  3. Einsteigerfragen
  4. Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter
    2.7k
    4.8k
    4.0k
190 Beiträge 20 Kommentatoren 35.4k Aufrufe 16 Beobachtet
  • V V8Turbo
    So bin jetzt mit einer aktuelleren Liste weiter gekommen... Für alle die es Interessiert hier Angehangen. Die Adressen in DEC umrechnen dann bekomme ich zumindest Werte. Leider habe ich wohl aber ein Kommunicationsproblem (?).
    modbus.0
    2023-01-12 11:52:27.690	info	Disconnected from slave
    modbus.0
    2023-01-12 11:52:26.690	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
    modbus.0
    2023-01-12 11:52:26.689	error	Request timed out.
    modbus.0
    2023-01-12 11:52:26.688	warn	Error: undefined
    modbus.0
    2023-01-12 11:52:21.763	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-01-12 11:52:21.741	error	Wrong CRC for frame: 255,1,3,46,9,40,0,219
    modbus.0
    2023-01-12 11:52:21.685	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
    Hier komplett...
    v6.3.5
    12
    Log-Größe: 25.6 KB
    Zeit
    debug
    Nachricht
    modbus.0
    2023-01-12 11:50:15.660	debug	Cleaning up request fifo.
    modbus.0
    2023-01-12 11:50:15.658	debug	Clearing timeout of the current request.
    modbus.0
    2023-01-12 11:50:15.654	info	Disconnected from slave
    modbus.0
    2023-01-12 11:50:14.652	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
    modbus.0
    2023-01-12 11:50:14.651	error	Request timed out.
    modbus.0
    2023-01-12 11:50:14.649	warn	Error: undefined
    modbus.0
    2023-01-12 11:50:09.726	error	unknown function code: 0x0, 0x0
    modbus.0
    2023-01-12 11:50:09.704	error	Wrong CRC for frame: 255,1,3,46,9,38,0,221
    modbus.0
    2023-01-12 11:50:09.647	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
    modbus.0
    2023-01-12 11:50:09.645	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2023-01-12 11:50:03.538	debug	[DevID_1/holdingRegs] Poll address 1165 DONE
    modbus.0
    2023-01-12 11:50:03.452	debug	[DevID_1/holdingRegs] Poll address 1165 - 23 registers
    modbus.0
    2023-01-12 11:50:03.452	debug	Initialization of scale factors done!
    modbus.0
    2023-01-12 11:50:03.450	debug	[DevID_1] Poll start ---------------------
    modbus.0
    2023-01-12 11:50:03.449	info	Connected to slave
    modbus.0
    2023-01-12 11:50:03.440	debug	connect to serial /dev/ttyUSB0 with 9600
    modbus.0
    2023-01-12 11:50:03.142	debug	Add holdingRegisters._Voltage_Phase_T: {"_id":"holdingRegisters._Voltage_Phase_T","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1187,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2023-01-12 11:50:03.142	debug	Add holdingRegisters._Voltage_Phase_S: {"_id":"holdingRegisters._Voltage_Phase_S","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1176,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2023-01-12 11:50:03.141	debug	Add holdingRegisters._Voltage_Phase_R: {"_id":"holdingRegisters._Voltage_Phase_R","type":"state","common":{"name":"","role":"level","type":"number","read":true,"write":true,"def":0,"unit":"V"},"native":{"regType":"holdingRegs","address":1165,"deviceId":1,"type":"uint16be","len":1,"offset":0,"factor":1,"poll":true}}
    modbus.0
    2023-01-12 11:50:03.141	debug	Initialize Objects for holdingRegs: [{"_address":1165,"name":"Voltage_Phase_R","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1165,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_R"},{"_address":1176,"name":"Voltage_Phase_S","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1176,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_S"},{"_address":1187,"name":"Voltage_Phase_T","description":"","unit":"V","type":"uint16be","len":1,"factor":1,"offset":0,"formula":"","role":"level","room":"","poll":true,"wp":"","cw":"","isScale":"","address":1187,"deviceId":1,"id":"holdingRegisters._Voltage_Phase_T"}]
    modbus.0
    2023-01-12 11:50:03.140	debug	Initialize Objects for inputRegs: []
    modbus.0
    2023-01-12 11:50:03.139	debug	Initialize Objects for coils: []
    modbus.0
    2023-01-12 11:50:03.138	debug	Initialize Objects for disInputs: []
    SOFAR-G3 External Modbus Protocol-EN-V1.10 (20220622).xlsx
    GlasfaserG Offline
    GlasfaserG Offline
    @v8turbo
    Ich kann dir bei deinem Wechselrichter nicht weiterhelfen .
    aber du stocherst nur rum ... ich würde das nicht mit ioBroker machen .
    Mache es so , mit einem Windows Programm QModMaster , zuerst alles raussuchen :
    https://forum.iobroker.net/post/829310
    • V Offline
      V Offline
      V8Turbo
      @glasfaser said in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
      QModMaster
      Naja die Adressen habe ich jetzt ja, diese passen. Hab jetzt von allen 3 Phasen die Voltage ausgelesen und die speichert es auch korrekt in den Objekten. Ich denke es ist hier ein Einstellungsproblem beim RS 485 Adapter ?!
      Brauche ich den einen Widerstand ? Habe vom Wechselrichter zum Raspi / Adapter ca. 40m Leitung Cat 7. Die ist aber 2x offen mit wago Klemmen.
      • wendy2702W Offline
        wendy2702W Offline
        @v8turbo Bei 40m ist ein Widerstand eigentlich kein muss.
        Ich denke eher es liegt an den Kommunikations Einstellungen.
        Woher kommst du z.B. auf 9600Baud ?
        Was ist mit Parity, Bits etc?
        Bei Modbus RTU über RS485 kann es erforderlich sein das du zwischen den Registern keine Lücke bei der Abfrage haben darfst.
        Beispiel: Du benötigst Register 1,2, 6,7,8 Dann muss du 3,4,5 auch eintragen.
        Habe ich das richtig gesehen das der WLAN kann? Wenn ja, was geht über WLAN?
        V GlasfaserG 2 Antworten Letzte Antwort
        • V Offline
          V Offline
          V8Turbo
          @wendy2702 Über WLAN ist der mit der Cloud verbunden, Solarman PV heißt die APP. Mehr geht nicht (?).
          Einstellung
          TCP Serial = Serial
          Port = /dev/ttyUSB0
          Baud = 9600
          Data bits = 8
          Stop bits = 1
          Parity = none
          Device ID = 1
          General
          Do not align addresses to 16 bits
          Data polling = 1000 ms
          Reconnect delay = 10000 ms
          Read timeout = 4000 ms
          Pulse time = 1000 ms
          Wait time = 100 ms
          Max read request length (float) = 60
          Max read request length (booleans) = 60
          Read interval = 150 ms
          Write interval = 150 ms
          Alle anderen haben keinen haken
          • wendy2702W wendy2702
            V Offline
            V Offline
            V8Turbo
            @wendy2702 said in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
            Bei Modbus RTU übner RS485 kann es erforderlich sein das du zwischen den Registern keine Lücke bei der Abfrage haben darfst.
            Heißt ich muss alle Abfragen ?
              GlasfaserG Offline
              GlasfaserG Offline
              @wendy2702 sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
              Er meint das , wenn du in der Instanzeinstellung den Poll nicht angehakt hast , bei 3,4,5
              Was ist mit nur einer RegisterAbfrage ( die anderen löschen ) in der Instanzeinstellung , kommt die gleiche Meldung
              • V Offline
                V Offline
                V8Turbo
                Also alle Zahlen von 1 - 1056 und dann 1057-1156 usw. eintragen oder wie meinst du das ?
                Hatte noch das hier gefunden, ist das immernoch so ?
                https://forum.iobroker.net/topic/22126/adapter-modbus-mehrere-geräte-ids-timeout-beim-auslesen-von-mehr-als-einen-teilnehmern/17
                • GlasfaserG Glasfaser
                  V Offline
                  V Offline
                  V8Turbo
                  schrieb am zuletzt editiert von V8Turbo
                  @glasfaser auch mit einem Register noch das gleiche...
                  modbus.0
                  2023-01-12 15:37:45.699	debug	Cleaning up request fifo.
                  modbus.0
                  2023-01-12 15:37:45.698	debug	Clearing timeout of the current request.
                  modbus.0
                  2023-01-12 15:37:45.694	info	Disconnected from slave
                  modbus.0
                  2023-01-12 15:37:44.693	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                  modbus.0
                  2023-01-12 15:37:44.690	error	Request timed out.
                  modbus.0
                  2023-01-12 15:37:44.689	warn	Error: undefined
                  modbus.0
                  2023-01-12 15:37:40.681	debug	[DevID_1/holdingRegs] Poll address 1056 - 1 registers
                  modbus.0
                  2023-01-12 15:37:40.681	debug	Initialization of scale factors done!
                  modbus.0
                  2023-01-12 15:37:40.679	debug	[DevID_1] Poll start ---------------------
                  modbus.0
                  2023-01-12 15:37:40.678	info	Connected to slave
                  modbus.0
                  2023-01-12 15:37:40.669	debug	connect to serial /dev/ttyUSB0 with 2400
                  Sporadisch läuft alles durch, dann geht es wieder 3,4,5x nicht
                  • V V8Turbo
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    modbus.0
                    wendy2702W Offline
                    wendy2702W Offline
                    @v8turbo sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                    Wieso jetzt 2400 ?
                    Die Werte müssen sich mit den Kommunikations Einstellungen vom WR decken.
                    V 1 Antwort Letzte Antwort
                      Wieso jetzt 2400 ?
                      V Offline
                      V Offline
                      V8Turbo
                      @wendy2702 habe rum probiert. Der WR hat 9600 eingestellt.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        @V8Turbo
                        @glasfaser sagte in Sofar Solar HYD10 KTL Wechselrichter an modbus Adapter:
                        Was war hiermit
                          @V8Turbo
                          Was war hiermit
                          V Offline
                          V Offline
                          V8Turbo
                          @glasfaser siehe 2 Beiträge weiter oben...
                          "@glasfaser auch mit einem Register noch das gleiche..."
                          • V V8Turbo
                            GlasfaserG Offline
                            GlasfaserG Offline
                            dann würde ich erstmal nur mit einem weitermachen !
                            Das Problem ist du wechselst immer hin und her .
                            • Welche aktuellen Einstellungen hast du in der Instanz
                            • einen aktuellen ioBroker Log mit nur einem Register wo ein Fehler kommt ..
                            • wird auch der Wert im Datenpunkt geschrieben , ist er auch richtig !?
                              V Offline
                              V Offline
                              V8Turbo
                              @glasfaser Anbei die aktuellen Werte. Der WR ist auch auf 9600 eingestellt.
                              Im Holding Register ist jetzt nur ein Eintrag
                              _address	name	description	unit	type	len	factor	offset	formula	role	room	poll	wp	cw	isScale
                              1412	Voltage_PV1		V	uint16be	1	0,1	0		state		true	false	false	false
                              Aktuelles Log von gerade Ebend.
                              modbus.0
                              2023-01-13 07:32:40.268	debug	Cleaning up request fifo.
                              modbus.0
                              2023-01-13 07:32:40.267	debug	Clearing timeout of the current request.
                              modbus.0
                              2023-01-13 07:32:40.263	info	Disconnected from slave
                              modbus.0
                              2023-01-13 07:32:39.566	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:39.565	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:39.263	warn	Poll error count: 2 code: {"err":"timeout","timeout":4000}
                              modbus.0
                              2023-01-13 07:32:39.262	error	Request timed out.
                              modbus.0
                              2023-01-13 07:32:39.261	warn	Error: undefined
                              modbus.0
                              2023-01-13 07:32:35.291	error	Wrong CRC for frame: 255,2,3,2,4,172,254,249
                              modbus.0
                              2023-01-13 07:32:35.259	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:35.258	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:35.255	info	Connected to slave
                              modbus.0
                              2023-01-13 07:32:35.249	debug	connect to serial /dev/ttyUSB0 with 9600
                              modbus.0
                              2023-01-13 07:32:29.251	debug	Cleaning up request fifo.
                              modbus.0
                              2023-01-13 07:32:29.250	debug	Clearing timeout of the current request.
                              modbus.0
                              2023-01-13 07:32:29.248	info	Disconnected from slave
                              modbus.0
                              2023-01-13 07:32:28.550	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:28.549	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:28.248	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                              modbus.0
                              2023-01-13 07:32:28.247	error	Request timed out.
                              modbus.0
                              2023-01-13 07:32:28.246	warn	Error: undefined
                              modbus.0
                              2023-01-13 07:32:24.277	error	Wrong CRC for frame: 255,2,3,2,7,173,63,201
                              modbus.0
                              2023-01-13 07:32:24.244	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:24.243	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:23.740	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                              modbus.0
                              2023-01-13 07:32:23.707	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:23.706	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:23.704	info	Connected to slave
                              modbus.0
                              2023-01-13 07:32:23.695	debug	connect to serial /dev/ttyUSB0 with 9600
                              modbus.0
                              2023-01-13 07:32:17.697	debug	Cleaning up request fifo.
                              modbus.0
                              2023-01-13 07:32:17.696	debug	Clearing timeout of the current request.
                              modbus.0
                              2023-01-13 07:32:17.693	info	Disconnected from slave
                              modbus.0
                              2023-01-13 07:32:16.995	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:16.994	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:16.693	warn	Poll error count: 2 code: {"err":"timeout","timeout":4000}
                              modbus.0
                              2023-01-13 07:32:16.692	error	Request timed out.
                              modbus.0
                              2023-01-13 07:32:16.690	warn	Error: undefined
                              modbus.0
                              2023-01-13 07:32:12.721	error	Wrong CRC for frame: 3,2,4,250,126,199,255,2,3
                              modbus.0
                              2023-01-13 07:32:12.688	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:12.687	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:12.686	info	Connected to slave
                              modbus.0
                              2023-01-13 07:32:12.677	debug	connect to serial /dev/ttyUSB0 with 9600
                              modbus.0
                              2023-01-13 07:32:06.678	debug	Cleaning up request fifo.
                              modbus.0
                              2023-01-13 07:32:06.677	debug	Clearing timeout of the current request.
                              modbus.0
                              2023-01-13 07:32:06.675	info	Disconnected from slave
                              modbus.0
                              2023-01-13 07:32:05.976	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:05.975	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:05.673	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                              modbus.0
                              2023-01-13 07:32:05.673	error	Request timed out.
                              modbus.0
                              2023-01-13 07:32:05.672	warn	Error: undefined
                              modbus.0
                              2023-01-13 07:32:01.668	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:01.667	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:01.165	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                              modbus.0
                              2023-01-13 07:32:01.133	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:01.132	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:00.627	debug	[DevID_2/holdingRegs] Poll address 1412 DONE
                              modbus.0
                              2023-01-13 07:32:00.589	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:32:00.588	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:32:00.587	info	Connected to slave
                              modbus.0
                              2023-01-13 07:32:00.579	debug	connect to serial /dev/ttyUSB0 with 9600
                              modbus.0
                              2023-01-13 07:31:54.579	debug	Cleaning up request fifo.
                              modbus.0
                              2023-01-13 07:31:54.578	debug	Clearing timeout of the current request.
                              modbus.0
                              2023-01-13 07:31:54.576	info	Disconnected from slave
                              modbus.0
                              2023-01-13 07:31:53.879	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:31:53.877	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:31:53.576	warn	Poll error count: 1 code: {"err":"timeout","timeout":4000}
                              modbus.0
                              2023-01-13 07:31:53.573	error	Request timed out.
                              modbus.0
                              2023-01-13 07:31:53.572	warn	Error: undefined
                              modbus.0
                              2023-01-13 07:31:49.604	error	unknown function code: 0x20, 0xa0
                              modbus.0
                              2023-01-13 07:31:49.564	debug	[DevID_2/holdingRegs] Poll address 1412 - 1 registers
                              modbus.0
                              2023-01-13 07:31:49.564	debug	Initialization of scale factors done!
                              modbus.0
                              2023-01-13 07:31:49.562	debug	[DevID_2] Poll start ---------------------
                              modbus.0
                              2023-01-13 07:31:49.561	info	Connected to slave
                              modbus.0
                              2023-01-13 07:31:49.554	debug	connect to serial /dev/ttyUSB0 with 9600
                              • V V8Turbo
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                modbus.0
                                V Offline
                                V Offline
                                V8Turbo
                                Achso die Werte trägt er, auch wenn alle im Holding stehen sporadisch mal ein (siehe Log oben). Also ja die Werte trägt er irgendwann wenn die Connection klappt ein und die stimmen auch.
                                  wendy2702W Offline
                                  Wenn ich mir den Screenshot ansehe hast du schon einiges an den Grundeinstellungen verbogen.
                                  ich würde mal mit diesen Beginnen:
                                  Also nach Instanz Installation nur den haken bei "Aliases benutzen" raus machen.
                                  Sicherstellen das der WR die gleichen Kommunikationseinstellungen verwendet die im Adapter eingestellt sind. > Baudrate, Data Bits, Stop Bits, Parität, Geräte ID
                                  Im Holding Register nur 1 Register Eintragen bei dem das Ergebnis eindeutig ist:
                                  Z.B. Frequenz HEX=484 DEC=1156 Unsigned 16bit Big Endian Faktor 0.01 Einheit Hz
                                  Dann schauen ob was kommt.
                                  Wenn nicht das Register in Holding löschen und bei Eingangsregister eintragen und testen.
                                  Meine SMA WR haben z.B. Eingangsregister definiert.
                                    V Offline
                                    V Offline
                                    V8Turbo
                                    @wendy2702
                                    Einstellungen sind so gesetzt... Bis auf den Haken bei "Adressen nicht auf 16bit...." der muss rein. (bzw. habe es auch gerade ohne probiert passiert das gleiche)
                                    Sicherstellen das der WR die gleichen Kommunikationseinstellungen verwendet die im Adapter eingestellt sind. > Baudrate, Data Bits, Stop Bits, Parität, Geräte ID <- Wie soll ich das machen ? Es gibt nur eine Einstellung im WR und da kann man die BAUD eintragen. Anleitung steht auch nichts...
                                    Holding Register, Eingangsregister kommt die gleiche Meldung im Log (siehe unten)...
                                    modbus.0
                                    2023-01-13 08:37:42.765	debug	Plugin sentry Initialize Plugin (enabled=true)
                                    modbus.0
                                    2023-01-13 08:40:01.661	debug	Cleaning up request fifo.
                                    modbus.0
                                    2023-01-13 08:40:01.660	debug	Clearing timeout of the current request.
                                    modbus.0
                                    2023-01-13 08:40:01.657	info	Disconnected from slave
                                    modbus.0
                                    2023-01-13 08:40:00.659	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-01-13 08:40:00.656	error	Request timed out.
                                    modbus.0
                                    2023-01-13 08:40:00.655	warn	Error: undefined
                                    modbus.0
                                    2023-01-13 08:39:55.652	debug	[DevID_2/inputRegs] Poll address 1412 - 1 registers
                                    modbus.0
                                    2023-01-13 08:39:55.651	debug	[DevID_2] Poll start ---------------------
                                    modbus.0
                                    2023-01-13 08:39:55.650	info	Connected to slave
                                    modbus.0
                                    2023-01-13 08:39:55.643	debug	connect to serial /dev/ttyUSB0 with 9600
                                    modbus.0
                                    2023-01-13 08:38:55.646	debug	Cleaning up request fifo.
                                    modbus.0
                                    2023-01-13 08:38:55.644	debug	Clearing timeout of the current request.
                                    modbus.0
                                    2023-01-13 08:38:55.641	info	Disconnected from slave
                                    modbus.0
                                    2023-01-13 08:38:54.641	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-01-13 08:38:54.639	error	Request timed out.
                                    modbus.0
                                    2023-01-13 08:38:54.638	warn	Error: undefined
                                    modbus.0
                                    2023-01-13 08:38:49.634	debug	[DevID_2/inputRegs] Poll address 1412 - 1 registers
                                    modbus.0
                                    2023-01-13 08:38:49.633	debug	[DevID_2] Poll start ---------------------
                                    modbus.0
                                    2023-01-13 08:38:49.632	info	Connected to slave
                                    modbus.0
                                    2023-01-13 08:38:49.623	debug	connect to serial /dev/ttyUSB0 with 9600
                                    modbus.0
                                    2023-01-13 08:37:49.627	debug	Cleaning up request fifo.
                                    modbus.0
                                    2023-01-13 08:37:49.626	debug	Clearing timeout of the current request.
                                    modbus.0
                                    2023-01-13 08:37:49.621	info	Disconnected from slave
                                    modbus.0
                                    2023-01-13 08:37:48.620	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                    modbus.0
                                    2023-01-13 08:37:48.617	error	Request timed out.
                                    modbus.0
                                    2023-01-13 08:37:48.616	warn	Error: undefined
                                    modbus.0
                                    2023-01-13 08:37:43.609	debug	[DevID_2/inputRegs] Poll address 1412 - 1 registers
                                    modbus.0
                                    2023-01-13 08:37:43.608	debug	Initialization of scale factors done!
                                    modbus.0
                                    2023-01-13 08:37:43.606	debug	[DevID_2] Poll start ---------------------
                                    modbus.0
                                    2023-01-13 08:37:43.605	info	Connected to slave
                                    modbus.0
                                    2023-01-13 08:37:43.586	debug	connect to serial /dev/ttyUSB0 with 9600
                                    V wendy2702W 2 Antworten Letzte Antwort
                                    • V V8Turbo
                                      @wendy2702
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      modbus.0
                                      V Offline
                                      V Offline
                                      V8Turbo
                                      Hab jetzt mal inverter Temperatur genommen statt PV Voltage... Aber ist ja das gleiche.
                                      OHNE Haken bei Adressen 16bit bla bla...
                                      modbus.0
                                      2023-01-13 08:46:16.526	debug	Cleaning up request fifo.
                                      modbus.0
                                      2023-01-13 08:46:16.525	debug	Clearing timeout of the current request.
                                      modbus.0
                                      2023-01-13 08:46:16.522	info	Disconnected from slave
                                      modbus.0
                                      2023-01-13 08:46:15.521	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                      modbus.0
                                      2023-01-13 08:46:15.520	error	Request timed out.
                                      modbus.0
                                      2023-01-13 08:46:15.518	warn	Error: undefined
                                      modbus.0
                                      2023-01-13 08:46:10.587	error	unknown function code: 0x20, 0x20
                                      modbus.0
                                      2023-01-13 08:46:10.517	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:46:10.516	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:46:10.516	info	Connected to slave
                                      modbus.0
                                      2023-01-13 08:46:10.511	debug	connect to serial /dev/ttyUSB0 with 9600
                                      modbus.0
                                      2023-01-13 08:45:10.515	debug	Cleaning up request fifo.
                                      modbus.0
                                      2023-01-13 08:45:10.514	debug	Clearing timeout of the current request.
                                      modbus.0
                                      2023-01-13 08:45:10.509	info	Disconnected from slave
                                      modbus.0
                                      2023-01-13 08:45:09.507	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                      modbus.0
                                      2023-01-13 08:45:09.505	error	Request timed out.
                                      modbus.0
                                      2023-01-13 08:45:09.504	warn	Error: undefined
                                      modbus.0
                                      2023-01-13 08:45:04.567	error	Error response: 20
                                      modbus.0
                                      2023-01-13 08:45:04.500	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:45:04.499	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:45:03.444	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:45:03.405	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:45:03.404	debug	Initialization of scale factors done!
                                      modbus.0
                                      2023-01-13 08:45:03.402	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:45:03.401	info	Connected to slave
                                      modbus.0
                                      2023-01-13 08:45:03.387	debug	connect to serial /dev/ttyUSB0 with 9600
                                      modbus.0
                                      2023-01-13 08:45:03.069	debug	Add holdingRegisters.1056_Temperature_Inv1: {"_id":"holdingRegisters.1056_Temperature_Inv1","type":"state","common":{"name":"","role":"state","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":1056,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                                      modbus.0
                                      2023-01-13 08:45:03.068	debug	Initialize Objects for holdingRegs: [{"_address":"1056","name":"Temperature_Inv1","description":"","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"state","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1056,"id":"holdingRegisters.1056_Temperature_Inv1"}]
                                      modbus.0
                                      2023-01-13 08:45:03.068	debug	Initialize Objects for inputRegs: []
                                      modbus.0
                                      2023-01-13 08:45:03.067	debug	Initialize Objects for coils: []
                                      modbus.0
                                      2023-01-13 08:45:03.066	debug	Initialize Objects for disInputs: []
                                      modbus.0
                                      2023-01-13 08:45:02.924	info	starting. Version 5.0.11 (non-npm: ioBroker/ioBroker.modbus) in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
                                      modbus.0
                                      2023-01-13 08:45:02.606	debug	Plugin sentry Initialize Plugin (enabled=true)
                                      host.raspberrypi
                                      2023-01-13 08:45:01.211	info	instance system.adapter.modbus.0 started with pid 5986
                                      MIT Haken bei Adressen 16bit blabla...
                                      modbus.0
                                      2023-01-13 08:47:55.508	debug	Cleaning up request fifo.
                                      modbus.0
                                      2023-01-13 08:47:55.507	debug	Clearing timeout of the current request.
                                      modbus.0
                                      2023-01-13 08:47:55.504	info	Disconnected from slave
                                      modbus.0
                                      2023-01-13 08:47:54.503	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                      modbus.0
                                      2023-01-13 08:47:54.501	error	Request timed out.
                                      modbus.0
                                      2023-01-13 08:47:54.499	warn	Error: undefined
                                      modbus.0
                                      2023-01-13 08:47:49.530	error	unknown function code: 0x20, 0x20
                                      modbus.0
                                      2023-01-13 08:47:49.497	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:49.495	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:48.443	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:48.411	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:48.410	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:47.356	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:47.323	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:47.322	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:46.269	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:46.165	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:46.163	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:45.109	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:45.076	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:45.075	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:44.022	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:43.985	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:43.984	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:42.930	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                      modbus.0
                                      2023-01-13 08:47:42.892	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                      modbus.0
                                      2023-01-13 08:47:42.891	debug	Initialization of scale factors done!
                                      modbus.0
                                      2023-01-13 08:47:42.889	debug	[DevID_2] Poll start ---------------------
                                      modbus.0
                                      2023-01-13 08:47:42.888	info	Connected to slave
                                      modbus.0
                                      2023-01-13 08:47:42.870	debug	connect to serial /dev/ttyUSB0 with 9600
                                      • V V8Turbo
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        host.raspberrypi
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        V Offline
                                        V Offline
                                        V8Turbo
                                        Und so sieht das ganze aus wenn es eine weile lief...
                                        modbus.0
                                        2023-01-13 09:14:40.917	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:14:40.916	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:14:40.910	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:14:39.907	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:14:39.906	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:14:39.905	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:14:34.935	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:14:34.901	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:14:34.900	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:14:33.843	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 09:14:33.793	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:14:33.792	debug	Initialization of scale factors done!
                                        modbus.0
                                        2023-01-13 09:14:33.789	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:14:33.787	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:14:33.778	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:14:33.501	debug	Add holdingRegisters.1056_Temperature_Inv1: {"_id":"holdingRegisters.1056_Temperature_Inv1","type":"state","common":{"name":"","role":"state","type":"number","read":true,"write":true,"def":0,"unit":"°C"},"native":{"regType":"holdingRegs","address":1056,"deviceId":2,"type":"int16be","len":1,"offset":0,"factor":1,"poll":true}}
                                        modbus.0
                                        2023-01-13 09:14:33.501	debug	Initialize Objects for holdingRegs: [{"_address":"1056","name":"Temperature_Inv1","description":"","unit":"°C","type":"int16be","len":1,"factor":1,"offset":0,"formula":"","role":"state","room":"","poll":true,"wp":false,"cw":false,"isScale":false,"deviceId":2,"address":1056,"id":"holdingRegisters.1056_Temperature_Inv1"}]
                                        modbus.0
                                        2023-01-13 09:14:33.500	debug	Initialize Objects for inputRegs: []
                                        modbus.0
                                        2023-01-13 09:14:33.499	debug	Initialize Objects for coils: []
                                        modbus.0
                                        2023-01-13 09:14:33.498	debug	Initialize Objects for disInputs: []
                                        modbus.0
                                        2023-01-13 09:14:33.357	info	starting. Version 5.0.11 (non-npm: ioBroker/ioBroker.modbus) in /opt/iobroker/node_modules/iobroker.modbus, node: v16.19.0, js-controller: 4.0.24
                                        modbus.0
                                        2023-01-13 09:14:33.037	debug	Plugin sentry Initialize Plugin (enabled=true)
                                        host.raspberrypi
                                        2023-01-13 09:14:31.670	info	instance system.adapter.modbus.0 started with pid 6057
                                        host.raspberrypi
                                        2023-01-13 09:14:30.562	info	Restart adapter system.adapter.modbus.0 because enabled
                                        host.raspberrypi
                                        2023-01-13 09:14:30.561	info	instance system.adapter.modbus.0 terminated with code 156 (START_IMMEDIATELY_AFTER_STOP)
                                        modbus.0
                                        2023-01-13 09:14:29.937	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
                                        modbus.0
                                        2023-01-13 09:14:29.936	debug	Plugin sentry destroyed
                                        modbus.0
                                        2023-01-13 09:14:29.934	error	Reconnect did not help, restart adapter
                                        modbus.0
                                        2023-01-13 09:14:29.933	warn	Poll error count: 13 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:14:29.932	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:14:29.931	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:14:24.960	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:14:24.929	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:14:24.928	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:14:24.927	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:14:24.921	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:13:24.923	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:13:24.922	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:13:24.919	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:13:23.918	warn	Poll error count: 12 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:13:23.917	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:13:23.916	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:13:18.944	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:13:18.914	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:13:18.914	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:13:18.913	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:13:18.907	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:12:18.908	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:12:18.907	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:12:18.905	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:12:17.904	warn	Poll error count: 11 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:12:17.904	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:12:17.903	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:12:12.931	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:12:12.901	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:12:12.900	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:12:12.897	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:12:12.891	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:11:12.895	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:11:12.894	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:11:12.890	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:11:11.890	warn	Poll error count: 10 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:11:11.889	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:11:11.888	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:11:06.919	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:11:06.885	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:11:06.885	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:11:06.883	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:11:06.876	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:10:06.877	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:10:06.876	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:10:06.873	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:10:05.872	warn	Poll error count: 9 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:10:05.871	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:10:05.870	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:10:00.898	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:10:00.868	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:10:00.867	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:10:00.865	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:10:00.860	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:09:00.863	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:09:00.862	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:09:00.858	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:08:59.856	warn	Poll error count: 8 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:08:59.856	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:08:59.855	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:08:54.885	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:08:54.853	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:08:54.852	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:08:54.851	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:08:54.846	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:07:54.859	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:07:54.858	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:07:54.844	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:07:53.843	warn	Poll error count: 7 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:07:53.842	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:07:53.841	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:07:48.871	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:07:48.839	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:07:48.839	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:07:48.838	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:07:48.831	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:06:48.835	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:06:48.834	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:06:48.830	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:06:47.830	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:06:47.829	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:06:47.828	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:06:42.855	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:06:42.826	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:06:42.826	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:06:42.825	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:06:42.820	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:05:42.824	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:05:42.822	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:05:42.819	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:05:41.819	warn	Poll error count: 5 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:05:41.819	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:05:41.817	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:05:36.922	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:05:36.815	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:05:36.815	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:05:36.814	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:05:36.807	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:04:36.809	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:04:36.808	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:04:36.806	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:04:35.806	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:04:35.805	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:04:35.804	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:04:30.909	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:04:30.802	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:04:30.801	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:04:30.800	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:04:30.790	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:03:30.793	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:03:30.792	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:03:30.789	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:03:29.789	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:03:29.788	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:03:29.787	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:03:24.891	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:03:24.785	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:03:24.784	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:03:24.784	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:03:24.778	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:02:24.781	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:02:24.780	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:02:24.777	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:02:23.777	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:02:23.776	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:02:23.775	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:02:18.874	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:02:18.772	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:02:18.771	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:02:18.770	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:02:18.761	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:01:18.764	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:01:18.763	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:01:18.759	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:01:17.759	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:01:17.758	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:01:17.757	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:01:12.856	error	Wrong CRC for frame: 255,2,3,2,0,26,125,143
                                        modbus.0
                                        2023-01-13 09:01:12.756	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:01:12.752	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:01:11.699	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 09:01:11.667	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:01:11.666	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:01:11.664	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:01:11.655	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 09:00:11.657	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 09:00:11.656	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 09:00:11.653	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 09:00:10.653	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 09:00:10.652	error	Request timed out.
                                        modbus.0
                                        2023-01-13 09:00:10.651	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 09:00:05.681	error	Error response: 20
                                        modbus.0
                                        2023-01-13 09:00:05.649	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:00:05.648	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:00:04.596	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 09:00:04.567	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:00:04.566	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:00:03.513	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 09:00:03.481	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:00:03.480	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:00:02.427	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 09:00:02.266	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 09:00:02.265	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 09:00:02.264	info	Connected to slave
                                        modbus.0
                                        2023-01-13 09:00:02.257	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:59:02.260	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:59:02.259	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:59:02.254	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:59:01.254	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:59:01.253	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:59:01.252	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:58:56.280	error	unknown function code: 0x20, 0x20
                                        modbus.0
                                        2023-01-13 08:58:56.251	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:58:56.250	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:58:56.250	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:58:56.243	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:57:56.245	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:57:56.244	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:57:56.241	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:57:55.242	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:57:55.241	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:57:55.240	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:57:50.269	error	Error response: Data address of some or all the required entities are not allowed or do not exist in slave
                                        modbus.0
                                        2023-01-13 08:57:50.268	error	Error response for FCx64: Illegal Data Address
                                        modbus.0
                                        2023-01-13 08:57:50.238	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:57:50.237	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:57:50.236	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:57:50.229	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:56:50.232	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:56:50.231	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:56:50.228	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:56:49.227	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:56:49.226	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:56:49.225	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:56:44.255	error	unknown function code: 0x20, 0x20
                                        modbus.0
                                        2023-01-13 08:56:44.223	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:56:44.222	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:56:43.169	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:56:43.137	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:56:43.136	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:56:42.084	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:56:41.987	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:56:41.986	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:56:41.984	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:56:41.977	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:55:41.981	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:55:41.980	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:55:41.976	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:55:40.977	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:55:40.975	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:55:40.974	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:55:36.063	error	Error response: 20
                                        modbus.0
                                        2023-01-13 08:55:35.973	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:55:35.971	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:55:34.919	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:55:34.887	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:55:34.885	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:55:33.832	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:55:33.800	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:55:33.796	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:55:32.743	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:55:32.709	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:55:32.708	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:55:32.707	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:55:32.700	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:54:32.703	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:54:32.701	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:54:32.698	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:54:31.697	warn	Poll error count: 1 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:54:31.696	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:54:31.695	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:54:26.724	error	unknown function code: 0x20, 0x20
                                        modbus.0
                                        2023-01-13 08:54:26.693	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:54:26.691	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:54:25.638	debug	[DevID_2/holdingRegs] Poll address 1056 DONE
                                        modbus.0
                                        2023-01-13 08:54:25.605	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:54:25.604	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:54:25.603	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:54:25.596	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:53:25.598	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:53:25.597	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:53:25.594	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:53:24.593	warn	Poll error count: 6 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:53:24.592	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:53:24.591	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:53:19.618	error	unknown function code: 0x20, 0x19
                                        modbus.0
                                        2023-01-13 08:53:19.588	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:53:19.587	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:53:19.585	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:53:19.577	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:52:19.579	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:52:19.578	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:52:19.575	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:52:18.574	warn	Poll error count: 5 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:52:18.573	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:52:18.572	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:52:13.602	error	Wrong CRC for frame: 3,2,0,25,61
                                        modbus.0
                                        2023-01-13 08:52:13.569	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:52:13.568	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:52:13.567	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:52:13.561	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:51:13.564	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:51:13.563	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:51:13.559	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:51:12.559	warn	Poll error count: 4 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:51:12.558	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:51:12.557	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:51:07.588	error	Wrong CRC for frame: 3,2,0,25,61
                                        modbus.0
                                        2023-01-13 08:51:07.555	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:51:07.554	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:51:07.552	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:51:07.545	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:50:07.547	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:50:07.546	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:50:07.542	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:50:06.542	warn	Poll error count: 3 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:50:06.541	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:50:06.541	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:50:01.569	error	Wrong CRC for frame: 6,3,2,0,25,61,142
                                        modbus.0
                                        2023-01-13 08:50:01.537	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:50:01.536	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:50:01.535	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:50:01.528	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        2023-01-13 08:49:01.528	debug	Cleaning up request fifo.
                                        modbus.0
                                        2023-01-13 08:49:01.527	debug	Clearing timeout of the current request.
                                        modbus.0
                                        2023-01-13 08:49:01.524	info	Disconnected from slave
                                        modbus.0
                                        2023-01-13 08:49:00.523	warn	Poll error count: 2 code: {"err":"timeout","timeout":5000}
                                        modbus.0
                                        2023-01-13 08:49:00.522	error	Request timed out.
                                        modbus.0
                                        2023-01-13 08:49:00.521	warn	Error: undefined
                                        modbus.0
                                        2023-01-13 08:48:55.550	error	Wrong CRC for frame: 6,3,2,0,25,61,142
                                        modbus.0
                                        2023-01-13 08:48:55.517	debug	[DevID_2/holdingRegs] Poll address 1056 - 1 registers
                                        modbus.0
                                        2023-01-13 08:48:55.516	debug	[DevID_2] Poll start ---------------------
                                        modbus.0
                                        2023-01-13 08:48:55.515	info	Connected to slave
                                        modbus.0
                                        2023-01-13 08:48:55.507	debug	connect to serial /dev/ttyUSB0 with 9600
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        modbus.0
                                        • V V8Turbo
                                          @wendy2702
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          modbus.0
                                          wendy2702W Offline
                                          wendy2702W Offline
                                          Das ist schlecht. Hersteller und/oder Installateur mal kontaktiert?
                                          Weil wenn das nicht passt kannst du lange probieren.
                                          Dann wäre noch wichtig ob das Excel auch wirklich zu deiner SW Version passt.
                                          Hast du mal den Rat von @Glasfaser befolgt?
