1.0.3 /opt/iobroker/node_modules/cycle
                                        npm ERR! extraneous: daemonize2@0.4.2 /opt/iobroker/node_modules/daemonize2
                                        npm ERR! extraneous: dashdash@1.14.1 /opt/iobroker/node_modules/dashdash
                                        npm ERR! extraneous: data-urls@3.0.2 /opt/iobroker/node_modules/data-urls
                                        npm ERR! extraneous: date-fns@ /opt/iobroker/node_modules/date-fns
                                        npm ERR! extraneous: debounce@1.2.1 /opt/iobroker/node_modules/debounce
                                        npm ERR! extraneous: debug@2.6.9 /opt/iobroker/node_modules/debug
                                        npm ERR! extraneous: decache@4.6.1 /opt/iobroker/node_modules/decache
                                        npm ERR! extraneous: decamelize@1.2.0 /opt/iobroker/node_modules/decamelize
                                        npm ERR! extraneous: decimal.js@10.4.3 /opt/iobroker/node_modules/decimal.js
                                        npm ERR! extraneous: decompress-response@6.0.0 /opt/iobroker/node_modules/decompress-response
                                        npm ERR! extraneous: deep-clone@3.0.3 /opt/iobroker/node_modules/deep-clone
                                        npm ERR! extraneous: deep-equal@ /opt/iobroker/node_modules/deep-equal
                                        npm ERR! extraneous: deep-extend@0.6.0 /opt/iobroker/node_modules/deep-extend
                                        npm ERR! extraneous: deep-is@0.1.4 /opt/iobroker/node_modules/deep-is
                                        npm ERR! extraneous: defer-to-connect@2.0.1 /opt/iobroker/node_modules/defer-to-connect
                                        npm ERR! extraneous: define-properties@1.1.4 /opt/iobroker/node_modules/define-properties
                                        npm ERR! extraneous: delay@5.0.0 /opt/iobroker/node_modules/delay
                                        npm ERR! extraneous: delayed-stream@1.0.0 /opt/iobroker/node_modules/delayed-stream
                                        npm ERR! extraneous: delegates@1.0.0 /opt/iobroker/node_modules/delegates
                                        npm ERR! extraneous: denque@1.5.1 /opt/iobroker/node_modules/denque
                                        npm ERR! extraneous: depd@2.0.0 /opt/iobroker/node_modules/depd
                                        npm ERR! extraneous: destroy@1.2.0 /opt/iobroker/node_modules/destroy
                                        npm ERR! extraneous: detect-libc@2.0.1 /opt/iobroker/node_modules/detect-libc
                                        npm ERR! extraneous: dgram@1.0.1 /opt/iobroker/node_modules/dgram
                                        npm ERR! extraneous: dijkstrajs@1.0.2 /opt/iobroker/node_modules/dijkstrajs
                                        npm ERR! extraneous: diskusage@1.1.3 /opt/iobroker/node_modules/diskusage
                                        npm ERR! extraneous: dns-equal@1.0.0 /opt/iobroker/node_modules/dns-equal
                                        npm ERR! extraneous: dns-packet@1.3.4 /opt/iobroker/node_modules/dns-packet
                                        npm ERR! extraneous: dns-txt@2.0.2 /opt/iobroker/node_modules/dns-txt
                                        npm ERR! extraneous: domexception@ /opt/iobroker/node_modules/domexception
                                        npm ERR! extraneous: dropbox-v2-api@ /opt/iobroker/node_modules/dropbox-v2-api
                                        npm ERR! extraneous: duplexer@0.1.2 /opt/iobroker/node_modules/duplexer
                                        npm ERR! extraneous: duplexify@4.1.2 /opt/iobroker/node_modules/duplexify
                                        npm ERR! extraneous: ecc-jsbn@0.1.2 /opt/iobroker/node_modules/ecc-jsbn
                                        npm ERR! extraneous: ecdsa-sig-formatter@1.0.11 /opt/iobroker/node_modules/ecdsa-sig-formatter
                                        npm ERR! extraneous: echarts@ /opt/iobroker/node_modules/echarts
                                        npm ERR! extraneous: eckles@1.4.1 /opt/iobroker/node_modules/eckles
                                        npm ERR! extraneous: ee-first@1.1.1 /opt/iobroker/node_modules/ee-first
                                        npm ERR! extraneous: emoji-regex@8.0.0 /opt/iobroker/node_modules/emoji-regex
                                        npm ERR! extraneous: enabled@2.0.0 /opt/iobroker/node_modules/enabled
                                        npm ERR! extraneous: encode-utf8@1.0.3 /opt/iobroker/node_modules/encode-utf8
                                        npm ERR! extraneous: encodeurl@1.0.2 /opt/iobroker/node_modules/encodeurl
                                        npm ERR! extraneous: end-of-stream@1.4.4 /opt/iobroker/node_modules/end-of-stream
                                        npm ERR! extraneous: engine.io-client@ /opt/iobroker/node_modules/engine.io-client
                                        npm ERR! extraneous: engine.io-parser@ /opt/iobroker/node_modules/engine.io-parser
                                        npm ERR! extraneous: engine.io@ /opt/iobroker/node_modules/engine.io
                                        npm ERR! extraneous: entities@ /opt/iobroker/node_modules/entities
                                        npm ERR! extraneous: error-ex@1.3.2 /opt/iobroker/node_modules/error-ex
                                        npm ERR! extraneous: es-abstract@ /opt/iobroker/node_modules/es-abstract
                                        npm ERR! extraneous: es-set-tostringtag@2.0.1 /opt/iobroker/node_modules/es-set-tostringtag
                                        npm ERR! extraneous: es-shim-unscopables@1.0.0 /opt/iobroker/node_modules/es-shim-unscopables
                                        npm ERR! extraneous: es-to-primitive@ /opt/iobroker/node_modules/es-to-primitive
                                        npm ERR! extraneous: es6-promise@4.2.8 /opt/iobroker/node_modules/es6-promise
                                        npm ERR! extraneous: esbuild@0.11.23 /opt/iobroker/node_modules/esbuild
                                        npm ERR! extraneous: escalade@3.1.1 /opt/iobroker/node_modules/escalade
                                        npm ERR! extraneous: escape-html@1.0.3 /opt/iobroker/node_modules/escape-html
                                        npm ERR! extraneous: escodegen@ /opt/iobroker/node_modules/escodegen
                                        npm ERR! extraneous: esprima@4.0.1 /opt/iobroker/node_modules/esprima
                                        npm ERR! extraneous: estraverse@5.3.0 /opt/iobroker/node_modules/estraverse
                                        npm ERR! extraneous: esutils@2.0.3 /opt/iobroker/node_modules/esutils
                                        npm ERR! extraneous: etag@1.8.1 /opt/iobroker/node_modules/etag
                                        npm ERR! extraneous: event-stream@4.0.1 /opt/iobroker/node_modules/event-stream
                                        npm ERR! extraneous: event-target-shim@5.0.1 /opt/iobroker/node_modules/event-target-shim
                                        npm ERR! extraneous: eventemitter3@4.0.7 /opt/iobroker/node_modules/eventemitter3
                                        npm ERR! extraneous: events@1.1.1 /opt/iobroker/node_modules/events
                                        npm ERR! extraneous: evilscan@ /opt/iobroker/node_modules/evilscan
                                        npm ERR! extraneous: execa@ /opt/iobroker/node_modules/execa
                                        npm ERR! extraneous: expand-template@2.0.3 /opt/iobroker/node_modules/expand-template
                                        npm ERR! extraneous: express-fileupload@ /opt/iobroker/node_modules/express-fileupload
                                        npm ERR! extraneous: express-session@1.17.3 /opt/iobroker/node_modules/express-session
                                        npm ERR! extraneous: express@ /opt/iobroker/node_modules/express
                                        npm ERR! extraneous: extend@3.0.2 /opt/iobroker/node_modules/extend
                                        npm ERR! extraneous: extsprintf@1.3.0 /opt/iobroker/node_modules/extsprintf
                                        npm ERR! extraneous: eyes@0.1.8 /opt/iobroker/node_modules/eyes
                                        npm ERR! extraneous: fast-deep-equal@3.1.3 /opt/iobroker/node_modules/fast-deep-equal
                                        npm ERR! extraneous: fast-fifo@1.1.0 /opt/iobroker/node_modules/fast-fifo
                                        npm ERR! extraneous: fast-json-stable-stringify@ /opt/iobroker/node_modules/fast-json-stable-stringify
                                        npm ERR! extraneous: fast-levenshtein@2.0.6 /opt/iobroker/node_modules/fast-levenshtein
                                        npm ERR! extraneous: fast-text-encoding@1.0.6 /opt/iobroker/node_modules/fast-text-encoding
                                        npm ERR! extraneous: fast-xml-parser@ /opt/iobroker/node_modules/fast-xml-parser
                                        npm ERR! extraneous: fastseries@2.0.0 /opt/iobroker/node_modules/fastseries
                                        npm ERR! extraneous: fecha@4.2.3 /opt/iobroker/node_modules/fecha
                                        npm ERR! extraneous: fetch-enhanced@5.0.2 /opt/iobroker/node_modules/fetch-enhanced
                                        npm ERR! extraneous: fetch-ponyfill@7.1.0 /opt/iobroker/node_modules/fetch-ponyfill
                                        npm ERR! extraneous: file-stream-rotator@ /opt/iobroker/node_modules/file-stream-rotator
                                        npm ERR! extraneous: file-type@3.9.0 /opt/iobroker/node_modules/file-type
                                        npm ERR! extraneous: file-uri-to-path@1.0.0 /opt/iobroker/node_modules/file-uri-to-path
                                        npm ERR! extraneous: fill-range@7.0.1 /opt/iobroker/node_modules/fill-range
                                        npm ERR! extraneous: finalhandler@1.2.0 /opt/iobroker/node_modules/finalhandler
                                        npm ERR! extraneous: find-up@1.1.2 /opt/iobroker/node_modules/find-up
                                        npm ERR! extraneous: fn.name@1.1.0 /opt/iobroker/node_modules/fn.name
                                        npm ERR! extraneous: follow-redirects@1.15.2 /opt/iobroker/node_modules/follow-redirects
                                        npm ERR! extraneous: for-each@0.3.3 /opt/iobroker/node_modules/for-each
                                        npm ERR! extraneous: forever-agent@0.6.1 /opt/iobroker/node_modules/forever-agent
                                        npm ERR! extraneous: form-data@4.0.0 /opt/iobroker/node_modules/form-data
                                        npm ERR! extraneous: forwarded@0.2.0 /opt/iobroker/node_modules/forwarded
                                        npm ERR! extraneous: fresh@0.5.2 /opt/iobroker/node_modules/fresh
                                        npm ERR! extraneous: from@0.1.7 /opt/iobroker/node_modules/from
                                        npm ERR! extraneous: fs-constants@1.0.0 /opt/iobroker/node_modules/fs-constants
                                        npm ERR! extraneous: fs-minipass@2.1.0 /opt/iobroker/node_modules/fs-minipass
                                        npm ERR! extraneous: fs.realpath@1.0.0 /opt/iobroker/node_modules/fs.realpath
                                        npm ERR! extraneous: fsevents@ /opt/iobroker/node_modules/fsevents
                                        npm ERR! extraneous: ftp-response-parser@1.0.1 /opt/iobroker/node_modules/ftp-response-parser
                                        npm ERR! extraneous: ftp@0.3.10 /opt/iobroker/node_modules/ftp
                                        npm ERR! extraneous: function-bind@1.1.1 /opt/iobroker/node_modules/function-bind
                                        npm ERR! extraneous: function.prototype.name@ /opt/iobroker/node_modules/function.prototype.name
                                        npm ERR! extraneous: functions-have-names@1.2.3 /opt/iobroker/node_modules/functions-have-names
                                        npm ERR! extraneous: gauge@ /opt/iobroker/node_modules/gauge
                                        npm ERR! extraneous: gaxios@ /opt/iobroker/node_modules/gaxios
                                        npm ERR! extraneous: gcp-metadata@5.2.0 /opt/iobroker/node_modules/gcp-metadata
                                        npm ERR! extraneous: get-caller-file@1.0.3 /opt/iobroker/node_modules/get-caller-file
                                        npm ERR! extraneous: get-intrinsic@1.2.0 /opt/iobroker/node_modules/get-intrinsic
                                        npm ERR! extraneous: get-stream@5.2.0 /opt/iobroker/node_modules/get-stream
                                        npm ERR! extraneous: get-symbol-description@1.0.0 /opt/iobroker/node_modules/get-symbol-description
                                        npm ERR! extraneous: getpass@0.1.7 /opt/iobroker/node_modules/getpass
                                        npm ERR! extraneous: github-from-package@0.0.0 /opt/iobroker/node_modules/github-from-package
                                        npm ERR! extraneous: glob-parent@5.1.2 /opt/iobroker/node_modules/glob-parent
                                        npm ERR! extraneous: glob@7.2.3 /opt/iobroker/node_modules/glob
                                        npm ERR! extraneous: globalthis@ /opt/iobroker/node_modules/globalthis
                                        npm ERR! extraneous: glossy@0.1.7 /opt/iobroker/node_modules/glossy
                                        npm ERR! extraneous: google-auth-library@ /opt/iobroker/node_modules/google-auth-library
                                        npm ERR! extraneous: google-p12-pem@4.0.1 /opt/iobroker/node_modules/google-p12-pem
                                        npm ERR! extraneous: google-polyline@1.0.3 /opt/iobroker/node_modules/google-polyline
                                        npm ERR! extraneous: google-tts-api@2.0.2 /opt/iobroker/node_modules/google-tts-api
                                        npm ERR! extraneous: googleapis-common@ /opt/iobroker/node_modules/googleapis-common
                                        npm ERR! extraneous: gopd@1.0.1 /opt/iobroker/node_modules/gopd
                                        npm ERR! extraneous: got@ /opt/iobroker/node_modules/got
                                        npm ERR! extraneous: gps-distance@0.0.4 /opt/iobroker/node_modules/gps-distance
                                        npm ERR! extraneous: greenlock-express@4.0.3 /opt/iobroker/node_modules/greenlock-express
                                        npm ERR! extraneous: greenlock-manager-fs@3.1.1 /opt/iobroker/node_modules/greenlock-manager-fs
                                        npm ERR! extraneous: greenlock-store-fs@3.2.2 /opt/iobroker/node_modules/greenlock-store-fs
                                        npm ERR! extraneous: greenlock@4.0.4 /opt/iobroker/node_modules/greenlock
                                        npm ERR! extraneous: gtoken@6.1.2 /opt/iobroker/node_modules/gtoken
                                        npm ERR! extraneous: hafas-client@ /opt/iobroker/node_modules/hafas-client
                                        npm ERR! extraneous: har-schema@2.0.0 /opt/iobroker/node_modules/har-schema
                                        npm ERR! extraneous: har-validator@5.1.5 /opt/iobroker/node_modules/har-validator
                                        npm ERR! extraneous: has-bigints@1.0.2 /opt/iobroker/node_modules/has-bigints
                                        npm ERR! extraneous: has-binary@0.1.7 /opt/iobroker/node_modules/has-binary
                                        npm ERR! extraneous: has-binary2@1.0.3 /opt/iobroker/node_modules/has-binary2
                                        npm ERR! extraneous: has-cors@1.1.0 /opt/iobroker/node_modules/has-cors
                                        npm ERR! extraneous: has-property-descriptors@1.0.0 /opt/iobroker/node_modules/has-property-descriptors
                                        npm ERR! extraneous: has-proto@1.0.1 /opt/iobroker/node_modules/has-proto
                                        npm ERR! extraneous: has-symbols@ /opt/iobroker/node_modules/has-symbols
                                        npm ERR! extraneous: has-tostringtag@ /opt/iobroker/node_modules/has-tostringtag
                                        npm ERR! extraneous: has-unicode@2.0.1 /opt/iobroker/node_modules/has-unicode
                                        npm ERR! extraneous: has@1.0.3 /opt/iobroker/node_modules/has
                                        npm ERR! extraneous: hash-base@3.1.0 /opt/iobroker/node_modules/hash-base
                                        npm ERR! extraneous: he@1.2.0 /opt/iobroker/node_modules/he
                                        npm ERR! extraneous: help-me@3.0.0 /opt/iobroker/node_modules/help-me
                                        npm ERR! extraneous: hex-rgb@4.3.0 /opt/iobroker/node_modules/hex-rgb
                                        npm ERR! extraneous: hosted-git-info@2.8.9 /opt/iobroker/node_modules/hosted-git-info
                                        npm ERR! extraneous: hot-patcher@1.0.0 /opt/iobroker/node_modules/hot-patcher
                                        npm ERR! extraneous: html-encoding-sniffer@3.0.0 /opt/iobroker/node_modules/html-encoding-sniffer
                                        npm ERR! extraneous: http-cache-semantics@4.1.0 /opt/iobroker/node_modules/http-cache-semantics
                                        npm ERR! extraneous: http-errors@2.0.0 /opt/iobroker/node_modules/http-errors
                                        npm ERR! extraneous: http-mitm-proxy@0.9.0 /opt/iobroker/node_modules/http-mitm-proxy
                                        npm ERR! extraneous: http-proxy-agent@5.0.0 /opt/iobroker/node_modules/http-proxy-agent
                                        npm ERR! extraneous: http-proxy-middleware@ /opt/iobroker/node_modules/http-proxy-middleware
                                        npm ERR! extraneous: http-proxy-response-rewrite@0.0.1 /opt/iobroker/node_modules/http-proxy-response-rewrite
                                        npm ERR! extraneous: http-proxy@1.18.1 /opt/iobroker/node_modules/http-proxy
                                        npm ERR! extraneous: http-signature@1.2.0 /opt/iobroker/node_modules/http-signature
                                        npm ERR! extraneous: http2-wrapper@ /opt/iobroker/node_modules/http2-wrapper
                                        npm ERR! extraneous: https-proxy-agent@5.0.1 /opt/iobroker/node_modules/https-proxy-agent
                                        npm ERR! extraneous: https@1.0.0 /opt/iobroker/node_modules/https
                                        npm ERR! extraneous: human-signals@2.1.0 /opt/iobroker/node_modules/human-signals
                                        npm ERR! extraneous: humanize-ms@1.2.1 /opt/iobroker/node_modules/humanize-ms
                                        npm ERR! extraneous: iconv-lite@0.4.24 /opt/iobroker/node_modules/iconv-lite
                                        npm ERR! extraneous: ieee754@1.1.13 /opt/iobroker/node_modules/ieee754
                                        npm ERR! extraneous: immediate@3.0.6 /opt/iobroker/node_modules/immediate
                                        npm ERR! extraneous: indexof@0.0.1 /opt/iobroker/node_modules/indexof
                                        npm ERR! extraneous: inflight@1.0.6 /opt/iobroker/node_modules/inflight
                                        npm ERR! extraneous: influx@4.2.3 /opt/iobroker/node_modules/influx
                                        npm ERR! extraneous: inherits@2.0.4 /opt/iobroker/node_modules/inherits
                                        npm ERR! extraneous: ini@1.3.8 /opt/iobroker/node_modules/ini
                                        npm ERR! extraneous: internal-slot@1.0.4 /opt/iobroker/node_modules/internal-slot
                                        npm ERR! extraneous: invert-kv@1.0.0 /opt/iobroker/node_modules/invert-kv
                                        npm ERR! invalid: iobroker.admin@ /opt/iobroker/node_modules/iobroker.admin
                                        npm ERR! invalid: iobroker.alexa2@ /opt/iobroker/node_modules/iobroker.alexa2
                                        npm ERR! invalid: iobroker.backitup@ /opt/iobroker/node_modules/iobroker.backitup
                                        npm ERR! invalid: iobroker.cloud@ /opt/iobroker/node_modules/iobroker.cloud
                                        npm ERR! invalid: iobroker.daswetter@ /opt/iobroker/node_modules/iobroker.daswetter
                                        npm ERR! invalid: iobroker.discovery@ /opt/iobroker/node_modules/iobroker.discovery
                                        npm ERR! invalid: iobroker.echarts@ /opt/iobroker/node_modules/iobroker.echarts
                                        npm ERR! invalid: iobroker.fahrplan@ /opt/iobroker/node_modules/iobroker.fahrplan
                                        npm ERR! invalid: iobroker.flot@ /opt/iobroker/node_modules/iobroker.flot
                                        npm ERR! invalid: iobroker.habpanel@ /opt/iobroker/node_modules/iobroker.habpanel
                                        npm ERR! invalid: iobroker.history@ /opt/iobroker/node_modules/iobroker.history
                                        npm ERR! invalid: iobroker.hmip@ /opt/iobroker/node_modules/iobroker.hmip
                                        npm ERR! invalid: iobroker.hue-extended@ /opt/iobroker/node_modules/iobroker.hue-extended
                                        npm ERR! invalid: iobroker.ical@ /opt/iobroker/node_modules/iobroker.ical
                                        npm ERR! invalid: iobroker.icons-mfd-svg@ /opt/iobroker/node_modules/iobroker.icons-mfd-svg
                                        npm ERR! invalid: iobroker.influxdb@ /opt/iobroker/node_modules/iobroker.influxdb
                                        npm ERR! invalid: iobroker.info@ /opt/iobroker/node_modules/iobroker.info
                                        npm ERR! invalid: iobroker.iot@ /opt/iobroker/node_modules/iobroker.iot
                                        npm ERR! invalid: iobroker.iqontrol@ /opt/iobroker/node_modules/iobroker.iqontrol
                                        npm ERR! extraneous: iobroker.jarvis@ /opt/iobroker/node_modules/iobroker.jarvis
                                        npm ERR! invalid: iobroker.javascript@ /opt/iobroker/node_modules/iobroker.javascript
                                        npm ERR! invalid: iobroker.js-controller@ /opt/iobroker/node_modules/iobroker.js-controller
                                        npm ERR! invalid: iobroker.material@ /opt/iobroker/node_modules/iobroker.material
                                        npm ERR! invalid: iobroker.mihome@ /opt/iobroker/node_modules/iobroker.mihome
                                        npm ERR! invalid: iobroker.mobile@ /opt/iobroker/node_modules/iobroker.mobile
                                        npm ERR! invalid: iobroker.moma@ /opt/iobroker/node_modules/iobroker.moma
                                        npm ERR! invalid: iobroker.net-tools@ /opt/iobroker/node_modules/iobroker.net-tools
                                        npm ERR! invalid: iobroker.ping@ /opt/iobroker/node_modules/iobroker.ping
                                        npm ERR! invalid: iobroker.pushover@ /opt/iobroker/node_modules/iobroker.pushover
                                        npm ERR! invalid: iobroker.pushsafer@ /opt/iobroker/node_modules/iobroker.pushsafer
                                        npm ERR! invalid: iobroker.sayit@ /opt/iobroker/node_modules/iobroker.sayit
                                        npm ERR! invalid: iobroker.shelly@ /opt/iobroker/node_modules/iobroker.shelly
                                        npm ERR! invalid: iobroker.simple-api@ /opt/iobroker/node_modules/iobroker.simple-api
                                        npm ERR! invalid: iobroker.socketio@ /opt/iobroker/node_modules/iobroker.socketio
                                        npm ERR! invalid: iobroker.sonoff@ /opt/iobroker/node_modules/iobroker.sonoff
                                        npm ERR! invalid: iobroker.tankerkoenig@ /opt/iobroker/node_modules/iobroker.tankerkoenig
                                        npm ERR! invalid: iobroker.telegram@ /opt/iobroker/node_modules/iobroker.telegram
                                        npm ERR! invalid: iobroker.text2command@ /opt/iobroker/node_modules/iobroker.text2command
                                        npm ERR! invalid: iobroker.trashschedule@ /opt/iobroker/node_modules/iobroker.trashschedule
                                        npm ERR! invalid: iobroker.tuya@ /opt/iobroker/node_modules/iobroker.tuya
                                        npm ERR! extraneous: iobroker.type-detector@1.1.1 /opt/iobroker/node_modules/iobroker.type-detector
                                        npm ERR! invalid: iobroker.vis-2-beta@ /opt/iobroker/node_modules/iobroker.vis-2-beta
                                        npm ERR! invalid: iobroker.vis-history@ /opt/iobroker/node_modules/iobroker.vis-history
                                        npm ERR! invalid: iobroker.vis-justgage@ /opt/iobroker/node_modules/iobroker.vis-justgage
                                        npm ERR! invalid: iobroker.vis-material-advanced@ /opt/iobroker/node_modules/iobroker.vis-material-advanced
                                        npm ERR! invalid: iobroker.vis-metro@ /opt/iobroker/node_modules/iobroker.vis-metro
                                        npm ERR! invalid: iobroker.vis-players@ /opt/iobroker/node_modules/iobroker.vis-players
                                        npm ERR! invalid: iobroker.vis-timeandweather@ /opt/iobroker/node_modules/iobroker.vis-timeandweather
                                        npm ERR! invalid: iobroker.vis-weather@ /opt/iobroker/node_modules/iobroker.vis-weather
                                        npm ERR! invalid: iobroker.vis@ /opt/iobroker/node_modules/iobroker.vis
                                        npm ERR! invalid: iobroker.web@ /opt/iobroker/node_modules/iobroker.web
                                        npm ERR! invalid: iobroker.wled@ /opt/iobroker/node_modules/iobroker.wled
                                        npm ERR! extraneous: iobroker.ws.server@1.0.1 /opt/iobroker/node_modules/iobroker.ws.server
                                        npm ERR! extraneous: iobroker.ws@ /opt/iobroker/node_modules/iobroker.ws
                                        npm ERR! invalid: iobroker.zigbee@ /opt/iobroker/node_modules/iobroker.zigbee
                                        npm ERR! extraneous: ioredis@ /opt/iobroker/node_modules/ioredis
                                        npm ERR! extraneous: ip@1.1.8 /opt/iobroker/node_modules/ip
                                        npm ERR! extraneous: ipaddr.js@2.0.1 /opt/iobroker/node_modules/ipaddr.js
                                        npm ERR! extraneous: is-arguments@1.1.1 /opt/iobroker/node_modules/is-arguments
                                        npm ERR! extraneous: is-array-buffer@3.0.1 /opt/iobroker/node_modules/is-array-buffer
                                        npm ERR! extraneous: is-arrayish@0.3.2 /opt/iobroker/node_modules/is-arrayish
                                        npm ERR! extraneous: is-bigint@1.0.4 /opt/iobroker/node_modules/is-bigint
                                        npm ERR! extraneous: is-binary-path@2.1.0 /opt/iobroker/node_modules/is-binary-path
                                        npm ERR! extraneous: is-boolean-object@1.1.2 /opt/iobroker/node_modules/is-boolean-object
                                        npm ERR! extraneous: is-buffer@1.1.6 /opt/iobroker/node_modules/is-buffer
                                        npm ERR! extraneous: is-callable@1.2.7 /opt/iobroker/node_modules/is-callable
                                        npm ERR! extraneous: is-core-module@2.11.0 /opt/iobroker/node_modules/is-core-module
                                        npm ERR! extraneous: is-date-object@1.0.5 /opt/iobroker/node_modules/is-date-object
                                        npm ERR! extraneous: is-extglob@2.1.1 /opt/iobroker/node_modules/is-extglob
                                        npm ERR! extraneous: is-fullwidth-code-point@3.0.0 /opt/iobroker/node_modules/is-fullwidth-code-point
                                        npm ERR! extraneous: is-glob@4.0.3 /opt/iobroker/node_modules/is-glob
                                        npm ERR! extraneous: is-nan@ /opt/iobroker/node_modules/is-nan
                                        npm ERR! extraneous: is-negative-zero@2.0.2 /opt/iobroker/node_modules/is-negative-zero
                                        npm ERR! extraneous: is-number-object@1.0.7 /opt/iobroker/node_modules/is-number-object
                                        npm ERR! extraneous: is-number@4.0.0 /opt/iobroker/node_modules/is-number
                                        npm ERR! extraneous: is-plain-obj@3.0.0 /opt/iobroker/node_modules/is-plain-obj
                                        npm ERR! extraneous: is-potential-custom-element-name@1.0.1 /opt/iobroker/node_modules/is-potential-custom-element-name
                                        npm ERR! extraneous: is-regex@1.1.4 /opt/iobroker/node_modules/is-regex
                                        npm ERR! extraneous: is-shared-array-buffer@1.0.2 /opt/iobroker/node_modules/is-shared-array-buffer
                                        npm ERR! extraneous: is-stream@2.0.1 /opt/iobroker/node_modules/is-stream
                                        npm ERR! extraneous: is-string@1.0.7 /opt/iobroker/node_modules/is-string
                                        npm ERR! extraneous: is-symbol@1.0.4 /opt/iobroker/node_modules/is-symbol
                                        npm ERR! extraneous: is-typed-array@1.1.10 /opt/iobroker/node_modules/is-typed-array
                                        npm ERR! extraneous: is-typedarray@1.0.0 /opt/iobroker/node_modules/is-typedarray
                                        npm ERR! extraneous: is-utf8@0.2.1 /opt/iobroker/node_modules/is-utf8
                                        npm ERR! extraneous: is-weakref@1.0.2 /opt/iobroker/node_modules/is-weakref
                                        npm ERR! extraneous: is@3.3.0 /opt/iobroker/node_modules/is
                                        npm ERR! extraneous: isarray@1.0.0 /opt/iobroker/node_modules/isarray
                                        npm ERR! extraneous: isexe@2.0.0 /opt/iobroker/node_modules/isexe
                                        npm ERR! extraneous: isstream@0.1.2 /opt/iobroker/node_modules/isstream
                                        npm ERR! extraneous: jmespath@ /opt/iobroker/node_modules/jmespath
                                        npm ERR! extraneous: js-sdsl@4.1.4 /opt/iobroker/node_modules/js-sdsl
                                        npm ERR! extraneous: js-sha512@0.8.0 /opt/iobroker/node_modules/js-sha512
                                        npm ERR! extraneous: jsbn@0.1.1 /opt/iobroker/node_modules/jsbn
                                        npm ERR! extraneous: jsdom@ /opt/iobroker/node_modules/jsdom
                                        npm ERR! extraneous: jsftp@2.1.3 /opt/iobroker/node_modules/jsftp
                                        npm ERR! extraneous: jshashes@1.0.8 /opt/iobroker/node_modules/jshashes
                                        npm ERR! extraneous: json-bigint@1.0.0 /opt/iobroker/node_modules/json-bigint
                                        npm ERR! extraneous: json-buffer@3.0.1 /opt/iobroker/node_modules/json-buffer
                                        npm ERR! extraneous: json-schema-traverse@0.4.1 /opt/iobroker/node_modules/json-schema-traverse
                                        npm ERR! extraneous: json-schema@0.4.0 /opt/iobroker/node_modules/json-schema
                                        npm ERR! extraneous: json-stable-stringify@ /opt/iobroker/node_modules/json-stable-stringify
                                        npm ERR! extraneous: json-stringify-safe@5.0.1 /opt/iobroker/node_modules/json-stringify-safe
                                        npm ERR! extraneous: json3@3.3.2 /opt/iobroker/node_modules/json3
                                        npm ERR! extraneous: jsonata@ /opt/iobroker/node_modules/jsonata
                                        npm ERR! extraneous: jsonc-parser@ /opt/iobroker/node_modules/jsonc-parser
                                        npm ERR! extraneous: jsonify@0.0.1 /opt/iobroker/node_modules/jsonify
                                        npm ERR! extraneous: jsonwebtoken@8.5.1 /opt/iobroker/node_modules/jsonwebtoken
                                        npm ERR! extraneous: jsprim@1.4.2 /opt/iobroker/node_modules/jsprim
                                        npm ERR! extraneous: jszip@ /opt/iobroker/node_modules/jszip
                                        npm ERR! extraneous: jwa@2.0.0 /opt/iobroker/node_modules/jwa
                                        npm ERR! extraneous: jws@4.0.0 /opt/iobroker/node_modules/jws
                                        npm ERR! extraneous: keypairs@1.2.14 /opt/iobroker/node_modules/keypairs
                                        npm ERR! extraneous: keyv@4.5.2 /opt/iobroker/node_modules/keyv
                                        npm ERR! extraneous: kind-of@6.0.3 /opt/iobroker/node_modules/kind-of
                                        npm ERR! extraneous: kuler@2.0.0 /opt/iobroker/node_modules/kuler
                                        npm ERR! extraneous: layerr@0.1.2 /opt/iobroker/node_modules/layerr
                                        npm ERR! extraneous: lcid@1.0.0 /opt/iobroker/node_modules/lcid
                                        npm ERR! extraneous: le-acme-core@2.1.4 /opt/iobroker/node_modules/le-acme-core
                                        npm ERR! extraneous: le-challenge-fs@2.0.9 /opt/iobroker/node_modules/le-challenge-fs
                                        npm ERR! extraneous: le-sni-auto@2.1.9 /opt/iobroker/node_modules/le-sni-auto
                                        npm ERR! extraneous: leven@2.1.0 /opt/iobroker/node_modules/leven
                                        npm ERR! extraneous: levn@0.3.0 /opt/iobroker/node_modules/levn
                                        npm ERR! extraneous: lie@3.3.0 /opt/iobroker/node_modules/lie
                                        npm ERR! extraneous: load-json-file@1.1.0 /opt/iobroker/node_modules/load-json-file
                                        npm ERR! extraneous: loadavg-windows@1.1.1 /opt/iobroker/node_modules/loadavg-windows
                                        npm ERR! extraneous: localforage@ /opt/iobroker/node_modules/localforage
                                        npm ERR! extraneous: locate-path@5.0.0 /opt/iobroker/node_modules/locate-path
                                        npm ERR! extraneous: lodash.defaults@4.2.0 /opt/iobroker/node_modules/lodash.defaults
                                        npm ERR! extraneous: lodash.flatten@4.4.0 /opt/iobroker/node_modules/lodash.flatten
                                        npm ERR! extraneous: lodash.get@4.4.2 /opt/iobroker/node_modules/lodash.get
                                        npm ERR! extraneous: lodash.includes@4.3.0 /opt/iobroker/node_modules/lodash.includes
                                        npm ERR! extraneous: lodash.isarguments@3.1.0 /opt/iobroker/node_modules/lodash.isarguments
                                        npm ERR! extraneous: lodash.isboolean@3.0.3 /opt/iobroker/node_modules/lodash.isboolean
                                        npm ERR! extraneous: lodash.isinteger@4.0.4 /opt/iobroker/node_modules/lodash.isinteger
                                        npm ERR! extraneous: lodash.isnumber@3.0.3 /opt/iobroker/node_modules/lodash.isnumber
                                        npm ERR! extraneous: lodash.isplainobject@4.0.6 /opt/iobroker/node_modules/lodash.isplainobject
                                        npm ERR! extraneous: lodash.isstring@4.0.1 /opt/iobroker/node_modules/lodash.isstring
                                        npm ERR! extraneous: lodash.once@4.1.1 /opt/iobroker/node_modules/lodash.once
                                        npm ERR! extraneous: lodash@ /opt/iobroker/node_modules/lodash
                                        npm ERR! extraneous: logform@ /opt/iobroker/node_modules/logform
                                        npm ERR! extraneous: long-timeout@0.1.1 /opt/iobroker/node_modules/long-timeout
                                        npm ERR! extraneous: long@4.0.0 /opt/iobroker/node_modules/long
                                        npm ERR! extraneous: lowercase-keys@2.0.0 /opt/iobroker/node_modules/lowercase-keys
                                        npm ERR! extraneous: lru_map@0.3.3 /opt/iobroker/node_modules/lru_map
                                        npm ERR! extraneous: lru-cache@6.0.0 /opt/iobroker/node_modules/lru-cache
                                        npm ERR! extraneous: luxon@ /opt/iobroker/node_modules/luxon
                                        npm ERR! extraneous: make-dir@3.1.0 /opt/iobroker/node_modules/make-dir
                                        npm ERR! extraneous: map-stream@0.0.7 /opt/iobroker/node_modules/map-stream
                                        npm ERR! extraneous: math-random@1.0.4 /opt/iobroker/node_modules/math-random
                                        npm ERR! extraneous: md5.js@1.3.5 /opt/iobroker/node_modules/md5.js
                                        npm ERR! extraneous: md5@2.3.0 /opt/iobroker/node_modules/md5
                                        npm ERR! extraneous: mdns-discovery@0.2.6 /opt/iobroker/node_modules/mdns-discovery
                                        npm ERR! extraneous: mdns@2.7.2 /opt/iobroker/node_modules/mdns
                                        npm ERR! extraneous: media-typer@0.3.0 /opt/iobroker/node_modules/media-typer
                                        npm ERR! extraneous: merge-descriptors@1.0.1 /opt/iobroker/node_modules/merge-descriptors
                                        npm ERR! extraneous: merge-stream@2.0.0 /opt/iobroker/node_modules/merge-stream
                                        npm ERR! extraneous: methods@1.1.2 /opt/iobroker/node_modules/methods
                                        npm ERR! extraneous: micromatch@4.0.5 /opt/iobroker/node_modules/micromatch
                                        npm ERR! extraneous: mime-db@ /opt/iobroker/node_modules/mime-db
                                        npm ERR! extraneous: mime-types@2.1.35 /opt/iobroker/node_modules/mime-types
                                        npm ERR! extraneous: mime@3.0.0 /opt/iobroker/node_modules/mime
                                        npm ERR! extraneous: mimic-fn@2.1.0 /opt/iobroker/node_modules/mimic-fn
                                        npm ERR! extraneous: mimic-response@1.0.1 /opt/iobroker/node_modules/mimic-response
                                        npm ERR! extraneous: minimatch@3.1.2 /opt/iobroker/node_modules/minimatch
                                        npm ERR! extraneous: minimist@ /opt/iobroker/node_modules/minimist
                                        npm ERR! extraneous: minipass@4.0.0 /opt/iobroker/node_modules/minipass
                                        npm ERR! extraneous: minizlib@2.1.2 /opt/iobroker/node_modules/minizlib
                                        npm ERR! extraneous: mixin-deep@2.0.1 /opt/iobroker/node_modules/mixin-deep
                                        npm ERR! extraneous: mkdirp-classic@0.5.3 /opt/iobroker/node_modules/mkdirp-classic
                                        npm ERR! extraneous: mkdirp@0.5.6 /opt/iobroker/node_modules/mkdirp
                                        npm ERR! extraneous: moment-timezone@ /opt/iobroker/node_modules/moment-timezone
                                        npm ERR! extraneous: moment@ /opt/iobroker/node_modules/moment
                                        npm ERR! extraneous: mqtt-connection@ /opt/iobroker/node_modules/mqtt-connection
                                        npm ERR! extraneous: mqtt-packet@ /opt/iobroker/node_modules/mqtt-packet
                                        npm ERR! extraneous: mqtt@ /opt/iobroker/node_modules/mqtt
                                        npm ERR! extraneous: ms@2.0.0 /opt/iobroker/node_modules/ms
                                        npm ERR! extraneous: multicast-dns-service-types@1.1.0 /opt/iobroker/node_modules/multicast-dns-service-types
                                        npm ERR! extraneous: multicast-dns@6.2.3 /opt/iobroker/node_modules/multicast-dns
                                        npm ERR! extraneous: mute-stream@0.0.8 /opt/iobroker/node_modules/mute-stream
                                        npm ERR! extraneous: mz@2.7.0 /opt/iobroker/node_modules/mz
                                        npm ERR! extraneous: nan@ /opt/iobroker/node_modules/nan
                                        npm ERR! extraneous: napi-build-utils@1.0.2 /opt/iobroker/node_modules/napi-build-utils
                                        npm ERR! extraneous: nearest-color@0.4.4 /opt/iobroker/node_modules/nearest-color
                                        npm ERR! extraneous: negotiator@0.6.3 /opt/iobroker/node_modules/negotiator
                                        npm ERR! extraneous: nested-property@4.0.0 /opt/iobroker/node_modules/nested-property
                                        npm ERR! extraneous: netmask@ /opt/iobroker/node_modules/netmask
                                        npm ERR! extraneous: node-abi@3.31.0 /opt/iobroker/node_modules/node-abi
                                        npm ERR! extraneous: node-addon-api@ /opt/iobroker/node_modules/node-addon-api
                                        npm ERR! extraneous: node-arp@1.0.6 /opt/iobroker/node_modules/node-arp
                                        npm ERR! extraneous: node-fetch@2.6.8 /opt/iobroker/node_modules/node-fetch
                                        npm ERR! extraneous: node-forge@ /opt/iobroker/node_modules/node-forge
                                        npm ERR! extraneous: node-gyp-build@4.6.0 /opt/iobroker/node_modules/node-gyp-build
                                        npm ERR! extraneous: node-ical@0.15.3 /opt/iobroker/node_modules/node-ical
                                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                        npm ERR! extraneous: node-mndp@0.0.3 /opt/iobroker/node_modules/node-mndp
                                        npm ERR! extraneous: node-rest-client@ /opt/iobroker/node_modules/node-rest-client
                                        npm ERR! extraneous: node-rsa@1.1.1 /opt/iobroker/node_modules/node-rsa
                                        npm ERR! extraneous: node-schedule@ /opt/iobroker/node_modules/node-schedule
                                        npm ERR! extraneous: node-ssdp@ /opt/iobroker/node_modules/node-ssdp
                                        npm ERR! extraneous: node-telegram-bot-api@ /opt/iobroker/node_modules/node-telegram-bot-api
                                        npm ERR! extraneous: node-wol@0.1.1 /opt/iobroker/node_modules/node-wol
                                        npm ERR! extraneous: node.extend@2.0.2 /opt/iobroker/node_modules/node.extend
                                        npm ERR! extraneous: nopt@5.0.0 /opt/iobroker/node_modules/nopt
                                        npm ERR! extraneous: normalize-package-data@2.5.0 /opt/iobroker/node_modules/normalize-package-data
                                        npm ERR! extraneous: normalize-path@3.0.0 /opt/iobroker/node_modules/normalize-path
                                        npm ERR! extraneous: normalize-url@6.1.0 /opt/iobroker/node_modules/normalize-url
                                        npm ERR! extraneous: npm-run-path@4.0.1 /opt/iobroker/node_modules/npm-run-path
                                        npm ERR! extraneous: npmlog@5.0.1 /opt/iobroker/node_modules/npmlog
                                        npm ERR! extraneous: number-allocator@1.0.12 /opt/iobroker/node_modules/number-allocator
                                        npm ERR! extraneous: number-is-nan@1.0.1 /opt/iobroker/node_modules/number-is-nan
                                        npm ERR! extraneous: nwsapi@ /opt/iobroker/node_modules/nwsapi
                                        npm ERR! extraneous: oauth-sign@0.9.0 /opt/iobroker/node_modules/oauth-sign
                                        npm ERR! extraneous: object-assign@4.1.1 /opt/iobroker/node_modules/object-assign
                                        npm ERR! extraneous: object-component@0.0.3 /opt/iobroker/node_modules/object-component
                                        npm ERR! extraneous: object-hash@3.0.0 /opt/iobroker/node_modules/object-hash
                                        npm ERR! extraneous: object-inspect@ /opt/iobroker/node_modules/object-inspect
                                        npm ERR! extraneous: object-is@ /opt/iobroker/node_modules/object-is
                                        npm ERR! extraneous: object-keys@1.1.1 /opt/iobroker/node_modules/object-keys
                                        npm ERR! extraneous: object-scan@ /opt/iobroker/node_modules/object-scan
                                        npm ERR! extraneous: object.assign@ /opt/iobroker/node_modules/object.assign
                                        npm ERR! extraneous: ohash@1.0.0 /opt/iobroker/node_modules/ohash
                                        npm ERR! extraneous: on-finished@2.4.1 /opt/iobroker/node_modules/on-finished
                                        npm ERR! extraneous: on-headers@1.0.2 /opt/iobroker/node_modules/on-headers
                                        npm ERR! extraneous: once@1.4.0 /opt/iobroker/node_modules/once
                                        npm ERR! extraneous: one-time@1.0.0 /opt/iobroker/node_modules/one-time
                                        npm ERR! extraneous: onetime@5.1.2 /opt/iobroker/node_modules/onetime
                                        npm ERR! extraneous: optionator@0.8.3 /opt/iobroker/node_modules/optionator
                                        npm ERR! extraneous: options@0.0.6 /opt/iobroker/node_modules/options
                                        npm ERR! extraneous: os-locale@1.4.0 /opt/iobroker/node_modules/os-locale
                                        npm ERR! extraneous: osx-temperature-sensor@ /opt/iobroker/node_modules/osx-temperature-sensor
                                        npm ERR! extraneous: oui@ /opt/iobroker/node_modules/oui
                                        npm ERR! extraneous: p-cancelable@2.1.1 /opt/iobroker/node_modules/p-cancelable
                                        npm ERR! extraneous: p-finally@1.0.0 /opt/iobroker/node_modules/p-finally
                                        npm ERR! extraneous: p-limit@2.3.0 /opt/iobroker/node_modules/p-limit
                                        npm ERR! extraneous: p-locate@4.1.0 /opt/iobroker/node_modules/p-locate
                                        npm ERR! extraneous: p-map@2.1.0 /opt/iobroker/node_modules/p-map
                                        npm ERR! extraneous: p-queue@6.6.2 /opt/iobroker/node_modules/p-queue
                                        npm ERR! extraneous: p-retry@4.6.2 /opt/iobroker/node_modules/p-retry
                                        npm ERR! extraneous: p-throttle@4.1.1 /opt/iobroker/node_modules/p-throttle
                                        npm ERR! extraneous: p-timeout@3.2.0 /opt/iobroker/node_modules/p-timeout
                                        npm ERR! extraneous: p-try@2.2.0 /opt/iobroker/node_modules/p-try
                                        npm ERR! extraneous: pako@ /opt/iobroker/node_modules/pako
                                        npm ERR! extraneous: parse-json@2.2.0 /opt/iobroker/node_modules/parse-json
                                        npm ERR! extraneous: parse-listing@1.1.3 /opt/iobroker/node_modules/parse-listing
                                        npm ERR! extraneous: parse5@ /opt/iobroker/node_modules/parse5
                                        npm ERR! extraneous: parsejson@0.0.3 /opt/iobroker/node_modules/parsejson
                                        npm ERR! extraneous: parseqs@0.0.5 /opt/iobroker/node_modules/parseqs
                                        npm ERR! extraneous: parseuri@0.0.5 /opt/iobroker/node_modules/parseuri
                                        npm ERR! extraneous: parseurl@1.3.3 /opt/iobroker/node_modules/parseurl
                                        npm ERR! extraneous: passport-local@1.0.0 /opt/iobroker/node_modules/passport-local
                                        npm ERR! extraneous: passport-strategy@1.0.0 /opt/iobroker/node_modules/passport-strategy
                                        npm ERR! extraneous: passport@ /opt/iobroker/node_modules/passport
                                        npm ERR! extraneous: path-exists@2.1.0 /opt/iobroker/node_modules/path-exists
                                        npm ERR! extraneous: path-is-absolute@1.0.1 /opt/iobroker/node_modules/path-is-absolute
                                        npm ERR! extraneous: path-key@3.1.1 /opt/iobroker/node_modules/path-key
                                        npm ERR! extraneous: path-parse@1.0.7 /opt/iobroker/node_modules/path-parse
                                        npm ERR! extraneous: path-posix@1.0.0 /opt/iobroker/node_modules/path-posix
                                        npm ERR! extraneous: path-to-regexp@0.1.7 /opt/iobroker/node_modules/path-to-regexp
                                        npm ERR! extraneous: path-type@1.1.0 /opt/iobroker/node_modules/path-type
                                        npm ERR! extraneous: pause-stream@0.0.11 /opt/iobroker/node_modules/pause-stream
                                        npm ERR! extraneous: pause@0.0.1 /opt/iobroker/node_modules/pause
                                        npm ERR! extraneous: performance-now@2.1.0 /opt/iobroker/node_modules/performance-now
                                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                        npm ERR! extraneous: picomatch@ /opt/iobroker/node_modules/picomatch
                                        npm ERR! extraneous: pidusage@ /opt/iobroker/node_modules/pidusage
                                        npm ERR! extraneous: pify@2.3.0 /opt/iobroker/node_modules/pify
                                        npm ERR! extraneous: pinkie-promise@2.0.1 /opt/iobroker/node_modules/pinkie-promise
                                        npm ERR! extraneous: pinkie@2.0.4 /opt/iobroker/node_modules/pinkie
                                        npm ERR! extraneous: platform@1.3.6 /opt/iobroker/node_modules/platform
                                        npm ERR! extraneous: pngjs@ /opt/iobroker/node_modules/pngjs
                                        npm ERR! extraneous: prebuild-install@7.1.1 /opt/iobroker/node_modules/prebuild-install
                                        npm ERR! extraneous: prelude-ls@1.1.2 /opt/iobroker/node_modules/prelude-ls
                                        npm ERR! extraneous: process-nextick-args@2.0.1 /opt/iobroker/node_modules/process-nextick-args
                                        npm ERR! extraneous: process@0.11.10 /opt/iobroker/node_modules/process
                                        npm ERR! extraneous: promisify-child-process@4.1.1 /opt/iobroker/node_modules/promisify-child-process
                                        npm ERR! extraneous: prompt@ /opt/iobroker/node_modules/prompt
                                        npm ERR! extraneous: protobufjs@ /opt/iobroker/node_modules/protobufjs
                                        npm ERR! extraneous: proxy-addr@2.0.7 /opt/iobroker/node_modules/proxy-addr
                                        npm ERR! extraneous: proxy-from-env@1.1.0 /opt/iobroker/node_modules/proxy-from-env
                                        npm ERR! extraneous: psl@ /opt/iobroker/node_modules/psl
                                        npm ERR! extraneous: pump@3.0.0 /opt/iobroker/node_modules/pump
                                        npm ERR! extraneous: punycode@2.3.0 /opt/iobroker/node_modules/punycode
                                        npm ERR! extraneous: pushover-notifications@ /opt/iobroker/node_modules/pushover-notifications
                                        npm ERR! extraneous: pushsafer-notifications@0.1.9 /opt/iobroker/node_modules/pushsafer-notifications
                                        npm ERR! extraneous: qjobs@1.2.0 /opt/iobroker/node_modules/qjobs
                                        npm ERR! extraneous: qrcode@ /opt/iobroker/node_modules/qrcode
                                        npm ERR! extraneous: qs@ /opt/iobroker/node_modules/qs
                                        npm ERR! extraneous: querystring@0.2.1 /opt/iobroker/node_modules/querystring
                                        npm ERR! extraneous: querystringify@2.2.0 /opt/iobroker/node_modules/querystringify
                                        npm ERR! extraneous: queue-tick@1.0.1 /opt/iobroker/node_modules/queue-tick
                                        npm ERR! extraneous: quick-lru@5.1.1 /opt/iobroker/node_modules/quick-lru
                                        npm ERR! extraneous: random-bytes@1.0.0 /opt/iobroker/node_modules/random-bytes
                                        npm ERR! extraneous: randomatic@3.1.1 /opt/iobroker/node_modules/randomatic
                                        npm ERR! extraneous: range-parser@1.2.1 /opt/iobroker/node_modules/range-parser
                                        npm ERR! extraneous: rasha@1.2.5 /opt/iobroker/node_modules/rasha
                                        npm ERR! extraneous: raw-body@2.5.1 /opt/iobroker/node_modules/raw-body
                                        npm ERR! extraneous: rc@1.2.8 /opt/iobroker/node_modules/rc
                                        npm ERR! extraneous: read-pkg-up@1.0.1 /opt/iobroker/node_modules/read-pkg-up
                                        npm ERR! extraneous: read-pkg@1.1.0 /opt/iobroker/node_modules/read-pkg
                                        npm ERR! extraneous: read@1.0.7 /opt/iobroker/node_modules/read
                                        npm ERR! extraneous: readable-stream@ /opt/iobroker/node_modules/readable-stream
                                        npm ERR! extraneous: readdirp@3.6.0 /opt/iobroker/node_modules/readdirp
                                        npm ERR! extraneous: readline-sync@1.4.10 /opt/iobroker/node_modules/readline-sync
                                        npm ERR! extraneous: readline@1.3.0 /opt/iobroker/node_modules/readline
                                        npm ERR! extraneous: redirect-https@1.3.1 /opt/iobroker/node_modules/redirect-https
                                        npm ERR! extraneous: redis-commands@1.7.0 /opt/iobroker/node_modules/redis-commands
                                        npm ERR! extraneous: redis-errors@1.2.0 /opt/iobroker/node_modules/redis-errors
                                        npm ERR! extraneous: redis-parser@3.0.0 /opt/iobroker/node_modules/redis-parser
                                        npm ERR! extraneous: regexp.prototype.flags@ /opt/iobroker/node_modules/regexp.prototype.flags
                                        npm ERR! extraneous: reinterval@1.1.0 /opt/iobroker/node_modules/reinterval
                                        npm ERR! extraneous: request-promise-core@1.1.4 /opt/iobroker/node_modules/request-promise-core
                                        npm ERR! extraneous: request-promise-native@1.0.9 /opt/iobroker/node_modules/request-promise-native
                                        npm ERR! extraneous: request-promise@4.2.6 /opt/iobroker/node_modules/request-promise
                                        npm ERR! extraneous: request@ /opt/iobroker/node_modules/request
                                        npm ERR! extraneous: require-directory@2.1.1 /opt/iobroker/node_modules/require-directory
                                        npm ERR! extraneous: require-main-filename@1.0.1 /opt/iobroker/node_modules/require-main-filename
                                        npm ERR! extraneous: requires-port@1.0.0 /opt/iobroker/node_modules/requires-port
                                        npm ERR! extraneous: resolve-alpn@1.2.1 /opt/iobroker/node_modules/resolve-alpn
                                        npm ERR! extraneous: resolve@ /opt/iobroker/node_modules/resolve
                                        npm ERR! extraneous: respjs@4.2.0 /opt/iobroker/node_modules/respjs
                                        npm ERR! extraneous: responselike@2.0.1 /opt/iobroker/node_modules/responselike
                                        npm ERR! extraneous: retry@0.12.0 /opt/iobroker/node_modules/retry
                                        npm ERR! extraneous: revalidator@0.1.8 /opt/iobroker/node_modules/revalidator
                                        npm ERR! extraneous: rfdc@1.3.0 /opt/iobroker/node_modules/rfdc
                                        npm ERR! extraneous: rgb-hex@3.0.0 /opt/iobroker/node_modules/rgb-hex
                                        npm ERR! extraneous: rimraf@3.0.2 /opt/iobroker/node_modules/rimraf
                                        npm ERR! extraneous: ripemd160@2.0.2 /opt/iobroker/node_modules/ripemd160
                                        npm ERR! extraneous: rrule@2.7.1 /opt/iobroker/node_modules/rrule
                                        npm ERR! extraneous: rsa-compat@1.9.4 /opt/iobroker/node_modules/rsa-compat
                                        npm ERR! extraneous: safe-buffer@5.1.2 /opt/iobroker/node_modules/safe-buffer
                                        npm ERR! extraneous: safe-regex-test@1.0.0 /opt/iobroker/node_modules/safe-regex-test
                                        npm ERR! extraneous: safe-replace@1.1.0 /opt/iobroker/node_modules/safe-replace
                                        npm ERR! extraneous: safe-stable-stringify@2.4.2 /opt/iobroker/node_modules/safe-stable-stringify
                                        npm ERR! extraneous: safer-buffer@2.1.2 /opt/iobroker/node_modules/safer-buffer
                                        npm ERR! extraneous: sax@1.2.1 /opt/iobroker/node_modules/sax
                                        npm ERR! extraneous: saxes@5.0.1 /opt/iobroker/node_modules/saxes
                                        npm ERR! extraneous: semaphore@1.1.0 /opt/iobroker/node_modules/semaphore
                                        npm ERR! extraneous: send@0.18.0 /opt/iobroker/node_modules/send
                                        npm ERR! extraneous: seq-logging@ /opt/iobroker/node_modules/seq-logging
                                        npm ERR! extraneous: serialport@10.5.0 /opt/iobroker/node_modules/serialport
                                        npm ERR! extraneous: serve-static@1.15.0 /opt/iobroker/node_modules/serve-static
                                        npm ERR! extraneous: set-blocking@2.0.0 /opt/iobroker/node_modules/set-blocking
                                        npm ERR! extraneous: setimmediate@1.0.5 /opt/iobroker/node_modules/setimmediate
                                        npm ERR! extraneous: setprototypeof@1.2.0 /opt/iobroker/node_modules/setprototypeof
                                        npm ERR! extraneous: sha.js@2.4.11 /opt/iobroker/node_modules/sha.js
                                        npm ERR! extraneous: sharp@ /opt/iobroker/node_modules/sharp
                                        npm ERR! extraneous: shebang-command@2.0.0 /opt/iobroker/node_modules/shebang-command
                                        npm ERR! extraneous: shebang-regex@3.0.0 /opt/iobroker/node_modules/shebang-regex
                                        npm ERR! extraneous: shelly-iot@1.1.2 /opt/iobroker/node_modules/shelly-iot
                                        npm ERR! extraneous: side-channel@1.0.4 /opt/iobroker/node_modules/side-channel
                                        npm ERR! extraneous: signal-exit@3.0.7 /opt/iobroker/node_modules/signal-exit
                                        npm ERR! extraneous: simple-concat@1.0.1 /opt/iobroker/node_modules/simple-concat
                                        npm ERR! extraneous: simple-get@3.1.1 /opt/iobroker/node_modules/simple-get
                                        npm ERR! extraneous: simple-swizzle@0.2.2 /opt/iobroker/node_modules/simple-swizzle
                                        npm ERR! extraneous: slip@1.0.2 /opt/iobroker/node_modules/slip
                                        npm ERR! extraneous: slugg@1.2.1 /opt/iobroker/node_modules/slugg
                                        npm ERR! extraneous: socket.io-adapter@2.4.0 /opt/iobroker/node_modules/socket.io-adapter
                                        npm ERR! extraneous: socket.io-client@1.7.4 /opt/iobroker/node_modules/socket.io-client
                                        npm ERR! extraneous: socket.io-parser@ /opt/iobroker/node_modules/socket.io-parser
                                        npm ERR! extraneous: socket.io@ /opt/iobroker/node_modules/socket.io
                                        npm ERR! extraneous: socksv5@0.0.6 /opt/iobroker/node_modules/socksv5
                                        npm ERR! extraneous: sort-keys-recursive@2.1.8 /opt/iobroker/node_modules/sort-keys-recursive
                                        npm ERR! extraneous: sort-keys@4.2.0 /opt/iobroker/node_modules/sort-keys
                                        npm ERR! extraneous: sorted-array-functions@1.3.0 /opt/iobroker/node_modules/sorted-array-functions
                                        npm ERR! extraneous: source-map-support@0.5.21 /opt/iobroker/node_modules/source-map-support
                                        npm ERR! extraneous: source-map@0.6.1 /opt/iobroker/node_modules/source-map
                                        npm ERR! extraneous: spdx-correct@3.1.1 /opt/iobroker/node_modules/spdx-correct
                                        npm ERR! extraneous: spdx-exceptions@2.3.0 /opt/iobroker/node_modules/spdx-exceptions
                                        npm ERR! extraneous: spdx-expression-parse@3.0.1 /opt/iobroker/node_modules/spdx-expression-parse
                                        npm ERR! extraneous: spdx-license-ids@3.0.12 /opt/iobroker/node_modules/spdx-license-ids
                                        npm ERR! extraneous: split@1.0.1 /opt/iobroker/node_modules/split
                                        npm ERR! extraneous: split2@3.2.2 /opt/iobroker/node_modules/split2
                                        npm ERR! extraneous: ssh2-streams@ /opt/iobroker/node_modules/ssh2-streams
                                        npm ERR! extraneous: sshpk@ /opt/iobroker/node_modules/sshpk
                                        npm ERR! extraneous: stack-trace@0.0.10 /opt/iobroker/node_modules/stack-trace
                                        npm ERR! extraneous: standard-as-callback@2.1.0 /opt/iobroker/node_modules/standard-as-callback
                                        npm ERR! extraneous: statuses@2.0.1 /opt/iobroker/node_modules/statuses
                                        npm ERR! extraneous: stealthy-require@1.1.1 /opt/iobroker/node_modules/stealthy-require
                                        npm ERR! extraneous: stream-combiner@0.2.2 /opt/iobroker/node_modules/stream-combiner
                                        npm ERR! extraneous: stream-shift@1.0.1 /opt/iobroker/node_modules/stream-shift
                                        npm ERR! extraneous: streamsearch@ /opt/iobroker/node_modules/streamsearch
                                        npm ERR! extraneous: streamx@2.13.2 /opt/iobroker/node_modules/streamx
                                        npm ERR! extraneous: string_decoder@1.1.1 /opt/iobroker/node_modules/string_decoder
                                        npm ERR! extraneous: string-width@4.2.3 /opt/iobroker/node_modules/string-width
                                        npm ERR! extraneous: string.prototype.trimend@ /opt/iobroker/node_modules/string.prototype.trimend
                                        npm ERR! extraneous: string.prototype.trimstart@ /opt/iobroker/node_modules/string.prototype.trimstart
                                        npm ERR! extraneous: strip-ansi@6.0.1 /opt/iobroker/node_modules/strip-ansi
                                        npm ERR! extraneous: strip-bom@2.0.0 /opt/iobroker/node_modules/strip-bom
                                        npm ERR! extraneous: strip-final-newline@2.0.0 /opt/iobroker/node_modules/strip-final-newline
                                        npm ERR! extraneous: strip-json-comments@2.0.1 /opt/iobroker/node_modules/strip-json-comments
                                        npm ERR! extraneous: strnum@1.0.5 /opt/iobroker/node_modules/strnum
                                        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                        npm ERR! extraneous: supports-preserve-symlinks-flag@1.0.0 /opt/iobroker/node_modules/supports-preserve-symlinks-flag
                                        npm ERR! extraneous: symbol-tree@3.2.4 /opt/iobroker/node_modules/symbol-tree
                                        npm ERR! extraneous: systeminformation@ /opt/iobroker/node_modules/systeminformation
                                        npm ERR! extraneous: tar-fs@ /opt/iobroker/node_modules/tar-fs
                                        npm ERR! extraneous: tar-stream@2.2.0 /opt/iobroker/node_modules/tar-stream
                                        npm ERR! extraneous: tar@ /opt/iobroker/node_modules/tar
                                        npm ERR! extraneous: tcp-ping@0.1.1 /opt/iobroker/node_modules/tcp-ping
                                        npm ERR! extraneous: text-hex@1.0.0 /opt/iobroker/node_modules/text-hex
                                        npm ERR! extraneous: text-table@0.2.0 /opt/iobroker/node_modules/text-table
                                        npm ERR! extraneous: thenify-all@1.6.0 /opt/iobroker/node_modules/thenify-all
                                        npm ERR! extraneous: thenify@3.3.1 /opt/iobroker/node_modules/thenify
                                        npm ERR! extraneous: through@2.3.8 /opt/iobroker/node_modules/through
                                        npm ERR! extraneous: through2@2.0.5 /opt/iobroker/node_modules/through2
                                        npm ERR! extraneous: thunky@1.1.0 /opt/iobroker/node_modules/thunky
                                        npm ERR! extraneous: to-array@0.1.4 /opt/iobroker/node_modules/to-array
                                        npm ERR! extraneous: to-regex-range@5.0.1 /opt/iobroker/node_modules/to-regex-range
                                        npm ERR! extraneous: toidentifier@1.0.1 /opt/iobroker/node_modules/toidentifier
                                        npm ERR! extraneous: tough-cookie@ /opt/iobroker/node_modules/tough-cookie
                                        npm ERR! extraneous: tr46@ /opt/iobroker/node_modules/tr46
                                        npm ERR! extraneous: triple-beam@1.3.0 /opt/iobroker/node_modules/triple-beam
                                        npm ERR! extraneous: tslib@1.14.1 /opt/iobroker/node_modules/tslib
                                        npm ERR! extraneous: tunnel-agent@0.6.0 /opt/iobroker/node_modules/tunnel-agent
                                        npm ERR! extraneous: tuyapi@ /opt/iobroker/node_modules/tuyapi
                                        npm ERR! extraneous: tweetnacl@0.14.5 /opt/iobroker/node_modules/tweetnacl
                                        npm ERR! extraneous: type-check@0.3.2 /opt/iobroker/node_modules/type-check
                                        npm ERR! extraneous: type-is@1.6.18 /opt/iobroker/node_modules/type-is
                                        npm ERR! extraneous: typed-array-length@1.0.4 /opt/iobroker/node_modules/typed-array-length
                                        npm ERR! extraneous: typedarray@0.0.6 /opt/iobroker/node_modules/typedarray
                                        npm ERR! extraneous: typescript@ /opt/iobroker/node_modules/typescript
                                        npm ERR! extraneous: uid-safe@2.1.5 /opt/iobroker/node_modules/uid-safe
                                        npm ERR! extraneous: ultron@1.0.2 /opt/iobroker/node_modules/ultron
                                        npm ERR! extraneous: unbox-primitive@1.0.2 /opt/iobroker/node_modules/unbox-primitive
                                        npm ERR! extraneous: underscore@ /opt/iobroker/node_modules/underscore
                                        npm ERR! extraneous: unix-dgram@ /opt/iobroker/node_modules/unix-dgram
                                        npm ERR! extraneous: unorm@1.6.0 /opt/iobroker/node_modules/unorm
                                        npm ERR! extraneous: unpipe@1.0.0 /opt/iobroker/node_modules/unpipe
                                        npm ERR! extraneous: uri-js@ /opt/iobroker/node_modules/uri-js
                                        npm ERR! extraneous: url-join@4.0.1 /opt/iobroker/node_modules/url-join
                                        npm ERR! extraneous: url-parse@1.5.10 /opt/iobroker/node_modules/url-parse
                                        npm ERR! extraneous: url-template@2.0.8 /opt/iobroker/node_modules/url-template
                                        npm ERR! extraneous: url@0.10.3 /opt/iobroker/node_modules/url
                                        npm ERR! extraneous: ursa-optional@0.9.10 /opt/iobroker/node_modules/ursa-optional
                                        npm ERR! extraneous: util-deprecate@1.0.2 /opt/iobroker/node_modules/util-deprecate
                                        npm ERR! extraneous: utils-merge@1.0.1 /opt/iobroker/node_modules/utils-merge
                                        npm ERR! extraneous: uuid@ /opt/iobroker/node_modules/uuid
                                        npm ERR! extraneous: validate-npm-package-license@3.0.4 /opt/iobroker/node_modules/validate-npm-package-license
                                        npm ERR! extraneous: vary@1.1.2 /opt/iobroker/node_modules/vary
                                        npm ERR! extraneous: vbb-parse-line@1.0.0 /opt/iobroker/node_modules/vbb-parse-line
                                        npm ERR! extraneous: vbb-parse-ticket@0.2.1 /opt/iobroker/node_modules/vbb-parse-ticket
                                        npm ERR! extraneous: vbb-short-station-name@1.0.1 /opt/iobroker/node_modules/vbb-short-station-name
                                        npm ERR! extraneous: vbb-stations@ /opt/iobroker/node_modules/vbb-stations
                                        npm ERR! extraneous: vbb-translate-ids@4.0.0 /opt/iobroker/node_modules/vbb-translate-ids
                                        npm ERR! extraneous: verror@1.10.0 /opt/iobroker/node_modules/verror
                                        npm ERR! extraneous: virtual-tsc@ /opt/iobroker/node_modules/virtual-tsc
                                        npm ERR! extraneous: w3c-hr-time@1.0.2 /opt/iobroker/node_modules/w3c-hr-time
                                        npm ERR! extraneous: w3c-xmlserializer@3.0.0 /opt/iobroker/node_modules/w3c-xmlserializer
                                        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                        npm ERR! extraneous: weak-daemon@1.0.3 /opt/iobroker/node_modules/weak-daemon
                                        npm ERR! extraneous: webdav@ /opt/iobroker/node_modules/webdav
                                        npm ERR! extraneous: webidl-conversions@7.0.0 /opt/iobroker/node_modules/webidl-conversions
                                        npm ERR! extraneous: websocket-stream@5.5.2 /opt/iobroker/node_modules/websocket-stream
                                        npm ERR! extraneous: whatwg-encoding@2.0.0 /opt/iobroker/node_modules/whatwg-encoding
                                        npm ERR! extraneous: whatwg-mimetype@3.0.0 /opt/iobroker/node_modules/whatwg-mimetype
                                        npm ERR! extraneous: whatwg-url@ /opt/iobroker/node_modules/whatwg-url
                                        npm ERR! extraneous: which-boxed-primitive@1.0.2 /opt/iobroker/node_modules/which-boxed-primitive
                                        npm ERR! extraneous: which-module@1.0.0 /opt/iobroker/node_modules/which-module
                                        npm ERR! extraneous: which-typed-array@1.1.9 /opt/iobroker/node_modules/which-typed-array
                                        npm ERR! extraneous: which@2.0.2 /opt/iobroker/node_modules/which
                                        npm ERR! extraneous: wide-align@1.1.5 /opt/iobroker/node_modules/wide-align
                                        npm ERR! extraneous: winston-daily-rotate-file@4.7.1 /opt/iobroker/node_modules/winston-daily-rotate-file
                                        npm ERR! extraneous: winston-seq-updated@1.0.4 /opt/iobroker/node_modules/winston-seq-updated
                                        npm ERR! extraneous: winston-syslog@ /opt/iobroker/node_modules/winston-syslog
                                        npm ERR! extraneous: winston-transport@ /opt/iobroker/node_modules/winston-transport
                                        npm ERR! extraneous: winston@ /opt/iobroker/node_modules/winston
                                        npm ERR! extraneous: wol@1.0.7 /opt/iobroker/node_modules/wol
                                        npm ERR! extraneous: word-wrap@1.2.3 /opt/iobroker/node_modules/word-wrap
                                        npm ERR! extraneous: wrap-ansi@2.1.0 /opt/iobroker/node_modules/wrap-ansi
                                        npm ERR! extraneous: wrappy@1.0.2 /opt/iobroker/node_modules/wrappy
                                        npm ERR! extraneous: ws@ /opt/iobroker/node_modules/ws
                                        npm ERR! extraneous: wtf-8@1.0.0 /opt/iobroker/node_modules/wtf-8
                                        npm ERR! extraneous: xml-name-validator@4.0.0 /opt/iobroker/node_modules/xml-name-validator
                                        npm ERR! extraneous: xml2js@0.4.19 /opt/iobroker/node_modules/xml2js
                                        npm ERR! extraneous: xml2json-light@1.0.6 /opt/iobroker/node_modules/xml2json-light
                                        npm ERR! extraneous: xmlbuilder@ /opt/iobroker/node_modules/xmlbuilder
                                        npm ERR! extraneous: xmlchars@ /opt/iobroker/node_modules/xmlchars
                                        npm ERR! extraneous: xmlhttprequest-ssl@ /opt/iobroker/node_modules/xmlhttprequest-ssl
                                        npm ERR! extraneous: xregexp@2.0.0 /opt/iobroker/node_modules/xregexp
                                        npm ERR! extraneous: xtend@4.0.2 /opt/iobroker/node_modules/xtend
                                        npm ERR! extraneous: y18n@3.2.2 /opt/iobroker/node_modules/y18n
                                        npm ERR! extraneous: yallist@4.0.0 /opt/iobroker/node_modules/yallist
                                        npm ERR! extraneous: yargs-parser@5.0.1 /opt/iobroker/node_modules/yargs-parser
                                        npm ERR! invalid: yargs@ /opt/iobroker/node_modules/yargs
                                        npm ERR! extraneous: yeast@0.1.2 /opt/iobroker/node_modules/yeast
                                        npm ERR! extraneous: zigbee-herdsman-converters@ /opt/iobroker/node_modules/zigbee-herdsman-converters
                                        npm ERR! extraneous: zigbee-herdsman@ /opt/iobroker/node_modules/zigbee-herdsman
                                        npm ERR! extraneous: zrender@ /opt/iobroker/node_modules/zrender
                                        npm ERR!     /home/iobroker/.npm/_logs/2023-01-21T21_53_52_781Z-debug-0.log
                                        @technodj23
                                        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                                        uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                                          @technodj23
                                          technodj23
                                          @thomas-braun sagte in Fire Tablet Jarvis aktualisiert sich nicht:
                                          armv7l
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          8.19.3
                                          node:internal/modules/cjs/loader:998
                                            throw err;
                                          Error: Cannot find module './lib/setup'
                                          Require stack:
                                          - /opt/iobroker/node_modules/iobroker.js-controller/iobroker.js
                                              at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15)
                                              at Function.Module._load (node:internal/modules/cjs/loader:841:27)
                                              at Module.require (node:internal/modules/cjs/loader:1067:19)
                                              at require (node:internal/modules/cjs/helpers:103:18)
                                              at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js:1:1)
                                              at Module._compile (node:internal/modules/cjs/loader:1165:14)
                                              at Object.Module._extensions..js (node:internal/modules/cjs/loader:1219:10)
                                              at Module.load (node:internal/modules/cjs/loader:1043:32)
                                              at Function.Module._load (node:internal/modules/cjs/loader:878:12)
                                              at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12) {
                                            code: 'MODULE_NOT_FOUND',
                                            requireStack: [ '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js' ]
