  4. Tr-064: Error: connect ECONNREFUSED
    5.5k
24 Beiträge 3 Kommentatoren 3.4k Aufrufe 2 Beobachtet
  • haselchenH haselchen
    @yunakato
    Sind Iobroker und die Box im selben Netz?
    192.168.0..... ?
    YunaKatoY Offline
    YunaKatoY Offline
    YunaKato
    @haselchen
    IOBroker läuft als Container einer Synology.
    Habe von Netzwerk Konfiguration wenig Ahnung. Bei Aufruf 192.186.0.32:8081 kommt IOB. 192.186.0.1 FB.
    Scheint also das selbe Netz ..
    root@iobroker:/opt/iobroker# ifconfig ```
    docker0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
            inet6 fe80::42:18ff:fe5f:4869  prefixlen 64  scopeid 0x20<link>
            ether 02:42:18:5f:48:69  txqueuelen 1000  (Ethernet)
            RX packets 2847  bytes 238290 (232.7 KiB)
            RX errors 0  dropped 0  overruns 0  frame 0
            TX packets 4112  bytes 54641521 (52.1 MiB)
            TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
    docker-9966fb33: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            inet 192.168.0.1  netmask 255.255.255.0  broadcast 192.168.0.255
            ether 02:42:55:49:a3:75  txqueuelen 1000  (Ethernet)
            RX packets 0  bytes 0 (0.0 B)
            TX packets 0  bytes 0 (0.0 B)
    docker88dab72: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet6 fe80::c01b:e7ff:fe82:c49a  prefixlen 64  scopeid 0x20<link>
            ether c2:1b:e7:82:c4:9a  txqueuelen 0  (Ethernet)
            RX packets 1747  bytes 145935 (142.5 KiB)
            TX packets 2943  bytes 54510772 (51.9 MiB)
    docker9d76624: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet6 fe80::a4c8:efff:fea9:e6ba  prefixlen 64  scopeid 0x20<link>
            ether a6:c8:ef:a9:e6:ba  txqueuelen 0  (Ethernet)
            RX packets 1083  bytes 130882 (127.8 KiB)
            TX packets 1169  bytes 130264 (127.2 KiB)
    dockerdb420aa: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet6 fe80::5445:59ff:fe73:bbd6  prefixlen 64  scopeid 0x20<link>
            ether 56:45:59:73:bb:d6  txqueuelen 0  (Ethernet)
            RX packets 17  bytes 1331 (1.2 KiB)
            TX packets 29  bytes 2483 (2.4 KiB)
    eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
            inet 192.168.0.32  netmask 255.255.255.0  broadcast 192.168.0.255
            inet6 fe80::211:32ff:fed1:91af  prefixlen 64  scopeid 0x20<link>
            inet6 2003:c4:df10:ac00:211:32ff:fed1:91af  prefixlen 64  scopeid 0x0<global>
            ether 00:11:32:d1:91:af  txqueuelen 1000  (Ethernet)
            RX packets 1029692  bytes 1164472883 (1.0 GiB)
            TX packets 304068  bytes 38597571 (36.8 MiB)
            device interrupt 89  base 0x4000
    eth1: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
            inet 192.168.0.33  netmask 255.255.255.0  broadcast 192.168.0.255
            ether 00:11:32:d1:91:b0  txqueuelen 1000  (Ethernet)
            device interrupt 88  base 0x2000
    lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
            inet 127.0.0.1  netmask 255.0.0.0
            inet6 ::1  prefixlen 128  scopeid 0x10<host>
            loop  txqueuelen 1  (Local Loopback)
            RX packets 511979  bytes 589046016 (561.7 MiB)
            TX packets 511979  bytes 589046016 (561.7 MiB)
    • YunaKatoY YunaKato
      @haselchen
      haselchenH Offline
      haselchenH Offline
      haselchen
      @yunakato
      Ich hab das auch auf einer Synology.
      Den Container habe ich im Host Mode.
      Vielleicht ist da der Unterschied, wenn du den Bridge Mode hast.
      YunaKatoY 1 Antwort Letzte Antwort
        @yunakato
        YunaKatoY Offline
        YunaKatoY Offline
        YunaKato
        @haselchen
        im Moment bin ich bezüglich FB 7590 AX ratlos.
        Setze die bisherige FB 7590 morgen auf Werkseinstung zurück und probiere damit nochmal
          @haselchen
          @yunakato ich denke das zurück setzen kannst du dir sparen. Ich denke dein iobroker container läuft im bridge modus. Stell den mal auf host modus um und die Netzwerk Probleme sollten weg sein.
          haselchenH YunaKatoY 2 Antworten Letzte Antwort
            haselchenH Offline
            haselchenH Offline
            haselchen
            @ciddi89
            Hab ich doch oben geschrieben 🤔
              @ciddi89
              @haselchen ich weiss. Aber es scheint so als hätte der Kollege den Hinweis ignoriert :man-gesturing-ok:
                YunaKatoY Offline
                YunaKatoY Offline
                YunaKato
                schrieb am zuletzt editiert von YunaKato
                @ciddi89 sagte in Tr-064: Error: connect ECONNREFUSED:
                Mein iobroker container IMHO läuft auf host. ? aber ..
                  @yunakato kannst du mal bei den container einstellungen von iobroker den bereich vom netzwerk zeigen
                  Da wo man bridge und host einstellt
                    YunaKatoY Offline
                    YunaKatoY Offline
                    YunaKato
                      @yunakato hmm muss mal überlegen wie es bei mir war. Nutze kein docker mehr. Ich meine das ich mein iobroker in beiden hatte. Bridge und host. Kannst du den bridge mode zusätzlich noch mit hinzufügen?
                        haselchenH Offline
                        haselchenH Offline
                        haselchen
                        @ciddi89
                        Hm, kenne ich so nicht .
                        Wenn du Host angibst kannste nix mehr verändern.
                          @ciddi89
                          @haselchen hm okay ja irgendwie hatte ich beides drin. Aber sollte eigentlich such nur mit host funktionieren.
                          Die frage ist ist der port 49000 auch auf der fritzbox für den iobroker offen?
                            haselchenH Offline
                            haselchenH Offline
                            haselchen
                            @ciddi89
                            Ja , dass passt alles .
                            Da muss nix manuell geöffnet werden.
                            Normal den Container im Host Modus und den FB Admin benutzen in den Adapter Einstellungen.
                            Eventuell Box neu starten aber dann sollte es funktionieren.
                              @ciddi89
                              @haselchen ja da hast du recht. Hab nun auch erst im start post gelesen das es vorher mit einer anderen Fritzbox lief. Dann kann man docker eigentlich ausschliessen. Und der port sollte automatisch geöffnet sein wenn man zugriff für Anwendungen aktiviert hat und den user entsprechend rechte gegeben hat.
                              Aber ich weiss selber das die fritzbox manchmal zickig ist. Daher wäre ein zurücksetzen evtl doch hilfreich, wenn alles andere nicht funktioniert :man-bowing:
                                YunaKatoY Offline
                                YunaKatoY Offline
                                YunaKato
                                @ciddi89 @haselchen
                                meine letzte Vermutung war, das die AX > FM 07.31 irgendwo zusätzlich einen Sicherheitsriegel hat. Letztendlich habe ich das gesamte Menu abgegrast aber nichts gefunden.
                                Nach drüber schlafen habe ich mir noch mal die Ausgabe von ifconfig oben angesehen. Die DS720+ hat zwar 2 Lan Ports wobei ich den zweiten meines Wissens nach nie genutzt habe. Die DS hört seit je her auf 192.168.0.32. Ausgegeben wird aber auch eth1: 192.168.0.33. Das ist mir so nie aufgefallen.
                                Zu meine Schande muss ich gestehen das ich vorgestern einen zweiten IOB Test-Container mit separater IP über MacVLan installiert habe. Wahrscheinlich hätte ich davon die Finger weg lassen sollten denn ich vermute stark, das ich dabei irgend etwas versemmelt habe. 😧 Test IOB liegt hier auf ist hier auf 192.168.0.100 jedoch kann weder aufrufen noch anpingen.
                                Es sind 6 Container installiert . Die Docker-Netzwerkübersicht sieht so aus:
                                Ich finde es auffällig, das "iobroker" nicht wie die anderen 4 Container unter Bridge aufgelistet werden.
                                Die Frage ist nun wie ich wieder rauskomme.
                                  @ciddi89 @haselchen
                                  haselchenH Offline
                                  haselchenH Offline
                                  haselchen
                                  @yunakato
                                  In dem du das Chaos da mal ordnest.
                                  Beide Container dürfen nicht laufen .
                                  Einen IOB Container musste immer abschalten .
                                  Und dann guckst dir genau deine Netzwerkeinstellungen in der Syno an.
                                  Ich weiß das da ne Menge einzustellen ist, aber auch mit Standard wie ich es habe läuft alles und zufriedenstellend .
                                    @yunakato
                                    YunaKatoY Offline
                                    YunaKatoY Offline
                                    YunaKato
                                    @haselchen sagte in Tr-064: Error: connect ECONNREFUSED:
                                    Zustimmung ! Mit deiner Vermutung am Anfang "Sind Iobroker und die Box im selben Netz?" hattest du das Problem eingekreist.
                                    Da es nun aber kein Thema des Forums ist wird der Mod eh bald intervenieren :-) Ich werde jetzt erst mal mit einem Backup auf einen PI umsteigen. Danach habe ich eine Aufgabe ...
                                    vielen Dank !
                                    Yun
