  4. Requested repository does not exist in config
    5.6k
39 Beiträge 6 Kommentatoren 5.5k Aufrufe 4 Beobachtet
  • VumerV Offline
    VumerV Offline
    Vumer
    Tach
    nach upgrade von debian 10 auf 11 isses bei mir auch aufgetreten.
    jf@iobroker:~$ iobroker update
    Used repositories: stable, Stable (default)
    Error: unknown repository is active - "stable". Known: Stable (default), Beta (latest)
    Adapter    "admin"        : 6.3.5    , installed 6.3.3  [Updatable]
    Adapter    "alias-manager": 1.2.4    , installed 1.2.6
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "device-watcher": 2.0.3   , installed 2.0.3
    Adapter    "devices"      : 1.1.2    , installed 1.1.1  [Updatable]
    jf@iobroker:~$ iobroker repo list
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    Active repo(s): stable, Stable (default)
    wenn ich unter Admin die Respiratori-Liste auf Standard zurücksetze wird das nicht übernommen.
    iob fix hilft leider nicht
    Thomas BraunT VumerV 2 Antworten Letzte Antwort
    • VumerV Vumer
      Tach
      @vumer sagte in Requested repository does not exist in config:
      stable
      iob repo unset stable
      iob update
      iob upgrade all --debug
      VumerV 1 Antwort Letzte Antwort
        stable
        iob update
        VumerV Offline
        VumerV Offline
        Vumer
        @thomas-braun sagte in Requested repository does not exist in config:
        jf@iobroker:~$ iob repo unset stable
        Repository "stable" deactivated.
        • VumerV Vumer
          @vumer
          Und der Rest?
            @vumer
            Und der Rest?
            VumerV Offline
            VumerV Offline
            Vumer
            noch dabei :)
              @vumer
              Und der Rest?
              VumerV Offline
              VumerV Offline
              Vumer
              jf@iobroker:~$ iob update
              Adapter    "dwd"          : 2.8.3    , installed 2.8.3
              Adapter    "echarts"      : 1.0.12   , installed 1.0.12
              Adapter    "g-homa"       : 0.5.3    , installed 0.5.3
              Adapter    "history"      : 2.2.4    , installed 2.2.4
              Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
              Adapter    "hm-rpc"       : 1.15.16  , installed 1.15.16
              Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
              Adapter    "info"         : 1.9.19   , installed 1.9.19
              Adapter    "iqontrol"     : 2.0.0    , installed 2.0.0
              Adapter    "javascript"   : 6.1.4    , installed 6.1.4
              Controller "js-controller": 4.0.23   , installed 4.0.23
              Adapter    "luftdaten"    : 2.2.4    , installed 2.2.4
              Adapter    "meteoalarm"   : 2.3.1    , installed 2.3.1
              Adapter    "mihome-vacuum": 3.8.6    , installed 3.8.8
              Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
              Adapter    "node-red"     : 4.0.0    , installed 4.0.0
              Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
              Adapter    "proxmox"      : 1.3.4    , installed 1.3.4
              Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
              Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
              Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
              Adapter    "spotify-premium": 1.2.1  , installed 1.2.2
              Adapter    "telegram"     : 1.15.2   , installed 1.15.2
              Adapter    "text2command" : 2.3.0    , installed 2.3.0
              Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
              Adapter    "uv-protect"   : 0.3.6    , installed 0.3.6
              Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
              Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
              Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
              Adapter    "vis-weather"  : 2.5.6    , installed 2.5.6
              Adapter    "weatherunderground": 3.4.2, installed 3.4.2
              Adapter    "web"          : 4.3.0    , installed 5.2.12
              Adapter    "ws"           : 1.3.0    , installed 2.2.1
              Adapter    "zigbee"       : 1.8.9    , installed 1.8.9
              jf@iobroker:~$ iob upgrade all --debug
              This upgrade of "devices" will introduce the following changes:
              -> 1.1.2:
              corrected the double states in light devices
              added CIE color type as equivalent to `rgbSingle` type
              Would you like to upgrade devices from @1.1.1 to @1.1.2 now? [(y)es, (n)o]: n
              No upgrade of "devices" desired.
              jf@iobroker:~$
              • VumerV Vumer
                -> 1.1.2:
                jf@iobroker:~$
                @vumer
                Warum ziehst du den Adapter nicht hoch?
                Was ist jetzt konkret dein Problem? Oder alles gelöst?
                  @vumer
                  VumerV Offline
                  VumerV Offline
                  Vumer
                  schrieb am zuletzt editiert von Vumer
                  https://forum.iobroker.net/topic/60877/devices?_=1672172286345
                  die Version hat einen Bug
                    @vumer
                    VumerV Offline
                    VumerV Offline
                    Vumer
                    ich vermute die Rechte
                    • VumerV Vumer
                      @vumer
                      ? Upgrade von Adaptern funktioniert doch?
                        @vumer
                        VumerV Offline
                        VumerV Offline
                        Vumer
                        aber die FM
                        admin.0
                        	2022-12-27 21:12:09.204	warn	No repository source configured
                        host.iobroker
                        	2022-12-27 21:12:08.054	warn	Requested repository "stable" does not exist in config.
                        admin.0
                        	2022-12-27 21:09:00.881	warn	No repository source configured
                        host.iobroker
                        	2022-12-27 21:08:29.456	warn	Requested repository "stable" does not exist in config.
                        admin.0
                        	2022-12-27 21:08:28.918	warn	No repository source configured
                        host.iobroker
                        	2022-12-27 21:08:28.510	warn	Requested repository "stable" does not exist in config.
                        • VumerV Vumer
                          aber die FM
                          admin.0
                          host.iobroker
                          admin.0
                          host.iobroker
                          admin.0
                          host.iobroker
                          du hast doch auf Stable umgestellt!
                          Wo und wann kommt diese Meldung?
                          • VumerV Vumer
                            aber die FM
                            admin.0
                            host.iobroker
                            admin.0
                            host.iobroker
                            admin.0
                            host.iobroker
                            @vumer
                            iob repo del 'Stable (default)'
                            iob repo addset stable http://download.iobroker.net/sources-dist.json
                              @vumer
                              VumerV Offline
                              VumerV Offline
                              Vumer
                              jf@iobroker:~$ iob repo del 'Stable (default)'
                              Cannot remove repository: Cannot delete active repository: Stable (default)
                              • VumerV Vumer
                                Tach
                                VumerV Offline
                                VumerV Offline
                                Vumer
                                • VumerV Vumer
                                  @vumer
                                  iob repo unset 'Stable (default)'
                                    @vumer
                                    VumerV Offline
                                    VumerV Offline
                                    Vumer
                                    sieht sehr gut aus
                                    Dankeschön👍
